[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
3 k werden da nicht reichen. ;)
Wenn ich den Schritt von der 3090 zur 4090 als Vergleich nehme müsste das locker reichen. War aber auch eher als Scherz gemeint. Oder doch nicht? Ach wer weiß das schon... erinnere mich nur an mich selbst vor 3 Jahren... "Mehr als 700€ werde ich nie für eine Graka ausgeben" soso. :d
Ich finde getrennte Konten auch gut...
Schliesslich hat man ja auch nicht den gleichen Scheidungsanwalt, oder? :ROFLMAO:
(Ups - der war böse :fresse: )
Und bei Cryptos heißt es " Not your keys - not your coins" :d
Den hatten wir aber, das hat die Angelegenheit für mich doch relativ glimpflich in Bezug auf die Kosten ablaufen lassen. :d
Und ebenfalls einen entspannten Rutsch Euch allen Hardwarebekloppten! ;)
Proshop: Was ist der unverschämteste Preis den man verlangen kann? Ja
Aber es gibt einen tollen Siegelring dazu!
Zum Thema Scheidung: es können nicht beide Parteien vom gleichen Anwalt vertreten werden, aber es reicht wenn man sich einig ist ein Anwalt für den Antrag etc.
PRO-Tipp für Ehemänner:
Beim Aufrüsten bei der selben Serie bleiben! Also rein optisch unterscheiden sich 3080Ti Suprim X und 4090 Suprim X für die gemeine Frau nicht wirklich.
Allerdings solltet ihr dann auch so smart sein und die neue OVP nicht zu offensichtlich ausstellen, um keine Fragen aufkommen zu lassen... :wall:
Oder einfach ne gesunde Beziehung haben wo man nichts verheimlichen muss 🤣
So extrem kann doch niemand entmannt werden?!
Hab ein B-die Kit . Siehe System .
Ja in Games ist der 13900k schon klar besser aber Timespy habe ich sogar aktuell etwas weniger Punkte im Grafik Score .
Muss erstmal auf Asus Board und neuer Plattform klar kommen . Aktuell stört mich im Idle die 40 Watt CPU Package Power .
Oh doch! Die Demütigen sind weiter verbreitet als man denkt.
Gutes neues Jahr allen!
DDR4 bremst halt ziemlich krass :d
Kann mir kaum vorstellen das es nur daran liegt.... Verstehe allerdings auch nicht warum man sich ein Z790 mit DDR4 holt. Hatte auch nur nen 11600k mit DDR4 3200 und auf 13600k mit DDR5 6000 gewechselt. CPU Points sind mehr als doppelt so hoch. Dachte das liegt eher an den E- Kernen....
Ergebnis von der Zotac, unten im Bild von der PNY. Zotac ging zurück wegen Brummilüfter
Naja 13900K mit DDR4 4000er erreicht 18.000 Punkte. Mit DDR5 7600er wären schon 30.000 Punkte drin.
Ja in den Games siehts auf jedenfall ziemlich gut aus , aber Darktide immernoch etwas CPU limit , aber mehr FPS und smoother gefühlt.
Dying Light 2 sieht jetzt auch ziemlich gut aus von der Performance her. Keine FPS Einbrüche mehr in dem kritischen Bereich.
Das Board finde ich bisher ganz ok . Bios geht auch klar soweit.
Vielleicht liegt auch an mir . Habe mich mit Alderlake und Raptor kaum beschäftigt und muss mich erstmal bisschen einlesen.
Guck mal Phoenix seine Grafikscore an auch mit DDR4 https://www.3dmark.com/3dm/85350663?
Hätte jetzt mal wenigstens 38K Grafikscore erwartet bei mir, aber nicht weniger als mit dem 10900K :lol:
Zufällig G Sync aktiv? War bei mir zum Beispiel der Grund, warum mein Grafikscore nur bei 32k lag. Nachm Ausschalten hatte ich 34500.
Ja Gsync aktiv aber FPS limit beim Bench deaktiviert bzw. Vsync.
Muss mal Windows auf Höchstleistung vielleicht mal umstellen und dann ggf. mal GPU Planung deaktivieren.
Heute aber nicht mehr. Will ertmal die Tage damit zocken und schauen ob da alles ok ist nach längerer Spielzeit .
Erstmal guten Rutsch bin grad rein^^...
Also der Score ist mit GPU Planung in Windows auf an, GPU +155, Speicher +1891, dann hab ich noch zusätzlich den Punkt bei 1,1V auf 3075 oder 3090 bei 1,1V hochgezogen.
Voltageregler musst du dafür auf max. setzen unter Luft konnte ich den Speicher sogar bis 1970 benchen.
Aber wie bei allen anderen geht da unter Wakü irgendwie weniger mit dem Speicher, ob er interne Takte da anders fährt weil kühler keine Ahnung.
Im GPU Treiber AF aus Texture quali auf höchstleistung und die vorgerenderten Bilder auf 4 stellen, das bringt nochmal etwas Punkte.Gsync hatte ich aus.
rbar im Bios ist auf an und das wars auch schon Overlay bei Steam schalte besser aus.
Mehr wars eigtl. nicht also stink normales 24/7 Betriebsystem, unter Luft mit GPU Planung an wären aber auch 41k drin gewesen
CPU Punkte mit GPU PLanung @Stock 25,5k und ohne glaube über 26k bei 4300CL15-15.
Ja, hatte auch keine FPS Begrenzung, aber die Grafikpunkte waren dennoch deutlich niedriger.
@MS1988
Deine CPU Punkte sind massiv zu wenig, da fehlt irgendwas wahrscheinlich daddeln da nur die Ecore´s, das würde ich mal abchecken.
Ich hab Win10 laufen, da Win 11 noch etwas fehlerbehaftet ist.
Weiß jemand ob, die Phantom und Phantom GS die selbe Chipgüte haben? Oder die MSI Gaming X und Supreme?
Ähnliche Themen
Antworten
6K
Aufrufe
360K
