[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sicher. Aber scheinbar wird nicht gewartet. DAS ist das eigentliche Problem.
Ich glaube nicht das nur weil wer schreibt er hätte eine für 2100€ bekommen können, auch direkt die gekauft wird für 2100€. Man sieht doch auch am "Preisverfall" der Scalper das wohl nicht mehr so gekauft wird.
Na, das hoffe ich doch sehr. Es ist eine Unsitte geworden mit egal was. Kann mich noch an vor 2 Jahren erinnern. Da hat einer sein altes Müllsofa über EBK "verkauft" (wirklich gegen Geld) der Clou war, dass man Klopapier dazu bekommen hat...
Würdet ihr eine 4090 FE einem Custom Modell wie bspw 4090 TUF vorziehen, wenn beide gleich viel kosten?
Ich würde zu gerne dein Gesicht sehen wenn ausgerechnet dich dieses nicht so besondere Problem ereilt. :ROFLMAO:
Diese Antwort wundert mich nicht. Da mache ich mir aber keine Gedanken. Meine Karte läuft nun bereits 14 Tage ohne Probleme. Es ist kein Fall mit meiner Karte bekannt und im Laufe dieser Woche kommt entweder ein Adapter oder noch besser sogar das ATX 3.0 Netzteil. Manche übertreiben halt gerne. Man sieht ja gut das dieses Thema total ausgelutscht ist und sich nur noch eine Handvoll Leute darüber unterhält.
nein. Ich würde immer die Custom vorziehen. Alleine schon weil der Umbau auf Wakü viel einfacher ist.
Roman hat die Frostbite 4090 getestet:
- Nur 450W Bios. Es ist nicht möglich das Powertarget zu erhöhen
- Nur 3 PCIe Stecker am Stromadapter dran
- Spulenfiepen vorhanden
Leider nicht attraktiv genug für 2500-2600 Euro
Interessant finde ich die Unterschiede bei den Wärmeleitpads:
Rückseite - hier wird bei Inno3D breitflächiger abgedeckt ("I" bei ALC);
Inno3D:
Aquatuning Kühler:
Aber anscheinend spielt das keine große Rolle laut Video.
ich ziehe die TUF sogar vor, wenn sie mehr kostet. allein schon weil sie zwei native HDMI_2.1 ausgänge am slotblech hat.
tobi
tobi
Ich hab meine TUF gegen eine FE getauscht, brauche einen Display Port und einen HDMI, daher reicht es. Gefällt mir auch besser und EKWB Wasserkühler kommt ja auch noch drauf.
sag ich doch, frag 4 Leute hast 5 Meinungen. Da hat jeder seine eigene Vorliebe und die Karten sind vom Prinzip alle so ähnlich, dass man das für sich selbst entscheiden muss.
Brauche mal eine Meinung von euch:
Der Lüfter meiner Zotac Trinity rattert ein wenig. Nicht arg laut, aber schon wahrnehmbar. Jetzt weiß ich nicht, ob da ein Lager unrund läuft oder nicht (meine 3080 FE hatte das auch).
Würdet ihr in der jetzigen Situation die Karte zurückschicken oder eher behalten. Hab sie für 2100€ bekommen, also verhältnismäßig "günstig". Zudem hat sie den blöden 150V Adapter. Das gute ist, zotac gibt insgesamt fünf Jahre Garantie.
Ich befürchte mit der ganzen Kabel Problematik könnte es ja vermutlich erstmal schwieriger werden einen adäquaten Ersatz zu bekommen.
Wenn es wieder eine Zotac werden soll, behalte sie. Meine (Trinity OC) hat auch hörbares Lüftergeräusch, wird wahrscheinlich bei Zotac so sein.
Beim Tausch gegen einen anderen Hersteller hat man dann statt Lüftergeräuschen eine gute Chance auf Spulenfiepen oder Rasseln, siehe hier.
Bzgl der Adapter-Geschichte: Laut Igors neustem Video scheint es wohl mindestens 4 Adapter Varianten im Umlauf zu geben
150V 4 löt pads (schlecht)
300V 4 löt pads (schlecht)
150V 2 löd pads combined (möglicherweise gut)
300V 2 löd pads combined (höchstwahrscheinlich gut)
Herausfinden kann man das von außen nicht. Nur durch Zerstörung des Adapters sieht man die Verlötung. Ist und bleibt also Rätselraten, welche Karten einen "vernünftigen" Adapter dabei hat.
Hier sieht man den Unterschied bei den zwei Löt-Arten (links: scheiße, rechts: stabil)
Nicht nur Chip Lotterie sondern auch Adapter Lotterie samt Lager und Spulenfiepen
Dies ist mit Abstand die Leistungsfähigste Generation seit langen aber wird überschatten von Problemen die uns verrückt machen
Lasst uns einfach die Daumen drücken, dass unsere GPUs so lange durchhalten bis es endlich Lösungen gibt 💁🏽
ansprüche sind halt verschieden und auf jeden fall günstig, wenn einem die basis reicht. einer bestellt ledersitze; der andere ein 9€ ticket; von A nach B kommen beide.
tobi
Stimmt. Hannover und Ledersitz Gleichnis... ich würde sagen ein VWler ^^
Funktioniert der Fanstop bei der Gigabyte Gaming OC wie zu erwarten? Also Lüfter aus sobald keine/minimale Last anliegt? Bei meiner KFA2 scheint das immer ne ganze Weile zu dauern bis die Lüfter sich abschalten und das führt die Funktion quasi ad absurdum, wenn die GPU-Lüfter nach dem Booten und nach jedem Spiel 10+ Minuten hörbar am drehen sind.
Ich weiß nicht wie ihr das sieht aber das ist die fetteste Karte die NV rausgebracht hat
Dafür können wir uns sicher bei AMD bedanken. Ohne deren frühe Ankündigung von 200 bis 300%, wären es bei NV wieder nur 20 bis 30% geworden.
Das Gefühl habe ich auch. Am Anfang stand ja noch der Verdacht/Gerücht im Raum, AMD würde ein "echtes" Chiplet Design (zwei separate GPU Cores) auf eine Graka patschen, das hat in NVIDIA wohl den Zugzwang geschaffen, minimum 100% Mehrleistung zu erbringen bei der neuen Generation. Am Ende konnte NVIDIA das Ziel durch gutes 4nm Verfahren + Chipausbeute bei selber Wattzahl erreichen, und AMD hat bloß in Chiplet Design ein paar kleinere Packages draufgepackt: gut also für NVIDIA.
Danke für das Feedback!
Auch beruhigend zu hören, dass es nicht nur meine Karte betrifft, bzw. dass das kein großes Problem zu sein scheint. Die fünf Jahre Garantie beruhigen ebenfalls...
Ist denn die FE nicht lauter als die TUF ?
Bei mir war FE , TUF und Strix anvisiert .
TUF OC konnte ich zu Release bekommen .
Moin zusammen, hat hier einer schon das thermaltake atx3.0 nt in kombi mit ner 4090 in Gebrauch und kann was zu Kabel und Lautstärke des nt machen?
Wer zockt alles MW2?
Mit dem neuen Treiber habe ich nur Probleme - Multimonitor Setup -> vom LG CX65 zurück zum LG 21:9 spackt rum.
MW2 spackte rum, bin daher zurück auf den alten Treiber 522.25. Kommt aber nur äußerst selten vor, dass Nvidia Treiber Probleme machen, was sollst, haben bestimmt gerade andere Probleme mit der Zündschnur :fire:
Hatte ich ebenfalls. Vor allem wurde die Karte instabil und ich hatte auch bei anderen Games freezes... Zurück auf alten Treiber und es war wieder ok
Naja Chip lotterie auch nur wenn man es sich einredet oder ,immerhin bekommt man die hz zahlen Dienstag stehen und bis jetzt sogar immer mehr auf Stock .....alles andere ist Wunschdenken
Ich würde mir ja gerne eine ne Strix kaufen .... Werde wochentlich einmal Asus nerven , bis jetzt wirds immer weggekauft und versucht auf eBay Kleinanzeigen zu verticken ...3200 die sollen ersticken daran
Funktionierte einen Tag. Aber kann nicht mehr sagen wie schnell die Fans auf 0% gingen (nach eine Spielephase; auf jeden Fall schneller als 10Min; nach Boot direkt aus). Hab dann lieber fix eine Kurve gebastelt bzw. bin ich im Desktop manuell auf 46 und 49 Prozent. Wenn die Fans angeworfen wurden gingen sie von 0 direkt auf 1600 und das war nervtötend.
Ähnliche Themen
