[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ach man was denkt sich eigentlich die Autokorrektur immer, geht einem manchmal echt auf den Sack.
Naja die Gerüchteküche ist sich noch nicht ganz einig aber möglicherweise wird die Poseidon eine Karte mit Wasserblock werden, mal sehen ....
Das Thema mit den 12VHPWR Steckern und Adapter von Cablemod ist schon frustrierend. Habe erst vor kurzem mein Case gewechselt ohne gross nachzuforschen, ob die Karte passt. 2-3 Fotos und Videos habe ich gesehen und war mir deshalb sicher, dass eine 4090 TUF mit sleeved Cablemod Kabel passen sollte. Aber jetzt ist der Biegeradius mehr als kriminell. Und einen Kauf des 180° Adapters kann man nun auch vergessen, wenn die reihenweise verbrutzeln.
Der Radiallüfter auf der LC kühlt aber nur die Komponenten der Stromversorgung mit geringer Drehzahl
Den letzten radialen Lüfter ohne Nebengeräusche hatte bei mir eine von ich glaub vier GTX 680 Classified. :oops:
Bei der Ares ii hatte Asus damals tatsächlich ein Einsehen und hat einen Axial-Lüfter übers VRM gepackt,
Das war meine erste +500W Karte damals, mit sehr kurzer Verweildauer.
@Nastya
Что тут смешного 🤔
Может быть будет правда так! 😆🤭
Keine Frauenverkäufe hier im Forum :) Z
Was waren das für Fotos? Ich habe mich wegen der Breite der 4090 extra von meinem Lian Li O11 XL getrennt, denn selbst das ist einfach nur zu schmal innen.
Und ich hab extra auf ein itx Gehäuse gewechselt und hab Temperatur technisch keine probleme
Von Youtube bis zu Reddit & PC Partpicker Builds war alles dabei. Im Nachhinein betrachtet sieht man oft, dass die Fenster nicht geschlossen sind oder dass andere Kabel verwendet werden. War im Hype wohl bisschen blind.
Welches Gehäuse hast du jetzt? Jedes normale Case im Form eines Define 7 sollte ja ausreichen.
Mit dem Evolv ATX hatte ich zumindest keine Probleme aber das Ding ist jetzt über 7 Jahre alt und selbst die PCIe Schrauben sind ausgeleiert…
Evtl. bleibe einfach vorerst beim Case. Gibt ja genug andere ähnlich Builds. Da passiert hoffentlich nichts.
Ja so ähnlich schlimm wie bei dir siehts aus. Ich drück uns die Daumen. :d
Äußerst schlau von Asus die Schläuche an der Seite anzubringen... 🤦‍♂️
Cablemod hasst diesen Trick. XD
Wäre auf jeden Fall interessant, wozu dieser Anschluss in Zukunft so in der Lage sein wird und ob er auch eine 4090 bzw 5090 ausreichend füttern können wird.
weshalb nicht gleich ein 420 radi :d ... finde ich optisch auch nicht so der burner :(
Unter 1.600! Über Geizhals reingehen!
Edit: Und weg...
In Sachen Abstand zur Backplate könnte es mit dem Wireview wohl eher zu Inkompatibilitäten kommen als wie mit dem CableMod-Adapter:
Schön zu sehen das die Anschlüsse des Wireviews vernünftig sind. Da dürfte nix kokeln
@c64user
Aber der Ausschnitt gehört doch jetzt zu einer der Buchsen beim CableMod-Adapter, oder?
Beim Wireview-Adapter schauts mit dem blosen Auge betrachtet aber tatsächlich anders aus als beim CableMod. Ich bin aber noch nicht dazu gekommen, mir das genauer anzusehen.
Verdammt bald ist die ja unter 1500€ zu haben... Glaube muss die schleunigst wieder verkaufen und die Kohle für eine RX 8900 XTX zurücklegen...
Nächste wird defintiv wieder eine AMD Karte. Nicht, dass ich unzufrieden wäre aber den Mehrpreis für Raytracing zahle ich nie wieder. Von mir aus kann AMD komplett auf Raytracing verzichten. Ich brauche kein Raytracing und schon gar kein Path Tracing. Mir reichen einfach nur schön scharfe texturen. Licht und Schatten und krasse Reflexionen sind mir ebenso vollkommen Latte, musste ich nun feststellen. Ein Metroid Prime Remastered fand ich zB einfach nur extrem geil und gelungen. Solche Spiele müssen auch gar kein Raytracing oder sonstiges bieten, wenn die sich einfach nur phänomenal gut spielen gut völlig gut aussehen ohne den ganzen zusätzlichen Schnick-Schnack und da gibt es noch viele weitere Beispiele die komplett bestens ohne auskommen und verdammt geil aussehen, wie auch TLOU.
Mache es bei den meisten Spielen eh off, da ich es nicht einsehe dafür mehr Strom herzugeben und die Leistung zu drosseln, auch wenn DLSS es teils wieder rausholt, ist es einfach nicht meins! Ich hab Nvidia ne Chance gegeben aber nein, ich gehe wieder zu AMD in der nächsten Gen.
Hauptsache effizient, nicht unnötig überteuert wie Nvidia und gut im Rastern, das reicht mir vollkommen aus. Zudem möchte ich auch weiterhin, wahrscheinlich noch über 10 Jahre bei 120Hz LG OLEDs bleiben also benötige ich auch nicht mehr als 120 bzw 118 FPS bei 120Hz in 4k! 💯
Äußerst interessant... Naja meine Gigabyte RTX 4090 Gaming OC läuft ebenfalls NIE über 60°C, da undervolted und mit einem zusätzlichen Lüfter auf der Backplate im Nacken "drangeklebt".
Zudem begrenze ich meine FPS immer bis 115 FPS maximal bei 120Hz. Aber wegen der Technik und dem Look schon wirklich ein Leckerbissen...
Ich hab jetzt noch etwas genauer drauf geschaut.
Tatsächlich haben die Buchsen beim Wireview 2 Schlitze:
Und hier der CableMod-Adapter:
Auf den ersten Blick ging ich hier davon aus, das es nur 1 Schlitz ist.
Aufgrund der sichtbaren Versätze könnte es aber sein, dass es auch dort 2 Schlitze sind:
Ob man dort diese Seiten verschweißt hat?
Warum da beim Wireview so viele Partikel zu sehen sind, kann ich nicht sagen.
Ich hab beide Adapter eigentlich gleich behandelt.
Die sehen irgendwie beide kacke aus. Glückssache ob der Kontakt gut ist oder nicht. Mein Seasonic sieht definitiv sauberer verarbeitet aus.
Auf den Bildern sah es erstmal besser aus, hatte aber nie ein Wireview Adapter in der Hand.
Nachricht gelöscht
Darf man mal ein Bild davon sehen? Hab auch so etwas vor (in Kürze 3-tägige Sommerlanparty im 30°C warmen Raum mit 25 Rechnern) und schaue mir gern etwas ab.
Bläst der drauf oder davon weg?
Zeige ich dir gerne heute zu Hause. Bin noch bis 17h arbeiten dann im Gym.
Wird man nur leider relativ schlecht sehen können. Ist ein Arctic P12 Lüfter, sind ja schön schmal. Habe ich mit 4 kleinen Klegebepads an den Ecken befestigt. Hält sehr gut und befördert die aufgewärmte Luft gut nach außen, bei mir nur leider zur 420er AiO aber die scheint es nicht groß zu kümmern. Nutze ja auch das Raijintek Paean Benchtable horizontal aufgestellt als Case. Die GPU steht demnach senkrecht sowie die AiO ebenfalls direkt dahinter nach den RAM Kits.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
