[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja mit dem MSI Center lässt es sich problemlos einstellen.
Weiß jemand, wann der Phanteks Glacier Kühler für die Suprim wieder auf Lager sein wird :geek:
Wie hast du die Suprim X bei dir eingebaut, bei mir hat es gar nicht reingepasst.
Da ist rgbfusion von gigabyte gold gegen. Schlankes programm. Keine prozesse im hintergrund und kannste de und installieren innerhalb 10 sekunden.
Die tools hatte ich alle. Bleibt trotzdem was übrig. Musste mit regedit tausend sachen löschen usw. Habe es aber nie mehr installiert bekommen. Der fehler kam bei etlichen beim googeln vor. Weiß nicht mehr was es war. Es hat immer gemeckert dass ein asus dienst fehlt.
Zudem kann die cpu mit armory crate nie mehr richtig idlen.
Nicht nur da, auch Corsair ICUE lässt die CPU nicht mehr Idlen...
Und das MSI Center obwohl im Autostart de-aktviert läd munter Dienste, LED-Keeper, Mystic-Light Service usw..
Warum ist jede RGB Software so verheerend..
Bzgl der MSI falls Mystic Light nicht läuft, TPM im Bios anmachen..
Mein jetziger PC ist mein erster und zugleich auch letzter PC mit RGB-Beleuchtung. Ich habe den Sinn davon nie verstanden, aber dachte, dass ich es selber auch einmal ausprobieren muss, bevor ich darüber urteilen kann. Ich habe bei mir (anfangs) alles über Razer Synapse gesteuert und was soll ich sagen? Dieses Programm ist einfach eine Seuche. Es frisst sinnlos Ressourcen und bietet meiner Meinung nach einfach keinen Mehrwert.
Vielleicht bin ich auch einfach zu pragmatisch veranlagt und kann mich dementsprechend nicht an Beleuchtung erfreuen. Es war ein Akt diesen "Virus" vom PC zu entfernen. Mittlerweile habe ich OpenRGB mit einem "complete dark Profil" im Autostart, welches einfach jegliche Beleuchtung abschaltet. Den einzigen Sinn sehe ich bei der Tastaturbeleuchtung. Alles Andere bringt doch letztendlich einfach nichts. Mein nächster PC wird ein schwarzer Kasten mit "hässlichen" schwarzen Noctua-Lüftern.
Wenn man eine schöne (Hintergrund)-Beleuchtung will, kann man das ja über eine ansprechende Raumbeleuchtung oder z.B. mit Ambilight erreichen. Alleine die ganzen zusätzlichen Kabel, die man sich spart und welche z.B. beim beleuchteten Mousepad zusätzliche USB-Ports fressen, fallen dann weg. Billiger ist es ohne Beleuchtung i.d.R. auch, beim RAM angefangen. Einfach sinnlos das Ganze, egal ob ASUS, Corsair, Razer oder MSI. ^^
Ich habe halt auch versucht zu verstehen, was das Menschen gibt. Ich sehe darin einfach keinen Mehrwert. Null.
haut das geld lieber in einen oled. das bringt 10mal mehr freude als bissi bling bling
Lass das doch einfach der Entscheidung des einzelnen. So teuer sind LEDs auch nicht, und vielen Menschen bringen die durchaus eine optische Freude. Auch wenn Du das nicht verstehen musst.
Mich nervt nur dass einige sich da immer so abschätzig äußern. Unser Hobby ist in der Gesamtheit nicht sonderlich rational oder nachhaltig. Da ist es an keinem über den anderen zu lächeln. Etwas mehr Toleranz und "sich mit dem anderen mitfreuen" wäre schon angebracht.
Allerdings taugt die meiste SW in der Tat nichts. Die einzig brauchbare ist tatsächlich die Steuerung von Aquacomputer, weil die auch komplett ohne Zutun des PC Prozessors läuft. Alles andere ist IMO Schrott.
Eben das verstehe ich nicht. Ich schaue doch auf den Bildschirm bzw. TV und nicht auf meine Beleuchtung im PC oder auf dem Schreibtisch. Das Geblinke bringt auch keine bessere Spielerfahrung oder dergleichen. Es geht doch um das Spiel und dessen Wahrnehmung. Alles drumherum ist doch komplett irrelevant.
Wo ich es noch ansatzweise verstehen kann, ist z.B. Ambilight bei Philips TVs. Vernünftig eingestellt kann das schon einen angenehmen subtilen Effekt liefern, wenn es ordentlich implementiert ist. Da blicke ich eben aber auch genau in die Richtung, aus welcher die Beleuchtung (hinter dem Screen) kommt.
Das mache ich z.B. nicht. Ich habe es selbst ausprobiert und das Ganze sogar komplett (Mousepad, Tischbeleuchtung, RAM, alle Lüfter, etc.).
Die von gigabyte ist clean.
Der Rechner steht eben nicht bei jedem versteckt unter dem Schreibtisch. Bei mir hängt er z.B. an der Wand überhalb des Monitors.
Ich verstehe z.B. nicht, warum man bei Benchmarks jedem Prozent hinterherhecheln muss, um dann hier stolz die Screenshots zu veröffentlichen. Aber hey, jedem Tierchen sein Posierchen. Ich werde mich jedenfalls nicht abschätzig über diese Menschen äußern.
Bei mir haben die LEDs am PC eine Aussage. Im Normalbetrieb ein kühles, freundliches, unaufgeregtes leicht pulsierendes Blau. Unter Last dann ein feurig flammend animiertes Rot. Und wenn dem Rechner richtig warm wird dann ein Farbgewitter.
Klar BRAUCHT man das nicht. Aber was genau BRAUCHT man schon an einem Gaming PC? So viel daran ist Show, dass nur den Besitzer erfreut. Und das ist gut so.
Muss den alles immer einen Mehrwert haben? Schmuck hat auch absolut keinen und trotzdem trägt ihn in irgendeiner Form fast jeder.
Manche Sachen haben einfach einen ästhetischen Mehrwert wenn du so willst.
„Schwarzer Kasten unter Schreibtisch PC“ ist mir persönlich inzwischen einfach viel zu langweilig.
Dir nicht? Völlig ok 👌
PS: Versuch mal das Thema „Mehrwert“ bei Deko Kram bei deiner Frau anzusprechen und schau was passiert 😂
PPS: Du selber hast ja bestimmt auch etwas an der Wand hängen oder in einem Regal stehen was absolut null Mehrwert hat, da wette ich drauf und sei es die geliebte Whiskey Flaschen Sammlung 😏
Nagut, dann hat es schon gewissermaßen eine Funktion. Das kann ich dann nachvollziehen. Ich habe die Temperaturen halt über das OSD vom RTSS im Blick.
Manche Sachen haben einfach einen ästhetischen Mehrwert wenn du so willst. „Schwarzer Kasten unter Schreibtisch PC“ ist mir persönlich einfach zu langweilig.
Das ist natürlich ein valider Punkt. Da bin ich auch froh, dass das weibliche Geschlecht ein Gespür dafür hat. Wo Du es ansprichst, lege ich auch auf jegliche Dekoration (außer Pflanzen) absolut keinen Wert. Manchmal wünschte ich, dass man den Sinn für Ästhetik irgendwie lernen kann, aber ich glaube, dass das nicht möglich ist. ^^
Bis auf Fotos, Kalender (Erinnerung an Termine) und Pflanzen tatsächlich nichts. :d
Jetzt hab ich es wieder getan 😱 :
msi 4090 suprim x
on the way. Mal schauen wie die sich verhält.
Bei dem Preis konnte ich nicht nein sagen.
Beste Grüße
Schaut aber extrem nice aus ngl
Bei 2000+ Grafikkarten sollte das schon eh ne Grundvoraussetzung sein einen Top Bildschirm zu haben.
Man muss schon Prioritäten setzen :bigok:
Ähnliche Themen
