DeathMetal
0815-was-so-läuft-Radio-Pop-Rock
OnePlus 2 und OnePlus X
Sammel- und Quatschthread
Willkommen im allgemeinen Sammelthread zum Nachfolger des vermeintlichen Flagschiff-Killers 2015 und 2016. Um den Thread zum Erstling freizuhalten, lasst uns uns hier austoben. Fragen, Meinungen zum Gerät und natürlich auch zum Thema "Invites" von nun an hier.
Daten zum Oneplus 2
Hardware- Color: Sandstone Black
- Dimensions: 151.8 x 74.9 x 9.85 mm
- Weight: 6.17 ounces (175 g)
- Operating System: OxygenOS based on Android 5.1
- CPU: 64-bit Qualcomm© Snapdragon™ 810 processor with 1.8GHz Octa-core CPUs
- GPU: Adreno™ 430
- RAM: 4 GB/3 GB LPDDR4
- Storage: 64 GB/16 GB eMMC v5.0 (available capacity varies)
- Sensors: Fingerprint, Accelerometer, Gyroscope, Proximity and Ambient Light
- Battery: Embedded rechargeable 3,300 mAh LiPo battery
- Max. SAR: Head: 0.795 W/kg, Body: 1.447 W/kg
Connectivity- Connectivity: (North America version)
- GSM: 850, 900, 1800, 1900MHz
- WCDMA: Bands 1/2/4/5/8
- FDD-LTE: Bands 1/2/4/5/7/8/12/17
- Wi-Fi: Dual-band Wi-Fi: 2.4GHz 802.11b/g/n and 5GHz 802.11a/n/ac
- Bluetooth: Bluetooth 4.1
- Positioning: Internal GPS antenna + GLONASS, Digital Compass
Audio- Speakers: Bottom-facing speaker
- Microphones: Dual-microphone with noise cancellation
Camera- Sensor: 13 Megapixel (1.3um)
- Lenses:6 lenses to avoid distortion and color aberration
- OIS: Yes
- Laser Focus: Yes
- Flash: Dual-LED
- Aperture: f/2.0
- Front Camera: 5 Megapixel - Distortion free
- Video: 4K resolution video, Slow Motion: 720p video at 120fps
Multimedia- Audio Supported Formats: Playback: MP3, AAC, AAC+, WMA (v9 and v10), AMR-NB, AMR-WB, WAV, FLAC, WAV, OGG Recording: WAV AAC AMR EVRC QCELP
- Video Supported Formats: Playback: HEVC (H.265), H.264, MPEG-4, DivX, Xvid, MPEG-2, MP4, MOV, 3GP, AVI, MKV, ASF
- Recording: AVC
- Image Supported Formats: Playback: JPEG, PNG, BMP, GIF
- Output: JPEG
Display- Size: 5.5 inch
- Resolution: 1080p Full HD (1920 x 1080 pixels), 401 PPI
- Type: LCD In-cell
- Protection: Corning© Gorilla© Glass
Ports, Slots, Buttons & Indicators
[*]Ports:- Data & Charging: USB Type-C
- Audio: Jack 3.5mm
- Buttons: Power Button, Volume Rockers Alert Slider, Capacitive / On-screen buttons
- SIM: 2 slots - Nano SIM (DSDS)
- Indicators: 1 LED notification light (multicolored)
In the Box- 1x OnePlus 2
- 1x USB Type-C Cable
- 1x OnePlus 2 USB Power Adapter
How To: Invite Tauschen
- Tested and this works - just follow these steps.
Have a OnePlus account? Go to step 1.
Don't have a OnePlus account? Go to step 2 and skip step 6.
- 1) If you already have an account, go ahead and login before claiming your invite and change your email address to some other address. Hint: if you use gmail you can use + aliases. E.g. if you have one@gmail.com, you can use one+two@gmail.com.
- 2) Create a new account using the email address attached to your OPT invite.
- 3) Claim the OPT invite.
- 4) Change the email address on the new account with the invite to the recipient's email address.
- 5) Tell the recipient to claim their account (and invite) by using the 'Forgot your password' feature.
- 6) [ONLY IF YOU DID STEP 1] Go and log back into your original account and change the email address back to your normal address.
- All done!
Credits: subtletiger auf reddit
Keinerlei Gewähr, ob es funktioniert und ob die AGB von OPO da etwas gegen haben.
Viel Spaß
