[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier nochmal bzgl. des Thermaltake Netzteils in Artikelform:
My major complaints about the Thermaltake Toughpower GF3 1350W are the super high OCP triggering points at 12V and the extremely loud operation because of the poorly tuned fan speed profile. The cooling fan suddenly goes to over 35 dBA, from passive operation, without any intermediate stages. High Power should adjust the fan speed profile properly, and if it cannot do it alone, it can look at the Cybenetics reports to check what needs to be done. For today’s standards, having a PSU outputting more than 50 dBA noise is unacceptable! It would be highly preferable to use a larger PCB and increase the PSU’s dimensions slightly, from 160mm depth to 180mm depth, to allow for a better airflow at the internals and larger heatsinks.
Lieber die Zeit etwas überbrücken bis ordentliche NTs auf Lager sind.
Bitte mal kurz für Doofe: habe ein Asus ROG Thor 1000W Platinum 2 hier liegen. Noch komplett eingeschweißt, könnte also wirklich ohne Drama noch zurück.
Hat das Ding jetzt den KORREKTEN 12VHPWR Anschluss, oder nicht? Mir ist klar, dass es auf einer Seite 2x 8 Pin ist und bei 450W schluss ist. Aber die 12VHPWR Seite, passt die jetzt an die 4090 oder nicht?
Warum frage ich jetzt so blöd? Wenns nicht passt, mache ich natürlich nicht einmal die Folie ab und so entsteht bis auf den unsinnigen hin und her Transport kein Schaden. Ich möchte halt verhindern dass ich alles aufreisse und dann bringt es mir nix.
Denn: heute kommt mein neues Gehäuse und dann will ich an den Umbau gehen. Kann auch das alte Netzteil nutzen, wollte halt ohne klobigen Adapter auskommen.
Also ich habe das 1200W Thor II Netzteil und das Kabel passt auf jeden Fall für die 4090. Es hat 2 Sense Pins, die 600W signalisieren. Ich warte trotzdem auf das Cablemod Kabel, das auf 4x 8 Pin endet bevor ich da 600W drüberjage.
Danke, dann passt alles. Wie gesagt: die 600W will und brauche ich nicht, deshalb hat mir die 1000W Version auch dicke gereicht. Ich will nur den Adapterbatzen da nicht herumeumeln haben. Ja, viel Geld dafür. Und noch besser: von dem unsinnigen OLED hab ich garnix, weil ich das im Torrent nicht sehen werde. :ROFLMAO:
Gibt es eigentlich schon einen Block für die SuprimX, ich finde nichts?
Meine kam ohne Express gestern an
Ähhh Samstag natürlich:d
@ SH
wie sind die Temps bei deiner Frostbite?
Habe bei 0,95V 300W und 2700MHz etwa 10K zum Wasser auf der GPU und Speicher, Hotspot 20K zum Wasser.
Wie hast Du die Karte so schnell erhalten? Habe auch Express gewählt und hoffe sie kommt heute an.
Ja eher Glück. DHL App zeigte Montag an, aber sie wurde dann doch Samstag zugestellt. :)
@ SH
Teste ich gleich mal. Einfach nur PowerTarget angepasst und fertig?
@ralle_h
Proshop meldet dass die Frostbite dort auf den 15.11 erwartet wird, hast du Proshop im bot?
Vielleicht hab ich da dann mehr Glück als beim Käsekönig...
@ralle_h
Der Preis ist echt gut. Dieses "Der Verkauf von vorrätigen Karten öffnet täglich (Montag bis Freitag) um 14.00 Uhr."
Ich habe dadurch bei Proshop noch nie eine Karte bekommen.
Nur Undervolting, also komplette Kurve +100Mhz und dann bei 0,95V gekappt/gerade ergibt bei mir rund 2700Mhz und knapp 300W unter Last.
Hast du die mhz schon ausgereizt? 2700mhz klingt ein bisschen wenig :) Ich teste es auch gleich mal
Gibt Benchmarks zur 4080
Sollte die 7900 XTX tatsächlich für 1000/1200 (€ Preise, sofern AMD denselben Aufschlag wie NVIDIA will) zu bekommen sein - UND mehr Leistung u. VRAM haben, ist das Produkt irgendwo DOA, da die meisten CUDA/creative professional Anhänger direkt zur 4090 greifen werden.
Kein Wunder, dass die 4080 (70) 12GB abgesagt wurde, die würde bei dem Preis/Konkurrenz einer 7900 XT vermutlich noch heftiger niedergehen.
Hier hat NVIDIA wohl zu heftig versucht NICHT die 3000 Generation zu beschneiden, da der Leistungsunterschied hier zur Ada Topkarte zu groß und zur Vorgängergeneration zu niedrig ist - sollte AMD jetzt delivern können, würde das für eine erhebliche Marktverschiebung sorgen. Wobei ich hier bezweifle, dass AMD die Produktionskapazitäten hat...
Ne das passt nicht beim 1000W ist nicht das richtige Kabel dabei, erst beim 1200er.
Ich hab gerade Mal überschlagen:
Vulkan Punkte der 6900xt × 1,05 (5% mehr schafft die 6950xt) × 1,5 (vorsichtige Schätzung zur 7900xtx nach AMD Folie) = 180.510 Punkte.
Nein, habe die Karte ja erst seit Samstag, wahrscheinlich gehen auch entweder weniger Volt oder mehr MHz, meine 3080 Ti lief mit 0,9V und +200MHz problemlos.
Was mir auffällt, die 4090 erwärmt das Wasser deutlich weniger, die 3080Ti hat zwar 40W mehr gezogen, hing aber besonders in VR eigentlich immer am Limit.
Dafür ist der Hotspot bei der 4090 etwas wärmer relativ zur GPU Temp, die 3080 TI hatte ich aber auch selbst mit der Wakü bestückt und wirklich jeden Abstand penibelst ausgemessen, das macht sicher kein Hersteller.
Ja wie jetzt? Geht es etwas genauer?
Gehts darum dass das nur für 450W freigegeben ist, oder funktioniert der Adapter vom 1000W garnicht?
Finde grad den Post nicht mehr aber die 1000W Asus PSU der neuen Gen machen wohl nur bis zu 450W über das beigelegte 12-Pin Kabel und das 1200W bis zu 600W.
Hier eine Teilquelle: https://www.hardwareluxx.de/index.p...uf-die-fe-karten-der-rtx-30-serie-update.html
EDIT: Es ist auf der Seite von Asus beim Thor Platinum II 1000W wieder auf bis zu 600W geändert worden: https://rog.asus.com/power-supply-units/rog-thor/rog-thor-1000p2-gaming-model/
Frag mich nicht was jetzt stimmt :d
Das wäre ja wurscht wegen 600W... Aber ich lese gerade das hier: https://rog.asus.com/forum/showthre...h-a-12VHPWR-cable-without-sense-pins&p=874971
es kann wohl passieren, dass beim 1000W Thor noch ein Kabel ohne Sense Pins dabei ist (wurden irgendwann umgepackt und dann kanns wohl sein dass sie eines haben das funktioniert). Öhm... ja...
Schrödingers Katze Effekt. Ist das korrekte Kabel in der verschweißten Verpackung, oder nicht?
Yeah! dann geht es zurück. Gut dass ich das noch vor dem Aufreissen mitbekommen habe. Dann gibts bei der Rückgabe hoffentlich keine Diskussionen.
Hab letztendlich die Gigabyte Gaming OC behalten, weil es dafür von EKWB ein Block gibt. Zwar war die KFA2 noch etwas leiser beim Spulenfiepen aber kann mich weder mit Byzki noch Alphacool Block anfreunden.
Naja noch nicht lieferbar, Support hat mich auf Ende November vertröstet, bestellt am 22.10.2022, vermerktes Lieferdatum bei der Bestellung war der 31.10.2022. Und leider für die Gaming OC ohne ABP. Ja ich weiß, braucht man nicht unbedingt, aber ich hätte mir die Option ABP wie bei der FE zumindest gewünscht.
Klappt grad gar nix :d Weder Cablemod (überfällig) noch EK.
Wann hattest deinen Block bestellt?
Ähnliche Themen
