[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das wäre ja wurscht wegen 600W... Aber ich lese gerade das hier: https://rog.asus.com/forum/showthre...h-a-12VHPWR-cable-without-sense-pins&p=874971
es kann wohl passieren, dass beim 1000W Thor noch ein Kabel ohne Sense Pins dabei ist (wurden irgendwann umgepackt und dann kanns wohl sein dass sie eines haben das funktioniert). Öhm... ja...
Schrödingers Katze Effekt. Ist das korrekte Kabel in der verschweißten Verpackung, oder nicht?
Yeah! dann geht es zurück. Gut dass ich das noch vor dem Aufreissen mitbekommen habe. Dann gibts bei der Rückgabe hoffentlich keine Diskussionen.
PCIe Gen 5.0 Ready​
Each ROG Thor 1000W Platinum II PSU is bundled with a 16-pin PCIe cable that can pipe up to 600W of power to PCIe Gen 5.0 graphics cards. Get ready for the future of power delivery.
*If you purchased a ROG Thor 1000W Platinum II PSU that did not come with a 16-pin PCIe cable, please contact your local ASUS customer service representative
Das steht auf der Produktseite von Asus beim Thor P2 1000W.
Danke, dann passt alles. Wie gesagt: die 600W will und brauche ich nicht, deshalb hat mir die 1000W Version auch dicke gereicht. Ich will nur den Adapterbatzen da nicht herumeumeln haben. Ja, viel Geld dafür. Und noch besser: von dem unsinnigen OLED hab ich garnix, weil ich das im Torrent nicht sehen werde. :ROFLMAO:
Ich meine mal irgendwo gelesen zu haben, das die keine 600W liefern sollen, sondern nur 450 Watt. Zumindest mit dem mitgelieferten Kabel. Es hat keinen nativen 12VHPWR Anschluss.
MSI ATX 3.0 1000 Watt Netzteil, Lieferbar:
ATX 3.0 sieht offiziell erst ab einer NT Leistung von 1100 oder 1200W 600W über 12VHPWR vor, afaik.
Hier mal meine Erfahrungen zu meiner 4090 FE im Vergleich Luftgekühlt vs WaKü.
Coretemps delta Luft bei 450W ca. 40Grad bei UV 300W ca. 25-30Grad
Coretemps delta WakÜ bei 450W ca. 18Grad bei UV 300W ca. 13-15Grad
Core OC Clock Luft +140 mit Wakü bis +235
RAM OC Clock Luft gingen bei mir +1000, mit Wakü bis +1800
Nur Undervolting, also komplette Kurve +100Mhz und dann bei 0,95V gekappt/gerade ergibt bei mir rund 2700Mhz und knapp 300W unter Last.
311W laufen lassen für 5 Minuten im Benchmark. Karte pendelt sich so bei 45 Grad ein. Die Lüfter auf den Radis laufen alle mit 600 rpm. Habe 2 x 360er Radis, die CPU und GPU kühlen. Ich höre einfach nichts von meinem System.
Leise, effizient und viel Leistung. Jetzt noch den Takt und Speichertakt finden. Einfach eine TOP KRASSE Karte.
Ich kann übrigens bestätigen, dass das Spulenfipen mit ca. 70% Powertarget komplett weg ist bis 250 FPS auf der Frostbite.
Moin, hab mir jetzt den be quit Adapter geholt, weil mein pc Neubau eigentlich nur noch auf ein nt wartet. Die bisher bekannten atx 3.0 sind nicht lieferbar oder nicht interessant iwie. Nvidia Adapter passt nicht ins Case und sieht auch kacke aus. Welches be quit nt würdet ihr empfehlen für ne 4090 mit 5800x3d?
vielleicht währe unter Luft auch etwas mehr RAM Takt drin gewesen, hab es aber erst unter WaKü bis zur obersten Grenze ausgelotet.
Das ist gar nicht in diesem Sinne möglich.
Bzw. in deinem Test hat es geklappt, weil deine Karte durchgehend limitiert wurde.
Hast du aber ein Spiel mit FPS Limit oder wie auch immer (gibt mehrere Situationen),
läuft die Karte auch mal gerne mit 1.05v, solange das PT nicht erreicht wird.
Und dann ist das Spulenfiepen wieder kurzzeitig oder länger oder in unregelmäßigen Intervallen vorhanden.
Ich nutze daher lieber fixes UV als dieses variable UV über PT.
Danke. Ich schaue mir das mal genauer an.
Hier ein Ergebnis mit 311 W undervolting der Frostbite. Speicher nur +800mhz.
Knapp 3000mhz mit 311 W ist schon gut. Da kann man auf jede Fall noch optimieren.
Da es offenbar noch nicht gepostet wurde:
Interessant, aber das ist wohl das mindeste was sie machen können. Heißt aber auch wohl, dass es jetzt in naher Zukunft schwerer werden dürfte eine 4090 zu bekommen. Die anderen Boardpartner werden das vermutlich genauso machen und erstmal Ware zurückhalten.
straight power 850w
Kommt auf das restliche System an. AIO, Laufwerke, Lüfter, Kirmes Zeug etc... Hab ebenfalls ein 5800X3D, die FE 4090 ist in Zustellung und ich hab ein beQuiet Straight Power 850W Platinum.
So muss man das wohl annehmen.
Die Frage wird sein wie das ganze mit dem Austausch ablaufen wird.
Normalerweise müsste Nvidia nen ganzen haufen Adapter auf an jeden Retailer schicken der 4090 verkauft mit der Anweisung einen neuen Adapter an jeden Kunden zu schicken der bereits ne 4090 gekauft hat.
Das ganze natürlich auf Nvidias kosten und mit ner Erkärung an den Endkunden warum da jetzt unaufgefordert so ein Kabel im Postkasten liegt, weil sicher nicht jeder 4090 Käufer mitbekommen hat dass es da ein Problem gibt.
Frage mich, ob Undervolting überhaupt etwas bringt, wenn ich das Powerlimit auch einfach auf das minimum an Leistung senken kann, wie ich je nach Spiel benötige.
Hab es zB in God of War bei 4K und knapp 120 FPS mit DLSS auf knapp 200 Watt geschafft. Die GPU läuft laut Leistungsoverlay bei 0,9Volt.
Lässt sich durch zusätzliches manuelles undervolting noch weniger Watt bei derselben Performance herausholen?
120 FPS in 4k und ein Verbrauch von unter 180 Watt wäre ja schon ein Träumchen 🤔
Das "Problem" am Powerlimit ist halt, dass sie wenn sie noch Power Budget hat, unnötigerweise auf 1.05V hoch geht, auch wenn es nicht sein muss, mit UV ist sie halt auf niedriger Spannung festgenagelt :d
Falls jemand den Fall hat mit dem ASUS ROG Thor Netzteil: ich habe mit dem Support gesprochen. Packung öffnen, wenn das Kabel fehlt (wie bei mir), dann die Kopie der Rechnung an den Asus Support und dann schicken die ein 16 Pin Kabel. Habe ich jetzt so gemacht.
Sind das dann 200W Gesamtsystem, oder nur Grafikkarte ?
AIO mit 360er Radi, 12 Rgb Lüfter, x570, 32 gb RAM & etwas rgb Kirmes Zeug von Corsair :)
Vielleicht das 1000w platinum?
Das Kabel fehlt aber gar nicht. Es ist einfach beim 1000W Netzteil nicht enthalten. Das hat nur einen 12 Pin. Steht auch so auf der Webseite.
Da würde ich dann wohl tatsächlich eher in Richtung 1000W gehen...
Ich habe das schon mehrfach gesagt: Das ist auch die einzig denkbare Lösung die NVIDIA anbieten wird meiner Meinung nach.
Das macht auch Sinn. Frage ist nur, ob jeder ein neues kostenloses Kabel bekommt und wie der Prozess sein wird bei jedem Hersteller, wenn man bereits eine Karte hat.
Kann mir gut vorstellen, dass es bei den neuen Kabeln zu Lieferproblemen kommen wird.
Moin,hat jemand von euch das neue BIOS (Version V2 2022/11/07) für die TUF 4090 OC Ausprobiert ?
Heißt dann aber auch, dass NVIDIA wirklich nur einschreitet wenn die 3/4er Adapter im Einsatz waren und die zwei bisher bekannten Fälle mit den nativen 12VHWR Kabel vom Netzteil sich mal schön an den Neztteilhersteller wenden können...
Zeigt aber auch, dass wenns mit nem Cablemod Kabel passiert man sich auch nur an Cablemod wenden kann, auch wenn die GPU Schaden genommen hat...
Ähnliche Themen
