[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
aber niemand hat es geschafft mit einem solchen Aufbau deutlich erhöhte Temperaturen zu erreichen.
Ich gehe auch nicht von höheren Temperaturen aus, sondern davon das die Mechanische Belastung zu Brüchen oder Kontakten führen kann. Also das was Igor am Anfang gezeigt hat (auch wenn es am Schluss nicht die Ursache war/ist??).
Naja mein Post war aber eigentlich auf "Locker aus dem Handgelenk"
Man, BIEG ES EINFACH. ES MACHT IMMER NOCH KEINEN UNTERSCHIED.
Dass man das täglich mehrfach sagen muss..
bezogen und nicht um eine Diskussion ob es Brennt oder nicht loszutreten. Bin mal kurz
Exakt wie bei mir. Seit Anfang Dezember genau 0 Abstürze bei 2730MHz @ 0.950v
Dead Space hat aber irgendein Problem glaube ich. Ist nicht normal wie das UV settings zerschießt. Ich denke man fährt besser wenn man für Dead Space ein eigenes Profil macht, denn eigentlich alle Spiele und Benchmarks sind auch mit niedrigeren Settings stable
Hab ich nicht :fresse:
Ich glaube, die User sind das Problem: Wollen einfach nicht wahrhaben, dass gewisse Taktraten nicht stable sind.
Ich bleibe dabei: Für Dead Space macht man ein eigenes Profil oder spielt einfach Stock und für alles andere kann man bessere Settings nutzen. Sehe meine 0,935V bei 2685MHz weiterhin als stable an. Nur weil ein Game da faxen macht, passe ich nicht global die Settings an.
Wundert mich das es darüber noch keine großartigen Threads gibt in Verbindung mit Dead Space Remake und GPU OC/UV. Denke auch eher das es am Spiel/Engine selbst liegt.Könnte auch am Shader Cache liegen.
Das Spiel läuft bei mir einwandfrei ob mit OC UV oder Stock .
Wen ich es jedoch übertreibe und die Karte über dem Limit betreibe dann bekomme ich auch abstürtze.
Gestern extra mal ausprobiert weil ich das mit den Abstürzen bei euch nicht nachvollziehen konnte da es bei mir seid Day One ohne Probs läuft .
Ach ja Spiele es mit 5760×3240 also mit 2.25 DL+DLSS mit RT Rest max Out.
Der AB-RTSS+Hwinfo machen auch keinen Ärger.
Auch Arbeitspeicher kann abstürze verursachen muss ja nicht zwingend eure Karte sein.
Danke! So sieht es aus. Vielleicht hat sich der Hersteller schon was bei den Stock Settings gedacht. Wie so oft müssen die nämlich jeden Used Case abdecken.
So instabil sind die Stecker und die Anschlüsse gar nicht, wie man auch schon immer wieder Nachgewiesen hat. Man muss schon permanent immer wieder extremst hin und her biegen, um einen Schaden zu provozieren. Und selbst dann reichen die verbliebenen Pins locker für eine sichere Verbindung aus.
Das ganze Drama war ein Sturm im Wasserglas. Der einzige echte Mangel ist die nicht so glücklich gelöste Verriegelung.
Nu ja wäre ja nicht so wen du bei 0,935V dann 2610mhz machst das die Karte dann um soviel langsamer wird das man Total viel Performance verliert.
Ganz im Gegen Teil richtig Stabel kann manchmal viel Konsistenter sein und gleich schnell laufen.
Und minimal weniger verbrauchen könntest du dann eventuell auch noch mal.
Ich würde mich an den MHZ nicht aufhängen lieber ein Stabiles Setting ermitteln was immer läuft und gut ist es.
Also entweder Caseking hat eine Menge Karten der Frostbite bekommen oder die Leute sind langsam abgedeckt mit den WaKü Karten.
Gibst du dann noch 1000 Speicher drauf?
Bei mir läuft die Kombi mit Strix auch super bisher.
Speicher läuft mit +1200MHz. Aber Performancetechnisch bringt das keinen Vorteil ggü. Stock. Vielleicht 1fps.
Taugt der Kühler der frostbite denn?
Preislich theoretisch teurer als andere Karten mit nachträglich installiertem Wasserkühler
Ich habe seit Kurzem ein kurioses Problem:
Nach einem Kaltstart erscheinen in GPU-z unter "GPU-Clock" lediglich zwei Striche. Di Karte taktet unter Last nicht hoch. Wenn ich in den "Energieverwaltungsmodus" im Treiber von "normal" auf "maximale Leistung" gehe, ändert sich das nicht. Erst nach einem Neustart scheint das Problem behoben.
Was kann ich tun?
Schau Mal mit DUDU ob Win 11 beim ersten Start damals einen AMD Grafiktreiber installiert hat für die IGPU wen die im Mainboard BIOS aktiviert war.
Und sich nun gegeben falls vielleicht etwas beißt.
Am besten noch mal alle Grafiktreiber Treiber runter putzen und dann noch Mal schauen.
Ist jetzt mit dem X670E Board ja vielleicht etwas anders mit der IGPU.
Mein Kühler der Frostbite funktioniert genau so, wie hier über die Alphacool-Blöcke berichtet. Die Montage passt, ansonsten ist ja technisch nicht verändert. nur ärgerlich, dass ein Siegel verklebt ist. Inno3D möchte also wissen, ob man den Kühler mal abgenommen hat.
Ich war so blöd und hab Ein und Ausgang vertauscht. Funktioniert trotzdem problemlos und ohne wirkliche Einschränkungen.
Welche Settings,laufen denn bei dir normalerweise im OC, bei Dead Space Remake?
Ich habe keinerlei Probs in anderen Games sei es Darktide/RDR2/Cyverpunk/MGOTG/Witcher
3/Metro etc. mit Ray Tracing auf Vollanschlag.
Hat mich aufjedenfall gewundert.
Die Leistung ist so ziemlich das Beste was man für die 4000er Karten bekommen kann.
Optik ist natürlich Geschmacksache!
Aber die letzten Wochen und Monate war die Karte nie mehrere Tage auf Lager und kaum zu bekommen….
Entweder 2760 mit UV bei 0,975V .
Oder Stock V mit 2910 MHz +1000 RAM auf Grund der Temp geht es von 2940 nach einer gewissen Zeit runter.
Speedway läuft noch mit 3GHZ durch nur mal so als Beispiel in Dead Space ist das aber nicht möglich.
Bei Caseking, nein. Weil viel zu teuer aaaaaaaaber... die Frostbite ist einfach ne Karte mit Alphacool Block, also natürlich taugt der was.
Ich muss bei selben Takt (~2700MHz) auf 0.975V gehen in Dead Space damit es nicht crasht. Ich hänge mich einfach nicht daran auf, dass ein Random Game, dass anscheinend irgendein Problem an der Engine oder was weiß ich hat, mit meinen ansonsten absolut stabilen Settings crasht. Kein Grund direkt panisch die Regler wieder zu bedienen, nur um sich dann sagen zu können, dass es jetzt wirklich stable ist. Alle anderen Games seit Monaten laufen auch weiterhin stabil mit diesen Settings und da ändert Dead Space gar nichts dran. Klar ist es kein riesiger Unterschied in der Performance, aber alles an dieses eine problematische Game anzupassen, was ich btw schon 2 mal durch habe und vermutlich in nächster Zeit nicht mehr spielen werde, ist einfach quatsch.
Weil es immer wieder in Vergessenheit gerät: Es gibt keine Spiele (oder generell SW), die "inkompatibel mit bestimmten OC / UV Einstellungen sind".
Es gibt nur OC/UV Einstellungen die absolut stable sind oder eben nicht.
Wenn es nur EINE SW gibt, die Instabilitäten aufdeckt, dann ist diese Einstellung eben nicht stable, punkt.
HW funktioniert korrekt oder eben nicht. Es gibt da nichts dazwischen, "sie funktioniert für SW A korrekt aber nicht für SW B".
Ähnliche Themen
