[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, das ist auch wieder so ne Sache. Mit so nem 350€ Board geht meistens nur DDR4. DDR5 Boards für 350€ können maximal 6000er Ram supporten.
Hab mir das ASUS ROG STRIX Z790-F ausgesucht.. So ne kack Hauptplatine für 550€. Ein Oberklasseboard hat zu Z490 Zeiten noch 250-300€ gekostet.
Ich behaupte ja, dass so ein Z790 Gaming X AX vollkommen ausreicht auch für einen 13900k (da würde zumindest ich die Limits auch vernünftig wählen) und das kostet unter 300€.
Wenn man viel IO braucht etc wird schnell teuer...
Wenn man bedenkt, dass man selbst bei den teuren Platinen den M2 PCIe 5.0 nicht nutzen kann ohne Lanes am PCIe 5.0 x16 zu verlieren (und ja die verliert man dann scheinbar auch im PCIe 4 Mode) frag ich mich wofür der überhaupt da ist...
Gigabyte hatte ich gar nicht aufm Schirm. Das sieht sogar ganz ansehlich aus. Danke für den Tipp :d
Selbst das normale UD macht schon bis zu 7600 Mt/s mit, also die Ausrede mit den teuren Boards gilt wirklich nicht, wenn man ein potentes Raptor Lake System aufbauen will. Bei den Geschwindigkeiten kostet der DDR5 Ram allerdings noch einiges, daher würde ich erstmal mit einem 6000er Kit starten. Wenn ich sehe wie dafür die Preise in den letzten zwei Monaten nach unten geknallt sind, bekommen wir noch in Q1 7000er Kits für 200€. Da sieht dann kein DDR4 Kit mehr Land (ja auch schon bei 6000ern nicht).
Was mich nur echt ankotzt ist, dass das einzig vernünftige weiße Z790 Board gleich so unverschämt teuer ist. Bis 500€ wäre ich ja dafür noch gegangen, aber was die fürs APEX verlangen geht echt auf keine Kuhhaut. Und da das weiße NZXT wirklich keine ordentlichen RAM Takte unterstützt, bleib ich erstmal bei meinem Prime A.
  • Danke
Reaktionen: hwk
Gibt auch gute 6400er Kits für 220€
Hätte wohl auch schon nen 13900K mit Gigabyte Board und 6400er RAM gekauft, wenn meine Vernunft nicht sagen würde warte auf die X3D und der Sockel ist Quasi tot :d
Ja...
Aber zum Benchen, jenseits von 7.500MHz RAM?
k.A. wie stabil die MBs bis 400€ bei 7.600MHz laufen
In der HOF sieht man oft das Maximus APEX und Maximus HERO
Aber das APEX hat trotz ATX nur 2x RAM-Slots (und noch einen Dritten etwas abseits)
Ja...
Sicher wenn man nur Benchen will dann lohnt sich so ein Apex vielleicht, aber wer bezahlt dann nur zum Benchen soviel?
Ich weiß ja nicht.
Aber jedem das seine :)
Ich weiß ja nicht.
Du bist hier in einem 4090 Thread. Ich glaube da würden schon viele fragen wer zahlt schon 2k für eine GPU :fresse2:
Ich (okay keine 2k "nur" 1790) aber ich Benche nicht wirklich, nur zum UV grob ausloten :d
Werde sobald MF die Teile verschickt auch Mal versuchen die Gainward zu modden mit anderen Lüftern... Mal sehen
Aber wer kauft/tauscht min. 5x die 4090, bis die Scores stimmen? :fresse:
Ich weiß ja nicht.
Aber jedem das seine :d
Ich nicht, falls du auf mich anspielst...
Ich hatte ne TUF zur UVP hab ne FE verkauft und nie ausprobiert, und dann die Gainward für 1790€ bekommen die quasi gleich zur TUF performed und deutlich weniger singt. Daher hab ich die TUF für 2000€ weitergegeben.
Es gibt genug Test dazu, klar ist es nicht viel Unterschied, aber es summiert sich eben alles, was ich aufgezählt habe, sodass es am Ende halt doch eine Summe an Unterschied wird. Muss ich das wirklich erklären?
sind nur 2 RAM-Slots, in den 3. kommt die Steckkarte für die beiden zus. M.2 Slots (roter Kreis)
Ich weiß ;)
Der Dritte sieht ja komplett anders aus. Die Bezeichnung "DIMM.2" ist im ersten Moment verwirrend
Beim APEX muss man sich entscheiden...
Möglichst schnellen RAM bis 8.000MHz und max. 32GB oder viel RAM mit wesentlich weniger Takt
Beim Hero könnte man Beides
Und wie läuft der 8000MHz RAM dann? Gear 4? :hmm:
Keine Ahnung, ob ich hier richtig bin, wollte aber dafür keinen Extra Thread aufmachen.
Thema:
4090 und CPU.
Aktuell habe ich einen i7 8700k verbaut, auf einem Asus Z390 Gaming F.
Ich nutze meinen Windows PC ausschließlich zum Zocken, und sonst nichts, für alles andere ist mein Mac da, falls das eine Rolle spielt.
Ich weiß, dass das Z390 PCI 3.0 hat, was aber laut diverser Tests keine große Rolle spielt.
Wie sieht es nun mit der CPU aus?
Aktuell zocke ich auf WQHD, und ich bin mir nicht sicher, ob ich überhaupt auf 4k umsteigen würde.
Wie stark würde mein 8700k limitieren?
Achso, der geht ohne Probleme bis 5 Ghz, falls das eine Rolle spielt.
Frage an sich:
Einfach 4090 kaufen und glücklich sein, oder doch lieber gleich volles Programm, neues MB, 13700k CPU und DDR5 Ram?
Hi, ich hab auch nen I8700k, auf 4,9 Ghz mit einer 4090 kombiniert. Also, Alles was bei 1440p Limitiert, wird auch in 4 K limitieren. Beispiel? .. Cyberpunk in der Jig Jig Street. Wenn du da durchläufst hängst du übelst im CPU Limit. Dies wird sich in 4 K auch nicht ändern. Stört das? .. neee.. Ist nur Temporär und es gibt halt kleine Microruckler. Wenn du vom Bereich weg bist, kein Problem.
Ich spiel Hauptsächlich Rollenspiele/ActionRollenspiele. Witcher3 limitiert seit dem RT update in Novigrad stark im CPU Limit mit dem I8700k. Da hilft dann DLSS2 auf Qualität und FrameGeneration an. Klar fallen die FPS dann und wann auf 65 FPS, Ja es gibt minimal Microruckler.. aber so wie ich das bisher überall gelesen und in Videos gesehen habe, haben extrem viele Probleme mit Ihrer neueren CPU dort. Ich bin bisher in jedem Spiel noch im spielbarem Bereich. Ich werd erst Ende nächsten Jahres frühestens Wechseln.. Bisher ist kein Spiel dabei, das so Probleme macht, das es nervt. Von daher, kaufen und glücklich sein.. Ich bin es.. anonsten gibt es ja noch Nvidia Downsampling.. :) um aus dem CPU -Limit ins GPU Limit zu kommen. Hauptsache über 60 FPS durchgehend. Ich spiel durchgehend in 4k auf dem LG Oled 42C2
Du hast doch noch guten DDR4.
Intel 13700K 450€
Asus Z690 D4 330€
Dazu verkaufst deine alte CPU mit Mobo als Bundle.
Ein APEX Z790 und 13900 sind halt auch maximal unvernünftig.
Habe jetzt erstmal als erste Maßnahme schonmal ne SN850 X 4 TB für 419 € bei Amazon bestellt.
Das ist schonmal ein guter Preis und eine gute M2 SSD https://www.amazon.de/dp/B0B7CQ2CHH...pre03-21&ascsubtag=Z9mzk0Q2VadKDTnvTXMGw&th=1
Die Schnapsidee mit dem Apex kam wegen dem RAM , damit auch 7200er rennt.
Bin da noch nicht so belesen bei den neuen Plattformen.
Strix D4 Z790 hatte ich mir schonmal angeschaut und da stehen max. 3600er DDR4 in der QVL .
Weiß daher nicht mal ob da Quick&Dirty mein 4000er Ramkit da einfach XMP @ Gear 1 läuft .
Dazu kommt das ich nach einigen Benches gesehen habe zb. in Spiderman , dass selbst ein 13700/13900K auch ins CPU Limit rennt mit einer 4090.
Hatte jetzt nur einen Bereich und Tageszeit wo es in Dying Light 2 auf 70 FPS abgekackt ist und es sich ruckelig anfühlte.
Sonst selbst auch in der großen Stadt läuft es meistens im 100 FPS Bereich im 4K Ultra RT Mode @ DLSS Qualität und LOD Multi original auf 100%.
Ich warte denke mal ab auf den 7800X3d und 7900X3d.
Dann mal sehen was die an Leistung bringen.
Denke das CPU Limit bei nem übertakteten 13900k ist vernachlässigbar. Der liefert überall die benötigten 144 FPS für den Bildschirm.
Hab auch mal grad einen brauchbaren Test gefunden mit 4090 und CPU´s.
Da sind auch 10900K dabei und 13700K @ D4 +D5
Lese ich mir gleich mal durch in Ruhe.
Habs jetzt einfach gemacht . Z790 Strix D4 + 13900K . Beim Strix D4 gibt es noch 60 € Cashback und somit dann 390€ für das Board.
Habe noch ein gutes B-Die Kit und werde daher den DDR4 behalten.
Sollte dann wieder paar Jahre halten hoffe ich mal .
No leider nicht!
Und ich geh da auch bei Star Citizen Anno so wie bei New World von aus .
Da gibt es garantiert noch ein paar die mir gerade nicht einfallen.
Mit Gigabyte Board und 100€ mehr hättest direkt 6400er DDR5 gehabt, aber du brauchst eventuell was das Strix D4 bietet? Oder hast 64GB DDR4?
Edit: das ist kein Angriff oder so nicht, dass hier gleich wieder eskaliert wird :)
Hab kein bock mehr auf Gigabyte .
Bin ja mittlerweile froh , dass das F21 Bios gut rennt , aber vorher AVX BUG.
Probleme mit den Leistungslimit , dass diese nicht übernommen worden.
Probleme mit der Lüftersteuerung .
Das ist jetzt behoben soweit.
Was geblieben ist . Die VRM machen Geräusche bei Mausbewegung oder zugriffe auf die SSD .
Fast Boot muss bei Windows deaktiviert werden , weil irgendwann Windows Dateien beschädigt werden und man dann via USB Stick reparieren musst.
Die M2 wird nicht richtig erkannt außer im CSM Mode was problematisch bei Windows 11 und kein R-Bar sonst geht.
Windows lässt sich dann installieren , aber die großen Upgrades auf eine neue Version muss ich dann via USB Stick machen , weil sonst bei der Intsallation via Windows und
Neustart dann der PC ausgeht und wieder startet und dann die Windows Installation wieder zurück gesetzt wird.
Die 950 Pro ist sogar in der QVL und ja funktioniert alles , wenn man weiß wie , aber durch den ganzen misst und der unfreundliche GB Support am Telefon , wenn man was erfragen möchte hat
dazu geführt das ich nun von dieser Firma geheilt bin und kein bock mehr auf ihre Produkte habe.
War früher seit Sockel A ein GB Fan , aber jetzt reicht es ....
Hoffe das Asus Board enttäuscht mich nicht .
Hätte gerne beim Asus noch ein Dualbios und eine Postcode LED , aber immerhin sind LED vorhanden bei Fehler RAM,CPU ,VGA, Boot.
Reicht eigentlich aus . Ne Backplate auf dem Board hätte ich auch noch gut gefunden , aber gut hat man früher auch nicht gebraucht.
Ähnliche Themen
