[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja ich hab auch grad bestellt und meine PNY bei Amazon storniert. Fast 300€ weniger inkl. Versand ist schon verlockend. Sollte sie mir zu laut sein: Für den Preis wird man sie ja easy wieder los.
Oder man Ghetto modded die Lüfter :d (falls es sonst passt, fiepen etc.), letzte Woche gab es ja den guten 10% Rabatt Code waren dann 1788€ inkl. Versand.. und es gab 1-2 gebrauchte für 1600 und 1680€
Was genau ist das? Kenne bisher nur den Fix bei der FE. Ist das bei der Gainward genauso einfach?
Na man nimmt die Lüfter (inklusive Shroud) runter und packt 2 vernünftige 120er oder sowas drauf :d, ob und wie leicht das bei der Phantom geht weiß ich aber nicht.
@Stagefire
Auch eine Versandbestätigung bekommen?
Ich habe jetzt erstmal Zwangsurlaub...
Achso, ich hab nun was simpleres erwartet.
Ne so spielereien fang ich in dem Preisbereich nicht an. Entweder sie gefällt mir oder eben nicht ^^.
Bei der 10% Aktion war ich leider immer am arbeiten als die Karten in Stock waren. Die 7% sind aber auch schon nett.
An die Leute die bei LDLC bestellt haben: Wie läuft das genau ab? Welcher Lieferdienst verschickt das bzw. an welchen wird das in Deutschland übergeben?
Colisexpat versendet nach DE und AT hat bei mir mit der FE von Frankreich funktioniert...Weiterversand von Colisexpat kannst du den Lieferdienst selbst wählen
Nachteil: Nur versichert bis 500 Euro keine höher Versicherung möglich
Meine PNY 4090 von Amazon wurde gerade eben überraschenderweise bereits mit DHL verschickt (y)
Habe meine FE heute zurückbekommen. Die hatten das mit meiner zurückgeschickten 4080 verwechselt?!
Naja egal. Habe jetzt mal nen groben Lüftermod gemacht. Sie ist bei 1500 rpm noch zu hören aber übertrumpfen meine Gehäuselüfter nicht mehr wenn diese beim erwärmen des gehäuses auch höher drehen. Das nervende penetrante Brummen ist fast eliminiert. Zudem kann man den oberen Lüfter ja auch noch per AB etwas drosseln. Da muss man schauen wie es sich auf die Temperatur auswirkt. Jetzt muss ich noch mit verschiedenen Abständen spielen um das Optimum zu ermitteln. Aber 2,5mm sind schon mal ein guter Anfang. Es fällt auch nicht direkt ins Auge wie ein Fliesmod oder ein Ghetto Mod... :-) So kann ich jetzt schon mit der FE leben. Umbauzeit 5 mInuten. Wenn ich es perfektioniert habe mache ich dazu ein Video.
Danke nochmal an @FightingFalcon
WTF.. grad mail von Amazon bekommen. Mein PNY Liefertmin ging vom 19.12. nun auf den 9.12.-12.12.??
Hat sich bei dir auch was getan?
Nope, 21.
Wer war das noch gleich mit der Anleitung dafür? Kann er sie nicht hier im Thread posten?
Die PNY 4090 die man bei Amazon bestellen kann soll die mit Abstand leiseste RTX 4090 laut PCGH sein, nur 0.9 sone unter Last und keine störenden Geräusche. Selbst die Asus TUF mit dem Silent Bios hat 1.4 Sone.
die Lüfter der TUF höre ich auch nicht, obwohl sie 60 cm neben mir steht, im offenen Gehäuse, dafür aber zeitweise etwas anderes :rolleyes:
Wow, Glückwunsch! Wann hast du sie denn eigentlich erwartet? War das eine von den lagernden oder Vorbestellung?
Danke.
12.-15.12 war der voraussichtliche Termin.
Gerade eben kam die Nachricht von DHL Express, dass sie bereits morgen zugestellt werden soll.
Hätte ich wirklich nicht damit gerechnet. Dachte eigentlich, dass man sich auf ein wochenlanges Verschieben des Liefertermins einstellen kann. Vor allem weil es mich schon gewundert hat, dass sie quasi seit einigen Tagen dauerhaft bestellbar ist.
Und nach allen Userberichten ist die PNY wohl eine der wenigen, die bei Leuten mit empfindlichen Gehör, in Frage kommen.
Wo kann man das nachlesen?
In der aktuellen PCGH 01/2023.
Ich zitiere mal
Unter Last legt die Karte ordentliche
2.745 MHz an, bei einem mittleren
Verbrauch von ~446 Watt. Hören
werden Sie davon nichts, denn
dem Kühler gelingt dieser Spagat
bei höchst erstaunlichen 0,9 Sone,
während die GPU höchstens 63
°C warm wird. Die drei 100-Millimeter-
Lüfter setzen diese Leistung
bei etwa 1.200 Umdrehungen pro
Minute um (das sind gerade mal 6
Prozent über der Minimaldrehzahl
der Lüfter, danach würden sie in
den Passiv-Modus gehen).
Ich zitiere mal
Danke, also nicht online nehme ich an? Mich hätte die Rezension an sich interessiert.
Was ich mich gerade Frage... wie kann es eigentlich sein, dass Amazon der einzige Händler ist (von dem ich bisher gehört habe) der 4090er als VORBESTELLUNG anbietet? Und selbst dann anscheinend nur mal hier und da ein Random-Modell. Warum bietet das sonst keiner an, sondern nur diese Mystery-Drops? Einfach die Mühe nicht Wert, da sowieso alles Insta-ausverkauft?
Die Gigabyte Aorus 4090 Master gibt es in DE sogut wie nicht. Mindfactory hat nun wohl 5 Stück... allerdings mit Seltenheits-Bonuspreis...
Wie sind die Strix den so? Bisher konnte vermutlich noch niemand eine Aorus Master mit der Strix vergleichen?
Spulen Fiepen oder Surren oder Rasseln war bei meiner Master sehr nah an richtig leise dran und klar besser als bei der Strix die ich habe.
Aber die Lüftersteuerung der Master war schlecht !
Im Silent Mode lief die Master bei 1450 RPM aus dem Zerofan an was echt störend laut war!
Das Suren meiner Strix ist da nicht so störend.
Verarbeitung Optik haptik so wie Material Anmutung war die Master klar hinter der Strix.
Kühleistung sind beide Karten Top.
Für Wakü Umbau würde ich die Master denke ich aber bevorzugen da die Spulen wirklich nur minimal zu hören waren gerade wen das Gehäuse nah bei einem steht würde es den Unterschied machen.
Aber ob alle Master so leise Spulen haben weiß ich nicht!
Weil die kleinen Händler Ihre Preise immer anpassen wollen um den maximalen Gewinn zu haben. Amazon ist das egal bei dem umsatz.
Weil sie die tuf immer im Performance Bios testen. Im Silent Modus ist sie nicht lauter als die pny.
Und im OC Bios war Sturm bei 1850U/min.
Keine Ahnung was die sich dabei gedacht haben.
Jap die komplette Lüftersteuerung war nicht gelungen in beiden Modis.
Ich hab es auch mit festem Wert bei knapp 1000 RPM versucht das führt da zu das die Lüfter bei frischem Windows start dann im Spiel gar nicht an gelaufen sind.
Kann das genau so unterschreiben. Kein Plan wie man so eine Karte mit einer so grottenschlechten Lüfterkurve zerstören kann. Leider nur bedingt steuerbar über Software. Die Lüfter starten manchmal leider auf 100% durch und regeln sich dann wieder runter
Ähnliche Themen
