[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Du polterst hier immer schön weiter Deine Agenda raus, irgendwo muss Asus Dir mal den Schnuller geklaut haben, anders lässt sich das doch nicht mehr erklären.
Und dir sollte man den Schnuller wieder zurück geben, damit Ruhe einkehrt. Es ging überhaupt nicht um Asus, also was blubberst du da jetzt rum?
Ich antworte auf das Geblubber auch nur, weil dieses Video ein Beispiel zeigt, wo überall Qualitätsunterschiede versteckt sein könnten, die man als User erstmal gar nicht so wahrnimmt. Ich sage nicht dass die Gigabyte Karten nun alle unten brechen, aber vielleicht sollte man einfach mal diese "alle karten sind gleich" Nummer etwas runterfahren.
Natürlich sind alle Hersteller gleich, weil die alle irgendwo ihre Probleme haben und hatten. Der einzige Unterschied steckt im Marketing, denn da ist Asus ganz weit vorne mit Hardware an sogenannte "Influenzer" zu verteilen.
Bei der Spannungsversorgung wurde es ja schon mehrfach aufgezeigt. Aber nun vielleicht auch beim PCB?
Das einzige was das Video zeigt, ist dass das Gigabyte PCB 2mm dick ist und das Asus PCb 1,6mm. Jeder der bissl Ahnung von Technik und Mechanik hat, dem ist sofort klar, dass das Asus PCB nicht wabbelt, weil da ne Schraube direkt drüber montiert ist... aber da geht der heilige Jay überhaupt nicht drauf ein. So kann man ganz schnell völlig inkompetenten Mist verbreiten.
Aber wenn dann auch noch Lüfter, Kühlerkonstruktionen und die Spannungsversorgung einfach besser sind, darf ne Karte schon etwas mehr kosten. Wenn einem das egal ist, dann einfach bei der günstigsten zugreifen und glücklich sein, genau so cool. Es sind jedoch definitiv nicht alle Karten gleich.
Alles rein subjektiv, denn das sind reine Behauptungen, da diese nirgends mal ansatzweise irgendwo belegt wurden.
Du magst gerne Asus, dann ist das so. Andere mögen halt Hersteller X. Jeder soll das mögen was er will. Nur artet das hier immer in, der Hersteller ist voll scheiße und der andere Hersteller ist gottgleich aus.
Auch Asus ist nicht überall scheiße, nur ist deren Verhalten in letzter Zeit nicht kundenorientiert, das haben ja mittlerweile ja auch paar der heiligen YTer festgestellt. Aber zu deiner Beruhigung, auch alle anderen Hersteller bekleckern sich hier und da nicht unbedingt mit Ruhm.
Und wenn das mit Gigabyte stimmt was der heilige Jay da berichtet, dann ist das auf der gleichen Ebene wie Asus, nämlich scheiße für den Endkunden... und darum geht's. Die Hersteller bewegen sich immer mehr und mehr in eine Richtung, weg vom Kunden. Produkte werden teurer, die Qualität schlechter und wenn es Probleme gibt, versucht man es dem Endkunden anzuhängen.
Würde diese Zotac nehmen. https://geizhals.de/zotac-gaming-geforce-rtx-4090-amp-extreme-airo-zt-d40900b-10p-a2815650.html
Die hat ein 24 Phasen Design mit den leiseren Spulen die auch auf den Ref. Karten sind .
Ist kein Ref PCB, das hat nur Inno3D.
Kannst du nicht lesen ?
Es handelt sich um die Spulen die auch auf dem Ref. Karten verbaut werden.
Habe nicht geschrieben das Zotac das Ref. Design verwendet für die Karte.
Love is in the air .....
Ist doch völlig egal wer was kauft wen das Geld da ist soll jeder kaufen was er will.
Ich für meinen Teil finde das jetzt ruhig die 5090 kommen kann .
Da NV anscheinend meint die 4090 TI so spät bringen zu müssen falls überhaupt dann können die sie behalten.
Hatte ja die Hoffnung für Ende Mai aber EOL Brauch ich mir später auch keine mehr holen .
Prächtige Idee ich eröffne dann auch parallel schon mal den Verfügbarkeits thread. :d
Und schon sind die Schiris wieder da bevor es überhaupt richtig rund ging. Da war ich schon auf Beerdigungen, die witziger waren. Lächerlich.
Träum weiter - träumen darf man ja 😂
4090 ist drei Quartale auf dem Markt und ist unangefochten an der Spitze.
Nvidia hat sämtliche Ressourcen vom Geforce Sektor in den KI Sektor verfrachtet und Gaming als Nebengeschäft erklärt.
In 10 Jahren will man die heutige Leistung der KI um den Faktor 1.000.000 übertreffen.
Ja es ist langweilig geworden da hilft nur träumen. :wink:
Rein aus der Leistungs Sicht ist fast egal welche 4090 man verbaut OC Leistungzuwachs ist in 4 K auch überschaubar.
Doch schon so früh...? :d
Was ich gehört hab, dass in Zukunft bis zu 90% der Arbeitsplätze, in Verwaltungen wegfallen könnten. Das ist schon unheimlich (wenn es wirklich so kommt)
Unheimlicher finde ich jedoch künstliche Juristen (Richter, Anwälte etc)
btw:
Wegen Spulen-Düdelei...
Glücklicherweise stört es mich nicht so. Zumal es mir bei Benchmarking völlig egal ist. Da ist der Mora - der Chiller mit 0,8PS-Kompressor sowieso - viel lauter :fresse:
Und beim Gaming trage ich ANC-Kopfhörer. Aber auch da ist die ASUS leiser, als bei Benchmarking, da ich je nach Game auf bis zu 50% PL (von 666W ausgehend) runtergehe
(Dead Island 2 sogar nur 40% PL bzw. max 215W Board Power Draw, bei durchgehend 120Hz - 4K - Ultra-Grafiksetting)
Hab mich bewusst für die TUF entschieden, weil die viel günstiger, als die Suprim war und ich annahm, dass es mehr Blöcke dafür gibt und für mich einfacher zu modden ist (ausreichend viele Lötpunkte für so ziemlich alles). Dass es noch eine dritte 4090 wurde (Strix OC), war nicht geplant. Aber der Preis war einfach zu gut... :)
Sofern auf der Karte Strix seht, vollkommen korrekt :d
Hatte ja eine Strix OC hier im ...im OC ging die glatte 15 MHz mehr als meine FE .
Da für hat meine Strix aber geheult als wen das Teil jemand verprügelt hätte.
Die FE ist da viel zurückhaltender.
Die Master war muxmäuschen Still.
@Thunderburne
Zwischen Suprim und Strix hab ich leider keinen Vergleich, da die Suprim direkt wieder zurückging
Bin mit bis zu 3.210MHz GPU (ohne Mod) und bis zu +1.950MHz VRAM unter Wasser sehr zufrieden
Ja die gaming oc war bei mir sogar fast unhörbar im offenen Gehäuse. Hab aber die singende suprim behalten da Sie zum Kauf Zeitpunkt gleichviel gekostet hat, wertiger ist und ingame über 3000mhz läuft.
@Thunderburne
Wow 3210 ist krass meine suprim läuft nur bis 3160mhz im 3d Mark unter Luft
@Thunderburne
So viel Glück hätte ich selbst bei 10 Karten nicht.
Aber mich stört es nicht beim Gaming in 4K tut sich da wen man 70FPS hat eh kaum was mit OC.
Punkte schön und gut.
Ach so ne TUF hatte ich ja auch noch hier die hab ich wohl verdrängt den das Teil klang wie Motorschaden :ROFLMAO:
Ich bin nach master TUF Strix bei der FE für 1850€ geblieben und bereue die Entscheidung nicht.
also zusammenfassend ihr seid euch uneinig ? (ich hab mich nun schon bissl umgeschaut, scheinbar sind alle gpus der 4000er reihe mit spulenfiepen behaftet) :unsure:
deswegen frag ich euch ja hier :)
zum thema alphacool , ich hatte 3 pumpen , mehrere fittinge , 3x aio -> das alles war nur billiger scheiss , das einzige was die können ist radiatoren
die suprim x hab ich gewählt wegen den 3 jahren garantie , erlaubten lüfterwechsel und guten wiederverkaufswert
beim thema wasserkühler ist man halt limitiert - ich bin nicht bereit ekwb 1cent in den rachen zu schieben , watercool hat leider keinen passenden kühler , alphacool (siehe oben) ... da bleibt ja nicht mehr viel ...
am liebsten wär mir watercool gewesen ...
Hatte bisher auch den Eindruck, dass Alphacool "Billigramsch" produziert. Die Radiatoren die ich von denen habe, sind billig, dünn und ungleichmäßig lackiert, sämtliche Kühlerlamellen waren verbogen und das billige Herstellerlogo war schief aufgeklebt.
Der Aurora Wasserkühler von denen, für die Suprim X, spielt aber qualitativ in einer anderen Liga. War erstaunt wie gut der verarbeitet ist. Gefällt mir optisch und leistungsmäßig deutlich besser als der von Phantek und ist zudem günstiger als Phantek/EK.
Bin von der 4090 MSI Suprim X auf die 4090 Asus Strix gewechselt Aber nicht wegen der Geräuschentwicklung. Beide Karten hochwertig verarbeitet, die Asus allerdings für mich mit dem absoluten Killerdesign.
Bin von der 4090 Asus Strix auf die 4090 MSI Suprim X gewechselt. Aber nicht wegen der Geräuschentwicklung. Beide Karten hochwertig verarbeitet, die MSI hatte für mich das bessere Gesamtpaket. Zum Kaufzeitpunkt 150€ günstiger und mehr Glück beim OC im Vergleich zur Strix. Meine Suprim ist minimal leiser als die Strix war. Einziger Vorteil der Strix waren die 2x HDMI. Ist sonst bisschen blöd, wenn man 2 TV`s als Monitore betreiben will.
Ich musste schmunzeln, als ich das Video gestern sah. Das einzige was das Video zeigt, ist dass Jay nicht messen kann. Wenn man genau hinschaut, sieht man, dass er bei der Gigabyte auch 1,6mm PCB-Stärke misst.
Das augenscheinlich stabilere PCB der Asus kommt, wie du bereits sagtest, von der Kühlerbefestigung in der unmittelbaren Nähe.
Aber bei den einen ist das Risiko wesentlich höher als bei anderen.
Gibt einige Karten, wo man gut Chancen hat, dass sie leise sind und das sind nicht die Karten von MSI oder Asus. ;)
hm okay, ich schau mir das erstmal an , zurückschicken kann ich ja immernoch
fakt ist das ich die gpu nicht in mein case bekommen wenn ich nicht auf wasserkühlung umbau , ich hab max 30cm platz und die karte ist 33cm mit stock kühler und nur 26cm mit wasserkühler
das aussehen spielt ja auch eine rolle - für mich sieht der alphacool echt billig aus und der phantek hochwertiger (am ende aber geschmackssache)
joa das hab ich mir auch schon durchgelesen
hat jemand die 4090 supreme x und kann mir sagen welcher von beiden passt ?
müsste eigentlich der "normal" sein oder
Versteht jmd die Antwort?
TBC
to be confirmed (wird noch bestätigt, also scheinbar noch nicht ganz raus)
Sollte der "normale" sein.
Die Sens Pins an der Suprim Buchse sind auf der Backplate Seite.
Du schreibst eine Scheisse, es ist immer wieder ein Fest. Es gab schon einige Videos zu den Spannungsversorgungen und den Unterschieden, die müssen jetzt hier nicht zum x-ten mal gepostet werden. Aber alles was Deiner Agenda entgegen steht, ist für Dich natürlich subjektiv. Dabei bist Du der einzige der noch gar nix beigetragen hat außer seinem "alles Scheisse" Geblubber.
Keiner hat gesagt dass einige Karten Scheisse sind. Nur dass es Unterschiede gibt. Und da ist nix subjektiv lol. Die springen einem sofort ins Auge, wenn man die Kühler abnimmt.
Und wenn die Gigabyte PCBs brechen, obwohl sie dicker sind, das wär das schon ziemlich peinlich. Ist am Ende aber auch wie gesagt irrelevant, nur eben ein Beispiel für die zum Teil sehr unterschiedlichen Konstruktionen der Karten. Asus hat zwar mit den Spulen dieses mal komplett ins Klo gegriffen, aber wenn ich mir anschaue, wie stümperhaft die Lüfterkabel bei der PNY verlegt sind, ist es kein Wunder dass bei vielen einer gar nicht funktionierte. Und wenn die Lüfter bei Zotac und Konsorten brummen wie n alter Schiffsdiesel kann man schon davon ausgehen, dass da n bisschen mehr gespart wurde bei den Lagern etc..
Aber sowas wissen eben nur Leute, die die Karten Zuhause hatten, auseinander genommen und ihre Erfahrungen hier geteilt haben, anstatt alles aus der Ferne anzuzweifeln und ständig Leute anzumachen, die sich mehrere Karten bestellt haben.
Wie es bei der Windforce ist weiß ich nicht, aber ich kann mir nicht vorstellen dass das PCB Bruch Problem bei der 4090 Gaming OC besteht, wenn man den mitgelieferten Winkel/Halter verwendet. Leider passt der nicht bei allen Mainboards. Aber wenns passt, dann ist die Konstruktion recht stabil, wenn auch merkwürdig anmutend. Weglassen würde ich den aber nicht. Die ganze Karte verlässt sich auf das Ding.
Und ja, Gigabyte wird versuchen sich mit irgendwas aus einem Garantiefall rauszuwinden. Das Internet ist voll mit entsprechenden Berichten. Was MSI, Asus & Co machen weiß ich nicht. Gigabyte ist aber dafür berüchtigt.
Ähnliche Themen
