[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das ist doch ein Spannungsmod :d
Musste jetzt bis auf 0,945V gehen bei 2715MHz damit das Intro ohne Crash durchläuft. Vorher war es bei 0,925V bei 2685MHz und lief in 10+ Games und sämtliche Benchmarks stabil. Werde dann jetzt wohl immer das Dead Space Intro als UV Test nutzen :d
Du kannst ja gerne mal den OCCT Stability Test versuchen, da wirst du noch ganz andere Ergebnisse bekommen: https://www.ocbase.com/
Die Last ist wirklich extrem und die Karte muss deutlich runtertakten, bin mir ziemlich unsicher ob man das mit Untervolting stabil bekommt. Meine 4090 ist über das PT bei ca. 350 Watt begrenzt und muss in dem Szenario bis auf 2055mhz runter takten.
Hab gerade mein offenes Gehäuse wieder auf vertikal umgebaut und musste dann zwingend das Anti-Sag-Blechding von Gigabyte verwenden, weil die Aorus dem PCIe ganz schön gebogen hat. Find ich schon nicht ungefährlich.
Was tun die, bei denen so ein Ding nicht ins Gehäuse passt?
Versteh irgendwie nicht was so ein "Vergleich" zeigen soll. Dafür haste halt zig andere Dinge im oder gar außerhalb des Gehäuses, um das Ding zu kühlen. Da lob ich mit den Luftkühler. Alles schön an einem Platz.
Seine Videos schau ich allerdings recht gern, sehr unaufgeregt und professionell präsentiert. Überlege sogar das Formd Gehäuse mal auszuprobieren trotz des Preises.
Naja, IM Gehäuse zu kühlen ist halt immer suboptimal. Man will die Hitze ja aus dem Gehäuse RAUS transportieren. So musst Du nicht nur Quirls an der GPU und CPU haben sondern zusätzlich jede Menge Quirls am Gehäuse selbst.
Klar ist eine gute WaKü Aufwand, und ob sich der lohnt, muss jeder selber wissen. Aber "Da lob ich mir den Luftkühler", als ob das in irgendeiner Weise besser wäre... ?!
Kommt Gott sei dank kaum vor
Leider nein. Gestern gekauft direkt nach der Installation nach dem Menü.. Crash. Spiel neu gestartet... direkt Crash, Rechner neu gestartet.. Spiel gestartet... Crash. Gelöscht und zurückgegeben. So ein Rotz brauche ich nicht.
Mal ein paar Monate abwarten bis die Fehler gefixt sind.
Du meinst Radi´s? :d
Wo oft wechselts du denn den Platz deines Rechners? (LAN-Parties?) :fresse:
Meine Bastelwut ist momantan wieder recht hoch (wenn ich mal Zeit dafür hab :rolleyes2:)
Hab mir mal die feinen QD3 für insgesamt ~260€ bei highflow.nl gegönnt :-)
Gibt es mittlerweile eigentlich für den 16 Poligen Anschluss nen brauchbaren 90 Grad Adapter?
Oder kurz "Enteignung", da Gegenwert vielleicht 2.000€ oder weniger... :haha:
Ich hoffe es wird nur ne Titan !
48 GB Brauch ich nicht und kann mir dann die 4000 einfacher schlecht reden!
Eine 4090 TI FE für 2200 wäre dann wieder zu attraktiv dann geht das rattern im Kopf wieder los
Nein, aber das Corsair-Premium-Kabel lässt sich super knicken und ist wirklich leicht biegsam. Kein Vergleich zu allen anderen Kabeln.
Netzteil aus dem Profil noch aktuell?
Ne da ist leider gar nichts mehr Aktuell. Habe mir das be quiet Straight Power 11 1200W geholt aber dafür passt ja nur das 12VHPWR Kabel von be quiet oder?
Nun in den letzten Monaten hab ich 4 Grakas ein und ausgebaut und einmal das ganze System in ein neues Gehäuse verfrachtet. Da lob ich mir doch die Einfachheit der Luftkühlung.
Aber ich wollte hier keine WaKü Debatte losbrechen, soll jeder machen was er will.
nVidia müsste da eigentlich eine Kompatibilitätsliste mit liefern für geeignete Gehäuse ;)
Das Ding wird sehr teuer. Warum auch nicht, wenn es keine Konkurrenz gibt. 2200 Euro halte ich für zu optimistisch gedacht
Kaufe ich nur wenn mehr als 100% performance zur 4090 rausgeballert werden. (y)
Ähnliche Themen
