[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Korrekt und es ist für jede Firma ja auch ratsam, die eigenen Produkte möglichst DAU sicher zu machen um eben derartige Kontroversen zu vermeiden.
Am Ende bleibt jedoch, dass man auch seine Lovelace Karte mit dem 12vhpwr Stecker sehr sauber mit dem Netzteil verbinden kann, wenn man es denn möchte. Da braucht es keine Steckerrevision für.
Überlege mir so ein Kabel für mein Netzteil zu holen, habe aber ein bequiet Straight Power 10 und laut der bequiet Webseite ist das Kabel für deren 11er und 12er Serie, wobei ich mir bei dem Stecker an der Netzteil Seite recht sicher bin, dass das auch bei mir passen würde. Bei Mindfactory kostet das Kabel 15 Euro, finde ich in Ordnung, und da steht auch nichts mit welchen bequiet Serien das Kabel kompatibel ist, meine Vermutung daher: pure Irreführung auf der bequiet Webseite, weil sie dort auch nur noch ab der 11er Serie Netzteile auflisten. :P
Zuerst schreiben sie allerdings:
Und mein NT ist natürlich ein ATX 2.4. :unsure:
ACHTUNG! Niemals nie einfach Kabel tauschen nur weil sie passen, gibt Hersteller die haben intern andere Belegungen, kann ziemlich schief gehen. Am besten Layout vergleichen.
Ich meine hier hatte damals zu 4090 Anfangszeiten jemand BQ angeschrieben und die haben gesagt, dass das Kabel vom Layout her auch zu älteren Netzteilen passt. Würde da aber nochmal genauer nachforschen und die ggf. selbst nochmal anschreiben
Ist ja alles bequiet. Und ich bezweifle, dass ein Hersteller so dumm ist die Belegung direkt am Netzteil selbst zu ändern aber den Stecker nicht zu ändern, das wäre mehr als fahrlässig. Dennoch würde ich erst mal im Internet nach weiteren Infos suchen, aber im Moment bin ich nur eines: absolut pleite. Hat also noch Zeit. :d
"Ist ja alles Bequiet" ist ja das Problem, die lassen auch nur fertigen und das 10er und die 11er kommen meines Wissens nach von einem anderen Hersteller.(Haben ja diverse 10er, kann also auch anders sein)
Aber Bequiet hat ganz gute Handbücher da steht alles drin. Hatte selbst mal alte Kabel früher und dachte die wären von dem Netzteil was ich einbauen wollte. War zumindest kein Billigheimer und die Schutzschaltung hat mich dann gerettet.
Ja, informieren ist immer besser als einfach ausprobieren. Und stimmt, ich hatte nicht dran gedacht, dass nicht jeder NT Hersteller ihre NTs auch selbst produziert.
Hat Cablemod inwzischen irgend ne Refund policy wenn man den Adapter nicht mehr nutzen will, oder werden die erst aktiv wenn es zu spät ist. Außerdem, hat hier jemand die 90° Kabel von denen im Einsatz? Sehen für mich nach guter Alternative aus, Optik ist mir egal.
Onboard GPU for the WIN! :)
Ich habe in Rome Total War 2 ziemlich heftige (häufig auftretende) black Screens. In anderen Games wie W3 oder Division 2 ist alles In Ordnung. In ForzaH 5 kommt es sehr selten vor.
Und zwar wird der Monitor für eine Sekunde schwarz, zeigt dann wieder das normale Bild (in Game, also kein Crash) und ich kann weiter zocken. Anhand von ausgeführten Aktionen und dem Sound ist auch klar, dass das Game normal weiter läuft. Wenn das Bild wieder da ist, sehe ich auch kurz die Statusanzeige des Monitors, so als ob er sich neu mit der DP/HDMI Source verbunden hätte, also wie wenn man die Quelle wechselt.
Dieses Problem trat mit der Inno 4090 oder anderen Karten jedoch nicht auf. Ich habe alle DP und HDMI Anschlüsse ausprobiert, es ist überall das gleiche. Weiter bin ich in der Fehlersuche allerdings noch nicht gekommen.
Kann das mit irgendwelchen inGame Einstellungen zu tun haben, die sich vielleicht mit gsync beißen oder so etwas? Habe allerdings nix verändert zur Inno, außer gleich den neuen Treiber installiert.
Da der Sound weiter läuft tippe ich darauf das dieser nicht über NVIDIA Audio ausgegeben wird?
Wenn das Game danach wie gehabt weiter läuft, dann denke ich es könnte ein Treiber Reset sein.
Mit DDU plus neu Installieren hast du schon probiert?
Korrekt, habe Aktivboxen per USB dran. Weiß gar nicht ob die ihren eigenen Treiber haben oder das über den Realtek läuft. Aber ich könnte die Ausgabe natürlich mal über NVidia laufen lassen, einfach um zu sehen ob er dann auch stockt.
DDU hab ich schon Jahre nicht mehr benutzt, vielleicht probier ich das mal.
Edit: heute Vormittag nach 1h zocken kein einziges Mal passiert. Oh man ey
Würde es einfach mal mit DDU und nem frischen Treiber testen.
Denke nicht das es ein Hardware defekt ist da kein Crash to Desktop oder Freeze geschweige denn Reboot vom System.
Deine Aktiv Boxen werden ja mit nem eigenen Treiber per USB versorgt.
Ganz wichtig immer nur eine Sache ändern um wirklich zu verstehen woran es lag. Änderst du nun den Treiber inkl Sound Konfiguration dann weißt du nicht woran es nun lag 👍🏻
Habe hier und da den selben Shice. Das passiert völlig willkürlich, ingame wie auch am desktop. Das BIld ist dann für ca 3s schwarz, der PC rennt aber normal weiter. Als ob das Bild-Signal zum Monitor kurz abreißt und der Monitor sich neu connected mit der Graka. Je nachdem wie schnell das ein Monitor macht, sind es 1s wie bei dir oder 3s bei mir.
Dann gibts Phasen wo 2-3 Wochen oder nen Monat das Problem nicht auftaucht und dann ballert es 7x am Tag sowas raus. Ich habe bei mir eher die Verkablung in Verdacht. Die ist bei mir etwas "kompliziert" mit Adaptern und Zwischenkabeln wegen vertical GPU Verbau, die Graka steht komplett im Gehäuse, also auch das Slotblech ist im Gehäuse und nicht an der Rückwand des Gehäuses:
Ich hatte das Problem auch mit der Vorgänger Graka und bei entsprechend "komplizierter" Verkabelung sowie mit dem Vorgänger-Monitor auch.
Obs aber wirklich die Verkabelung ist, habe ich auch noch nicht erforscht.
DDU habe ich auch noch nicht probiert.
Hab ich absolut nicht… wenn Bild da ist, ist Bild ohne Aussetzer da.
Nutze Monitor und TV jeweils durchgehend mit 1.78 DLDSR.
Aber ja, DDU hilft manchmal echt Wunder.
Was auch sein can, ist, dass es am Energiesparmodus liegt, fallt mir spontan ein. Bin aber gerade zu faul für langwierige Nachforschungen, vorallem weil mal tagelang oder wochenlang Ruhe ist, aktuell ist wohl so ne Phase am Start. :o
Eventuell mache ich mal DDU am Abend.
Habe ein ähnliches Problem. Allerdings im Desktop Betrieb. Für 2 Sekunden habe ich einen Black Screen. Das kommt aber eigentlich nur vor wenn ich Fenster maximiere oder aus dem Hintergrund hole. Beim Gaming überhaupt keine Probleme damit. Habe deswegen schon Windows neu installiert. Treiber mit DDU gelöscht. Neues Kabel gekauft. Monitor resettet. Hat alles nichts gebracht. Jetzt habe ich mal nen anderen DP Anschluss genommen. Bis jetzt habe ich ruhe.
Wackelt mal ein bisschen an euren Monitor Kabeln und schaut ob ihr diese Signal Aussetzer provozieren könnt.
Hatte sowas bei mir mit ner 3080TI und da lag es am Kabel (HDMI), weil das kein 2.1 Kabel war sondern nur 2.0 und die Bandbreite nicht geschafft hat, die von der Graka als Output kam.
Also erstmal danke für die vielen Beiträge zum Thema, scheine ja nicht der Einzige zu sein.
Es ist aber wie verhext, heute vormittag wirklich alle Games und Lastszenarien probiert, keine Black Screens. Obwohl ich weder an Treibern noch an der Hardware irgendwas verändert habe.
Das macht die weitere Fehlersuche natürlich erstmal schwierig. Werde mit dem DDU Deinstall aber noch warten, bis es wieder auftaucht.
Ich hasse so etwas wirklich und wünsche das Niemandem. Ich hatte auch schon PC Probleme, die sich wegen schwerer Reproduzierbarkeit über ein halbes Jahr hin streckten (RAM Defekt, der sich erst spät finden ließ).
Vielleicht hast ja Glück und es bleibt nun weg. :d
Hast du unter-/übertaktet? Wenn ja, könnte es natürlich auch daran liegen.
Alles 100% Stock. Kein Undervolting, kein OC. Bin da inzwischen sehr strickt. :fresse:
Cablemod says that their 90 degree 12vhpwr cables never melted. It is definitely a good alternative.
Ist irgendwas im Eventlog vom Eventviewer?
Übertakten macht ja auch keinen Sinn mehr. Hat man mal den ersten Platz, ZACK kommt Holzmann mit seiner Speerspitze um die Ecke und man kann einpacken. Macht echt keinen Sinn mehr ;)
Ähnliche Themen
