• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie man ne Karte oced weiß ich, es geht mir um den lächerlich hohen Verbrauch sobald man nur das kleinste bisschen OC anlegt…
Achso na OC lohnt sich quasi nicht, bei 2550Mhz@0,88V und +1500 da ist sie enorm effizient bei mir.
Selbst im Port Royal peaked sie keine 300W und inGame max. Leistungsaufnahme ist unter 260W.
Meine läuft stabil bei 0,95v @ 2745MHz. Damit zieht die Karte sich maximal 300-320W beim Spielen und man hat keine nennenswerten Leistungseinbußen.
Im TimeSpy sind das 34.000 Punkte gegenüber Max-OC mit 38.200 Punkten.
Ja, die FE ist etwas weniger überteuert. (1860€)
Die ist leider nicht verfügbar.
Hier kannst noch etwas sparen und sieht nicht ganz so speziell aus:
Die ist ebenso nicht verfügbar.
Na ja, mit 3% Shop-Cashback ist die Manli auch "nur" 1.900 EUR bei Cyberport. Da wird es wohl die werden.
Hab mir jetzt die Manli bestellt. Krieg bald Nachwuchs und ich wollte vorher gern fertig sein mit dem Basteln.
Wird mein 10700k, der ggf. 5 Ghz AllCore bringt, die 4090 sehr ausbremsen? Ziel sind immer 4K@120fps. Hätte da eher gegen Endes des Jahre smit eiem Ryzen 7 7800X3D geliebäugelt, falls der Preis stimmt.
Bis der Ryzen da ist, tuts der 10700K auch. Aber der bremst schon deutlich.
4K120 kannst du damit vergessen.
Ziel sind immer 120FPS bei 4K? Also dann wirst Du auch mit der 4090 je nach Spiel an den Reglern drehen müssen. Ist super individuell, auch DLSS und FG sind ja nicht jedermanns Sache. Der 10700 wird das sowieso nicht bringen, aber eben auch mit schnelleren CPUs klappt das nicht immer.
Gerade bei 4K ist der Bottleneck doch bei den meisten spielen mit zb einem 10700 doch gar nicht mehr so relevant..
Bei der 4090 schon. Selbst mein 12700K hält die Graka in manchen Games (RDR2 in Städten bspw.) noch zurück.
Alternativ gebe es noch für ~100 EUR Aufpreis die Lösung einen 11900K zu kaufen und den 10700k zu verkaufen. Da hätte ich zumindest PCI-E Gen4.
Wie gesagt, das kommt auf das Spiel an ist aber nicht die Regel. Es gibt dazu ja zig Benchmarks, dass ist ziemlich ernüchternd. So ein Upgrade auf ein 13er Gen bringt weniger als man denkt, besonders bei 4K.
Also meine eigene Erfahrung die ich mit dem 10900K 5 GHZ und 4090 hatte.
Habe 4K 144 HZ Monitor.
DX 11 Games relativ unproblematisch. Da war Nvidia irgendwie immer recht gut drinne da die CPU zu entlasten.
DX 12 Games mit Openworld mit relativ hoher Sichtweite bzw. höherer LOD Distanz können ein Problem darstellen , weil
da die CPU auch zu arbeiten hat . Dann bist du ggf. dann bei 80-120 FPS je nach Game.
Mit RT wird das ganze noch etwas verschärft , weil Raytracing geht auch auf die CPU .
4K 120 HZ zuverlässig erreichst du aber generell nur mit DLSS und wenn das Game das kann noch mit FG als unterstützung , wenn viel Raytracing im Spiel ist.
Spiele ohne RT schafft teils die 4090 auch ohne Upscaling Technologie .
Du kannst mit einem 10700K definitv zocken , aber holst nicht das max. je nach dem aus der Karte raus.
Mit einer starken CPU hast du unter anderem besser min. FPS und auch einen sauberen Frametimeverlauf in einigen Games.
Keine gute Idee, zumal der 11900K fast keine Mehrleistung im Gegensatz zum 10700K bietet.
OK, dann setze ich den 10700k auf 5 GHz AllCore, undervolte die 4090, schalte DLSS Quality + ggf. DLSS 3 an und schaue erstmal, was so bei rumkommt. Vielleicht findet sich am JAhresende bei kleinanezigen auch noch ein günstiger 5800X3D.
Hab das Upgrade 10900->13700 nur gemacht, damit ich höhere maximal FPS erreiche. Notfalls werden die Grafikregler etwas nach rechts geschoben. Für 4K144 reicht der 10900/10700 einfach nicht mehr, weil er in manchen Spielen nichtmal 100FPS packt.
Jo wollte eigentlich auch auf Meteorlake warten, aber vom Kopf her war es auch inaktzeptabel für mich so viel Geld für ne GPU auszugeben und nicht
mal die volle Leistung zu erreichen in 4K bis 144 FPS . Für mich ist das kein Drama , wenn ich 70-80 FPS in einem Singleplayer Game habe, aber wenn man weiß
das mehr geht , dann möchte ich das auch nutzen können , weil mehr FPS fühlen sich auch besser an für mich zumindest.
Naja für altes Board und CPU habe ich noch paar Kröten bekommen und kommt noch Cashback.
Kann man noch verkraften .
Bin aber von Sockel 1700 immernoch nicht 100% überzeugt .
Die Leistung von Raptor ist sehr gut , aber die Leistungsaufnahme könnte weniger sein .
Hat bisschen was von Ampere :d
Der traurige Höhepunkt meiner CPU Limit-story :shot:
Egal, übermorgen kommt dann der 13700K :)
So hab ich mir das vorgestellt. :)
Gleiche Szene mit dem 13700K - mit dem 5GHz 10900K war ich komplett im CPU Limit und hatte trotzdem weit unter 100FPS.
Sieht doch jetzt gleich viel besser aus und fühlt sich vor allem deutlich geschmeidiger an.
Was ist das eigentlich für ein Game ?
A Plague Tale: Requiem. Absoluter Hardwarekiller :d
Ach hab nicht mal den ersten gespielt. Müsste ich mir mal anschauen.
Hab noch über ein Jahr Gamepass Ultimate.
Ist aber schon geil 40 FPS mehr (y)
@s L i X
könntest du für mich mal folgendes bitte testen? :) Wenn du Zeit findest und überhaupt Bock drauf hast. Solltest du Cyberpunk drauf haben, bitte die Jig Jig Street und unten der Einkaufsmarkt. ob du da durchgehend im GPU Limit bist, bei 4 k und DLSS quali und rest auf max. :)
Und/oder Witcher 3 in Novigrad auf dem Platz, mit Blick auf die Scheiterhaufen. Auch da RT max. und DLSS2 Quali mit FG
Weil das sind die Stellen die mein 8700k durchgehend verkackt.. der Läuft auf 5,1 Ghz, aber man merkt das limitieren halt fast aktuell in jedem RT Game :). Es ist aber noch nicht so extrem störend. Bin immer noch am überlegen ob 13XXX oder AM5 mit den 3D Prozessoren. Noch warten bis Februar?..... der 13900KS ist mir zu teuer, für das Gebotene.
Klar, hab Urlaub :d Cyberpunk hab ich nicht, aber kann ich morgen testen. Da kommt n Kumpel mit seinem PC für ne kleine Gamingsession vorbei, der hat das. Witcher 3 hat er auch.
Hab bislang 3 Spiele getestet
13700K @ 5,4/4,3 vs 10900K @ 5
A Plague Tale: Requiem: 60% mehr FPS im CPU Limit
SpiderMan Remastered: 50% mehr FPS im CPU Limit
Ready or not: 75% mehr FPS im CPU Limit
Warten hab ich mir abgewöhnt. Wenn ich jetzt Leistung brauche, kaufe ich jetzt. Und ich bezweifle sowieso, dass Ryzen nem Raptor groß überlegen sein wird. Mal davon abgesehen, dass diese X3D Teile in Benches komplett abkacken, da hab ich auch kein Bock drauf.
CP 2077 war ich selbst beim 10900K im GPU Limit selbst @ DLSS Performance bis 120 FPS.
Da hat sich nicht viel getan. Das Spiel wurde aber soweit ich weiß auf den 10900K optimiert vom Entwickler.
8700K ist da bisschen zu schwach für CP 2077 . Da war der 10900K schon gut ausgelastet , aber hat gereicht .
@Slix : Ready or Not muss ich mal installieren. Nach dem letzten Patch lief es zwar schonmal deutlich bessser, aber gab teilweise noch FPS drops mit dem 10900K .
Moin,
ich habe die Tage eine 4090 FE ergattern können. Ich stelle mir jetzt die Frage ob ich meine aktuelle 4090 Suprim X behalte oder die FE einbaue.
Für die FE spricht aus meiner Sicht das die Luft teils aus dem Gehäuse abgeführt wird und die Karte etwas kleiner ist als die Suprim X. Die Suprim ist dafür aber wohl wahrscheinlich etwas leiser und ein paar Prozent schneller :unsure:
Welche würdet ihr behalten?
@s L i X Danke Dir. :)
@MS1988 ok, hät ich jetzt nicht erwartet. :) Danke..
hmmm mein innerer Dämon überlegt :d
Einbauen und testen . Kannst nach Spulenfiepen entscheiden , wenn du mit Kühlung und Lautstärke der Suprim X zufrieden bist.
Zudem musst du entscheiden ob dir ggf. der Lüfter der brummern kann bei der FE dich stört.
  • Danke
Reaktionen: gjn
Und eben der Beweis (oder ein Beweis) dafür, dass auch bei der 4090 in 4K die CPU absolut entscheidend ist.
Moin,
Also ich kann nicht verstehen, wie hier einige mit dem Lüfterbrummen der FE zurecht kommen. Und ja, das haben alle, das ist keine Lotterie wie beim Fiepen. :) Wenn Du also auch zu diesen Leuten gehörst, würde ich die FE nehmen, die ist meiner Meinung nach allen Vendorkarten überlegen. Nicht in jedem einzelnen Punkt jeder einzelnen Karte, aber im Gesamtkonzept
600W PT
warme Luft z.T. direkt aus dem Gehäuse
beste Haptik
kleinster Formfaktor
niedrigster idle Stromverbrauch
Zero Fan Mode
wertigstes Design
niedrigster Preis (mit Abstand)
Das mit dem Stromverbrauch ist ein sehr guter Punkt. Die Suprim X zieht hier knapp 40 Watt im Idle an einem Monitor mit 240 Hz und 5120x1440. Mit meiner vorherigen Karte war der Verbrauch deutlich geringer.
Werde die Karte dann nachher mal einbauen :)
Moin,
Schneller ist sie nicht. Die paar MHz kannst du auch auf die Nvidia 4090FE takten. Leiser ist die Suprim X, hauptsächlich wegen dem zweiten lauteren Lüfter bei Nvidia. Keine Ahnung was die Ingenieure da fabriziert haben. Mich stört es nicht. Sie ist kleiner.. der Luftanteil der hinten rausgepustet wird ist gering... der vordere Lüfter pustet die Meiste luft seitlich aus der Karte. Dazwischen ist ein luftloch.. Die Luft teilt sich auf .. nach hinten raus und dort wo der Power Adapter angeschlossen wird.
Mach es daran fest, welche Dir besser gefällt, welche Dir wertiger vorkommt und ob die Suprim stärkeres Spulenfiepen hat.. :) so würd ich das machen. Ich hab die 4090FE und hatte auch eine Gamerock 4090 (Bananenkarte - deswegen zurückgeschickt.) Leiser war die Gamerock bei Last, Effizienter war die 4090FE die hat bei gleichem Takt weniger Strom verbraucht.. warum auch immer. :)
Jedenfalls ist die 4090FE in meinem gehäuse zwischen 63-67° heiss, bei 40-47% Lüftergeschwindigkeit. Da ist noch viel Luft nach oben, aber, dann wird sie halt schön Laut. :)
  • Danke
Reaktionen: gjn
Das neue Zuhause für die 4090 FE bin gespannt wie sich das Farblich passt mit den weiß Silber Akzent!
Der X3D im Februar perfektes Timming für die 4090.
Ähnliche Themen
