• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
aber da steht doch nur:
Die DLSS-Frame-Generierung erfordert eine Grafikkarte der GeForce RTX 40-Serie und die Aktivierung der hardwarebeschleunigten GPU-Planung im Betriebssystem. In Windows 11 ist diese Option standardmäßig aktiviert.
Aktivieren der hardwarebeschleunigten GPU-Planung in Windows 10:
  1. Drücken Sie die Windows -Taste auf Ihrer Tastatur und geben Sie "Grafik" ein und drücken Sie die Eingabetaste. - Das Grafikeinstellungsmenü sollte sich öffnen.
  2. Schalten Sie im Menü „Grafikeinstellungen“ die Option „ Hardwarebeschleunigte GPU-Planung “ um.
  3. Starten Sie Ihren PC neu.
HINWEIS: Es wird empfohlen, Upscaling (DLSS) auf Grafikkarten mit 16 GB oder weniger VRAM und einer Auflösung von 1440p oder höher zu aktivieren.
Ja und warum wird es wohl empfohlen mit weniger als 16GB upsampling zu nutzen? vmt. weil da der VRAM limitiert. Portal RTX hat auch ganz schön viel VRAM gefressen. :unsure:
Der Vram einer 4090 wird schon reichen .
Ggf. sind 4070TI Käufer angeschissen .
dort wird doch nur empfohlen DLSS(FG) zu benutzen weil CP2077 VRAM lastig wird ab 1440P und höher. Und das ist doch schon lange eine bekannte Hilfe wenn man zu wenig Vram hat.
Oder verstehe ich da jetzt was falsch?
Ist nicht böse gemeint.
Frame Generation ist doch ein Upscaler (DLSS3) der die VRAM Belastung reduziert so wie die anderen DLSS Generationen...... oder ist dem nicht so?
PS: @Foxel wenigstens hast du deinen eigenen Satz von DLSS3 auf FG geändert ;-)
Vor paar Tagen tauchte hier ne Frage auf...aufheulen der Lüfter im Idle oder Youtube schauen bei der Gigabyte Gaming OC. Ist mir jetzt seit 22.10. nicht aufgefallen. Aktuell ist es mir tatsächlich bei der 200sten Stunde in Eldenring für eine sec. passiert. Kurz aufgeheult dann wieder normal und nur einmal. Hab immer noch das Auslieferungsbios drauf. Ansonsten funktioniert die Karte ohne Probleme. Dies geschah aber nach nem kurzen Win 10 und Geforce Experience Update und die Batterien vom Xbox Controller waren gerade leer. Keine Ahnung ob da ein Zusammenhang besteht.
Beste Grüße
Nope, passiert völlig random. Schreibe demnächst mal Gigabyte an was die dazu sagen. Wundert mich das noch keiner was offizielles dazu hat.
Beinhaltet das Update jetzt auch den "RT Overdrive" Modus?
Ich habe bisher nur Nvidia Reflex & Frame Generation in den Einstellungen gefunden, mehr hab ich nicht geguckt. Ich schaue mal eben.
Scheint nicht so, in der Ray Tracing Kategorie hat sich nichts verändert.
nicht das ich wüsste.. Bin auch froh, das das nicht klappt. Was tun bei falschen OC Einstellungen. :)
beim Mainboard gibt's den BIOS flashback. Finde, so fragil sollte ein gpu BIOS heutzutage nicht mehr sein, zumal es mir um weniger Spannung, weniger Leistungsaufnahme und mehr Effizienz geht.
Grad mal getestet
Mit FG werden bei mir in 4K und ohne DLSS ca. 15,95GB belegt und ca. 13,90GB verwendet.
Auch eine RTX4080 wird hier wohl keine Probleme haben
Ohne FG sind es knapp 2 GB jeweils weniger
Ist für mich aufjedenfall ein Mehrwert, werde es aktiviert lassen.
Grad mal getestet
Dying Light 2 hat wohl auch ein Update bekommen . Werde mal nach der spätschicht auch CP 2077 und Dying Light 2 Testen .
Mit FG hoffe ich ggf. In Dying Light 2 immer 144 FPS halten zu können . Meine lief schon so gut , aber ggf. kann man weiter den Lod Multi hoch ziehen ohne ins CPU Limit zu rennen . Bin mal gespannt nachher .
Bei CP 2077 freut man sich über jeden Performance Schub . Vorallem wenn dieses Jahr hoffentlich das DLC kommt . Echt mal wieder Bock auf das Game .
Guten Abend :)
endlich ist meine MSI Suprim X angekommen!
Mir kommt es so vor als würde die Karte ganz leicht durchhängen nach hinten raus. Augemaß und keine Wasserwaage.
Beim ASUS Board ROG ist ein Ständer mit dabei, genau wie bei der MSI Karte. Beide kann ich aber nicht wirklich gebrauchen.
ASUS ist zu niedrig und MSI zu groß :d
Nutzt ihr so einen Ständer zur Stabilisierung der 4090?
Oder mache ich mir nur unnötig Sorgen?
Danke und LG
Passieren wird wahrscheinlich nix ohne Ständer aber hernehmen würd ich schon einen. Meine Strix hat 36cm Länge und 2,5kg da schadet so nen Ständer sicher nicht.
Ja, die Daten sind bei der MSI ähnlich... vielleicht sollte ich den unteren Lüfter doch wieder ausbauen. Aber ich dachte erstmal an "Belüftung > GraKa Ständer" :)
Dann muss ich mir wohl was eigenes basteln....
(Anmerkung zum Bild: der Ständer steht nicht dauernd auf dem Lüfter, war nur zur Veranschaulichung)
Grad mal getestet
Habe Cyberpunk 2077 jetzt getestet. Bei der Presse Version, die mal rumgegeistert ist, war es noch nicht so gut umgesetzt wie jetzt. FG ist für mich auf jedenfall auch in Cyberpunk aktiviert. Mit DLSS 2 auf Quali und FG zwischen 93-116 FPS (VSYNC über Treiber). Wegen LG 42C2 begrenzt. Richtig angenehm Smooth. Auch für mich auf alle Fälle ein Mehrwert.
FG aktiviert, ohne DLSS 2 aber nicht zu gebrauchen. Auch wenn da mehr als 60 FPS oben steht, fühlt es sich durch den Input lag und den Stutter nicht flüssig an. :)
Baumarkt regelt:fresse2:
Der Vertikal-Mount war gnadenlos überfordert. Die Karte hing über 10mm schief. Also habe ich 3Uhr Morgens in der Schraubenkiste rumgewühlt und etwas zusammengetütelt :shot:
Endlich bald wieder neues Spielzeug 🔥
Ist gekauft sobald verfügbar! :)
Wurde aber auch echt Zeit, die 4090 ist schon wieder 3 Monate alt.. langweilig.
Ähnliche Themen
