[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Von wegen... Warte seit 4 Wochen und habe seit 2 Wochen eine Tracking Nummer die mir immer nur Anzeigt das irgendwann etwas in den Netherlands ankommen soll aber nix passiert,
Soviel zu Cablemod. Ganz zu schweigen von den horrenden Lieferkosten.
Mein Cablemod ist heute in der Zustellung mit GLS, hatte am 07.10. bestellt. Also ca. ein Monat für die Lieferung.
Problem ist am Ende, dass die Umgebungstemperatur des Steckers zu heiß wird. Gerade die Abwärme der Grafikkarte bei 400+ Watt oder gar Richtung 600w bei nur durchschnittlicher Gehäuselüftung kann dem Stecker bei längeren Sessions schnell zum Verhängnis werden.
Glaube ich nicht, denn dann wären wesentlich mehr betroffen. In meinem Case wird es gut warm und da schmilzt nichts.
Wenn ich das richtig in Erinnerung habe, dann sind die Kabel/Stecker doch bis über 100°C zertifiziert?
Jetzt nehmt halt nicht alles so ernst. Ein bissl Flax darf doch sein
***** meint das ernst.
O
Ich habe erst Oktober 23 bestellt. Das lässt die Laune ja sinken. Eu Store am A....
Besser als nen Group buy bei mechas. Warte seit über 1 Jahr auf meine Tastatur. Die keycaps haben 6 Monate gedauert für meine anderen keycaps warte ich bereits 18 monate😆
Auch einfach mal Kram verkaufen, den man gar nicht hat. Vorrätiges Zeug anbieten machen alle. Und man will ja besonders sein.
@***** -40°C bis 105°C: https://www.digikey.com/en/products/detail/amphenol-cs-fci/10161719-124GLF/15789337
Deine Theorie ist schwachsinnig.
Teclab hat das Teil bis 1450W geprügelt und selbst das hat der Stecker mitgemacht bei 127°C:
Then we increased the load from 300W by 300W, until we reached 1450W, with approximately 25 minutes, taking the set to 127 degrees without causing damage.
https://www.reddit.com/r/nvidia/comments/yex4fc/test_of_the_16pin_connector_performed_by/
Und dann unterschätzt du noch eine konstante Abwärme von 400 bis eventuell 600 Watt.
Nimm mal ne 10 Watt Glühbirne in die Hand.
Okay. Du glaubst wirklich dass in dem Bereich soviel Abwärme auf die Steckverbindung einwirkt, dass das eine echte Ursache sein könnte? Das müsste doch enorm viel Abwärme sein. Ich tue mich gerade schwer damit wenn ich an Temperaturen von 100°C+ denke.
Ich kanns nicht ausschließen. Ich bin kein Techniker. Aber irgendwie tue ich mich damit echt schwer.
Dazu haben wir jetzt Winter, da wird alles qool bleiben xD
Wir hatten letzte Woche in NRW bis zu 25°C. Wo Winter?
Amphenol gibt bis zu 105°C als "operating temp." an. Wenn die Lufttemperatur in deinem Case so hoch ist, dann killt dir das auch sämtliche andere Komponenten.
Die Leute messen alle außen und nicht im Inneren und wie gesagt, Temperatur hat einen Einfluss auf Stromwiderstände.
Teclab erreichte 1450W und 127°C und der Stecker bleib intakt. Wieso ignorierst du das? ;)
naja is nix neues das mit steigender Temp der Widerstand steigt
und steigender Widerstand heisst du brauchst mehr Saft um das auszugleichen > wieder mehr Temp > wieder mehr Widerstand
sis is a devils circle!
Ach ja, die 25°C auf wenige Stunden haben ausgereicht um die gesamte Wohnung oder das Haus aufzuheizen? :d
Du Vergleichst wenige Stunden bis 25°C bei einer Nachttemp von 10 bis 15°C mit dem Sommer bzw. Hochsommer?
Der Stecker ist bis zu einer Betriebstemperatur von 105°C zertifiziert und wurde bis 127°C getestet.
Was ist das für ein Hochsommer, der dein Case auf über 105°C aufheizt und wie überleben das deine HDDs, SSDs und das Mainboard?
Dem widerspricht auch niemand, aber wenn man mal ins Datenblatt schaut, stellt man fest, dass die Specs. bis 105°C gehen: https://www.digikey.com/en/products/detail/amphenol-cs-fci/10161719-124GLF/15789337
Meinst du nicht, dass das auch andere Komponenten und Kabel killt, wenn du eine solche Lufttemperatur in deinem Case erreichst?
Der verlinkte Elektriker erklärt halt, warum das Kabel "overloaded".
Hier ist ein Elektriker? Der dem widersprechen kann? Ich sehe nur Amateure wie mich. Ansonsten würde sich doch ein Elektriker hier zu Wort melden und die Theorie von Sylwester. in Frage stellen, oder? Und das natürlich auch fundiert begründen.
Naja, die wenigsten werden Ihre Rechner draußen stehen haben, in meiner Wohnung sind auch im Winter keine 10-15°C, insofern macht aus meiner Sicht die Jahreszeit für eine Temperaturbetrachtung im Rechner keinen Riesenunterschied.
Teclab pumpt 1450 W durchs Kabel und erreicht 127°C.
Datenblatt von Amphenol (der Hersteller des Steckers!) bescheinigt einen einwandfreien Betrieb bis 105°C.
*****: "Die lügen alle und sind Amateure. Sylwester ist der einzig wahre und hat recht und das kann ich beurteilen, obwohl ich selbst gerade zugegeben habe keine Ahnung zu haben":
Kannste dir nicht ausdenken.
  • Haha
Reaktionen: THK
Ich habe mir da einfach selbst was zusammen gereimt. Ob es stimmt ? Keine Ahnung, bin weder Elektriker, noch habe ich einen Doktor Titel.
Steht das Kabel zu sehr unter Zug-Spannung (Biegeradius), ist der Kontakt nicht mehr 100% gegeben. Also wird entweder eine kleine Stelle viel stärker belastet oder aber es kommt zum "Funken-Flug". Der Funken-Flug ist natürlich für uns gar nicht wahrnehmbar, da es um Millimeter (wenn nicht noch kleiner) geht.
Vielleicht reicht das aber schon für den Temperatur Anstieg aus. Das normale Kabel / Stecker wird niemals 105Grad oder mehr erreichen.
Kabelbrand entsteht ja nur durch 3 Auslöser : Lockere/Lose Verbindungen , Kabelbruch oder Überbelastung. Hier würde ich als Laie auf Punkt 1 tippen.
Blicke bei cablemod nicht mehr durch.
Wie kann ich da jetzt den 180grad Adapter bestellen?
Hatte mich an dem "release" Tag da mit Email eingetragen, dann kam auch direkt die Bestätgungsemail aber seit dem Funkstille.
In 4 -6 Wochen bekommt man einen Link zum Bestellen wenn man sich da angemeldet hat. und dann nochmal 4-6 Wochen wahrscheinlich für Versand. Dieses Jahr wird das wohl nix mehr. Und verfügbarkeit ist ja auch evtl. fraglich. Das Ding will ja gefühlt jeder mit einer 4090 haben.
Gehe davon aus dass da nur alle 2 Wochen ne ladung rausgeht mit dem Schiff.
Ich zitiere mich selbst "Das Internet ist ein seltsamer Ort :d"
q.e.d
Shit. Dann ist also nicht nur MSI mit ihren nativen Kabeln betroffen.
Scheint also doch ein genereller (Teil)Defekt innerhalb der gesamten Spezifikation/Revisionsnummer zu sein.
Die Frage ist natürlich jetzt nurnoch, welche Chargen sind betroffen...
Dieser Power Adapter / Seasonic Kabel Fall ( Nr 28 ) is nun auch in die Liste mit aufgenommen worden : ( achtet aber auf den Text )
Es wäre auch interessant, ob die bisherigen Fälle nicht zumindest zum Teil vom User verursacht wurden. Ich meine, wir hatten hier im Thread auch schon nicht ganz eingerastete Stecker und sogar zurückgeschobene Pins. Beides wurde nicht gleich bemerkt und sorgt dann bestimmt für Übergangswiderstände.
Soll jetzt kein Strohhalm sein, denn wenn es so wäre, hätte das Nvidia schon lange verkündet. Nur wäre es wirklich interessant ob solche Fälle auch dabei sind. Nur um es eben zu wissen. Man weiß ja aktuell generell sehr wenig.
Ich denke schon das da ein paar dabei sind die selbst schuld daran waren das dies bei ihnen passierte weil sie wie du sagtest den Adapter vielleicht nich ganz eingerastet haben ( was ja diesmal etwas anders is als all die Jahre zuvor ) oder wirklich zu agressiv gebogen haben besonders in der Anfangs Zeit um Ende Oktober Rum gabs sicher Leute die darauf nich so geachtet haben weil sie es jahrzente vorher auch nich so grossartig mussten wie man es nun muss weil das so blöd verlötet wurde. Vielleicht sind da auch 1 oder 2 Leute dabei die absichtlich einfach ihr Kabel etwas angeschmort haben um die Liste zu vergrößern zumindest könnte ich mir das vorstellen.
Aber die meissten Fälle dürften durch Adapter / Kabel entstanden sein wo die Qualitätskontrolle versagt hat ( 4 unterschiedliche Lötungen wurden ja bisher bei verschiedenen Adaptern entdeckt obwohl die Lötung immer gleich sein sollte weil es ja ein Serien Produkt ist sowie 150 und 300er Kabel obwohl bei eiem Serien Produkt immer das gleiche Kabel verwendet werden müsste und überprüfung ob alle Kabel auch fest verlötet sind und keins einfach von sich aus abfällt wie auf dem einem Bild von Igor ja zu sehen war das dies passieren kann )
Ähnliche Themen
