[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das einzige das ich wirklich kritisiere:
Wenn man die Backplatte abschraubt, fallen dir alle Abstandshalter raus, und für meinen Geschmack war es eine riesen Fummelei, die dann später wieder nutzen zu können. Einen habe ich gleich gar nicht mehr gefunden
Oh ja die Dinger sind echt nervig :d .. die haben eigentlich ein Gewinde drinn und bleiben somit an der Schraube hängen aber ich hab bei meinem EK 4090 Strix Kühler 2 Abstandshalter die kein Gewinde hatten
und hab beide verloren als ich die Backplate nochmal abgemacht hatte die find ich nich mehr wieder und sind weg da ich Backplate aber eh nur recht Locker angezogen hab is das aber nich weiter wild
aber die Dinger sind echt Nervig bei der Montage und Demontage der Backplate.
Hat jmd schon dieses Adapter ausprobiert?
Nope, aber hier ist ne Reddit discussion darüber.
Hauptkritikpunkte sind, dass das Ding halt immer noch hässlich ist. Aber zu funktionieren scheint er.
Hat jemand diese Kabel von Fasgear und kann berichten? Werde das glaub mal bestellen und testen, sonst ist ja nichts verfügbar aktuell.
Da haben wohl viele das Fasgear.
Danke, bei Amazon sind die Ratings ja auch i.O. aber wollte mal hier Fragen. Hab eins bestellt, wird dann schon klar gehen. Die Seasonic Kabel sind ja leider nicht mehr bestellbar. Lässt sich das Kabel halbwegs gut biegen an der Graka? Das O11 XL hat so wenig Platz bis zur Glaswand 🙈
Ich denke, wenn man das Kabel vor dem einstecken biegt sollte das gut gehen, ich musste meins nicht so extrem biegen :d macht nur einen "normalen" Bogen auf dem Weg nach unten 😅
Nö, würd ich auch nicht, der adapter ist bescheuert, sollen lieber so einen adapter machen den man dann direkt mit 4x8 Pin am Netzteil anstecken kann als so nen schwachsinn
Die Netzteilanschlüsse sind nicht genormt.
Aber modDIY bieten auch passende Kabel für viele Netzteile auf dem Markt an.
Auch mit 90 Grad? Am sinnvollsten wäre eh wenn die Hersteller native 90 Grad Kabeln den atx3.0 Netzteilen beilegen
Das Kabel lässt sich super verlegen, selbst etwas knappere Bends sind ohne weiteres möglich!
Fasgear Qualität hat mich echt positiv überrascht.
Warum hässlich?
Habe es auch am Evga Supernova P2 1200.
Läuft tadellos mit einer 4090. Auch volle 600 Watt kommen an, kann es auch super biegen
Weil der Adapter halt hässlich ist. Wer will denn so ein Tentakel/Dreizack-Adapter im PC haben?
@s L i X
Der Originale von NV? das ist fakt.
Aber die Fasgear Lösung finde ich super, geht halt direkt ins Netzteil.
Gott.... Steh ich auf dem schlauch...
Ja die 90 Grad Lösung geht überhaupt nicht...
Ja, das Fasgear Kabel ist schick, aber er meinte den blöden NV-Adapter :d
Ich rede vom Modyi 90 degree adapter ^^
Das Fasgear sieht gut aus.
Limitiert beim Score mein 5950X?
Die Karte läuft während dem Benchmark komplett mit 3090 Mhz durch.
Mit 3105Mhz komme ich auf 39K
Der erste Satz + dein Resultat machen so keinen Sinn.. ich sehe das eher als Schwanzvergleich an.
Ist es normal, dass eine Änderung im „Energieverwaltungsmodus“ (NV-Panel) nur nach einem Neustart übernommen wird?
@Zw3nn0r
Du warst doch an der Qualität des EKWB Kühler intressiert?
Gestern habe ich die Karte umgebaut, wofür noch warten, hab ich mir gedacht.
Der Kühler ist für meinen Geschmack wunderbar verarbeitet, der Umbau wäre "eigentlich" problemlos gewesen, wenn man denn die Anleitung aufmerksam gelesen hätte... :unsure:
Es gibt Thermal Pads in 2 Stärken, 1mm und 2mm, und was glaubst du, welcher Blödmann das nicht gecheckt hat, und dann die Hälfte wieder neu machen musste?
:d
Zum Glück war der ausreichend dabei!
Weiterhin war Thermal Grizzly WLP dabei, auch ausreichen, denn ich musste ja den Kühler dank der Pads die ich verwechselt habe, ein zweites mal reinigen und neu mit WLP versehen.
Einen habe ich gleich gar nicht mehr gefunden, aber das ist nicht so tragisch, ich habe in da weggelassen, wo die Backplatte am GraKa Halter anliegt.
Beim Aufräumen später habe ich ihn natürlich gefunden, trotz vorheriger erfolgloser Suche :d
Die Temps sind Top, ich habe einen MO-RA3 extern, unter Luft waren es um die 65 Grad, nun bewege ich mich um die 46/47 Grad, hab aber noch eine fette Luftblase in der GraKa, die einfach nicht verschwinden will.
Alles in allem bin ich absolut zufrieden!
Hab mir jetzt noch einen GraKa Halter bestellt, so eine Stütze, das die Gurke dann auch mal gerade Hängt :)
Soll morgen schon kommen, dann mach ich ein Foto, bei Bedarf.
Danke für die Info, konnte mir am Fr. eine GIGABYTE 4090 OC schießen bei Ebay (Saturn) und habe bei Alternate einen EK QuanVector² Master RTX4090 Kühler bestellt und ich werde auf jeden Fall die Anleitung aufmerksam lesen! :-)
Sind deine Temps nicht etwas hoch oder hast du bei Dir alles auf Silent ausgelegt? Ich überlege ob es ratsam ist erst die Karte testen und dann Umbauen oder gleich umbauen. Müsste ich halt 2x Wasser ablassen oder ich mache am Ende eine lange Nase? :unsure:
Ist anzuraten. Zum Testen kannst du ja eine andere Kiste nehmen. Notfalls Netzteil umbauen, das geht schneller als am Wasserkreislauf herumzufingern. Wieso eigentlich ablassen? Schnelltrenner und gut.
ich weiß garnicht mehr, wie ich auf den genannten Wert gekommen bin.
Im Wasserkühler Thread für die 4xxx Karten hab ich noch mal Temps nachgereicht.
Beim Far Cry 5 zocken vorhin nach 30 Minuten war der Höchstwert glaube ich 42 Grad, bei 30,5 Grad Wasser.
Sowie man aber zb in einem Dualig ist, oder was kauft, sind wieder 35 oder 36 Grad angesagt.
Eventuell werd ich noch mal neue Pads und WLP von Thermal Griizzly bestellen, und zumindest GPU seitig noch mal erneuern.
Besser erst testen, hab ich auch gemacht.
Früher hab ich auch direkt umgebaut, aber 2k€ ist schon eine Hausnummer.
Stell dir vor die hat das schlimmste Spulenfiepen aller RTX4090, und du musst sie dann behalten :d
Edit:
Ich musste sogar heute Morgen noch mal Wasser lassen, weil ich gestern in der Anspannung vergessen habe, meinen neuen High Flow 2 zu verbauen :d
Edit:
Bei Zuviel Kaffee oder Bier drückt halt schnell die Blase :fresse2:
Das habe ich auch festgestellt, aber keine Ahnung ob das normal/gewollt ist. Bei meiner 1080Ti hat das on-the-fly funktioniert.
Seit der 4090 hat mein PC auch Probleme mit dem Standby-Modus :unsure:
Beim boot bekomme ich das hier angezeigt.
Noch bevor ich das Logo vom Mobo sehe.
Mit der Founders hatte ich das nicht und jetzt mit der KFA2 schon.
Wurde da was beim BIOS der Karte vergessen zu deaktivieren oder habt ihr das auch?
Ähnliche Themen
