[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hör sie hier schon piepsen :fresse2:
Ich auch - gerade :fresse:
Eig. gibt es keinen Unterschied zur TUF (Non-OC-Version)
Mom. höre ich die Spulen kaum, weil die Lüfter auf 85% laufen :d
Aber RAM geht wesentlich besser :)
Bei der TUF sind nur bei bestimmten Benches nicht ohne Weiteres max +1.500 (eingestellt in AB) möglich - sonst nur +1.450 oder 1.475 :(
Und mit der Strix im Schnelltest +1.950 (bzw. 12.452MHz im AB-Onscreen oder 1.557MHz Durchschnitt bei Speed Way) :)
Und mit der Strix im Schnelltest +1.950 bzw. 12.452MHz im AB-Onscreen bzw. 1.557MHz Durchschnitt bei Speed Way :)
Ja, meine Strix ging auch extrem gut, aber eben die Fieperei. Bin gespannt was Du so nach ein paar Tagen sagst. Viel Erfolg weiterhin. Wenn es die White nochmal zum Normalpreis gibt, steig ich auch nochmal ein. :fresse:
Nachricht gelöscht
Soll angeblich trotzdem kein richtiger Vollbild Modus sein, was bei mir Probleme mit dem ausgewählten Gsync Modus erklären würde.
GSync geht schon, es darf nur kein Fenster oder Overlay Fenster *über* dem Spielefenster sein. Auch nicht die Windows Startleiste.
Ggf. Tab aus dem Spiel raus und wieder rein. Das löst das Problem i.d.R.
Danke, weiß ich schon. Aber kein Bock drauf :d
Beim gaming zieht die CPU meistens 65W und da sind die Temps aktuell ohne GPU in der Loop bei 60°. Passt schon ^^
Jo ist trotzdem verschenktes Potenzial. Der X3D braucht Combo Breaker äähm Strike 3 oder halt -30 sonst ist er nicht das was er sein könnte und zwar einfach mega :d
Noch - oder gabs die schon günstiger? (ich verfolge die Verfügbarkeit nicht mehr)
Günstiger als dieses Angebot für eine non-OC Strix meines Wissens bisher nicht. Aber vermutlich wird sich der Preis in ein paar Wochen aufgrund der mittlerweile sinkenden Nachfrage weiter nach unten orientieren.
Die 3090 Strix wurden nie verschenkt, selbst als die Preise nach dem Mining Boom einbrachen. Ich denke dass die 4090 Strix mit die wertstabilste Karte bleiben wird, trotz ihrer Fieperei.
Ach ich bin auch so'n Sucker. Aber nicht weil ich denke dass sie schneller ist, sondern weil sie die einzige weiße Karte haben. Wenn die nicht gefiept hätte, hätte ich sie behalten und die Kohle wäre völlig irrelevant.
So hat jeder seine Gründe. Am Ende zahlt man für die "Features", die einem wichtig sind. Deswegen ist man aber nicht gleich dämlich. Ne Manli käme mir nie in den Case, egal ob sie genau so schnell wie ne Strix ist. :)
Strix oder Nix :d
Na dann zeig mal wo man die kaufen kann. :rolleyes:
Hm, gibt wohl nur 4080 und 4070Ti...
Die BP spricht mich etwas an...
Hatte mal leihweise ein Z790 AERO-MB. Sah auch wertig aus...
Nach langer Hardware Abstinenz hab ich mir die Zotac Extrem Airo bestellt, könnte vielleicht jemand was zu Spulenfiepen sagen.
Karte wird gleich auf Wakü umgebaut.
Einfach ne gigabyte gaming oc kaufen. Da haben sie die spulen anscheinend weg gelassen, so leise wie meine ist. Dafür bekommst du wahrscheinlich kein oc Wunder und verlierst im daily 1 fps.
Nach 4 Monaten hab ich nun endlich eine 4090 Frostbite, für nur 2050€, huiiii. Jetzt nur noch bis Juni warten das die Wakü Boards kommen. Yaay
Wasn Jahr. Weiss zufällig jemand ob die Frostbite eine relevante Flussrichtung hat? Hab das Paket noch nicht geöffnet, kenne sie nur von Fotos, dort sind klar Pfeile gekennzeichnet. Sieht aber nach simplen Lamellenkanälen aus, oder hat die einen Düsenblock ?
Ich würde den Block unbedingt korrekt anschließen. Gerade an der Düse und dem Finnenblock hat man ja ordentlich getüftelt. Der große Aufwand mit dem Custom Loop und dann Anschlüsse vertauschen und schlechtere Temps haben? No way.
Technische Highlights
Die Finnenstruktur dieser Eisblock Kühlergeneration wurde gemeinsam mit Nvidia-Boardpartnern entwickelt. Die Finnendicke beträgt 0.4 mm, der Abstand der Kühlfinnen zueinander 0.4 mm. Das gewährleistet einen sehr guten Wasserdurchfluss bei gleichzeitiger Erhöhung der möglichen Kühlfläche. Die Düsenplatte verfügt über ein überarbeitetes Inlay, dass den Wasserdruck besser auf die Finnen verteilt und die Wärmeaufnahme optimiert. Der angepasste Wasserzufluss verhilft dem Wasser zu einem besseren Einströmwinkel.
Soll mit eine der besten sein was Spulenfipen angeht.
Eine Gigabyte Master hatte ich die war von den Spulen superleise da müsste man schon richtig das Ohr auf die Karte legen um etwas zu hören dann aber auch wirklich minimalst.
Habe drei von denen zum Falten in Betrieb - eine rasselt ganz leise, aber sehr erträglich. Aktuell 1x Bykski, 1x Granzon, 1x Luft.
Der dritte Umbau, auch auf Bykski, kommt dieses weekend dran. Die mit dem Granzon hat das leichte Rasseln - hatte sie unter Luft nicht. Vielleicht hatte ich es wegen der Terrorlüfter auch nur nicht gehört, da wirklich nur sehr leise. Werde jetzt beim Umbau auch die BP Spulen-Pads der Granzon mal testweise entfernen.
Geil !
Sieht der Granzon real auch so gut aus wie auf den Bildern .
Der gefällt mir optisch auf jeden Fall sehr gut .
Ähnliche Themen
