[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@Queue
vielen lieben Dank für deinen Beitrag, genau so was habe ich mir erhofft, als ich hier meine Frage gestellt habe.
Die von dir genannten über 60 FPS durchgehend reichen mir vollkommen.
Natürlich möchte ich irgendwann upgraden, aber ich möchte erst einmal warten, bis AMD ihre neuen CPUs vorstellt, da mir der 3D Cache sehr zusagt - muss mich aber noch ein wenig mehr damit auseinandersetzen.
Somit suche ich mir nun schon mal ein schönes Gehäuse aus, für den Umbau, und wünsche dir schon mal einen guten Rutsch :)
Ich hatte auch noch gutes DDR4 von Micron. Mit 100€ Cashback von Asus habe ich das Z690 D4 genommen. Bei hohen Auflösungen bringt auch Top RAM nicht sehr viel . Bei FHD sieht es wohl besser aus . Man muß ja nicht immer gute Teile abgeben wenn der Nutzen neuer Teile nicht besonders groß ist.Ohne gutes DDR4 würde ich aber auch auf DDR5 setzen zumal der Abstand immer größer und der RAM immer besser wird. DDR4 stagniert ja DDR5 erreicht immer neue Rekorde.
Die täglichen Proshop 14 Uhr "Scheinangebote" kannste total vergessen.
Habe ich 3mal mitgemacht und seitdem nie wieder, ist Zeitverschwendung.
Das dachte ich mir schon. Vor allem wäre mir kein Händler bekannt, der weiße 4090-er Strixen verkauft. Wie kommt der Proshop dann an seine Ware? Eigene Lackiererei? ;)
Ich hab vor kurzem endlich mein Kabel von Moddiy erhalten, aufgrund des Platzmangels im Gehäuse war ich auf dieses Soft Silikon Kabel angewiesen. Jetzt bin ich mir aber unsicher ob das so richtig ist, zwecks den ungenutzen Pins am Kabelende Richtung Netzteil (Bequiet Dark Power Pro 11):
Sieht doch alles normal aus.
Einfach öfter mal hier vorbei schauen hab meine bei LDLC bestellt wird aber erst geliefert
Für zu teuer. Waren (glaube ich) 2.500 Euro.
Naja die weißen waren auch schon bei Ampere immer teurer. eine White Strix gab es auch bei der 3090 nie für unter 2.500€, erst ganz am Ende als Lovelace vor der Tür stand. Das ist halt der Aufpreis für "fancy". :d
Edit: Falls Ihr Eure Karten bekommt, bitte unbedingt ein Update zum Fiepen geben. Irgendwer meinte ja, dass Asus hier dann andere Spulen verbaut, aber das glaube ich stand heute erstmal nicht. Aber wenn die White Strixx nicht mehr fiepen wären sie den Aufpreis sogar wert. :lol:
Bin gespannt, ob ASUS und Noctua wirklich eine Karte bringen. Wenn die derbe rasselt wird das ein medialer Supergau.
Dafür müssten die Reviewer aber dann auch endlich mal darauf achten. Ich mein der Anfang ist gemacht, hin und wieder wurde es bei 4080 und 90 erwähnt. Aber das muss ein fester Bestandteil eines jeden Reviews werden, egal ob NVidia oder AMD. Klar, ist auch immer Lotterie und anwendungsbasiert, aber ein paar Standardtests könnte man schon machen.
@Queue
Kein Problem, Dir auch einen guten Rutsch. Ich hab auch erstmal mit der Nvidia 4090 ausprobiert. Für mich klappt es noch gut mit dem i8700k und dem 750 Watt bequiet dark power 10 Netzteil. :d Max OC läuft auch noch.
In diesem Forum hast du halt die Enthusiasten, der Enthusiasten. :) Wenn da nicht der 5 MORA mit dem Gefrierschrank dem Chiller und der FensteMOD verbunden ist, fehlt was im Haus. Überspitzt ausgedrückt. Hehe, von daher kocht es manchmal hoch, weil da so viel Emotion drin steckt. Hobby halt.
Ich will mir auch den neuen 3D anschauen von AMD und den Intel XxxxxKS.. Erst dann entscheide ich mich. Klar, ist auf etwas besseres warten im PC Bereich sinnfrei, dann wartet man ewig. Wenn es nicht gerade kurz vor einem neuen Launch ist.
Mal schauen. Sobald ein Spiel mit zu starkem ruckeln mir auf den Sack geht, ist innerhalb kürzester Zeit was neues da. Bisher komm ich zurecht. :)
Ich hab manchmal angst vor mir selbst.. Spiel läuft nicht richtig - scheiß drauf - 4090 gekauft.
F*ck, hänge im CPU Limit mit der Karte - scheiß drauf - 13900k gekauft
Rechtfertigen tu ich das immer mit "Jo, is halt ein Hobby" :fresse2:
Solange die Frau bzw. der Lebenspartner damit einverstanden ist, ist alles okay. Hobby bleibt Hobby.
Mmh, vielleicht sollte ich meiner Frau allerdings mal sagen, dass ich mir schon wieder eine neue Karte gegönnt habe :unsure:
Die glaubt noch immer, ich hätte nur meine CPU und mein Netzteil erneuert. Dabei stehen aktuell schon wieder vier 4090-er-Kartons im Arbeitszimmer rum :lol:
Mein ich ja. Hier wird halt gut die Wirtschaft angekurbelt. :) glaube hier gibt es wenig Leute die länger als 5 Jahre irgend ein hardwareteil nutzen. :d außer nen Mora oder ähnliches.
Ich bin froh das mir High FPS nicht wichtig ist, sonst wär es auch viel teurer für mich. ;D
Das "Problem" hab ich nicht. Hab nur eine Freundin und wohne auch (noch) nicht mit ihr zusammen. :d
LOL, ich bete für Dich, dass sie nicht mal aus Neugierde "4090" googled :shot:
Oder den Tatsachen ins Auge sehen und erkennen, das es eine Sucht ist? :d
Ist es halt wirklich. :(
Hab kein bock mehr auf Gigabyte .
Bin ja mittlerweile froh , dass das F21 Bios gut rennt , aber vorher AVX BUG.
Probleme mit den Leistungslimit , dass diese nicht übernommen worden.
Probleme mit der Lüftersteuerung .
Das ist jetzt behoben soweit.
Was geblieben ist . Die VRM machen Geräusche bei Mausbewegung oder zugriffe auf die SSD .
Fast Boot muss bei Windows deaktiviert werden , weil irgendwann Windows Dateien beschädigt werden und man dann via USB Stick reparieren musst.
Die M2 wird nicht richtig erkannt außer im CSM Mode was problematisch bei Windows 11 und kein R-Bar sonst geht.
Windows lässt sich dann installieren , aber die großen Upgrades auf eine neue Version muss ich dann via USB Stick machen , weil sonst bei der Intsallation via Windows und
Neustart dann der PC ausgeht und wieder startet und dann die Windows Installation wieder zurück gesetzt wird.
Die 950 Pro ist sogar in der QVL und ja funktioniert alles , wenn man weiß wie , aber durch den ganzen misst und der unfreundliche GB Support am Telefon , wenn man was erfragen möchte hat
dazu geführt das ich nun von dieser Firma geheilt bin und kein bock mehr auf ihre Produkte habe.
War früher seit Sockel A ein GB Fan , aber jetzt reicht es ....
Hoffe das Asus Board enttäuscht mich nicht .
Hätte gerne beim Asus noch ein Dualbios und eine Postcode LED , aber immerhin sind LED vorhanden bei Fehler RAM,CPU ,VGA, Boot.
Reicht eigentlich aus . Ne Backplate auf dem Board hätte ich auch noch gut gefunden , aber gut hat man früher auch nicht gebraucht.
Klingt ja übel mit dem GB :oops:
Ich nutze seit Jahren ASUS und bin recht zufrieden. Dual BIOS brauchte ich noch nie, aber BIOS Flashback ist ganz nett. Man braucht nur NT, MB und den USB-Stick. Der Rest CPU, RAM ist unnötig zum Flashen. Gerade dann sehr nützlich, wenn das aktuelle BIOS eine neue CPU noch nicht unterstützt :d
Ähnliche Themen
Antworten
6K
Aufrufe
371K
