[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich glaube das verstehst du falsch, er bezieht sich auf den MW2 Techniktest.... und rechnet anhand der AMD Folien und seinen Ergebnissen die Leistung hoch.
Das wäre ja abgefuckt und hilft niemanden. Aus den Marketing Folien kann man weder bei NV noch bei AMD irgendetwas verlässliches ableiten…
Also die iChill Black ist schon verdammt sexy. Ob da aber so ein kleiner 240mm Radiator reicht um die Grafikkarte flüsterleise zu halten? Ich würde da Reviews abwarten...
Die MSI hat auch nur einen 240er Radiator und der Radiator der iChill soll 38mm dick sein, also dicker, als der Standard AIO Radiator. Da ich kein OC betreibe, sollte er reichen. Bei der MSI waren die Temepraturen, bis auf den RAM, auch gut.
Die MSI hat aber einen dritten Lüfter direkt auf der Platine. Und der ist laut und die Temperaturen des RAMs trotzdem schlecht.
Die iChill soll einen vollen WaKü Block haben, wo der RAM mitgekühlt wird. Ich werde es sehen :).
Seit knapp einer Woche kommt ja gar nichts mehr über den Ticker zum UVP…
Die 1949€ meiner Phantom habe ich danach nie wieder gesehen und auch bei den anderen Karten nicht mehr. Gar nicht mal so geil.
Ist doch egal, Leute zahlen auch gerne 2k - 2,4k für ne Karte 😂
Gefällt ganz gut der Kram.
So meine Gaming OC läuft jetzt endlich auch messbar im Silent-BIOS. Habe das Gefühl ich musste nach Änderung der Einstellung an der Karte den PC einmal booten und dann nochmal neustarten. Habe Fast Boot an, k.A. ob das damit zusammenhängt. Konnte jetzt im Hitman-Benchmark 1700rpm/61c im OC-BIOS und 1400rpm/65c im Silent-BIOS messen. Jetzt rühr ich erstmal gar nichts mehr an. :d
1400? Ist das nicht ein bischen viel fürs Ohr? Aber hey. Jeder so wie er mag.
Könnte man die Ichill Black auch auf normale WaKü umbauen oder sind solche Anschlüsse bei den AIO Kühlungen nicht modifizierbar? Laut den Bildern könnte man darauf schließen dass das machbar wäre. Ich hab noch nen Gewindeschneider G1/4 Zoll hier liegen :d
Hmm.. gibts mittlerweile genauere Infos wegen den Karten? gibt es Modelle die man auf jeden Fall kaufen kann? Modelle die man auf gar keinen Fall kaufen sollte?
Nein.
Beste Grüße
Die leisesten sind wohl von KFA2 und teilweise auch Zotac.
Der Rest fiept, brummt, zirpt, trillert das sich die Balken biegen. Leider.
Tldr: wenn du (verdammt viel) Glück hast ist eine Karte leise 🍀
Kurz nach dem letzten 1949er Drop der Gainward hat Alternate ja die Preise angezogen. Die haben am längsten durchgehalten mit UVP Preisen. Jetzt bekommt man glaube ich nur die FE zur UVP aber auch nur, weil es Nvidia Vorgabe ist. Die Preise abseits der FE bei NBB sind ja unterirdisch. Wobei eine Asus Karte ist glaube ich auch zur UVP möglich über deren eigenen Shop. Aber da ist gefühlt seit Ewigkeiten nichts mehr gedroppt
kaufen kannst du alle... bei Gainward und Palit kann es zu Lüfterproblemen kommen. Ansonsten gibts bei allen höherpreisigen die Chance auf Spulenfiepen, wie bei allen Karten. Die günstigeren haben meist weniger Spulenfiepen (so kam es mir vor, bei dem was ich so lese hier - oder die leute sind taub). Die FE ist ok, im vergleich zu den anderen Karten. Alle Kühler sind ausreichend Dimensioniert und halten die Karten ansich leise. Laut ist, wenn dann Spulenfiepen oder defekte Lüfter. OC bringt in den meisten Fällen nicht viel. UV oder PT Reduzieren ist KING. Viele haben die TUF Karten und sind was Wertigkeit angeht, angetan. Zotac mögen die meisten nicht, da sie so rund abgelutscht aussehen. Beim Adapter, der bei allen Karten beigelegt ist, haben viele bedenken. Ansonsten sind glaub ich viele mit der Leistung der 4090 sehr zufrieden.
So, nochmal Geld rausgehauen... hab jetzt ein ROG Thor 1000W Netzteil bestellt. Mir reichen die maximal 450W auf dem 12VHPWR und so kann ich ruhiger schlafen - auch wenns vielleicht Blödsinn ist.
Ich denke nämlich dass es mit den ganzen China-Lockdown Meldungen über den Jahreswechsel eher weniger Ware geben wird. Aber auch das: Spekulatius
Bei Alternate liegen im Outlet immer noch 4 Trinities rum... will wohl keiner für 2.240 EUR ;)
Wenn du dir das Cablemod Kabel bestellst, sollte mit dem Netzteil auch 600W möglich sein. Geht da ja nur um das mitgelieferte Kabel. 1000W sollte ja an sich genug sein.
jou, denke auch, das die Preise bis mitte nächsten Jahres nicht fallen, sondern steigen werden. @12VHPWR... solang es Dich beruhigt und du dann einfach zocken kannst ohne nachzudenken. Go for it. Das so bescheuerte Lötarbeiten solche Panik auslöst... Ich war vorhin noch hin und hergerissen für 40€ den bequiet Adapter auf Amazon zu kaufen.. aber .. NE ich seh das nicht ein.. WENN was schmort, dann schlag ich NBB die 4090FE ums Gesicht.. mein Rechner läuft nur, wenn ich daneben sitze.. ich werd das schon mitbekommen. :)
Ausreichend für eine 4090?
Die Frage wurde doch schon tausend mal gestellt, und es gibt hunderte Reviews mit Netzteil-Empfehlungen. Muss das hier wirklich sein?^^
Stock wird dein NT an der Kotzgrenze laufen, mit UV/PL reduzieren sollte es gehen, aber da passt dann kein großer Prozessor mehr rein (200W aufwärts). 850w sollte Minimum sein.
Abhängig was du sonst noch für Hardware und Peripherie im Rechner hast.. ich hab nen Dark power 10 750Watt.. aber nur nen i7 8700k und die 4090FE... manchmal bei hohem OC geht die gesamtlast auf 650~670 Watt hoch. Bei nem stärkerem Prozessor, seh ich da Probleme. Wenn du kein OC betreibst, müsste es ausreichen. Ich würd schon bei der Empfehlung von BeQuiet bleiben.. eine 4090 sollte ein 850 Watt Netzteil bekommen.
Ernstgemeint?
Naja viele Karten brauchen halt ne Spannungserhöhung für 3ghz. (Oder schaffen es garnicht)
Würde mal in 15mhz schritten runter gehen bis das nicht mehr passiert
Also auf 2990 läuft die gpu noch unf ab 3000mhz wird das display schwarz. soll ich die spannung dann erhöhen?
bedeutet das jetzt das ich ein nicht sobgutes pcb erwischt habe oder muss ich nocj mit den werten spielen?
Ein 12700k sonst nichts besonderes.
Aber vermutlich wäre es besser um sicher zu gehen doch ein stärkeres zu kaufen.
Vermutlich gibts schon irgendwo weiter hinten eine Standard Empfehlung? Werd mal blättern. Danke.
Ähnliche Themen
