[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@kmwteam
Hatte noch keine Zeit und Lust danach zu schauen, ob es neben der aktuell schlechten Durchlüftung noch am Treiber oder am zugemüllten WIN10 liegt. Zudem hab ich bei FF zig Tabs laufen
Die idlet total unterschiedlich, meine Gaming OC so bei 30 aber manchmal nach Gaming usw auch bei 40-50 Grad und geht dann gaaaaanz langsam runter.
Was mir noch aufgefallen ist...
Das Delta zw. GPU-Temp und Hotspot-Temp ist bei mir 10-12K bei "Board Power Draw" von 350W
Da haben Andere "nur" ein Delta von 6-8K
Evtl. sitzt der TUF-Kühler nicht richtig!?
Es kommt gerade im Idle ja auch stark auf die Gehäusebelüftung an. Bei mir ist der vertical Mount ideal in Kombination mit dem Strix Kühler. Die Lamellen sind genau so ausgerichtet das die langsam drehenden Lüfter im Caseboden die Luft durch die Lamellen nach oben drückt. Dazu ziehen die Lüfter am Radiator die Luft auch noch durch den offenen Bereich am Ende der Grafikkarte. Da kann man dann bei ca. 500upm auch locker 32-35 Grad im Idle auf der GPU haben.
Beste Grüße
Meine TUF...
Case ist aktuell schlecht durchlüftet. Momentan 48°C GPU bei 0% Lüfter
Was habt ihr so bei 0% Lüfter?
Ich habe bei 20°C Zimmertemperatur eine GPU-Chip-Temperatur von 34°C im Idle bei meiner Phantom (VRAM auch 34 °C). Der Hotspot ist 41 °C warm.
Ich habe es so eingestellt, dass die GPU-Lüfter erst bei 40 °C anspringen. Das ist halt im Idle und beim Surfen nie der Fall.
- 6x140er Lüfter in der Front (Push-Pull)
- 2x140er Lüfter oben
- 1x 140er Lüfter hinten
Sind Noiseblocker eLoops X und laufen alle konstant bei 600 RPM (quasi fast lautlos).
(+ 2x 40er RAM-Lüfter ^^)
sitze hier halbnackt und friere nicht. kommt man da mit 20grad hin ? :d
die wohnung hat fußbodenheizung bzw. wärmepumpe. thermostat steht mittig. laut vermieter soll ich das für die effizienz so lassen. hier ist nie kalt.
sollte also zimmertemp sein
So. Hab jetzt nen Kollegen glücklich aus der Wohnung verabschiedet und 2000€ + Bonus zum ausgeben :d.
Immer wieder krass wie klein die 3080 gegenüber den 4090 ist. Und die fand ich schon ordentlich groß. Bin immer noch froh die ml für 799€ bekommen zu haben. Werde ich wohl nie abgeben die Gute.
Beste Grüße
unter "alerts-sign-up" *Nvidia GPU alerts*
Auch das finde ich nicht. Kenne mich mit Discord nicht aus. Aber wenn es eh das gleiche wie telegram ist brauche ich es nicht. da ich jetzt auch eh nicht mehr auf der suche bin nachdem das FE Brummen wohl als FE Feature gelten darf. Danke Dir dennoch!
Fehlt das bei dir?
Aktualisiere nochmal. Du musst eine gewisse Zeit dort Member bzw. reg. sein, bevor du dort was machen kannst
Ok. länger als 10 minuten bin ich schon drin. Weiß aber nicht ob ich mal eine Phone Number verifiziert habe???
Laut meinem Profil hab ich keine hinterlegt...
Bin dort allerdings schon länger. K.A. ob die Rules inzwischen geändert wurden
Der Channel sieht deine Nummer eh nicht. Der Dev/Mod will nur sichergehen, dass du nicht als zig Personen auftrittst und dort Blödsinn machst (zb Scam-Links posten etc)
4090 FE Stock Kühler gegen EK 4090 FE Block : ( bringt bei seinem Setup 8 - 14 Grad )
Der Byksi gefällt mir nicht !
Der Alphacool wirkt da deutlich edler .
Ganz schön viele Phantom Karten im Alternate Outlet. Was ist mit der kArte? Ist das die mit den lauten Lüftern? Oder kommt jetzt die ganze Scalperware zurück?
Ähnliche Themen
