PlayDoh Silverstone TJ 07 - with acrylic pipe
arg-ist
PlayDoh Silverstone TJ07
Anew worklog:
At this worklog ı use my old Silverstone TJ07. I call it as PlayDoh of the cases.I want to make 3 different cases from this case.
First worklog TJ07 V1
What I want to achieve are:
To combine front panel with the side window.
To install liquid cooling and achieving this via acrylic pipe.
To use a special distributor for water distribution as midplate.
To enlarge the case for radiators since it is not wide enough.
To stick some parts into the case to obtain a dynamic view
first 5.25 rotated
made a window at middileplate for water distributor
two 80 mm fan holes are used for pump and tops
The tops mounted on an alu plate
and the plate with tops mounted to the case
The pumps with modkit are sticked to the backpanel
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-900-d-case-p1-1002736.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/jumbo-case-997157.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/4-way-hdd-switcher-1033308.html
Worklog http://www.hardwareluxx.de/community/f143/self-made-cosmos-ii-clear-panel-1034027.html#post22531803
To mount PSU ı made a window at the top.
Made a mounting kit to mount psu.
To cover the hole spaces around MB made these parts with gromets.
made 2 X360 Rad stands for rad mounting
First meeting with acrylic pipes. I had worked before with glass pipes and Copper pipes.
But Acrylic was differnt. First experiments -how to measure -
Some tools to work. A plastic mieter box , a handsaw, and a file for the ends.
and some experiments to bend
İt was easy to bend L parts, but U and S parts was difficult.
Therefore I made m y bending table.
I can bend with different Radius and bend in 2 and 3 directions
and first experiments with acrylic pipes.
update
Looks good, but why don´t you cool your graphic?
clap the bend well?
I want to make a waterdistrubutor to this place as midplate
You have two ways to cut plexis
With CNC Router
or with CNC Laser
I used CNC laser
acrylic sheets from bottom to top.
No 1: 5mm milk White
No:2 10mm clear
No: 3 5mm clear
No: 4 2mm milk white
bonding acrylic sheets with cloroform.
dont use bits for metal use bits for wood..
You've got some pretty good Ideas ;)
The waterdistributor looks amazing. Pleas keep posting your updates
Fans were taken out to enlarge the case for 2x Thermochill 360 rads
I made a radiator shroud for fans and used a phobya 3x rad. Gril.
This was applied on the back cover.
Covered view of the case.
Lets call it Art. The Idea with the midplate is Awsome! Currently I dont Understand the Reason fot mounting the PSU this special way.
I am architekt, ı don t like buildings in rational forms.
Like these
ı like irrational and dynamic forms
of course ı like irrational and dynamic cases. my favorite case is Raven01
First ı planned pumps out of the case
To compansate these , ı mounted psu on the case
Ihave enough place for PSU in the case, if ı put it vertical , but these is my choice...
And strengthened with fanshroud out of the case and with flash shining theme
Back cover painted and finished.
Made a plexi cover for 5.25, that ı not use.,with flash shining theme. illuminated with led.
added some colors to the case...
Sorry..................viel arbeit, aber nix für mich. Schön ist anders!!
