[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@12VHPWR... solang es Dich beruhigt und du dann einfach zocken kannst ohne nachzudenken. Go for it. Das so bescheuerte Lötarbeiten solche Panik auslöst...
Es ist nicht rational, ich bin da ein bissl psycho. Muss man ganz klar sagen. Muss bestimmt nicht sein, aber MIR hilft das im Kopf (ein wenig - für andere Sachen im Kopf wieder nicht)
Also auf 2990 läuft die gpu noch unf ab 3000mhz wird das display schwarz. soll ich die spannung dann erhöhen?
bedeutet das jetzt das ich ein nicht sobgutes pcb erwischt habe oder muss ich nocj mit den werten spielen?
Nicht jede 4090 schafft 3000... NVIDIA garantiert Dir bloß 2520. Alles darüber ist "nice to have".
Abgesehen davon, ja eine Spannungserhöhung könnte helfen.
Wie aber bekannt ist, kann man die Spannung nur bedingt nach oben schieben. Die RTX 4000er Generation ist nicht durch Leistung begrenzt (Energieumsatz pro Zeitspanne, aka Watt), sondern durch Spannung. Da wird schnell abgeregelt, bzw. die Karte wird instabil.
Nein. Ab 850. Mit OC ab 1000.
Mann kauft keine 2000 Euro Karte um dann 30 Euro mit dem Netzteil zu sparen.
Mir geht es nicht um 30 Euro zu sparen. Das Netzteil habe ich eben schon. Da geht es dann eher darum ein komplett neues zu kaufen.
OC werde ich sowieso nicht nutzen eher UV.
Im Zweifel kann Dir ein abschaltendes Netzteil die Karte kaputt machen, ob Du das Risiko in Kauf nehmen möchtest, musst Du eben entscheiden.
Gab hier im Forum genug Fälle, wo die Community auf Fehlersuche ging (blackscreen absturz, Karte kaputt), wo sich am Ende rausgestellt hat: Zu kleines Netzteil, oder defektes.
Bei der Gigabyte Gaming OC? Da sind 1400rpm völlig in Ordnung. Ein Stück lauter als die TUF im Silent-Modus, dafür aber kein nerviges Spulenfiepen.
Hab ich mir gerade mal angehört. Könnte man aushalten aber für mich wäre es nichts; bin aber auch durch die letzten ~8 Jahre WaKü "geschädigt". Spulenfiepen oder LoadBuzzing hab ich aber auch nicht bzw. kann ich es nicht raushören.
Mann kauft keine 2000 Euro Karte um dann 30 Euro mit dem Netzteil zu sparen. Google ist Dein Freund.
Hä, na klar! Die Kombi mit dem Müll Adapter und nem 35€ NT ist doch ne Bombenmischung :lol:
Deine Entscheidung. Ich würde es nicht machen. NT ist zwischen 30-60% Last idR am effizientesten. Denke 850 Watt sind das Minimum. Ich habe mein 750 Watt Corsair RMX auch gewechselt. Ist halt nun mal so.
Das ist viel zu leistungshungrig, da kratzt Du stock an der 200 Wattmarke rum (mal ganz von Spikes abgesehen). Bei einem 750W Netzteil solltest Du maximal 100-125 Watt auf der CPU einplanen.
Niemals vergessen, dass jeder Lüfter Strom verbraucht (~5 Watt pro Lüfter. NON RGB), das Motherboard (12th Gen Intel) selbst braucht idR ~75 Watt, optische Drives brauchen 30w, 3.5 HDDs ca. 10W, M.2 oder 2.5" SSDs ca 8 Watt.
Das ganze muss man sich immer zusammenaddieren, "nur" mit der CPU und GPU ist es nicht getan.
Mal ganz abgesehend davon, dass alle Geräte, die in den USB-slots des PCs stecken (soweit keine eigene Stromversorgung), selbstverständlich auch Strom brauchen (Maus, Tastatur, externe Festplatten usw).
Ja denke auch das wird besser sein. Du bist mit deinem zufrieden? Welches hast du dir gekauft?
Du lachst mir ist -als Student- ~2007 mal ein LC Power (550W) Netzteil "explodiert" und hat gebrannt.
Habe WaKü und Pentium 940 OC gemacht oder so und am NT gespart. Das ist heute aber unrealistisch.
Thermaltake Thoughpower ATX 3.0 1650 Watt mit zwei nativen 12 Pin Kabeln. Totaler Overkill, aber habs im Angebot bekommen.
Ich empfehle gerne das 1350 Watt mit einem nativen 12 Pin Kabel. Für den Preis und ATX 3.0 ist es absolut top. Die Reviews bestätigen das. Premium zu einem Preis der gerade noch OK ist.
@Minga bua : schau gerne mal hier rein:
Thema 'Netzteil Kauf: Thermaltake + RTX 4090: 1200W ATX 2.4 für 169 oder 1200W ATX 3.0 für 263' https://www.hardwareluxx.de/communi...4-für-169-oder-1200w-atx-3-0-für-263.1324978/
Ich denke nämlich dass es mit den ganzen China-Lockdown Meldungen über den Jahreswechsel eher weniger Ware geben wird. Aber auch das: Spekulatius
Haben ist besser als nicht haben und brauchen, habe ich mir schon öfter gesagt.
Habe noch immer drei Netzteile (es waren mal fünf) und zwei 3090 FTW3 auf Lager. :LOL:
Bei Alternate liegen im Outlet immer noch 4 Trinities rum... will wohl keiner für 2.240 EUR ;)
Die spielen Körbchen wechsel dich, warten auf den 10%-20% Rabatt auf Outlet Artikel.
Hast du die Karte denn sonst noch niedriger laufen? Reserven sind im Bezug auf die Temperatur natürlich noch da, aber ich bin eher Fan von "festen" hardwareseitigen Einstellungen. Deswegen war es mir auch wichtig, dass das Silent-BIOS prüfbar läuft.
Über den Newsletter gibt es das ab und zu, kommt dann meistens Donnerstag oder Freitag Nachmittag, GPUs waren aber auch schon exkludiert davon. :sneaky:
In den letzten 2 Jahren, waren Grafikkarten immer ausgeschlossen in den Outlet Aktionen. Wird bestimmt so bleiben :)
Die MSI Liquid geht richtig gut. Ein Kumpel von mir hat gestern seine Liquid bekommen und ist kein 600W Bios drauf. Schon komisch.
Warum hat AMD jetzt eigentlich 2 Jahre Zeit und Geld für die Entwicklung verschwendet???
Sie hätten doch einfach sagen brauchen, dass die Leute die nicht so viel Geld ausgeben wollen, sich eine 3080 oder 3090 kaufen sollen, und diese Runde einmal aussetzen. :-)
Nun mit 1850 Speicher
Heute Nacht wird es kalt. Ich leg den Rechner dann mal raus zum Benchen :d
Und 1900 Speicher fehlerfrei
RTX 4080 bei über 1500 Euro
War doch zu erwarten, möglicherweise werden die Preise aber nach unten angepasst, sofern AMD tatsächlich delivern kann.
Deren fake 8K (halbe Resolution) Gerede und "50% schneller" sind - genau wie bei NVIDIA - nicht aussagekräftig, hier muss man erst auf Reviews abwarten, ob die 7900 XTX tatsächlich auf Augenhöhe mit einer 4080 steht.
so 4090 drin, meine fresse pumpt die FPS
Wir sollten uns das als Consumer sehr wünschen. Denn Wettbewerb stärkt unsere Position und drückt die Preise. Daher verstehe ich die AMD/NV Fanboys nicht. Ich habe seit 2016 Aktien beider Firmen. AMD von 3,25 auf über 60 und Nvidia von 32,60 auf knapp 600 (gab vierer Split). Damit kann ich nun Gaming PCs finanzieren, bis ich 100 bin.
  • Asus ROG Strix GeForce RTX 4080 OC - 1.969,90 Eur
  • LOL
aber idle Luft 49° die GPU? is dat normal?
Edit: ah is Zero RPM Fan auf der TUF
Ähnliche Themen
Antworten
6K
Aufrufe
381K
