[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja ist halt auch nur ne werbefigur mittlerweile.der vontent von ihm ist seit wochen wenn nicht Monaten absolut nichts mehr interessantes sondern lediglich unboxing etc..
Wow, was geht denn auf dem Cablemod-Subreddit ab? Ein wahrhaftes Schmelzfest innerhalb der letzten Stunden. Es wird sogar schon über eine Class Action gesprochen.
Feine Sache oder?
Fasgear Kabel still going strong, auch nachdem ich das schon viel zu oft aus und eingesteckt habe nach den paar Board und 4090 Tauschaktionen :d
Auch seit Tag 1 der vor nem halben Jahr war.
Regelmäßig 450-550 Watt drüber, nix an verschmolzenen Material zu sehen.
Ich kann das kaufmännisch null beurteilen. Keine Idee wie hoch die Materialkosten für so ein Ding aktuell sind. So ein Adapter scheint von der Konstruktion und Komplexität aber eher einfacher?
Das Corsair Kabel ist jedenfalls, obwohl nur zwei Stränge und für 600W freigegeben, völlig ohne Probleme. Da schmort nichts. Zum Glück.
Naja, wenn man sieht, dass man die Adapter trotz einrasten 1-2mm raus ziehen kann, sprich dieser Riegel zum einrasten zu lang ist, dann muss man sich schon an den Kopf fassen. Nach dem einrasten mit dem beiliegenden Adapter war da kein wirkliches Spiel mehr bei mir, da müssten schon stärkere Kräfte dran zerren (wie wenn das Seitenteil stark dagegen drückt) damit das ein Problem wird. Allerdings, nach dem hier die letzten Tage bekannt wurde, dass die Rev2 Stecker/Buchsen bereits im Umlauf sind und ich meine Karte ja noch keine Woche habe, bin ich mir nicht 100% sicher ob ich noch den alten habe. Kann aber gerade nicht nachgucken. :unsure:
Der Adapter scheint jedenfalls eine Fehlkonstruktion zu sein.
Ich glaube eher, dass man sich übernommen hat. Der Stecker von NVidia ist halt nicht perfekt. Die Kabelpeitsche allerdings funktioniert problemlos, so auch bspw. Mein Kabel von Seasonic. Der Adapter bietet aber viel Spielraum für eine schiefe Montage, so dass die Enden des Steckers dann doch wieder unsauber sitzen. Und auf Grund der Größe kommt man auch schlecht an den Stecker selbst bzw. kann ihn gar nicht gut genug einsehen.
Naja und dann war das Ding auch noch so teuer. Sie haben dann relativ schnell bekannt gegeben, dass sie betroffene Karten ersetzen bzw. reparieren lassen. Warum sollten sie das tun, wenn NVidia klar der Schuldige ist?
Alles ziemlich Banane. Bin jedenfalls froh kein Geld dafür rausgeschmissen zu haben und für ein paar Kröten einfach das Seasonic Kabel genommen zu haben. Selbst das Fasgear war von guter Qualität.
Sind diese Kabel denn so viel besser als der beiliegende Adapter?
Für mich waren es zwei Faktoren
1.) Platzverbrauch, die 4 schwänzige Peitsche + 4x8 Pin Kabel bis zum Netzteil. Das trägt auf und gibt im blödesten Fall noch Windschatten.
2.) Anzahl der Steckverbindungen. Beim Adapter hast du eben noch zusätzlich die Anschlüsse bei denen der Adapter in die normalen Stromkabel geht. Das entfällt beim direkten Kabel.
Das Cablemod 3x8 Pin zu 12VHPWR Kabel braucht für den 600W Betrieb einen 8 Pin weniger als die Adapterpeitsche. Neben Platz & Optik ein wichtiger Vorteil. (imo)
Ein Netzteil mit einem direkten 12VHPWR Stecker/Kabel wäre meine letzte Wahl.
Thermalright TFX oder Alphacool Apex für die 4090? (Die Apex hat Igor empfholen, daher frag ich besser :)
Bei mir tatsächlich die erste Wahl. Marken-Netzteilhersteller traue ich eine gewisse Kompetenz zu.
Habe ich auch gedacht und dann hat sich das Dark Power 13 vom Chef mit einem Knall verabschiedet. :fresse2:
Zudem kommt noch die Tatsache dazu, dass man den Stecker mit leichtem Zug lockern und somit das berüchtigte Problem sogar Netzteilseitig begünstigt. Möchte ich mir nicht antun bis das Thema geklärt ist.
Dann liegt das an BQ. Bei Seasonic ist das Kabel aller erster Güte und der Stecker sitzt bombenfest.
Seasonic ist hammer - stimme ich dir zu. Mein Season *hust* Corsair AX850 läuft auch einwandfrei. Wird mal Zeit, dass sie ein High End Modell mit der neuen Technik rausbringen. Bisher gibts nur die billigen Vertex Gold Modelle.
Dürften ziemlich ähnlich sein. Persönlich kenne ich davon nur die Apex. War auf der CPU etwas sehr zäh/fest, das könnte aber auf der GPU richtig gut sein. Die TFX hatte ich persönlich noch nicht. Deshalb tue ich mich da schwer.
Bei der Apex nicht erschrecken. Der erste Test wird wahrscheinlich schlechte Temperaturen bringen, weil sie sich da anpasst und in Form bringt. Nach Abkühlung und erneutem Test sollte es besser sein.
Die Apex lässt sich imho richtig scheiße verteilen. Ich schwöre ja nach Jahren immer noch auf die olle Noctua NT-H1. Ja, damit hat man gegenüber den krassesten High-End Pasten nen Grad mehr, aber die lässt sich stressfrei verarbeiten und ist auch noch relativ günstig.
Thanks! Werde berichten.
Vielleicht ist doch etwas suboptimal an den Cablemod Adaptern? Ich weiß es nicht, aber ich finde es auffällig, dass es diese Adapter trifft. Über die originalen Peitschen oder Netzteilkabel lese ich irgendwie nichts.
Wenn man bewegliche Kabelbuchsen nicht an ein Kabel crimpt, sondern starr auf eine AdapterLeiterplatte lötet, muß man sich nicht wundern, das sie nicht immer die vom Hersteller klassifizierte Belastungsspezifikation mehr erbringen können.
Zumindest kannst du gut wiedergeben was du so liest.(Sorry aber jeder Kommentar ist irgendwie ein Echo was so andere von sich geben, ohne Hintergrund Wissen, bischen Erfahrung schadet nie)
Jede Verbindung sollte für den den geeigneten Zweck dienen, löten ist in dem Fall eigentlich besser, dürfte auch nichts mit dem Problem zu tun haben.
Das Problem ist der Übergangswiederstand aufgrund der Kack Befestigung. Bei den Kabelmod Teilen hast du eben noch einen größeren Hebel. Das Zurücksetzen der Sense-Pins ist nur eine Notlösung da die dann eher die Karte nicht starten wenn das Kabel nicht ganz drin ist.Der Stecker ist ganz einfach eine Fehlkonstruktion.(Für diese Art von Verbindung) Schau dir mal Stecker aus der Automobilindustrie an, da werden die teilweise beidseitig gesichert vor verrutschen bzw. fehlerhafter Montage.
Bei meiner 3080 hatte ich die PCIE Kabel einfach angelötet da Gigabyte mal wieder must gebaut hatte.
Nun, ein Auto fährt auch rum und steht nicht auf/unter dem Tisch. Das da in Autos ganz andere Streckverbindungen genutzt werden, ist daher nur logisch.
Stimmt. Müsste der 12VHPWR Stecker Beschleunigungen in diverse Richtungen sowie Erschütterungen oder gar massive Temperaturunterschiede abkönnen, wäre er sicher anders gemacht worden. Wobei ich Autos kenne deren Steckverbinder das auch nicht wirklich erfüllen. Aber das ist wieder was anderes.
Trotzdem ist die Geschichte mit den verkürzten Sense Pins ein guter Schritt. Einfach weil es einen Betrieb verhindert bei dem die Steckverbindung zu lose ist. Interesant wird es wenn es zu Unterbrechungen im laufenden Betrieb kommt, weil jemand einen "Wackelstecker" hat. Ich denke bis man da drauf kommt wird wieder wild gesucht werden.
Ich denke auch dass die Spur von Igor W. dass es auch teilweise mit den Temperaturen zu tun hat die von der Platine auf den Stecker wirken, nicht so ganz falsch ist. Auch EVGA hat damals in dem Video zusammen mit Gamers Nexus die Ansicht vertreten dass sie nicht verstehen warum der Stecker dort sitzt wo er sitzt, weil das einer der heißesten Stellen auf der Platine ist. Aber gut. Muss man jetzt mit leben und darauf schauen dass man soviel Effekt wie möglich wegnehmen kann als Anwender. Denn sonst hat man am Ende die *rschkarte.
Warum werden die da wohl so gesichert? Weil die Dinger ihr leben lang durchgeschüttelt werden. In einem PC ist das nicht der Fall, und daher ist so eine Sicherung auch nicht notwendig. Der Stecker könnte sicherlich "optimaler" sein, aber er ist keine Fehlkonstruktion. Zeit meines PC Builder Lebens prüfe ich jeden! Stecker, egal ob Lüfter 3 pin oder Mobo24 pin drei mal nach dem Einstecken, ob er richtig sitzt. Die Leute gehen einfach so sorglos mit sowas um. Dann noch die Größe der Karten, die dazu führt dass die Kabel/Stecker nach dem Einbau beim Schließen des Cases zusätzlich belastet werden usw.... sorry aber das ist einfach Fahrlässigkeit oder Dämlichkeit.
Richtig ist, dass der dicke Cable Mod Adapter einfach noch mehr Angriffsfläche bietet und sich somit wahrscheinlich eher verschiebt als ein Kabel.
Es geht nicht um den Unterschiedlichen Widerstand zwischen Löt- oder Crimp- Verbindung an den Kontakten(der ist fast gleich groß), sondern um die mechanische AUsrichtung zwischen Pin und Buchse. Eines von beiden muß beweglich sein, damit die volle Kontaktfläche zwischen Pin und Buchse zustande kommt. Wenn du einen Adapter auf Leiterplattenbasis an die Grafikkarte stöppsels, ist weder Pin noch Buchse beweglich. Ergo ist die Kontaktfläche(eigendlich sind es nur Kontaktpunke) zwischen Pin und Buchse manchmal nur noch halb so groß, weil Pin und Buchse sich nicht mehr exakt zueinander ausrichten können. Das wird einem auch sofort klar, wenn man mal eine Buchse aus dem Buchsengehäuse nimm, und sie auf einen nackten Pin steckst.
Ganz ähnliches Problem tritt auf, wenn das an der Buchse angecrimpte Kabel zu großen Aussendurchmesser hat. Dann kann sich der Buchsenkontakt im Buchsengehäuse auch nur sehr wenig bewegen(auf den Pin ausrichten).
DIe Verriegelung zwischen PinWanne und KabelBuchsenGehäuse hat mit den grundlegenden mechanischen Funktionsbedingungen zwischen Pin und Buchse nix zu tun, wenn man davon ausgeht, das der Anwender in der Lage ist das BuchsenGehäuse komplett in der PinWanne zu versenken.
So Jungs.
Karte auf Wasser umgebaut und getestet.
Kranke Performance im Vergleich zur 3090.
Ging mir eher um die zweckmäßige Verbindung, daher der Vergleich. Wie einige schon angemerkt haben wären ggf. 2 Haltenasen rechts und links besser um ein verschieben zu verhindern.
Aber der Fehler sitzt in vielen Fällen sicher auch vor dem PC :)
Ähnliche Themen
