• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dieses BIOS hat eine andere CRC-Checksumme im Vergleich zu meiner Version, die ich letztes Jahr bekommen hab
Die BIOS-Version und die ID sind aber exakt gleich (ist aber nichts Neues bei ASUS)
Teste das Bios nun auch, was direkt negativ aufällt, ist das der Speichertakt im Idle oben bleibt. denke ist bei allen so oder?
War bei der 3090 auch schon so...
Kann man jedoch fixen, indem man in AB ein Profil mit dem normalen Idle-Takt erstellt, das beim Start von AB automatisch geladen werden kann. Bei der 3090 ging das jedenfalls
Die Frage habe ich mir bei meinem Setup zB andersrum gestellt : Wie hoch ist die Leistung um immer ins Framelimit zu laufen, bei mir 116FPS@4K - das ist bei vielen Titeln schon unter 70% PL der Fall - also hab ich das nie versucht.
Die Vermutung liegt aber Nahe das da nur noch wenige % Punkte an Gewinn für sehr viel Energie raus kommen.
Ich hätte aufgrund der Steckerproblematik auch Sorge das dauerhaft anzulegen......
Welche Kabel bekommst du ?
Ich suche immer noch hierfür eine ALternative :
Andersrum habe ich einen gefunden, aber dann steht die Peitsche nach oben weg.......
Ich frag bei den gedrehten Winkelsteckern immer wie man den irgendwann wieder abbauen will wenn die Haltenase unten, also vom Stecker verdeckt ist...
Ist die Nickelbeschichtung nicht extra auf dem Kupfer drauf damit Flüssigmetall verwendet werden kann .... :geek:
Jo, watercool hat meine Mail beantwortet:
Die Nickelschickt stellt keine Probleme beim Flüssigmetall dar. Kupfer kann ebenso damit verwendet werden. Problematisch reagiert nur Aluminium.
Du hast eine Custom Wasserkühlung.. fragst aber ob Flüssigmetall bei Nickel / Kupfer kein Problem sind?! Big oof oder wie die Kids immer sagen.
Caseking hat momentan INNO3D GeForce RTX 4090 iChill Frostbite, 24576 MB GDDR6X auf Lager​
Preis ist echt hoch. Vor 2 Wochen gabs bei nem anderen Händler für 2080€.
selber bauen und Geld sparen :bigok:
werde iwie gerade von der schei*e verfolgt.... gestern morgen gab es bei mir 3x dwm.exe Crash, mit Blackscreen (gpu lüfter bleiben dabei aber silent und drehen nicht hoch), aber ohne gpu load! War einmal im idle, einmal im luxx und 1mal auf youtube. Habe dann per DDU den aktuellsten Treiber runtergeworfen und wieder den vom 3.1.23 installiert. Konnte den ganzen Tag dann problemlos zocken und es trat auch nicht mehr auf.
Jetzt nach der Arbeit PC eingeschaltet, 2min Browser offen, Blackscreen. Also reboot, Ereignisanzeige nach Fehlern durchsucht, zack wieder Blackscreen... Aktuell läuft es wieder seit 20-30min und jetzt habe ich den Beitrag hier auf reddit gefunden: https://www.reddit.com/r/buildapc/comments/yuqhag/rtx_4090_black_screen_issues/
Habe jetzt natürlich nicht den ganzen Thread durchsucht, aber hat das noch einer hier? Bzw evtl sogar eine Lösung dafür?
ich glaube das passt hier rein
ich habe meine schon einmal vorbestellt :d, träumen darf man ja 8-)
Palit bei Alternate nur heute im Live Shopping in der Cyberweek für 1799€ (ohne Versandkosten)
Wie ist das eigentlich bei der Gamerock - wird das PCB wieder gerade, wenn man den Kühler runternimmt und einen Wasserblock installiert?
Naja, der reddit thread ist da weit zutreffender, ich habe ja keine Crashes in Games, selbst mein zugemoddetes gta5 läuft problemlos und da zieht die 4090 (0.95v/2760mhz/90% PT) bis zu 380W bei 100% Load. Bei mir friert ja auch der PC nicht ein, nachdem blackscreen kann ich alt+f4 und enter drücken und die Kiste fährt normal runter.
Nach bisschen lesen werde ich jetzt mal HAGS deaktivieren in Windows und wenn es dann nochmal auftritt werde ich mir das 12pin Kabel meines tollen MSI NTs mal genauer anschauen, bei reddit konnten es wohl einige lösen durch einen Kabeltausch
Hast du mal im Event Log von Windows nachgesehen? Wenn da nvlddmkm mit reset als error drin ist, dann stell im Nvidia Control Panel die „Power - prefer maximum performance“ ein. Ich glaube es hängt an den downclocks des rams in Zusammenhang mit den Temperaturen (zu niedrig) im idle.
Ja, da taucht immer vor dem blackscreen eben mehrfach ein crash von dwm.exe auf.
Habe aber gerade nochmal geschaut und jetzt diesen hier gefunden:
Ereignis 465, DxgKrnl (Winlogon in session 1 (console) reuqested session stop using GPU, returned status STATUS_SUCCESS, with progress stage of successful)
Interessanterweise taucht der Fehler 4 mal vor den dwm.exe crashes und blackscreens auf, aber ich hatte den Blackscreen genau 5 mal :fresse:
Deine Mudda ist kein Problem auf Nickel im Gegensatz zu LM kannst du watercool zurückschreiben (y)
1634428944791-png.680766
roman hatte die tage ein video zu LM auf Nickel. da hats den kühler gefressen. weis aber nciht mehr ob das zusammenhing ^^
Ähnliche Themen
