[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Und leider immer nur Software Lösungen um das RGB Gedöns abzuschalten. Macht einen Schiebeschalter für den optischen Schmutz, dann kann man von Kirmes auf Ruhe umschalten.
Einfach einen WaKü-Block drauf. Dann ist man das RGB Gedöns auch los. Evtl. kommt man bei manchen Karten an die RGB-Stecker ran, ohne den Kühler wesentlich zu demontieren.
Hast du schon eine andere 4090?
Nope, bin noch auf meiner 3090 Strix. Als ich die Strix Preise für diese Gen gesehen hab, hab ich im Traum nicht mehr dran gedacht wieder eine Strix oder so zu kaufen.. Gerade nachdem ich mit meiner(schon vor dem Umbau auf Wasserblock) schon nicht zufrieden war. Karte lief mit dem Powerlimit auf max (480W) immer auf 80°C auch mit custom Fancurve und hat sich langsam immer mehr under mehr richtung 1700mhz (wenn nicht sogar weniger) bewegt.
Verfügbar.
Ja schon klar, seit gestern gab es mind. 20 Meldungen. Aber man kommt nicht durch
btw... vlt hat jemand meine Strix ergattert die ich an ASUS zurückgeschickt habe.. erkennbar am V1 Bios das ich draufgemacht hab, außer sie flashen es wieder zurück. Ansonsten erkennbar am Rasseln, Fiepen und Schreien wie sonst was, OC kaum möglich.. Ich bin ja jemand der sie tatsächlich schön findet, mag den rot-blauen Anstrich. Aber nach meiner 3080ti Strix hab ich echt keine Lust mehr beim Zocken so dermaßen angeschrien zu werden dass ich schon gezwungen bin mit Headset zu spielen
Ich habe das bei Saturn geschafft. Mit anderen Worten, ich habe den alternativen Endgegner geschafft - und das mit fast 42 Jahren, also DEUTLICH aus dem Wettkampfalter raus. Ich feiere mich dafür heute noch.
Glückwunsch, schaffe es nicht obwohl ich 8 Jahre jünger bin ;)
Vlt klappt es noch. Hab ja momentan die FE, die evtl ein Lüfterproblem hat, wie vorher schonmal beschrieben. Die ist ansonsten nicht schlecht.. Ich will, wie viele hier einfach eine leise und kühle Karte haben, Größe egal.. oder ich wage mich an das Wakü Thema und rüste CPU und die FE um... das wäre dann das nächste Projekt
Womit kann man jetzt das RGB der FE steuern?
Open RGB?
So wie ich gehört habe kann man oben das X farblich einstellen und den Schriftzug an und ausschalten und oder dimmen?
Danke
In Anbetracht der MArktlage würde ich kein Ding raus machen. Der Geruch ist nach 2 Tagen weg.
Sieht nach einem Rückläufer aus. Wahrscheinlich von einem Spulenfieperhypochonder.
Bau sie ein, teste sie und wenn alles gut ist hast Du 3 Jahre Garantie und kannst Spass haben.
Das mit der RGB Steuerung würde mich auch interessieren. Hab schon mehrere Versionen ausprobiert, geht nix....
Dachte ich gestern Vormittag auch, alles durchgemacht, auch Bestellbestätigung bekommen. Und am Nachmittag wurde das kommentarlos storniert.
Inwiefern kaum OC möglich was hat sie denn mitgemacht bzw. nicht mitgemacht?
Hat jemand von Euch schon mal getestet, wie hoch der Temperaturunterschied beim Einsatz einer aktiven im Vergleich zur passiven Backplate ist?
Die Backplate kann schon gut warm werden auf jeden Fall. Seitdem ich die 20 Euro Ghettomod benutze, ist die Backplate nicht mehr heiß. Kann sie jederzeit anfassen im vollen Betrieb
Hab mich falsch ausgedrückt, sry.. OC ging bei 1.1V schon knapp über 3000 MHz, Mem dafür aber kaum über 500, dann gab es schon erste Artefakte.. UV hatte eher Probleme gemacht. 900mV/2600 MHz war nicht stable, erst bei 2540 MHz.. Bei Speedway ist die Strix nicht an die FE rangekommen, egal was ich gemacht habe..
So schaut aber keine Folie bei einer neuen Strix aus und der Geruch ist schon sehr offensichtlich gewesen.
Einfach dann die nächsten 1-2Wochen selbst probieren. Dann habt ihr wenigstens eine Rechnung auf euren Namen, wenn ihr die Karte dann neu eingetütet bekommt und falls euch der Rest nicht stört.:wink:
Vielleicht fragst mal ob einer die haben mag .
Meine Thunderburne sucht ja eine Karte .
Du bist ein anständiger Luxxer und vielleicht ist das ne gute Lösung. Kannst die Karte dann noch testen ob sie läuft und dann wäre das ne Möglichkeit .
Gibt mehr Infos zu der 4090 Galax Hof, wird auf 1000 Watt "begrenzt" sein (hat 2x neuen 12+4 pin Anschluss).
Ok meine ist auch kein OC Wunder, ich hatte gestern nur kurz getestet aber meine hat 2625@900mV geschafft. Bei 1.1V konnte ich nur +170 Core im TSE machen. Mem geht auf jeden Fall schon mal auf +1000. Das muss ich noch genauer ausloten.
Wieso das nicht direkt eine RTX 4090 Ti ist, ist mir ein Rätsel...
Echt eine Verschwändung von Material ohne das krasse Powerlimit vollständig auszureizen.
Ähnliche Themen
