[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
so 4090 drin, meine fresse pumpt die FPS
Ja habe gestern The Outer Worlds gezockt. Brutal was die in 4k rausdrückt im Gegensatz zur 3090. Mit letzterer war das nicht spielbar @4k und jetzt total geil! Auch Cyberpunk hat mich krass überrascht :eek: Bei Star Citizen hab ich nur im Weltall mehr Frames aber die Städte sind CPU lastig. Leider habe ich den 5800X3D noch immer nicht... absolut beschissen gelaufen :(
ja ich meine ich hab ne 3080ti und das is ja nun keine schlechte Karte, aber die 90 knallt richtig derb
  • Asus ROG Strix GeForce RTX 4080 OC - 1.969,90 Eur
  • LOL
War doch zu erwarten, 20% on top auf die NVIDIA MSRP und dann nimmt sich Asus auch nochmal minimum 100-300 €.
Die 7900 XTX wird hierzulande auch nicht unter 1300/1400 € zu bekommen sein, US-Unternehmen erhöhen wegen des schwachen Euros aktuell massiv die Preise. Hier sollte sich keiner Illusionen hingeben.
Aktuell ist eine schlechte Zeit, neue Technik zu kaufen (es sei denn, man ist Interessent an Google oder Microsoft Produkten, die zB das Pixel 7 Pro oder die XBOX mit Verlust verkaufen, weil diese Riesen Marktanteile wollen) - aber das wird AMD nicht machen. Dazu sind die zu klein und haben zu wenig Geldreserven.
Ach scheisse ich habe 4090 gelesen ....
4080 für 2000, natürlich. Die bringt zwar nur 60% der 4090. Aber was solls.
7900XTX wird 1399, Custom +0 bis +300 Euro
7900XT wird 1299, Custom +0 bis +250 Euro
Und die Preise sind in Anbetracht zu dem was NV abzieht ok.
Habe eben Teesatz gelesen.
hier bei dem link
Ist doch gut, dann kann Nvidia die Preise für die 4090 höher setzen auf 2,5k oder mehr, wird ja sowieso gekauft wie Brötchen :)
Also auf 2990 läuft die gpu noch unf ab 3000mhz wird das display schwarz. soll ich die spannung dann erhöhen?
bedeutet das jetzt das ich ein nicht sobgutes pcb erwischt habe oder muss ich nocj mit den werten spielen?
Wenn du die Spannung erhöhst wird der takt höher gehen.
Dann musst du vielleicht noch in 15 mhz Schritten mit dem Takt runter gehen wenn er noch abstürzt.
Schlecht würde ich nicht sagen. Hatte eine Karte gesehen die mit Spannungserhöhung nur ca 2850 geschafft hat.
Denke um die 3000mhz is gut mit Spannungserhöhung.
Und alles über 3100 wär schon super.
Hier im Forum war das höchste was ich mitbekommen habe 3160.
Aber auf 100mhz mehr oder weniger kommts nicht an.
Was schafft denn dein Speicher? Der Speicher OC bringt noch etwas mehr nach meinem test (z.b. in shadow of the tomb raider)
Wenn du da um die +1500 schaffst, ist der Speicher gut und macht viel wieder wett.
Ob du es "sollst": bringt halt eher wenig. Nur wenn du die 3000 aus spaß mal knacken willst zu empfehlen.
Gibt ja momentan das problem mit abfackelnden stromanschlüssen und da könnte man schon etwas vorsichtiger sein.
Man kann die Karte eh besser undervolten. Dann ist sie leise, kühl, verbraucht viel wenige strom und verliert kaum Leistung dabei.
Z.b. 0,9v und 2600mhz könntest mal testen wenn dich das interessiert. Dann in 15mhz schritten hoch oder runter bis es abstürzt.
12700k, DDR5 6000 3080ti vs
13700k, DDR5 7200, 4090
SO ich gebe auch mal meinen Quark zu RDNA3.
-Preislich ist das Ding OK. Super ist es nicht, da €/FPS schlechter ist als die 6900XT.
Aber besser dran als die 4080 oder 4090.
-RT Leistung enttäuschend. Nicht mal 2x. Leaks sprachen von 3x..
-Effizienz enttäuschend. 7900XTX mit 355W hat weniger Leistung als eine 4090 mit 70% PL (315W). Ergo eine 4090 hat ne bessere Effizienz.
-Raster Leistung OK, nichts was mich vom Hocker haut. Nix mit 2x Leaks...
Was absolut peinlich war, war die Präsentation...
Und die ganzen Balken haben nichts ausgesagt, weil die Fussnoten mit den Einstellungen etc. komplett fehlen.
Es wurde nichtmal gesagt, welches FSR genutzt wird...
Fazit...will immernoch meine 4090 Founders...wo bleibt die Nvidiaaaaaaa
Und AMD Leaker sind riesige Fanboys...denen kann man nicht glauben :d
Hi, ist das normal das meine 4090FE in Timespy, Firestrike oder Cyberpunk bei 100% Last nur 350, 420 Watt zieht? Ich dachte wenn die kann bis 600W.
Hast du die Karte denn sonst noch niedriger laufen? Reserven sind im Bezug auf die Temperatur natürlich noch da, aber ich bin eher Fan von "festen" hardwareseitigen Einstellungen. Deswegen war es mir auch wichtig, dass das Silent-BIOS prüfbar läuft.
Ja aber bin noch nicht komplett fertig mit den Einstellungen. Im Moment maximal ca. 890 RPM bis 60 Grad.
Interessant ist auf jedenfall, dass AMD GPU leaks häufig sehr weit weg von der Realität sind - und NVIDIA leaks sind meist sehr nahe dran.
Das heißt am Ende einfach nur, dass AMD sehr gut darin ist, Leaks zu verhindern/Leaker zu verwirren (falsche Daten) und NVIDIA hier mehr Probleme hat, letzteres kommt vermutlich aus dem Fakt, dass NVIDIA ein viel, viel größeres Unternehmen ist und es ist schwieriger, zichtausende Leute zu kontrollieren als ein paar hundert.
Ja. Die ist spannungslimitiert. In wenigen Fällen wird die über 450 gehen.
Kommt am Ende aber auf die Anwendung an, in manchen Games will sie mehr (soweit mehr da ist).
Sei doch froh, weniger Hitze, weniger Abwärme, leisere Lüfter und trotzdem gewaltige Leistung...
Nun mit 1850 Speicher
[/URL]
Heute Nacht wird es kalt. Ich leg den Rechner dann mal raus zum Benchen :d
Und 1900 Speicher fehlerfrei
[/URL]
Eigentlich ist der Benchmark Müll weder mein noch dein Ergebniss ist Gamestable im Alltag ...
Aber ich kann deinen Ehrgeiz verstehen ;-)
P.S. Radiator im Kaltem Wasserbad könnte helfen ;-)
War doch zu erwarten, möglicherweise werden die Preise aber nach unten angepasst, sofern AMD tatsächlich delivern kann.
Deren fake 8K (halbe Resolution) Gerede und "50% schneller" sind - genau wie bei NVIDIA - nicht aussagekräftig, hier muss man erst auf Reviews abwarten, ob die 7900 XTX tatsächlich auf Augenhöhe mit einer 4080 steht.
Lustig dass hier bezweifelt wird ob die 7900xtx auf Augenhöhe mit der 4080 agieren kann. Die 7900XTX wird deutlich schneller als die 4080 sein was Raster betrifft
aber idle Luft 49° die GPU? is dat normal?
Edit: ah is Zero RPM Fan auf der TUF
Chrome lastet die Karte bei mir so stark aus , dass die Lüfter dauernd anspringen(>58°C). Aber das war bei den anderen Generationen auch so.
Kurzfristig kann man dort die GPU Beschleunigung ausschalten, langfristig kommt ja eh ein Block drauf
Die 7900 XTX wird RT technisch höchstwahrscheinlich auf der Stufe einer 3090 stehen, dementsprechend muss man hier erstmal abwarten und Tee trinken.
Mal ganz abgesehen davon, dass die 4080 von deutlich schnellerem DLSS 2.4/3.0 profitieren kann, die aus der neuen Tensor Generation herstammt, dementsprechend kann man hier bei ähnlicher Bildqualität vermutlich auch in Rasterization Titeln - bei DLSS Verfügbarkeit, NICHT 3.0 - vorbeiziehen.
Aber wie schon gesagt, warten wir erstmal ab.
alles gut X Cellence, hab kein Chrome
die bleibt nur bis der Block da is auf Luft, ist nur eingebaut zum rumspielen und damit die 3080ti weg kann
An alle mit einer Gigabyte Gaming OC: war bei euch der 4 Zack Adapter eingeschweisst, oder war das Tütchen offen?
Mein könnte nämlich ein Rückläufer sein.
1.) Versendet aus einer Berliner Filiale
2.) Außen herum war der Karton an allen Seiten vermackt, so wie das typischerweise durch die Stretchbänder passiert, die in der Filiale mit der Diebstahlsicherung an den Boxen angebracht wird. Eh schon komisch. Und so kann man auch nicht sehen ob schonmal einer dran war. Siegel waren außen keine dran.
3.) Die Innenbox war um 180° gedreht, d.h. die Klappenöffnung ging zur Rückseite, nicht zur Außenverpackung Oberseite
4.) Die Tüte mit dem Adapter war offen - der Akapter zeigt aber keine Biegung und auch keine Marken vom schonmal Einstecken (wobei ich nicht weiß ob man das sehen müsste)
5.) Die Siegel an der Karte selbst sehen original und ungeöffnet aus (ich weiß aber nicht ob man die mit Wärme o.ä. unbeschädigt abnehmen kann).
ja ist vollkommen normal.. durch den besseren 4nm fertigungsprozess ist sie viel effizienter als angenommen. Die Kühler auf den Karten sind alle auf 600 WATT ausgelegt.. die Karten brauchen aber alle weniger.. selbst wenn du OC betreibst.. wirst du wahrscheinlich nie die 600 Watt auf der Karte selbst haben. .. Deswegen sind hier ja alle von der Leistung und der Effizienz beeindruckt bei UV. Brauch teils weniger als ne 3090, mit viel mehr Leistung.
Bin auch froh, dass die nicht so viel zieht. Was mich aber ein bisschen nervt ist das die relativ lautes Spulenfiepen hat. Naja mal schauen was das UV bringt.
Deine FE hat deutlich hörbares Spulenfiepen?
Interessant, du bist der erste, von dem ich das höre.
Ist natürlich schwierig, da Feedback zu finden, weil nur so wenige Menschen überhaupt eine 4090 FE haben.
@Jopafa machst Du das mit dem MSI Afterburner oder?
Was sind denn so typische Wert für 4090 OC.
Ja, MSI Afterburner.
Nach meiner Recherche:
2850-3160 mhz von dem was ich so gesehen habe bei 1,1v
Und Speicher OC von +800-2000 (bei 2000 kann man den regler nicht weiter schieben)
Meine Karte macht z.B. maximal 3060mhz, das aber auch überall stabil bei 1,1v (geht dann teils auf 3030 oder 3000 runter sobald die temperatur steigt)
Speicher schafft die +1500
Bei 0,9v 2670mhz.
Hab auch noch ein 0,85 und 0,95 undervolting setting aber bin grad nicht zuhause um nachschauen zu können.
Uuuund das erste native ATX 3.0 Kabel ist abgeraucht :d
Jay. Wie ich schon sagte, da die Adapter für die Tonne sind, dürfte es bei den Kabeln (die auf denselben Spezifikationen beruhen) auch ähnliche Fehler geben. Hier sollte man also eine Generation 2 abwarten, oder man hat eben Glück.
(MSI MEG 1300 hier in dem Fall)
Laut User war das Kabel, der er sich der Probleme bewusst war, nicht stark gebogen und saß bombenfest drinnen.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
