[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Geforce Experience = bloatware - zieht leistung ohne ende und telefoniert nach hause
ich mein generell für games (fps,latenzen)
Ich finde den aktuellen und den davor recht gut. Das mit den Latenzen ist so eine Sache. Mit dem DPC Latency Tester hast du massiv Latenzen. Spätestens wenn die VRAM Clockrate umspringt. Die merkt man aber in Spielen nicht. Und ich spiele auch gerne Fightgames, da wäre jede Latenz schon deutlich wenn da eine wäre.
ABER irgendwas haben die seit dem letzten Treiber anders gemacht. Wenn dein System nicht richtig stabil ist, kommt es schneller zu Abstürzen. Nicht dass du dich hinterher beschwerst.
Bei Amazon hast öfter nur zwei Jahre Garantie, da einige Hersteller Garantie dann nur gegenüber Amazon geben.
Wenn man also eine Karte länger als zwei Jahre nutzen möchte ist Amazon nicht unbedingt der beste Reseller.
Habs so gemacht Asus Karte mit 3 Jahren Garantie .
Teil registriert und beim Asus Store gekauft .
Ob wenn was ist mehr davon habe beim Asus Store gekauft zu haben müsste ich dann sehen.
Hoffe natürlich nicht . Bisher ist mir auch noch keine Graka kaputt gegangen.
Letzte mal wo was über die Zeit kaputt gegangen ist war ein Asrock Mainboard Sockel A.
Da haben sich die Kondensatoren aufgebläht . Sonst halt mal Probleme mit einem Asus Monitor der aber ein Serienfehler hatte PG27AQ .
Da haben sich sowohl Asus wie auch Alternate vorbildlich verhalten oder von Amazon mein aktuelles 7000D mit defekter Scheibe erhalten, aber auch da hatte sich
Amazon und Corsair cool verhalten^^. Lediglich mit Coolermaster bzw. CK hatte ich mal wegen ein Case ein Problem und dies war nicht schön gelöst worden von CK .
War aber halt schon defekt geliefert worden und schon lange her.
Sonst CPU´s , Rams , Mainboards , Grakas etc. halten bei mir Jahrzente.
Da ich manches auch weitergebe in der Familie , weiß ich daher , dass die Sachen bis heute noch laufen, aber klar kann jeden mal treffen.
Die Waterfurz hat ja den Vorteil, dass sich aufgrund des deutlich geringeren Gewichts des Kühlers (gegenüber Lukü oder FC) der phyische Stress aufs PCB in Grenzen halten dürfte.
Jetzt haben wir doch tatsächlich ein pro AIO Argument aufgetan, wenn auch auf Gigabunt beschränkt. :oops:
Super witzige Namen hast Du da immer für Hersteller und Produkte. Alles selbst ausgedacht?
hatte gigabyte nicht probleme mit brechenden pcb's ?
Aufpassen! die 3080 und 3090 von GB sind dafür recht bekannt. Problem dabei: sie hatten noch kein Anti Sag Bracket dabei und es wurde auch lt. Handbuch keines verlangt. Meine 4090 Gaming OC hat bestimmt nicht ohne Grund so einen Metallwinkel als Anti Sag Bracket dabei. GB wird das Problem schon kennen. Wer den bzw. überhaupt keinen Anti Sag Bracket nutzt und horizontal verbaut, der braucht sich nicht wundern.
Die Frage ist aber ob andere Marken sich da anders verhalten. Wobei ich kein Gigabyte Fan bin und mir schon bewusst ist, dass Gigabyte das ausnutzt um auch andere Garantiefälle direkt mal abzubügeln.
Bei den GB 3080 und 3090 fallen auch gerne mal die Speicher wegen Überhitzung aus. Und komischerweise ist die 4090 Gaming OC eine der Karten mit den bestgekühlten Speichern... warum wohl?
Die kennen die Schwachpunkte ganz genau, sagen aber nix dazu. Seid vorsichtig mit Gigabyte Hardware. Wenn alles in Ordnung ist sei es drum. Aber hofft nicht darauf dass eure "Garantie" was wert ist wenns drauf ankommt. Wobei... wie sind da die anderen? Vermutlich auch nicht anders.
Um ehrlich zu sein, vor 10+ Jahren hatte ich mal zwei AMD Karten, da ist jeweils der VRAM hops gegangen (war dann auch meine letzte AMD), bei beiden innerhalb der ersten Monate. Mir ist noch nie eine Grafikkarte wegen Alter kaputt gegangen. Meine noch aktuelle ist jetzt auch über 4 Jahre alt und läuft einwandfrei.
Tja, Garantie iss futsch... :haha:
Vielleicht das Video mal an Caseking weiterleiten😉🙊.
Ich denke auch, dass Gigabyte genau weiß, wo die Probleme ihrer Produkte liegen. Leider beheben sie diese anscheinend nur nicht immer so gerne (z. B. Thema Lüftersteuerung). Wenn ich mir die Konstruktion meiner RTX 4090 Aorus Master mit labiler 2er-Slotblende, ohne stützenden Metallrahmen und samt dünner, nicht vollständig gefalteter Backplate betrachte, dann würde ich mich nicht wundern, wenn diese auch irgendwann Probleme machen könnte. Mein Karte ist ab Werk sogar leicht durchgebogen beginnend ab Slotblende bis Screencooling-Ausschnitt. In manchen YouTube-Videos sieht man auch gelegentlich eine mehr oder weniger verbogene Backplate im Bereich der Seitenumrahmung des "Screencoolings". Meine weist das auch auf. Wenn auch nur leicht.
Andere Hersteller wie MSI oder Asus verbauen seit Generationen nicht umsonst einen zusätzlichen Metallframe, der mit der Slotblende verschraubt ist und gemeinsam mit der Backplate das PCB stützt und die Last besser verteilt.
mal die 4090 etwas im dschungel ausführen :d
Video und Download
Ich hoffe, dass ich es noch erlebe solche Videos Games (in 4K und höher) mal in VR zu sehen. Der Unterschied von 24, 27, 32 (oder gar mehr) zu VR ist extrem. Auch wenn man auf 85" zocken würde
Das Gefühl, wenn man bei Resident Evil nachts im „kalten“ Wald steht, ist brutal :asthanos:
Das offene Fenster im Winter verstärkt den Effekt "kalter Wald" nochmals :-[
Ich würde mir "Dead Island" zukünftig auch für VR wünschen. Wenn hinter einem diese extrem aggressiven "Schlachter" (Butcher) herlaufen, gäbe das noch einen ziemlichen Kick
Aber ob meine "Pumpe" das noch mitmacht...? :d
Endlich mal was zum Speicher Testen, habe Rainforest und Burning Forrest Demo auf Anschlag parallel laufen lassen, 22GB GPU Speicher Auslastung.
Wo bekommt man diese Demos eigentlich her?
Das Tropical sieht ja Mal echt schick aus in dem Video?
Du kaufst ja auch nicht die Demo sondern die Assets - ist nicht dafür da das du benchmarkst.
Jemand ne idee wo man 10GB hochladen kann? :)
Google Drive
Will nächste Woche diese Karte bestellen:
Die wird vermutlich ebenso einen Power Adapter nutzen? Ist das noch ein Thema oder nur bei der FE von NVidia selbst?
Wie ist eigentlich so die Erfahrung beim untertakten, geht ihr da einfach auf Power Limit 350w und gut oder gibt es da noch mehr Spielraum um noch mehr Leistung/Watt raus zu kitzeln?
Besser per UV 👍🏻
Nimm dir den Curve Editor von AB.
Bei 0.9v den Takt auf 2650mhz und schauen ob es stabil läuft 😃
Edit: Jap die nutzt ebenfalls den 12vhpwr Adapter. Kontrolliere einfach das dieser sauber steckt und eingerastet ist.
Der Curve Editor von AB ist nicht mehr bugged? Hab gelesen, dass der die Einstellungen nicht behält, aber das waren ältere Beiträge von Anfang des Jahres, wurde eventuell bei neueren AB Versionen gefixt?
Ja, über die Adapter hab ich mich mal etwas mehr informiert, Hauptproblem scheint kein richtiger Sitz zu sein. Die aktuellen Adapter brennen aber nicht mehr durch wie bei den ersten der 4090 FE die stark bemängelt wurden wegen zu schwacher Leitungen?
0,875 @ 2550 und Speicher +1000 ist der "sweet Spot" den eigentlich jede 4090 Karte schafft.
Bei Spielen DLSS einschalten, auch wenn man es eigentlich nicht braucht, spart ordentlich Energie.
FPS über das NVIDIA Control Panel begrenzen ist ebenfalls ein quick win.
Alles zusammen hat man keine außerhalb von Benchmarks spürbaren Leistungsverluste, aber dafür ein deutlich kühleres Zimmer. Und man spart 30-50% Stromkosten.
Das klingt gut, sind ein paar gute Tipps, die ich auf jeden Fall ausprobieren werde. Wenn OV mehr bringt als rein die Watt zu begrenzen, werde ich mir das definitiv ansehen.
Ich beschränke mich nur auf absenken von PL mit möglichst hohem Takt
Damit ist die FPS-Vola moderater, als mit zusätzlichem UV (ist ja auch logisch)
Nebenbei weniger aufwändiger, als dieses Curve-Herumgezerre :d
@Hoto
Zum einstellen habe ich es so gemacht das ich im Hintergrund Heaven(Alternativ Kombustor) laufen hab lassen und an der Stelle wo man die wenigsten Frames hat(Meist beim Drachen) die Szene einfach angehalten.
Jetzt kann man per Afterburner einstellen und schauen wie die Wattzahl bzw. die FPS sich verhalten. Danach kann man immer noch per 3DMark schauen ob es stabil läuft, geht so halt schneller um grob auszuloten was Min/Max möglich ist.
Exakt so hab ich es auch gemacht 👍🏻
Hab leider ne schlechtere erwischt.
2550mhz plus 1000mhz RAM at 0.9v
Dafür aber super silent das Teil
Edit: mit 2600mhz läuft Port Royal durch aber BF2042 schmiert damit ab.
Deshalb hab ich den Takt etwas reduzieren müssen
Ähnliche Themen
