# ExpFavMenu - Configuration file.
http://www.skyrimnexus.com/downloads/file.php?id=3545
# This configuration file is used by the favoritesmenu.swf UI element to show
# what YOU want to see for the favorites menu. You can edit the config file
# manually with a text editor or using the Config GUI from the mod download
# page under miscellaneous.
# *** IMPORTANT ***
# This file IS required by the favoritesmenu.swf. If you need to delete this
# file, please also delete the favoritesmenu.swf file or replace it with
# another favorites menu mod. If you delete this file, the ExpFavMenu flash
# file WILL cause a crash to the desktop on opening the favorites menu. YOU
# HAVE BEEN WARNED.
# For more information about the format of this config, you should read the
# configuration manual located at:
https://bitbucket.org/theit8514/expfavmenu/wiki/Configuration
# This section is used by the Config GUI so it knows what version you have.
[FavoritesMenu]
Version=1.5
# This section mainly deals with the menu as a whole, such as position on screen and number of items.
[Menu]
X=275
Y=250
ItemCount=10
Width=150
PageUpDownPercent=75
BackgroundType=solid
BackgroundTransparency=50
BackgroundColor=1C1C1C
BorderTransparency=50,50,50,50
BorderColor=D8D8D8,D8D8D8,D8D8D8,D8D8D8
BorderWeight=3,3,3,3
CenterSelected=2
[Item]
HotKeyColor=0080FF
BaseColor=D8D8D8
BorderTransparency=0
TextAlign=left
Sort=1
EquipIconAlign=left
[Debug]
Enabled=0
