[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
1,68 auf 70kg :fresse2:
Der hat wohl eine FE zum Geburtstag bekommen und verkauft die Zotac jetzt, weil sein Auto kaputt gegangen ist und er dringend Geld braucht.. Account seit knapp 2 Jahren mit guten Bewertungen aktiv.. Aber er antwortet auch gerade nicht mehr.. vermutlich war einer schneller als ich..
So kaputt war sein Auto wohl doch nicht. :( :fresse:
Hast Du einen Framelimiter an?
Manche Games funktionierten erst nach einem Patch flüssig mit einem Framelimiter.
Versuch mal FG und lass das Spiel ins VSYNC rennen.
Ja 117 FPS aber da Lauf ich nicht rein und vsync im Treiber an im Spiel aus.
Ah und Open RGB erkennt meine Strix nicht in der aktuellen Version.
Also K.I.T ist immer noch Case zu sehen.
Hihi ... das kannst Du doch gar nicht wissen. Vielleicht wurde der Account-Hacker tatsächlich nur wegen seines kaputten Autos kriminell. Bei manchen reicht ja schon, wenn's Bier alle ist :rofl:
Aber jut, dass Du Dich gar nicht erst auf den Weg machen konntest - da weißt Du ja wirklich nicht, was für kaputte Typen Dich erwarten!
Lass mal den Framelimiter weg und versuche durch setting auf 120FPS zu kommen oder schalte mal die Bildwiederholrate auf 100hz ein damit du im vsync läufst. Und dann bereichte nochmal über die smoothness.
Werd ich später noch Mal versuchen .
Läuft aktuell 4K maxout mit RT +DLSS Qualität
Kannst ja auch zur Not auf 60Hz gehen wenn Du keine 100FPS erreichst. Die gleichen Probleme hatte ich bei Uncharted und Plague Requiem. Nach einem Patch brauchte ich aber diese Umgehungslösungen nicht mehr...
:lol:
Ich habe jetzt das Strix OC Bios auf meine TUF OC geflasht und teste, ob wirklich mehr MEM MHz laufen, wie von @Dwayne_Johnson behauptet.
Mit +1400 hatte ich Bildfehler bei Warhammer Darktide (FrameGen on).
*Der Test hat nicht lange gedauert :fresse:
Kann ich nicht bestätigen mein Lieber.
Das hätte mich stark gewundert, meine TUF non OC packt bis +1700MHz ohne Bildfehler.
Darktide läuft mit der 4090 auf 3440x1440 mit 2.25x Dynamic Super Resolution (5160x2160) mit DLSS quality und Framegeneration mit RT nur auf ~110fps in ruhigen Szenen. Um aber im aktiven gameplay >100fps zu bleiben musste RT definitiv aus. Muss aber sagen Framegeneration funktioniert bei mir mit Darktide super und spielt sich besser als ohne.
EDIT: Interessanterweise hatte DSR bei mir wirklich nur minimalem impact. Dazu sollte man aber auch wissen das Darktide unglaublich schlecht optimisiert ist (sowohl Performance wie Stability) und sehr CPU lastig ist. Ich habe "nur" einen 5600X drin.
Da würde ich eher dsr statt rt ausschalten.
Darktide schwechelt sogar mein 5800X3D manchmal .
An die PNY 4090 Besitzer, funktionieren bei euch alle 3 Lüfter?
Bei mir gehen auch nur 2, wie in der einen Amzon Bewertung.
Der Lüfter an dem Ende mit den Video Ausgängen dreht sich nicht.
Nein, es drehen sich alle 3 ^^
Das einzige auffällige ist, das bei 100% fanspeed die vorderen beiden etwas langsamer als der hintere dreht (aber nur bei 100%)
Die vorderen beiden sitzen beide auf dem ersten Fanheader, der hintere hat einen eigenen. Probier mal ob der connector vielleicht einfach nicht richtig drinnen ist und drück den nochmal etwas ran.
ECC (Error Correction Code) ist die Fehlerkorrektur. Damit verlierst du Performance, das ist für anspruchsvolle und wissenschaftliche Workloads gedacht bei denen keine Fehler passieren dürfen.
Was ECC ist, ist mir bewusst. Wissen wollte ich, ob jemand mal gemessen hat, wie viel Performance genau flöten geht. ;)
Hab für meinen Kollegen eine 4090 FE in Frankreich bestellt und die wurde bereits versandt.
Hatte auch schon mal geschaut. Der mittlere und der "hintere" lüfter (der bei mir nicht geht) hängen am selben Fan Header. Der sah auch fest eingesteckt aus, ahbe versucht nochmal zu drücken aber da hat sich nichts bewegt.
Der mittelere bekommt alle 4 Leitungen (GND, 12V, PWM, RPM), der hintere nur 3 (GND, 12V, PWM). Die 3 "zusätzlchen" Leitungen für den hinteren Fan sind ja mit den anderen zusammen gcrimpt im Stecker für den Fan Header. Da könnte evtl. irgendwo ein Fehler sein.
Wenn z.B. bei dir alle Lüfter laufen, denke ich eher nicht das es ein Systematischer Fehler ist, z.B. am Lüfter mit nur 3 Leitungen PWM mit RPM vertauscht angeschlossen.
Nein, das wird nichts systematisches sein. Guck mal ob du den Stecker entfernen und prüfen kannst, ohne den Kühler abzunehmen, vielleicht findest du das Problem. Ansonsten ist es ein Defekt. Hoffe du bekommst es behoben, die Karte selbst ist absolut top.
Wie kommst du jetzt eigentlich doch zur PNY? Gab es die mal für 1949€ bei Amazon?:o
2.094€ hat die jetzt gekostet, also 94 über dem, was ich max. ausgeben wollte., falls Du darauf anspielst.
Ja genau, hatte mich nur gefragt warum du nun sogar doch mehr bereit warst zu zahlen, nachdem ja die FE sogar günstiger geworden ist.
Aber drücke dir die Daumen, dass deine Karte problemlos rennt :) Spulenfiepen kann die PNY auch zu Anfang haben, war bei mir aber nach 2-3 Tagen Nutzung deutlich besser geworden und ist inzwischen nur noch direkt mit dem Ohr am Case hörbar :)
Ich sags mal so, ich kann gar nicht so schnell essen, wie ich kotzen möchte, jedes mal wenn der FE Lüfter hochdreht. Das verschiebt irgendwann auch die härtesten Budget Grenzen. Falls NVidia mir eine neue Graka im Austausch zurück schickt, geht die ungeöffnet zu Ebay. Und wenn ich meine zurück bekomme, geht die als gebraucht zu Ebay. Die Entscheidung ist bereits gefallen. Vorausgesetzt die PNY ist leise. Ansonsten geht die per Widerruf zurück und ich probiere an der FE den Lüfter Mod, der hier im Forum rumgeistert.
Werde aber (zumindest hab ich das vor) einen etwas ausführlicheren Vergleich der beiden Karten posten, wenn es die Familie zulässt. In der Weihnachszeit soll man da irgendwie immer etwas mehr Zeit mit verbringen habe ich gehört. Weiß aber auch nicht warum.
Ja Nvidia hätte das wirklich besser machen können.
Bisschen mehr platz für den Lüfter und dann wäre es ja schon gut.
Eigentlich ist der FE Kühler wirklich solide und das PCB eh einfach top.
Ist aber nicht das erste mal das irgendwas mit Fe´s nicht stimmt.
Hatte damals eine GTX 1080 FE und die hatte direkt diesen Lüfterbug.
Naja viel zu vergleichen gibt es da nicht, die FE sieht schicker aus und hat das deutlich solidere PCB, die PNY hingegen ist bzgl. des Kühlers einfach absolut leise.
ich würde sagen 1500-1600rpm bei der PNY entsprechen etwa der FE bei minimaler Drehzahl. Bei einer Last die 400-450W erzeugt dreht die PNY Full Stock auf ~1300-1400 rpm und ist bei allen Temperaturen etwa 8-10 grad besser als die FE im gleichen Szenario (auch full Stock).
Wenn man die PNY lüfterkurve auf 1000 rpm (minimale Drehzahl) fixiert, dann ist sie etwa 1-2 grad kühler als die FE.
Ich habe meine daily bei 2700MHz @885mV (=300-330W) und komme mit 1000rpm nicht über 58 Grad auf dem Core und bleibe für Speicher und Hotspot deutlich unter 70 grad bei +1350 MHz auf dem Speicher.
Also alles in allem ist die FE die Karte für OC Rekorde/WaKü und die PNY holst du für undervolt/Stock @wakü Lautstärke 😅
So bei Dark Tide mit Frame Generation muss bei mir der Limiter und Vsync aus sein dann ruckelt auch nix .
Das läuft dann echt gut merke auch kein Tearing.
Also wenn Du VSYNC an lässt und deine fps deine maximal bildwiederholrate schafft sollte es auch gut laufen oder?
Weil ohne VSYNC hast Du tearing.
Wichtig. Vsync im NVCP an und im Spiel aus.
Nein wen V Sync an ist dann ist es brocken bei mir!
Hab dann obwohl 120 130 140 150 FPS in der Scene gehen plötzlich nur 105 /110 oder 115FPS die Total unruhig laufen total komisch halt nicht 120FPS wie es bei 120HZ sein sollte mit Vsync auch der Limiter funktioniert nicht da wo ich in gesetzt habe.
Das funktioniert hier bei mir nicht das konnte man anfangs auch bei Global Foundries im Test sehen bzw. sagte er das zum jetzigen Zeitpunkt Vsync und FPS Limiter Probleme machen..
Zum Tearing schrieb ich dir ja oben nehme es nicht war bei diesem Spiel.
Es gibt Games bei dennen ist das Stark ausgeprägt da ich hier bis zu 160FPS erreiche auf meinem Oled und das Spiel da anscheinend nicht so undankbar ist fällt es mir nicht auf.
Ich find es Mega wie solide ich das Game @Air mit 3GHZ Spielen kann echt Hammer die Strix Meistert das echt gut!
Edit :mit DL 1.78 auf 5120×2880 bin ich dann in der VRR bzw Gsync Range drinn.
Hallo zusammen,
ich bekomme morgen meine 4090 FE und habve ein BeQuiet Dark Power 12 pro (1200W). Der neue Stecker von Bequiet ist niergens lieferbar. Kennt jemand zufällig eine kompatible, lieferbare alternative?
Die Karte wird Freitag unter Wasser gesetzt und soll eigentlich ab Freitag Abend auch verwendet werden. Hab irgendwie keine Lust auf diesen 4 PCI-E auf 1x 12VHPWR Adapter von Nvidia
PS: Das hier ist der von Bequiet welchen ich nirgends finde
Ähnliche Themen
