[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Same Same
100% glück
Bin jetzt erst zum Einbau der Strix gekommen. Ganz schön fett das Teil. Aber ich wusste ja, das sie länger als die vorher verbaute 4090 Suprim ist.
Um die GPU wieder vertikal zu montieren muss ich mich wohl leider von meinem Dark Base trennen. Aber welches Gehäuse nehmen, wenn ich eine oben eine 420er AiO einbauen möchte? :rolleyes:
Hab ein B-die Kit . Siehe System .
Ja in Games ist der 13900k schon klar besser aber Timespy habe ich sogar aktuell etwas weniger Punkte im Grafik Score .
Muss erstmal auf Asus Board und neuer Plattform klar kommen . Aktuell stört mich im Idle die 40 Watt CPU Package Power .
Wird sicher bald mehr, wenn die Settings alle stimmen...
Eig. will ich keinen neuen Unterbau, weil der 5950X ein richtig massives Arbeitstier ist. Aber irgendwie hab ich schon Bock. Gerade, weil die 4090 in manchen Situationen an Datenhunger leidet
Ich kann mich aber nicht entscheiden - 13900K + 8000er-RAM oder wieder ein AMD-Unterbau. Ich würde mir schön in den Ar... beißen, wenn die neuen X3D dem 13900K doch nicht das Wasser reichen könnten :rolleyes2:
Zieht der 13900K eigentlich mehr Strom als der 10850K @ 5GHz? Will meinem 750er NT nicht noch mehr Last zumuten. :fresse:
Nice, woher ist das? und ist es für 600W "sicher" ausgelegt?
"Sicher" würde ich nicht sagen, aber man kann mit offenem PL sehr viel Leistung fahren (HW und Stecker ständig überwachen und mit Sensoren ausstatten, wäre nicht unwichtig)
Wurde hier gekauft...
Im Nachhinein ärgere ich mich, dass ich das nicht auch noch gekauft hab
Ne der 10900k lief mit HT . Habe paar Stunden Dying Light 2 gespielt und die CPU performt da echt gut . Kein CPU Limit und generell mehr FPS . Bf2042 auch gespielt . Lief zwar vorher schon gut , aber hier ist in jeder Lage das Fps Limit erreicht . Also zum gamen sehr stark die CPU . Hat sich schon gelohnt . Auch die schnelle M2 wo jetzt auch die games drauf passen macht sich positiv bemerkbar .
@Slix Ja im Idle, obwohl die Spannung auf 0,68V absinkt und die Taktraten runter gehen ca. 40 Watt Package Power . In Dying Light 2 sind’s mal 150 Watt Package Power . Bei CP2077 müsste es noch mehr sein , weil da waren die Temps höher , habe aber nicht nachgeschaut . BF2042 war auch so 150 Watt . Der 10900k @ 5 GHz war immer besser in Sachen Leistungsaufnahme gegenüber Stock 13900k , wobei man sagen muss 24 Kerne und 8 P Kerne @ 5,5 GHz ist schon krass .
Objektiv betrachtet macht es Sinn den 7800X3D und 7900X3d abzuwarten.
Die Frage dann wie sich 96 vs 192 V Cache untereinander verhalten.
Der 7800X3d wird definitv Sparsamer sein und sollte dann auch dicke performance haben für die 4090.
Würde meine auch gerne einbauen, aber leider habe ich vor 7 Jahren den Fehler gemacht den AGB an einer ungünstigen Stelle zu montieren (umpositionieren ist nicht so einfach möglich), daher passt nur die FE :fresse:
Der traurige Höhepunkt meiner CPU Limit-story :shot:
Egal, übermorgen kommt dann der 13700K :)
Hast jetzt ein upgrade gemacht ? :d
Ja, 13700K mit DDR5 bestellt. Bin gespannt ob ich die 144Hz halten kann.
Dann berichte mal mit deinen Games.
Bisher Darktide , BF2042 und Dying Light 2 gezockt,
Dying Light 2 wird die GPU jetzt richtig belastet und geht teilweise knapp an die 450 Watt ran @ Stock .
War an einer stelle sogar im PL bei der GPU und musste um 15 MHZ weiter absenken.
Also das Game ist kein Thema mehr .
BF2042 auch kein Thema soweit. Bei Darktide zwar etwas mehr FPS aber ähnliche minimum FPS und GPU eher bei 95 % .
Denke bei Ubisoft Titel wie Assassin`s Creed und Farcry 6 sollte mehr Power dann sein , weil das ziemlich CPU limitiert sind die Games.
Bei CP 2077 haben sich die minimum FPS etwas verbessert auch im GPU limit, aber lief schon mit dem 10900K eigentlich gut .
@ujmoskito01
Wunderbar, das Gehäuse habe ich auch, und würde es eigentlich auch gerne behalten :)
Wie viel Platz bleibt da noch, OHNE den Radiator in der Front?
Und wie viel Platz ist seitlich zu Abdeckung?
Ich frage, weil ich dann wohl mit dem 16/10 Schlauch seitlich an der Karte vorbei müsste.
Wenn ich meinen AGB um 90 Grad nach Rechts drehe, sollte ich eigentlich keine Probleme bekommen, denke ich.
Und plötzlich nutzt du nur DLSS oder so, was dann der eigentliche Grund ist :d
DLSS ist tatsächlich aktiv. Ohne DLSS hab ich allerdings teilweise sogar mehr FPS. :fresse:
Gleiche Szene ohne DLSS:
Und schon ist das CPU Limit weg… :)
Die 100% waren jetzt eher Zufall. Pendelt trotzdem noch zwischen 86% und 99%. Aber ja, ist etwas weniger.
Warum denn so klein eingestiegen?
Der 13900K wäre doch die richtige Hausnummer.
Der X7700X von AMD liegt in manchen Spielen direkt hinter dem 13900K. Die kommenden X3D- Modelle dürften das Verhältnis nochmal ändern:)
Der Aufpreis zum 13900K ist mir für nen reinen Gamingrechner einfach zu krass. Auf die 2-3FPS kann ich verzichten.
13900K vs 10900K
Irgendwo ist da der Wurm drinne bei dem Bench.
Da stimmt was gewaltig nicht. Bei dir sind CPU und GPU höher taktend, trotzdem sieht es bei mir in Summe "besser" aus: https://www.3dmark.com/3dm/86358917?
edit: hast du mal geschaut, ob windows bei dir alle Kerne nutzt? Bei mir waren anfangs nur 16 Kerne in Verwendung, weil er das im Windows Startup vom 9900K noch drin hatte (warum auch immer).
Denn gerade der CPU Benchmark ist bei dir signifikant niedriger. Der müsste eigentlich höhere Werte erreichen.
Jetzt musste ich wirklich lächeln .
So was darfst du nicht schreiben wen du ne 4090 im Rechner hast. :bigok:
Habe mal @ Stock gerade getestet und Windows auf Höchstleistung gestellt.
Sieht schon was besser aus ist aber noch nicht optimal .
Da fehlt trotzdem noch einiges. Was mir aufgefallen ist, ist dass du beim 10900k die ganzen Sicherheitsfeatures wie Speicherintegrität abgeschaltet hattest, beim neuen Prozessor stehen aber VBS status und HVCI status auf "running".
Ich muss das bei mir abschalten, weil sonst meine X-Fi nicht mehr mitspielt, kann also nicht sagen ob und wieviel da an Leistung hängen bleibt.
Ähnliche Themen
Antworten
6K
Aufrufe
312K
