• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wird nicht passieren, 50% wäre schon sehr optimistisch.
Ich weiß. Die 100% Anforderung schützen vor dummen Geldaushaben. :o
Es ist aber tatsächlich so, wenn das Teil 20% schneller sein soll: Ob das Spiel nun 100 oder 120fps rausballert, oder 40 zu 48fps, ist auch schon shiceegal. (y)
Bei 40 zu 80fps sieht es dann aber schon anders aus. Das muss Lederjacke liefern, sonst gibts eben keine Kohle. (y)
Am Ende zählt der Vram.
Denn Vram ist durch nichts zu ersetzen, außer durch noch mehr Vram.
Real Man have 48 GB Vram!
Mein Wort zum Sonntag :d
Jo aber is ein bekannter directx crash der schon im ea Forum offiziell bestätigt wurde. Kommt Gott sei dank kaum vor, heute 1x mid game und 1x beim starten vom Spiel.
Ist halt komisch hab ca 12 Stunden ohne irgendwelche Mucken .
Nun in den letzten Monaten hab ich 4 Grakas ein und ausgebaut und einmal das ganze System in ein neues Gehäuse verfrachtet. Da lob ich mir doch die Einfachheit der Luftkühlung.
Aber ich wollte hier keine WaKü Debatte losbrechen, soll jeder machen was er will.
Wen man ne Wakü auf die Karte baut hat man sich in der Regel dafür entschieden die ne Weile zu nutzen.
Desweiteren gibt es da auch Schnellkupplungen was einen Umbau genauso schnell zu läst.
Und zum testen von 4 Karten @Air ist auch kein Problem .
Hab ja auch eine Master TUF, Strix und nun eine FE verbaut war kein Problem.
Der Vorteil bei einer Wakü bleibt halt auch da das die 300& 450-500W nicht im Gehäuse die anderen Komponenten auf heizen.
Ein gut durchdachtes Wakü Build muss nicht zwangsläufig aufwendiger sein.
Vom 8auer wurde ein Winkeladapter mit Display angekündigt.
Meinst Du die Graka-Videos, in denen man den aktuellen Prototypen immer wieder mal sehen konnte, oder gabs da zwischenzeitlich eine konkrete Ankündigung, die ich verpasst habe?
Roman hat in einer seiner letzten Videos gesagt das es "demnächst" auf den Markt kommen soll.
Das Ding wird sehr teuer. Warum auch nicht, wenn es keine Konkurrenz gibt. 2200 Euro halte ich für zu optimistisch gedacht
Bei 24 GB halt ich es für realistisch mit ab 2200-2300 für die FE als TI .
Bei 48 GB gehe ich von aus das es eine echte Titan ist wo alles frei geschaltet ist und ein Preis von um die 3500-4000 durch aus möglich für möglich.
Naja, zumindest weiß man, wie "WireView" aussieht. Mehr als 30€ für das Ding wären jedoch überzogen
Und was macht WC...?
In 2 Tagen soll es den HK V Pro geben. Bilder immer noch Mangelware. Bahnt sich da wieder ein Papiertiger an, wie bei Ampere?
Ich denke es wird (wenn dann) eine Titan. Eine 4090 Ti macht von der Namensgebung keinen Sinn, da die Karte nicht an Gamer vermarktet werden muss und AMD eher schwach war. Wäre die 7900XTX sehr nah dran an der 4090 und gewinnt sogar einige Titel, so wie das bei 3090 und 6900XT war, würde eine 4090 Ti wohl Sinn machen. In der aktuellen Marktlage macht aber wohl eine Titan dann am meisten Sinn weil so die Karte locker 3500€ könnte. Nächsten Monat ist ja auch 10 Jähriges Jubiläum der Titan Klasse...Würde sich perfekt anbieten. Aber mal sehen, bisher ist ja jetzt nur ein weiteres Foto von diesem Prototypen aufgetaucht.
Wenn sogar deren Contakt - Frame von TG 40€ kostet, das Äquivalent von Thermaltake nur schmale 13€, dann vermute ich mal, dass für das Teil mindestens 99,90€ aufgerufen werden ^^
Findest Du das Detailbild im Shop nicht interessant?:unsure: Ansonsten gehe ich davon aus, das die HK-Designsprache der letzten Kühler fortgeführt wird. Von daher bin ich da völlig tiefenenstspannt und warte geduldig darauf, bis der Kühler physisch vor mir liegt.
Befürchte ich auch...
Da ist man mit "PMD-USB und PCIe" wesentlich besser und günstiger dran. Zumal das Teil einiges mehr kann
Niemand, ausser WC weiss, wie der Block aussieht...
Der "Lückenfüller" (Bild von innen) sieht eher wie ein Renderbild mit reinkopierten Frässpuren aus
K.A. warum man um die Bilder des Blocks so ein Geheimnis macht
Also 3500-4000€ für ne Grafikkarte ist nur noch absurd. Da werden sich die aller, aller wenigsten zu durchringen. Selbst hier im Hardwarebonzenforum :fresse:
Wenn es die Karte mit nem Gratisspiel gibt, nehme ich eine... :fresse2:
Da wäre bei mir dann auch Schicht im Schacht.
Ich habe zwar den Block auch vorbestellt, jedoch wäre ganz schön wenn man vorher sieht was man kauft.
Das wurde schon bei 1000€ und 2000€ gesagt. :fresse:
Schon, aber das kann man noch irgendwie stemmen. Bei dem doppelten muss man sich dann schon fragen, ob Mr. Lederjacke nicht doch etwas viel "Kräuter" raucht.
Für 4000€ bekommt man nen soliden Gebrauchtwagen.
Sorry aber das muss man nicht. Also die Titan könnte auch 10.000€ kosten, sie richtet sich nicht an den normalen Gamer. Für mich sind ja jegliche Preisdiskussionen bei einem Gut wie Grafikkarten sinnlos, aber bei der Titan müsste doch jeder einsehen, dass die preislich nicht "mitspielen" muss?
Es gibt ja auch Kunden für Voodoo HiFi. Also sicher auch für so eine Grafikkarte.
Das mit DLSS Balanced ist mir auch aufgefallen und man muss echt bei jedem Start dran denken. Denke ich warte noch 1-2 Patches. Heute erstmal Plague Tale Requiem abgeschlossen und jetzt geht es ein paar Tage an die PS5 für den Rest von God of War Ragnarök.
Mit zarten +0,03Volt mehr fast 1.000Watt in Furmark... :oops:
Links = PMD-USB - rechts = EVC2SE
Gesamtleistung (CPU und RAM waren @ default - nicht mal XMP)
Nebenbei gleich noch den Belastungtest, der Corsair-12VHPWR-Kabelpeitsche gemacht, die ja nur 2 statt 3 oder 4 Zuleitungen hat. Also fast 500W pro Kabel :d
Warm wurde aber nur der Shunt am PMD-USB...
Um die genaue VGPU und VRAM zu messen, müsste ich nochmal die BP runtermachen, nachmessen und gleich noch ein besseres Mini-Display mit 4 Digits anlöten
Ähnliche Themen
