[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Lass dich nicht beirren. Bis der 13700K nimmer reicht, gibts eh was neues. Und dann macht der 13900K im Vergleich auch keinen Stich dagegen.
Da fehlt trotzdem noch einiges. Was mir aufgefallen ist, ist dass du beim 10900k die ganzen Sicherheitsfeatures wie Speicherintegrität abgeschaltet hattest, beim neuen Prozessor stehen aber VBS status und HVCI status auf "running".
Ich muss das bei mir abschalten, weil sonst meine X-Fi nicht mehr mitspielt, kann also nicht sagen ob und wieviel da an Leistung hängen bleibt.
Ja das habe ich vergessen zu deaktivieren.
Das sieht schonmal besser aus @ Stock von der Grafikscore her.
So mit OC komme ich dahin wo es etwa hin sollte.
38850K . Danke @FR4GGL3 . Anwenderfehler wie ich mir gedacht habe :d
Ich verstehe halt meinen Graphics Score nicht.
cpu limit im normalen Timespy bei dir in den beiden Graphics Tests, macht daher auch wenig Sinn hier zu Vergleichen, besser im Extreme
@MS1988 deiner CPU fehlen trotzdem irgendwo ca. 8k Punkte
Joa das kann sein , aber die Grafikscore passt und GPU ist voll ausgelastet.
Das ist schonmal ok . Denke hängt mit Ram zusammen.
Habe gerade in Youtube Video gesehen wo jemand mit DDR 5 6400 MHZ 2000 Punkte mehr CPU Score hat.
Time Spy Extreme passen die CPU Score bei mir auf jedenfall.
Habe gerade auch mal getestet, bei mir sind es auch nur noch 20k CPU Score, liegt nach kurzer Recherche wohl an 22H2 und ist nur im "normalen" Timespy nachvollziehbar - alles im Lot :)
Wollte ich eben auch Posten, da ich analog bei 20K mit Win11 22H2 "rumkrebse" und nun kurz verunsichert war ob ggf. etwas nicht passt (obwohl die neue Kiste ganz gut läuft). Den Reddit - Beitrag fand ich dann ebenfalls.
Der Extreme habe ich auch etwa das was die benches die ich im Netz gefunden habe bezüglich CPU haben.
Scheisse mit der Kernisolierung vergessen zu deaktivieren^^ , aber danke das hats schonmal gebracht .
Ja, das passt. 103,2% schneller als mein bestes Ergebnis mitm 10850K.
@ujmoskito01
Wunderbar, das Gehäuse habe ich auch, und würde es eigentlich auch gerne behalten :)
Wie viel Platz bleibt da noch, OHNE den Radiator in der Front?
Und wie viel Platz ist seitlich zu Abdeckung?
Ich frage, weil ich dann wohl mit dem 16/10 Schlauch seitlich an der Karte vorbei müsste.
Wenn ich meinen AGB um 90 Grad nach Rechts drehe, sollte ich eigentlich keine Probleme bekommen, denke ich.
Ohne den Radiator in der Front sollte es keine Probleme mit der Strix geben. Ich habe vorne eine Push / Pull Konfiguration und daher passt es mit dem Cablemod Vertical Mount nicht mehr. Die 4090 Suprim war halt deutlich kürzer und es passte gerade so.
Schon geändert?
Du wirst sonst ärgern...
Lohnt sich der 13900 wirklich gegenüber dem 13700? Stehe vor derselben Frage und kann mir das gerade bei 4K irgendwie nicht vorstellen. Mit also einer 4090.
Die meisten mit einer 4090 zocken doch eh in uwqhd/4k. Wer da unbedingt von einem z.B. 10700K auf den 13700K oder noch höher aufrüsten will, hat meiner Meinung nach echt einen an der Waffel :ROFLMAO: . Bei den meisten Spielen bringt es genau fast gar nichts. Und bei den paar, wo es was bringt, sind die Unterschiede auch nicht riesig bzw. fühlbar, weil man sowieso schon jenseits der 80-100fps zockt. Zudem investiert man in einen halbtoten Sockel. Hätte da eher noch auf Meteor Lake gewartet oder die neuen amd cpus.
Im PCGH Leistungsindex sinds afaik 3% im CPU Limit (720p glaub ich) zwischen 13700k und 13900k
Nein, einfach nur nein. Selbst eine ältere CPU vs das Aktuellste ist der Unterschied nicht so groß, wie viele weiß machen wollen.. es geht um vereinzelt Games, die ins CPU Limit laufen können. Wenn dir der Aufpreis für ein paar Prozent die du nur beim sorgfältigen Auslesen es wert sind.. go for it.
Ein CPU Upgrade fühlt sich selbst wenn man eine Generation auslässt und nur alle 4 Jahre kauft irgendwie immer noch einfach schlecht an. Vor allem wenn man dafür noch die Plattform wechseln muss. Ein Haufen Kohle für marginale Verbesserung. Hier den Leuten zu empfehlen doch lieber den 13900K zu kaufen, weil der 13700K ja zu schlecht sei, halte ich da für ziemlichen Unfug.
Die gibt es noch? Bzw. Leute kaufen tatsächlich noch Printmedien? :d
Der Vorteil des 13900k ist zum Großteil rein der Takt. Ein wenig noch der größere Cache. Das Mehr an Kernen wird doch nicht verwendet - Anno vielleicht, weiß nicht genau.
Aber der Preisunterschied zum 13700k war es mir einfach nicht wert.
Was man auch noch sagen muss, für den 13900k werden die besseren Chips verwendet. Für Übertakter also evtl. deshalb noch interessant, zum einfach einbauen und so lassen, bringts das aber nicht.
btw: die 16% gelten für Anwendungen. Bei spielen bleibt es sogar unter 3%. Der Gesamtindex wird eben von dem deutlichen Plus bei Anwendungen beeinflusst. Wer nur spielt, dem kanns egal sein.
Boah.. Jetzt hadere ich gerade mit mir die Bestellung abzuändern. Danke :shot:
Alles gut war nur etwas Spass .
Ich hab gerade meine X3D abgegeben und baue mir ein AM5 zusammen als übergang kommt auch erstmal nur der 7700X rein bis die 3D kommen.
Mit dem Intel hätte ich jetzt natürlich sofort Leistung bin aber Später limitiert.
Da ich so ungerne immer alles auseinander schraube hab ich mich erstmal so entschieden.
Ich warte jetzt nur noch auf einen FE drop:lol:
Dann sind wir zumindest CPU-Schwager.
Als Board habe ich das ASUS CROSSHAIR X670E. Am WE wird gebastelt. Die 3090er kommt noch mit. Bis eine FE dropt... :coffee:
Ein mehr als Fürstlicher Unterbau für deine 4090 .
Dafür das die Kiste dann wohl 5 Jahre + hält eine Edle Investition.
Ich schwanke noch auf Grund des Preises was das Mainboard für meine 4090 angeht.
Ähnliche Themen
Antworten
6K
Aufrufe
371K
