PlayDoh Silverstone TJ07
Anew worklog:
At this worklog ı use my old Silverstone TJ07. I call it as PlayDoh of the cases.I want to make 3 different cases from this case.
First worklog TJ07 V1
What I want to achieve are:
To combine front panel with the side window.
To install liquid cooling and achieving this via acrylic pipe.
To use a special distributor for water distribution as midplate.
To enlarge the case for radiators since it is not wide enough.
To stick some parts into the case to obtain a dynamic view
first 5.25 rotated
made a window at middileplate for water distributor
two 80 mm fan holes are used for pump and tops
The tops mounted on an alu plate
and the plate with tops mounted to the case
The pumps with modkit are sticked to the backpanel
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-900-d-case-p1-1002736.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/jumbo-case-997157.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/4-way-hdd-switcher-1033308.html
Worklog http://www.hardwareluxx.de/community/f143/self-made-cosmos-ii-clear-panel-1034027.html#post22531803
Anew worklog:
first 5.25 rotated
OTHER WORKLOGS
