[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist das bios ein offizielles von asus, welche Karte hat das von Hause den drauf?
Von wem es genau ist bzw. wer es gemoddet hat, weiß ich auch nicht. Aber diese Version aus den Links weiter oben ist nicht die Version, die ich seit Dez hab
Und das, obwohl BIOS-Version und ID exakt identisch sind. Der Inhalt ist es aber nicht, laut CRC-Checksumme
Ist ja nicht selten, dass ASUS verschiedene BIOS/Firmware mit exakt der gleichen Versionsnummer raushaut (siehe Apex 0088 etc)
Kann es sein, dass Dead Space ein ziemlicher UV Killer ist? Meine Settings liefen monatelang in verschiedenen Games ohne Probleme und im Dead Space Intro crasht es direkt.
Dann war dein Settting nicht wirklich stabil...
Hab gestern 3h gespielt, ohne Probleme (immer mal wieder 1-2 kleine Ruckler)
Musste jetzt bis auf 0,945V gehen bei 2715MHz damit das Intro ohne Crash durchläuft. Vorher war es bei 0,925V bei 2685MHz und lief in 10+ Games und sämtliche Benchmarks stabil. Werde dann jetzt wohl immer das Dead Space Intro als UV Test nutzen :d
Sowas ist mir damals bei Starwars Battlefront aufgefallen. Das müßte die selbe Engine sein. Battlefront war damals auch das einzige Spiel was mit meinem UV Probleme gemacht hat.
Deswegen setz ich einfach den Frame Limiter im Treiber und gut ist. Dieses ganze Undervolting ist am Ende halt nur ne Spielerei. In den Games, wo die Karte ausgelastet wird, möchte ich auch jedes FPS. Und in den Spielen, wo der Limiter greift, habe ich entsprechend niedrigere Leistungsaufnahme und Temps ohne Stabilitätssorgen.
Also kann natürlich jeder machen wie er will, aber meine 4090 soll frei sein. :d
Ich würde Voltage nach unten hin auch nicht anfassen...
PL und FPS-Limit reichen völlig. Die "paar Watt", die man mit Reduzierung von VGPU einsparen will, werden nicht selten vom Frust bei verpasstem Auto-Save bei "Game-Abkackung" wieder aufgefressen. Nee, danke...
Ich hab eher das Problem, dass ich nach ner Weile Ruckler bekomme, das obwohl die Graka und das PT zu teilweise nur 50% ausgelastet ist :rolleyes2:
Läuft bei mir inzwischen DLSS Qualität bei 5760*3240 .
Da hast du nicht mehr 50%.
Ach spiel das auch mit XBOX Controller am Oled vom Sofa aus .
Ich kriegs nicht hin, ich hab regelmäßig Ruckler drin. Hab alles auf Ultra, spiele auf dem Dell aw3423dw daher nichtmal echtes 4k. Framelimit auf 141fps, die Graka langweilt sich und trotzdem hab ich ständig mikroruckler, gerade im Kampf nerven die echt. DLSS an oder aus macht keinen Unterschied, selbst ohne läuft es über 120fps.
Hat hier mal jemand nochmal Plague Tale angeschmissen mit den hinzugefügten RT Schatten? Das ist ja brutal wie das auf die CPU drückt. Quasi konstant im CPU Limit sobald ein paar Gegner auftauchen und dann geht´s bis auf 40FPS runter mit dem 5800X3D in Kapitel 10. Schon krass. FG hilft, aber die Frametimes sind trotzdem sehr unruhig. Denke ich spiele ohne RT weiter, macht optisch eh keinen so großen Unterschied. Jetzt wird mir aber auch klar, wieso das so lange gedauert hat. Läuft wie scheiße auf der Engine, die eh schon ohne RT die CPU frühstückt. Wenn die jetzt noch RT GI und Reflections gemacht hätten wären wir so bei 10 FPS wahrscheinlich :ROFLMAO:
Eigentlich ist es einfach: Wenn man ein grundsätzlich stabiles Setting gefunden hat, geht man mit dem Takt leicht runter und mit der Spannung leicht hoch. Dann gibt es normalerweise auch keine Überraschungen. Mein Setting für die 6900XT hat die 2 Jahre, die ich Karte hatte, gut überlebt.
Jetzt bin ich auch nicht bei den TOP UVlern mit 2790MHz@990mV, dafür laufen die Sachen, die die meisten als kritisch bezeichnen, problemlos. Witcher RT (was ja dauernd abstürzen soll), Metro RT, usw.
Zusätzlich zum UV (bringt locker 60-80W) hab ich natürlich die max. Framerate im Treiber den 100Hz meines Monitors angepasst und G-Sync-Kompatibilität aktiviert.
Ja ich habe auch einige Ruckler, aber so schlimm finde ich es tatsächlich nicht. Ist ja nur manchmal und nicht konstant.
Wenn es mit den Leichen bzw. Leichenteilen zusammenhängt kann man es ja mal mit einem No-Kill-Run probieren 😆
Bei einem Game mit Denuvo DRM würde ich mich nicht wundern das man wieder ein CPU Limit hat.
Darüber wäre ich auch nicht überrascht, bei mir ist es auch egal ob ich Grafikdetails von Ultra auf High oder sogar Medium stelle, das ruckeln bleibt und ist auch reproduzierbar.
Das verdirbt mir gerade echt den Spaß. Das Steam Forum ist auch voll damit.
Ja Denuvo könnte gut sein. Sollte aber fixbar sein relativ zügig. Hoffe ich doch. Scheint ja auch noch ein paar Bugs zu geben mit New Game+ und Items
Schon Cool 8K DLSS Performance alles Ultra läuft echt schick.
In deinem Bild war ein Link zu Aliexpress hinterlegt siehe den Link in meinem Beitrag. Hattest du das direkt auf Luxx hochgeladen oder einen externen Bilder Hoster?
Same. Musste grade erstmal mein UV deutlich nach oben korrigieren für Dead Space. Lief davor in einfach allem stabil. o_O
Extern weil die Datei 8Mb hatte halt in 8K JPG.
Kann mir kaum vorstellen, dass es am OC / UV liegt.
Crashed alleine schon während dem Ladesymbol, wenn man das Game startet. Und das gibt 0 Last auf die Karte, da wird nichts gerendert außer das Lade Icon.
Irgendwas zickt da in Verbindung mit dem AB und dem RT. Da müssen die noch was mit einem Performance Patch drehen.
Ansonsten gelungenes Remake.
Bei mir ist es immer in der Startscene gecrasht, kurz nach dem Hyperraum.
Mit mehr Spannung lief es dann jetzt über 2h stabil. Wie erklärt es sich sonst wenn es nicht an OC/UV liegt, wenn das Abhilfe schafft?
Hatte jetzt auch noch nichts auf der 4090 gezockt was annähernd soviel Hardware frisst OotB.
Kannste doch ohne Spannungsmod eh nichts mit anfangen? Mit 1.1V bekomme ich die Karte unter Wasser nicht mal auf 60°C.
Ähnliche Themen
