[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Weil es immer wieder in Vergessenheit gerät: Es gibt keine Spiele (oder generell SW), die "inkompatibel mit bestimmten OC / UV Einstellungen sind".
Es gibt nur OC/UV Einstellungen die absolut stable sind oder eben nicht.
Wenn es nur EINE SW gibt, die Instabilitäten aufdeckt, dann ist diese Einstellung eben nicht stable, punkt.
HW funktioniert korrekt oder eben nicht. Es gibt da nichts dazwischen, "sie funktioniert für SW A korrekt aber nicht für SW B".
Wenn ein Game aus mittlerweile bestimmt 20 Probleme mit meinen Settings verursacht und es bei diesem einen Game bleibt, sehe ich das Problem nicht bei meinen Settings. So einfach ist das. Völlig egal was jetzt die Definition von stable hier im Luxx ist. Da müsste es mindestens in einem anderen Szenario noch crashen damit ich weiß, dass es nicht eine Besonderheit von Dead Space ist.
So…mein Update zu „idle Crash / Bildschirm flackert / nvlddmkm error“
Meine GPU ist 100% Game Stable in Stock und OC…glaubt mir das mal…
Habe alles Probiert, was man im Bios machen kann inkl RAM 2133Mhz. Board ist ein X570 Tomahawk mit dem aktuellsten Agesa 1.2.0.7 vom Herbst. Treiber macht auch keinen Unterschied inkl. DDU.
Der Crash/Flackern tritt nur auf NACH dem Beenden von Games auf.
Und jetzt kommt’s -> genau immer dann wenn der VRAM/GPU runter taktet auf Minimum und die Memory Junction unter 38C fällt.
Also ist es (eindeutig) eine Instabilität bei Minimum Clock und niedrigen Temperaturen. In Games oder gleich nach dem cold Boot unter 37C ist es kein Problem.
LÖSUNGEN:
Asus 1000W vbios, dort taktet der vram nicht runter im idle.
Nachteil -> hoher Idle (50w vs 25w) und KEIN Temperatur Limit.
NVControl Panel -> prefer maximum performance.
Nachteil -> noch höherer Idle, da weder GPU noch vram runter Takten. (60w)
Falls noch jemand dieses Problem hat, dann schaut mal ob es bei euch am Temp & Vram downclock liegt.
PS: vram downclock ist keine Lösung (bei mir).
Naja es ist aber nun mal leider so, dass man Stabilität in der Hinsicht nicht beweisen kann, weil man es nie schaffen wird jeden Use-Case abzubilden... :d
Aber wenn du einen Weg für dich gefunden hast damit umzugehen ist das doch auch okay!
Hab Mal ne kurze Frage an die Leute die das Glück hatten ne 4090FE zu ergattern, wenn denn Mal ein drop ist kann man mit PayPal Zahlen (Raten) oder nur KK und Amazon Pay ?
Weiß das jemand ?
Weiß das jemand ?
Ich habe mit PayPal gezahlt. Aber ohne Ratenzahlung. Wurde mir aber glaube ich trotzdem angeboten. 9,99% Zinsen sind aber schon heftig bei einer 2K Grafikkarte
OK danke dann warte ich Mal auf einen drop, ja 10% sind viel sind es mir aber wert, weil Mal eben 2k aus dem Ärmel schütteln ist nicht. Hatte bis vor kurzem ja ne Airo Finanziert aber als ich die zum Mediamarkt brachte wegen den Lüftern haben die das einfach erstattet und die Finanzierung somit beendet. Jetzt wollte ich dann auf ne FE gehen. War mir aber nicht sicher ob das wieder so klappt, aber dann bin ich beruhigt und Versuche Mal mein Glück hoffe da tut sich was jetzt Mal letzte drop war glaube am 17.01 oder ?
Gibt es eigentlich eine Möglichkeit, die Karte dauerhaft auf fixen 900-1000MHz zu betreiben? Oder ist das PT auf 33% die einzige Möglichkeit? Wobei die Taktrate da ordentlich am schwanken ist.
Geht mir speziell um Spiele, die die Karte absolut kalt lassen. Zum Beispiel League of Legends oder CS GO. Da schafft die Karte es wahrscheinlich auch mit 400Mhz, das Spiel auf 144FPS zu halten. :fresse:
So sieht es aus. Da kann man es sich 10x schön reden mit "ja aber alle anderen Games..."
Sorry aber dann ist das Setting nun mal nicht Game stable. Heißt ja nicht, dass man damit nicht leben kann, ändert aber eben nix an dieser Tatsache.
Wenn Deadspace Remake bei @ Stock nicht Crasht , dann triggert es halt OC etwas stärker als andere Games.
Einzige Game wo es auch mal @ Stock Crasht ist bisher Darktide wo es mir aufgefallen ist nach einer Runde zurück in den Bereich wo man Waffen modden kann oder Missionen wählen kann.
Übrigens weil mir aufgefallen das Nvidia Reflex mit Dying Light 2 Probleme macht ist dieses scheinbar auch dem Entwickler aufgefallen und hat vorserst einen Fix gebracht der Standardmäßig Reflex deaktiviert
mit dem Hinweis im Hotfix das die das Problem erstmal weiter untersuchen , weil sonst kann ich selber auch sagen Nvidia Reflex hat bisher in vielen Games wo ich es aktiv habe keine Probleme gemacht .
Elegant! :LOL:
Man muss sich nur zu helfen wissen. Und bestimmt ist diese Lösung um einiges billiger als extra einen Ständer nachzukaufen.
ich wette dagegen. 2 löcher im case. wiederverkauf uiuiuiui :d
die 9,99% gibs nur bei 12 monate +
wenn man 3 oder 6 wählt isses weniger. trotzdem aber viel und aktuell gehen die zinsen ja durch die decke...
falls wer sich wundert :d
Nein. Das stimmt einfach faktisch nicht.
Aus der Sicht der SW hat die Hardware sich immer gleich und zuverlässig zu verhalten. Wenn sich die HW mit Stocksettings so verhält, dass die Software damit perfekt funktioniert, dann hat die SW erstmal keinen Fehler. Wenn Du dann an der HW (oder deren Taktrate, Spannung etc.) etwas verändert, und die SW dann damit auf einmal nicht mehr korrekt funktioniert, dann ist das niemals die Schuld der SW.
Sondern es gibt dann halt bestimmte Konstellationen, bei denen Deine HW-Einstellungen Probleme machen. Diese Probleme mögen bei anderen Spielen nicht sichtbar sein, oder mehr oder weniger zufällig nicht auftreten, aber sie sind dennoch vorhanden.
Das heißt, Du hast ein instabiles System mit diesen Settings.
Was würdest Du denn sagen, wenn Du einen PC fertig konfiguriert kaufst ohne etwas an dessen Konfiguration zu ändern. Dieser PC stürtzt aber in bestimmten, ganz seltenen Spielen oder Situationen ab. Würdest Du es dann dem Händer durchgehen lassen wenn er sagt "aber der PC läuft doch in 20 anderen Spielen, also ist alles ok!"?
Wohl doch nicht oder?
Übrigens meine Karte schafft 3000 MHz in Dead Space 6K DLDSR stable @ 1.075v :drool:
Das werden nur ganz wenige Karten schaffen… die meisten auch nicht mit 1.100v.
Meine macht die 3000 Mhz in Dead Space @ 1.060 da habe ich dann keine Probleme mehr mit Crashes. Spiele ohne DLSS @ 2K 144 Fps Lock.
Komischerweise macht meine, die 3000 Mhz in anderen Games ohne Probleme @ Standart Spannung.
Valhalla ist da auch immer sehr anfällig, was OC angeht. Alles was unstable ist crashed direkt nach ein paar Minuten.
Dead Space Remake ist anscheinend das neue "Non Plus Ultra" um den Takt zu prüfen...
Das Ding ist, dass es bei Dead Space im Steam Forum z.B. haufenweise Leute gibt, die diesen DirectX Fehler (device hung) bekommen. Z.B. hier: https://steamcommunity.com/app/1693980/discussions/0/3770110614223783524/
Glaube das ist kein Zufall und noch weniger glaube ich, dass alle diese Leute zu aggressives UV oder OC drauf haben. Zumal einige behaupten, keinerlei UV/OC Settings aktiv zu haben. Deine Erklärungen überzeugen mich demnach nicht. Wenn ich jetzt laut dir ein instabiles System habe, weil ich für Dead Space ein eigenes Profil habe und für alles andere mein Standard benutze, kann ich trotzdem extrem gut damit leben, weil es in der Praxis komplett irrelevant ist. Zumindest solange, wie es tatsächlich ein Dead Space exklusives Problem bleibt.
Nochmal: Wenn der Fehler verschwindet, sobald man die Taktrate und Spannung auf Stock setzt KANN ES KEIN SW-Fehler sein!!!!
Sei doch nicht so stur. Es gibt auch noch viele andere Menschen, die OC/UV und dann laut schreien, wenn die SW nicht korrekt funktioniert. Diese Menschen sind der Horror aller Support-Leute. Und bitte reih Dich da nicht ein, sondern verstehe doch, dass es nicht sein kann, dass eine SW "inkompatibel mit OC/UV" ist. Es ist immer die Einstellung, die Schuld ist, niemals die SW. Das macht einfach schlicht keinen Sinn.
Die HW hat sich immer und zu jeder Zeit zuverlässig gleich zu verhalten. Tut sie das nicht, dann stimmt was mit der HW oder ihrer Einstellung nicht.,
Was aktuell, zumindest in meinen Augen und auch nur auf die Frostbite mit Cover bezogen, ein Problem darstellt, man hat nur sehr wenige Händler mit den Karten. Somit ist der Preis aktuell auch noch sehr hoch und leider auch sehr stabil. Wobei die Karten, dass ist jetzt meine persönliche Meinung, nicht wirklich viel sinken werden, vieleicht noch 100 oder 150€ im Schnitt. Und mit den steigenden Zinsen hast Du auch recht, wobei man bei solchen Konsumerkrediten oft die versteckten Kosten wie Bearbeitungsgebühren oder Versicherungen/Absicherungen übersieht. Meist werden solche Kredite unterm Strich teurer als man erst dachte. Weiterhin kann man auch oft sehr schnell den Überblick verlieren was man eigentlich alles finanziert hat und dann bricht so ein Kartenhaus schnell mal ein (Kann muss aber nicht).
Es stottert gelegentlich, wo ich mit 4K oder 5K DLDSR keine Probleme habe. Ob es an der CPU liegt? Dann müssten aber 4K und 5K ebenfalls Probleme bereiten.
Wobei das Stottern mit einem FrameLimit auf 70 sehr gut reduziert wird. Ich spiele ja Dead Space auf einem 4K TV mit Controller.
Das ist doch der übliche Traversal Stutter in dem Game. Ist in jeder Auflösung vorhanden. Mal ist es besser, mal schlechter. Je nachdem wo man sich befindet. Nächste Woche kommt das Digital Foundry Video, wo das auch behandelt wird. Dachte zunächst der erste Patch hätte das behoben aber nachdem ich dann weitergespielt habe ist es doch wieder aufgetreten. Wenn man weniger FPS hat merkt man es aber auch weniger. Habe daher DLSS aus gestellt. Bei 4K mit DLSS Quality und ständig über 100 FPS ist es schon sehr nervig.
Hallo. Mal eine Frage an die Profis hier. Ich hab gerade wieder Cyberpunk angefangen und merke, dass die 2080 Ti arg an die Grenzen kommt. Ich überlege daher eine 4090 zu kaufen. Ich zocke primär auf 3440x1440. Die Frage ist allerdings, ob ich meinen Unterbau (9900K mit DDR4 4000) behalten kann oder das wenig Sinn macht. Laut Anzeige in spielen (hier zB Cyberpunk) hänge ich im GPU Limit. Hab irgendwie wenig Lust alles auszutauschen.
Die 9900K wird reichen. Du kannst auch ne 4080 nehmen, für 3440x1440 reicht die auch, speziell mit Frame Generation. Ich bin mit der 4090 bei 5120x1440 permanent auf 120+ fps (alle Einstellungen inkl. RT maxed out).
Kann ich dir beantworten. Du wirst ebenfalls , nein SAVE auch im CPU limit sein
ich zocke mit eiem 9700k@5GHZ DDR4 3200 aber auf 5120x1440 MAX Details mit DLSS 3 Quality und habe ich ebenfalls keine 99-100% Auslastung der GPU. Eher 80-90
Du mit 3440-1440 wirst noch mehr ins CPU Limit laufen.
Ich werde auch sofort nächsten bzw. übernächsten Monat auf den 7800x3d wechseln, weil es einfach nervt.
Die 4090 ist viel zu schnell für die alten 9000er von Intel....habe ich mit mehreren Games getestet. Ich hänge sehr offt im CPU limit. Das einzige was wirklich sau gut läuft ist Plague Tale 2
Aber ansonsten Witcher, Hitman 3 Cyberpunk habe ich keine perfekte Auslastung. Hitman 3 .....50-70% Auslastung...das ist das heftigste
Also entweder rüstest du wie ich auch CPU auf damit du GPU besser ausgelastet ist oder du wechselst lieber 4080. Damit wirds wohl besser laufen
@Katakuri1991 Welche Framerate hast Du denn mit Quality und Frame Generation an?
würde jetzt sagen 80-120 FPS aber ohne 50-60FPS 70-80% Auslastung....aber die restlichen Games ist die 4090 viel zu schnell......da hänge ich schon arg im CPU Limit.
Nachtrag: Habe schnell Cyberpunk angeschmissen und getestet. MAX DLSS 3 Quality
Also 80-120FPS meistens um die 80-90FPS . Geringste Auslastung jetzt beim rennen 69% Höchste 98%. Schwankt aber sehr, dementsprechend fallen auch die FPS aus.
Da muss definitiv eine neue CPU her!
Mit demEVC2 geht das...
Takte weiß ich leider nicht, weil GPU-Z und HWinfo immer den gleichen Takt anzeigte. Muss aber weniger gewesen sein, bei weniger als einem 1/4 der Aufnahmeleistung (520W vs 120W)
Furmark @1.920x1.080 ohne AA
"Output Voltage" und Input Power" von links nach rechts (im Screenshot)...
1,05V - 0,945V - 0,84V - 0,734V
520W - 360W --- 245W -- 120W
645fps - 591fps - 522fps - 439fps
1,24 ---- 1,64 ---- 2,13 --- 3,66 (<-- Werte = fps pro Watt)
Bis 710mV konnte ich runter, aber das schon nicht mehr stabil (bei Furmark zumindest). Und ohne es manuell nachzumessen, weiss ich nicht, inwieweit die angezeigte Spannung in der EVC2-Software stimmt. Will sowieso noch paar Sachen ans PCB löten
Ja geht ganz einfach:
1. Eingabeaufforderung als Admin starten -> im Windows Startmenü CMD suchen und rechts als Admin starten.
2. sicher gehen dass man (sollte Standard sein) in C:\Windows\System32 Ordner ist
3. folgendes eingeben: nvidia-smi -lgc X,Y
Hierbei ist X der Minimum Takt und Y der Maximum. Alternativ kann man einfach nur X eingeben, dann ist der Takt fest.
Beispiel:
nvidia-smi -lgc 210,1110
Damit würde die Karte nur zwischen 210 und 1110MHz takten.
Bonus Info:
Min Takt Standard sind 210 und Max sollte immer ein Vielfaches von 15 plus 210 sein. Wenn man was krummes wie 210,999 eingibt geht das natürlich auch…dann taktet die Karte auf den nächst niedrigeren Boost Bin -> also 990Mhz.
Bonus Info 2:
Mit „nvidia-smi -lmc 405,5001“ kann man den VRAM auf 10GHz anstelle der 21GHz beschränken. Hier gibt es allerdings deutlich weniger Boost Bins (zB nur 405,810,5001,10501(?)) und diese korrelieren mit Boost Bins des GPU Cores. Also eine Kombi auf 210MHz Core und 5001MHz VRAM geht nicht…Resultat ist, dass der Core auf 435MHz angehoben wird.
Um das ganze wieder rückgängig zu machen einfach „nvidia-smi -rgc“ eingeben, oder den PC neu starten!
PS: Eignet sich auch sehr gut um maximale Overclocks oder Undervolts stabil zu bekommen, da man das komische boosten der GPU „limitieren“ kann. Kalt boosten die Karten plötzlich 30-45MHz höher als in Afterburner hinterlegt… einfach -lgc 210,3000 eingeben und man kann sich sicher sein, dass es niemals mehr als 3000Mhz sein werden. Wenn man dann zusätzlich noch seine Afterburner Kurve im Temperatur Fenster eingibt, dass man haben will dann gibt’s keine „random“ crashes.
Ich habe zB. meine Kurve auf „kalt“ 3120MHz eingestellt und sobald ich Game oder benche geht sie auf 3075-3090MHz. Mit dem zusätzlichen „-lgc 210,3120“ verhindere ich ein überboosten…man könnte natürlich auch „-lgc 210,3075“ eingeben und hätte unabhängig von der Temperatur immer den gleichen Takt und nur die Spannung wäre statt 1,1V dann im kalten Zustand 1,095 oder weniger.
Viel Spaß.
(Text unten hat nichts mit der Frage oder Nvidia-smi im eigentlichen Sinne zu tun - keine Sorge, dass ihr durch Nvidia-smi crashes bekommt -> man kann diesen doofen 4090 Bug der anscheinend 1-5% aller karten betrauert aber damit „beheben“)
PPS: falls ihr idle crashes mit nvlddmkm habt kann man „-lmc 810,X“ oder „-lmc 5001,X“ (wobei X die im afterburner gewünschte maximale VRAM MHz sind - bei mir zB 12302) eingeben und den VRAM am absoluten downclock hindern. Sind dann 10-20W mehr in idle, aber dadurch auch im Leerlauf keine Fehler mehr…
PPPS:
Falls Interesse besteht erkläre ich gerne nochmal wie man das ganze per task schedualer und BAT Datei beim Computer Start automatisch (wahlweise silent oder mit Bestätigung) oder als Desktop Icon ausführt.
Sehe ich das eigentlich richtig, dass die OC Versionen der Karten völliger Mumpitz sind, weil der Boost Takt einer OC karte niedriger sein kann, als der einer Standard Karte?
Meine TUF OC hier ist mit 2595MHz angegeben. Die boostet aber nur bis 2700MHz. Allerdings boostete meine FE höher (2520MHz), auf 2715MHz. Und meine PNY (ebenfalls 2520MHz stock) boostete auch bis 2700MHz. Ich dachte je höher der "offizielle" Boost Takt, desto höher dann auch der tatsächliche? Oder anders herum, wenn das am Ende keine Rolle für den tatsächlich gehaltenen Boost Takt in 3D Anwendungen spielt, warum dann überhaupt OC Versionen anbieten?
Ähnliche Themen
