[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja, wenn was passiert, ist bestenfalls der Port verschmort und Adapter ist raus,
Das meine ich, eigentlich will man den Adapter jetzt nicht mehr nutzen, aber dann hat man halt 60€ umsonst rausgeworfen.
Northdrige ist wohl der Meinung, dass das Problem bei Nvidia liegt, weil es immer auf der Karte schmilzt.
Ist eine ganz komische Nummer… Cablemod Matt vermutet, dass einzelne Karten zu viel Strom ziehen und es dadurch zum Melting kommt. Warum aber, lief Capoos 4090 ohne Probleme zuvor?!
Cablemod verweist auf 55K verkaufte Adapter, wovon nur einer von 20 Usern nachgewiesen hatte, dass der Adapter richtig angeschlossen war:
Ja klar, die Leute holen sich so nen teuren Adapter, aber wissen nicht, dass dieser ordentlich bis zum Ende durchgeführt sein muss. Ist da keine Anleitung bzw. Hinweis dabei?
Könnte natürlich sein, dass die Amperzahl irgendwie hochschiesst, aber das würde doch eigentlich zumindest an der Wattzahl zu sehen sein.
Und ich habe vorher das beiliegende Kabel und danach ein Fasgear-Kabel verwendet, keine Probleme über Monate hinweg. Karte lief permanent bei den gleichen UV-Einstellungen und dann wurde auf Cablemod erweitert. Keine Veränderung an den Werten, Karte lief wie auch vorher im UV... nur das dann anscheinend 350W gereicht haben um den Adapter mit Karte zu verschweißen. Ich vermute, hätte ich nach dem Einbau auf den Cablemod-Adapter sofort das UV rausgenommen, wäre der Adapter inkl Port sofort verschmort. Leider weiß man ja nicht wie die Einstellungen bei den ganzen anderen Fällen waren.
Und das mit dem 1 von 20 werte ich erstmal als Abwehrhaltung seitens Cablemod. Keiner will jetzt der Buhman sein, weil wenn sich rausstellt, dass die Adapter Stress machen, kauft den Kram niemand mehr und evtl. gibts dann in den USA irgendwelche Rechtsansprüche seitens der User. Dazu kommt, dass es dann schon mind. 2 User gibt, denn die haben von mir die Fotos und das Video per Mail erhalten.
Als ob alle so blöd sind und ihre Kabel nicht richtig einstecken, gerade nachdem das Thema alle Hardware News wochenlang beschäftigt hat, sollten die meisten wissen wie man mit den Kabeln zu verfahren hat. GN hat halt ne schöne Vorlage für die Hersteller geschaffen, erstmal alles auf den User schieben.
Denke es gibt vermutlich 2 voneinander getrennte Probleme, der 12VHPWR Port scheint einfach ziemlich anfällig zu sein.
Einmal mit nicht ausreichend eingesteckten Steckern und jetzt kommen das Problem mit dem Adapter dazu.
Vielleicht kann der Port einfach nur schlecht mit solch einer Art von Verlängerung?
Vielleicht waren es einfach nur schlecht gebaute Adapter? Meiner müsste zu den ersten Batches gehören die versendet wurden.
Und warum kokelt es immer an der Karte, warum nicht schon am Kabel?
Und jetzt kommt auch noch das Ding auf den Markt, als 180° Adapter schon ganz cool, aber wer sichert uns jetzt, dass die Dinger nicht das gleiche Problem bekommen wie die Cablemod Adapter:
Bei mir lüppt der Cable Mod 180 C Adapter (Variante B) und das Corsair Type 4 12VHPWR Kabel bisher (Tag 1 wohlgemerkt) ohne Probleme auch über 450 W.
Laut Igors Lab wird der Adapter nur wegen der Karte selbst warm (da in der Nähe) - nicht wegen dem Saft auf den Adern...
Was mich aktuell schon wundert, das meine 4090 FE immer unterschiedliche Sweet Spots besitzt. Also gemeint ist je nach Engine (DX12, DX11, DX9) und ob RT im Einsatz ist oder nicht.
Siehe dazu: https://www.hardwareluxx.de/communi...00-undervolting-sammler.1325830/post-29927213
*edit*
Hat zufällig in letzter Zeit jemand das 12VHPWR Kabel von Seasonic bei Alternate bestellt? Da steht irgendwie seit Januar 12 Tage Lieferzeit drin, schicken die das dann auch wirklich mal raus oder wird da einfach seit Monaten geschoben?
Ich habe meins von Alternate. Die schicken wirklich raus. Ich glaube bei mir hat es ne Woche gedauert.
Wurden irgendwelche Marken genannt?
Ich konnte bisher feststellen, dass nicht die ganze Buchse, sondern nur ein Teil davon zu warm wird. Also ungünstige Aufteilung von +12V und Masse
Falls nicht mal bei Caseking schauen, da habe ich mein Kabel her, 2 Tage war es da.
3x 8Pin und das ganze Theater über Stecker schmelzen, neue Kabel, neue Netzteile usw hätte es nie gegeben und alle wäre glücklich. :d
Der Punkt ist die 4090 sollte normal 600 Watt PL @ Stock haben , wenn Nvidia es nicht geschafft hätte von Samsung zu TSMC zu wechseln . Daher war schon der Gedanke schon ok und der Stecker ist ja an für sich nicht verkehrt . Muss halt ordentlich produziert werden . Die next Gen. werden womöglich nicht mehr so überdimensionierte Luftkühler haben wie es aktuell der Fall ist .
Man sieht auch das Asus die TUF in der neuen rev. ganz schön abgespeckt hat .
Seit mir damals 2 NTs kaputt gegangen sind, nachdem ich auf Custom Cablemod Kabel gewechselt habe, habe ich die Firma immer gemieden. Wäre natürlich echt nen Hammer, wenn da nun viele User von dem geschmolzenen Adapter betroffen sind! Irgendwie ist die 40er Gen. verflucht!
Was genau war da denn los? Hab aktuell auch am Seasonic das Cablemod Kabel, da das originale nicht verfügbar war. Aber bisher scheinen die Probleme ja nur die Adapter betreffen
Schon seltsam, monatelang war Ruhe mit dem Thema und jetzt ploppt es wieder auf in Verbindung mit dem Adapter. Dabei wurde der schon so lange verschoben.
Was mir damals bei meinem Cablemodkabel aufgefallen ist: Die einzelnen Buchsen innerhalb der Pins sind teilweise unterschiedlich lang. Hatte damals etwas Sorge, dass der Kontakt bei den verkürzten Buchsen evtl. Nicht richtig besteht und es zu einem erhöhten Übergangswiderstand kommt. Habe dann aber festgestellt, dass es an meinem Asus Kabel was ich zuvor genutzt habe auch so ist und hab es einfach probiert. Bis heute 0 Probleme aber könnte es sein, dass dieses Problem bei den Adaptern evtl. noch stärker ausgeprägt sein kann?
Werde dann wohl einfach meine 4 köpfige Krake weiter behalten, nicht ganz schön, aber bisher erfreulich unproblematisch. Läuft einfach und das mit meinem 700W Fanless Netzteil von Seasonic.
Dieses Originale Seasonic Kabel mit nur 2 Anschlüssen wird mir zb von Seasonic selbst nicht empfohlen bei meinem NT, hatte mal per E-Mail nachgefragt.
Finde jetzt irgendwie schwer von den paar anekdotisch fehlerhaften Adaptern auf eine gesamte Krise des Steckers zu schließen.
Es sind halt einfach, wie bei fast jedem Fehler, Montagsmodelle dabei. Das wird sich nicht verhindern lassen und es gibt hier kein allgemeines Problem - weder mit dem Adapter, noch mit dem 12VHPWR-Stecker.
In der Regel sind die NT‘s so ausgelegt das 300 Watt pro 8PIN Buchse durchgehen . Daher auch oft Doppelstränge dabei bei den 8PIN Kabel bei den Netzteilen dabei .
Sehe das daher unproblematisch und fahre selber in der Regel nicht mehr als die 450 Watt . Für OC Tests habe ich aber auch die 600 Watt PL eingestellt und selbst da kommt man garnicht vollkommen hin . Sehe das relativ entspannt . Mit Corsair und deren Kabel bin ich zumindest wirklich zufrieden .
Natürlich nicht, aber mit dem Adapter jetzt ging es von einem "Ja Kabel ist halt nicht richtig eingesteckt" zu "Der war auf jeden Fall drin und ist trotzdem geschmolzen" Problem.
Verstehe nicht was das ändert?
Es sind halt fehlerhaft produzierte Adapter im Umlauf, wo vermutlich die internen Kontakte nicht in die Messtoleranz passen und daher durch erhöhte Übergangsspannung dafür Sorgen, dass der Adapter viel zu warm wird und im Fall von Capoo dann dazu führen, dass sich der Adapter nicht mehr von der Karte lösen lässt. Wird man vermutlich aber nie herausfinden, was genau da jetzt passiert ist.
Wenn das ein weiter verbreitetes Problem wäre, würden die Leute hier nicht einfach so Ihre Adapter wieder abziehen können. Sofern die zahlen von CableMod stimmen handelt es sich hier um eine Fehlerquote von Sub 0.1% (55000 verkaufte Adapter bei 20 gemeldeten Defekten, und da ist noch Raum für ne Dunkelziffer damit es Sub 0.1% bleibt) und das finde ich ist mehr als im Rahmen.
Damals haben die meisten User ja auch alle gesagt, dass das Kabel richtig eingesteckt gewesen sei. Wenn jetzt rauskommt, dass es doch nicht nur ein Userproblem war, hat GN den Herstellern aber einen tollen Dienst erbracht :ROFLMAO: Kurz nach dem Video kam dann ja das Statement von Nvidia, das einfach die Aussagen von Steve bestätigt hat und alle waren fein raus.
Wireview gibt es ja leider noch nicht für 16-Pin :/
doch :)
Weiss jemand zufällig, wo man die Thermal Grizzly WireView mit 12vhpwr-Anschluss bestellen kann?
jetzt :)
Es gibt noch kein garantiertes Datum.
nun ist die 12vhpwr version online :)
Schade, dass der Wireview nur 180Grad ist. Für die Founders ist das jetzt nicht so toll, da liegt das Kabel ja über dem hinteren Lüfter.
Allerdings muss man auch auf Grund der Breite aufpassen - bei der Zotac 4090 Airo ist neben der 12VHPWR Anschlussbuchse ein Bios Trigger und ich glaube, dass das WireView hier "drauf drücken" würde.
Ich habe eine Frage an Euch. Ist es irgendwie sinnvoll ein Motherboard BIOS Update auszuführen, jetzt wo ich auf die 4090 umgestiegen bin? Die GPU sitzt auf einem MSI Z690 EDGE mit einer 12900k, aber mit ziemlich altem BIOS. Es gab nie Probleme, daher habe ich das nie updated. Grund für die Frage ist, da ich bei Benchmarks auf Stocksettings ohne UV, z.B. in Port Royal, immer etwas hinter dem liege was "vergleichbare Hardware" anzeigt. Bspw. 25700 statt 26400. Im Prinzip stört mich das nicht, da ich sowieso UV betreibe, aber wenn ich durch ein BIOS Update etwas mehr Leistung bekomme, ist das natürlich auch schön.
Ein Motherboard-Bios wird deine Performance nicht verbessern. Deine Grafikkarte wird einfach aus irgend einem Grund nicht so gut boosten wie der Durchschnitt - wobei beim Durchschnitt soweit ich weiß auch übertaktete Hardware mit rein spielen, kann also sein das du genau im Durchschnitt stehst für nicht-übertaktete Karten.
Ich hab mir gestern mal die 3DMark-Database angesehen, es wäre halt wirklich schön wenn es da eine flag für "stock" gäbe, damit man weiß wie man dran ist.
Der Wireview Adapter wäre ja als Alternative zum Cablemod interessant. Der Preis geht sogar im Vergleich, nur frage ich mich, die Cablemod Adapter werden nach Igors und Cablemods Aussage ja ziemlich warm, wie soll das dann bei den Wireviews ablaufen wenn da noch ne Platine inkl. Display dranhängt und scheinbar ist die Blende vorne aus Plastik?
Der Wireview Adapter würde bei mir gar nicht passen. Zu wenig Platz zur Scheibe.
Guck dir den Stecker mal genau an, der ist ein ganzes Stück versetzt, da sollte genügend Platz sein.
bei den Zotac Karten guckt nur der Button übers PCB hinaus. Wenn der Stecker drinnen steckt, hast du noch ein ganzes Stück Versatz bis die Platine des Wireviews beginnt.
  • Maße: 50 x 63 x 33 mm (L x B x H)
Hmm, den Part des Steckers abgezogen der in der Karte verschwindet, vielleicht 5 - 7 mm, da biste auch bei knapp 2,5 cm die über die Karte hinausschauen
Kann hier mal meine neue Gigabyte Aorus Waterforce Extrem zeigen:
Eine sehr schöne kompakte Karte, sie liegt im Idle bei 25 Grad, das ist etwas 5 Grad niedriger als die Strixx, die ich zuvor hatte, es ist auch eine Rev.1.1 mit dem 600 Watt PT
Leider verfügt die Karte nicht über ein Dual Bios, was aber wegen des 600W PT zu verschmerzen ist, außerdem ist keinerlei RGB vorhanden
Dann mal sehen wie sich das Kärtchen unter Last verhält :)
ich hab mal mit ner Voltcraft Temperaturmesspistole an und um den 12VHPWR Anschluss gehalten (habe keine Adapter, nur das bequiet Kabel) und habe da total unauffällige Temperaturen unter 40° an meiner Zotac 4090. Messe ich am falschen Punkt ? Hatte zum Aufheizen ein paar Minuten 3DMark laufen. Am WE werde ich mal ein paar Zockerstunden machen und nochmal messen...
Du kannst stark davon ausgehen das du unbetroffen bist. Solche Defekte treten meist am Anfang auf und dann eher gar nicht mehr.
Ähnliche Themen
