• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab letztendlich die Gigabyte Gaming OC behalten, weil es dafür von EKWB ein Block gibt. Zwar war die KFA2 noch etwas leiser beim Spulenfiepen aber kann mich weder mit Byzki noch Alphacool Block anfreunden.
Kann man aus deiner Aussage schliessen, dass der Alphacool-Kühler auf die KFA2 passen würde? (obwohl die KFA2 NICHT in der Kompatibiltätsliste aufgeführt wird?)
Das Kabel fehlt aber gar nicht. Es ist einfach beim 1000W Netzteil nicht enthalten. Das hat nur einen 12 Pin. Steht auch so auf der Webseite.
Zum einen hat mir die Support Dame was anderes erzählt und zum anderen steht auf der Webseite wie heute hier schon einmal zitiert:
"PCIe Gen 5.0 Ready
Jedes ROG Thor 1000W Platinum II Netzteil wird mit einem 16-Pin-PCIe-Kabel geliefert, das bis zu 600W Leistung an PCIe Gen 5.0 Grafikkarten liefern kann. Mach dich bereit für die Zukunft der Stromversorgung.
*Wenn Sie ein ROG Thor 1000W Platinum II-Netzteil erworben haben, das nicht mit einem 16-poligen PCIe-Kabel geliefert wurde, wenden Sie sich bitte an Ihren ASUS-Kundendienstvertreter vor Ort."
Quelle: https://rog.asus.com/de/power-supply-units/rog-thor/rog-thor-1000p2-gaming-model/
Heißt dann aber auch, dass NVIDIA wirklich nur einschreitet wenn die 3/4er Adapter im Einsatz waren und die zwei bisher bekannten Fälle mit den nativen 12VHWR Kabel vom Netzteil sich mal schön an den Neztteilhersteller wenden können...
Zeigt aber auch, dass wenns mit nem Cablemod Kabel passiert man sich auch nur an Cablemod wenden kann, auch wenn die GPU Schaden genommen hat...
https://www.reddit.com/r/nvidia/comments/ye9ede/will_be_cablemod_12vhpwr_cable_void_my_4090/ zumindest die Garantie erlischt scheinbar nicht ....
Ja, das würde ich als CableMod auch behaupten...
Aber wenns Netzteil dir die GPU zerschießt, an wen wendest dich dann?
Das ist doch immer das Problem, auch mit dem Nvidia Adapter, kann Nvidia sagen "ja dein Netzteil war schuld"...
Das hat man jetzt zumindest schon das öfteren gelesen. PCB Layout der KFA2 ist auch Referenz, sollte also mit hoher Wahrscheinlichkeit passen.
Hat hier jemand aktuell seinen 5950x oder 5900x mit einem 5800x3d getauscht? Macht es sinn. Google seit tagen und finde immer unterschiedliche aussagen.
Ja ich hab den 5950x durch den 5800X3D ersetzt, weil FS2020 enorm vom größeren Cache profitiert und ich den Rechner nur für das Spiel nutze.
Generell schau einfach Benchmarks zu den Spielen an, die du spielst.
Glaub da kann man viel diskutieren und spekulieren bezüglich Verantwortung, Schaden, Adapter und Kabel..... Am Ende sieht man es ja wie sich einzelne Parteien dazu verhalten und äußern. Recht haben heißt eh leider nicht immer Recht bekommen :d
"PCIe Gen 5.0 Ready
Klick halt mal auf technische Daten und schau dir die Anschlüsse an. Da steht dann nix mehr von 16 Pin
Das "Problem" am Powerlimit ist halt, dass sie wenn sie noch Power Budget hat, unnötigerweise auf 1.05V hoch geht, auch wenn es nicht sein muss, mit UV ist sie halt auf niedriger Spannung festgenagelt :d
Ok das ist eine gute Info danke und
Hauptsache die Karte stürzt nicht ab.
Und beim Powerlimit auf 2% stürzt die auch nicht ab, nur dass das Spiel wahrscheinlich unspielbar ist, oder? 😂
Es gibt unterschiedliche Aussagen. Auf der Packung steht auch nix von 16 Pin. Genau deshalb hatte ich mit dem Support telefoniert und sie sagten mir dass sie mir ein korrektes zuschicken. Werde ich ja sehen was sie mir antworten, da die Anfrage unterwegs ist. Wenn nicht, gehts halt trotzdem zurück. Wer soll sich denn in dem Irrenhaus noch auskennen?
Schau mal in die Wakü Threads da gibt es ein paar Infos darüber.
Hab meine KFA2 zu Alphacool eingeschickt , die wird dann vermessen und bewertet.
Fakt ist trotzdem, das du dann gleich ein Netzteil kaufen kannst, wie ein Be Quiet, und dir dazu das Adapterkabel holen kannst. Denn nix anderes ist dein Asus Thor Netzteil.
Es bietet KEIN nativen 16 Pol (12+4) Anschluss am Netzteil.
Ich würde lieber ein natives ATX 3.0 Netzteil holen, wie z.B: das von MSI, was seit 2 Tagen verfügbar bei Mindfactory ist.
Die Federn dann auch offiziell die 2-3 fache Lastspitzen ab.
Transient Power Spike? Wie bereits mehrfach angesprochen ist lediglich der 6+2 Konnektor auf dem PCB der GPU für 150W rated. Das Kabel selber und der Anschluss am PSU können deutlich mehr.
Wieoft willst die 580W Frage eigentlich noch stellen? 🤪
bis sich mehr Leute beteiligen und das mal bei sich anschauen und Meinungen dazu einholen
ich würde den Spike bei 4x8 gern mal sehen und ob das über 600 geht
oder ob vielleicht damit die Lanes/Rails auf dem PCB gemeint sind?
Das kann nur ein Auslesefehler sein, um in den Genuss von 600Watt zu kommen, muss der 4x8 Adapter genutzt werden.
wie oben eben:
Und wisst ihr was das schlimmste ist? Ich werde trotz 4090 zum Großteil doch wieder GoG Spiele aus den 90ern anwerfen... Schice drauf...
:LOL:ich wollte ja jetzt endlich mit Cyberpunk 2077 anfangen, aber jetzt hörte ich das dieses Cop Ding noch nicht richtig funktioniert...das DLC steht auch noch vor der Tür, DLSS3 ist auch noch nicht implementiert...also suchte ich ein anderes, die 4090 auslastendes Spiel und kam dann auf die Militärsimulation Wolfenstein "Old Blood"....das Spiel schafft es sogar meine 4090 in die Knie zu zwingen, man kann alles auf maximum stellen, aber wehe ich stelle AA von 8x auf 16x, dann hab' ich nur noch 60-80fps statt den 140fps im Limiter.o_O
8x AA
16x AA
Ich habe das selbe "Problem". Kam mir auch schon in den Sinn. Hat diesen Spike denn sonst niemand?
würde mich auch interessieren und darum der Repost :)
welche Karte hast du genau?
Ich überleg auch das MSI aber der Reddit Post mit den geschmorten Kabel von dem nt bereiten mir iwie sorgen
Hallo, das interessier mich sehr, weil ich auch vor allem auf den FS2020 gehe. In welcher Auflösung spielst Du (4k? oder sogar VR?) und wieviel hat das im unterschied ausgemacht (ich habe noch einen 5950x rumliegen, aber noch keine passende Grafikkarte. Auf welche fps Werte kommst mit der 4090? Danke und viele Grüße
auffällig ist: bei den 25? Fällen ist nicht eine einzige FE dabei
und die Mehrheit sind 4x8 Lösungen und weniger 3x8 Lösungen
So die iChill Black kam vorhin glücklicherweise an :). Verpackung von Caseking TOP, Karton von außen versiegelt, Karte im perfekten Zustand, so wie es auch sein sollte! Die Karte ist sehr wertig verarbeitet, sieht etwas nach Custom WaKü aus. Es war nicht so einfach allein die Karte einzubauen und anschließend an der Gehäusewand den Radiator. Dieser ist übrigens um einiges dicker, als die normalen CPU AIOs. Dagegen sieht der 420er Radiator meiner H170 wirklich dünn aus :d. Karte läuft perfekt und die Pumpe ist nicht hörbar. Die Lüfter drehen im Idle auf 200rpm. Spulenfiepen konnte ich bei 144fps nicht feststellen, mehr habe ich noch nicht getestet. Die Pumpe der Corsair AIO ist auf jeden Fall das Lauteste in meinem System nun.
Kurze Frage, ist die Postion des Radiators so in Ordnung, bezüglich der Luftblasen? Karte mit Pumpe soll ja nicht der höchste Punkt sein.
Edit: Bin sehr froh, dass ich lange warten musste und die Suprim X dann doch nicht die Karte für mich war. Manchmal braucht es eben einen Wink des Schicksaals :). Inno3d und Artic haben da echt was Feines auf die Beine gestellt 8-). Die Nvidia Adapter war ein 3 Stecker, also sollte die Karte, so wie die Frostbite, 450W PL haben, was für mich mehr als ausreicht und auch das Stromkabel schonen sollte :d. Jedoch war es etwas schwerer, als bei der 3090Ti, das Stromkabel richtig reinzustecken. Musste am Ende nochmal deutlich schieben, bis es dann richtig fest war. Also falls jemand auch eine Inno3d Karte hat, überprüft das nochmal!
Ist das hier schon bekannt?
Das Problem der RTX 4090 könnte laut neuer Berichte noch größer sein als befürchtet
Die Situation ist unklar
Clickbait Müll.
Wenn du nur Spiele spielst und sonst nichts machst kann man nix besseres momentan machen als einen 5800X3D einzubauen. Meinen 5950x kann ich quasi 1:1 austauschen vom Geld her gesehen. Das reicht dann erstmal bis die 5090 rauskommt.
5800X3D kommt diese woche inklusive neues Torrent gehäuse :). Fehlt nur noch die 4090...und vorallem das Corsair Kabel.
Ähnliche Themen
