http://www.xtremesystems.org/forums/showthread.php?t=211476Tony schrieb:VALUE matters to us at OCZ, you all know we have a new SSD coming called Vertex which we are positioning as a high performance part; what you didn't know is we have also been working on a new budget/value part.
I get questions about Core V3 all the time, the drive I will talk about here was destined to be Core V3 but we decided it needed a new name...hence enter Apex
Now I am going to be very clear about this new drive and where we think it will shine and where we are positioning it.
Apex is based off Core V2...now before you all shout crappy Jmicron again please listen up. We wanted to bring a cheap fast drive to market, one for the hardware raid fanboys but also one for those who don't mind a little OS tweaking so they can run 1 drive in a laptop etc or run SB raid with 2 or more drives. The point here though is this drive will be very affordable.
I have been watching forums for 2 months now and hardware/software raid is starting to gain momentum, people are liking what they see with SSD on it.
so:
What we have done with Apex is create a drive with internal raid0
So what does this mean in terms of speed? Well it depends on the sata controller on your motherboard but I can tell you I saw 180+ (actually touched 200) reads and 140+ writes on ICH8m (OCZ DIY Laptop), and on my HP Pavillion 9000 which uses an NVidia chipset, I am seeing 140writes and 160+ reads. Now i can't run any write tests as im actually real world testing this drive every day for 10 hrs, my system here has had 50 to 80GB of data on it at various times over this week while I have been testing... so when I bench it i get what you guys will see..IE this drive is in use.
I will post the ATTO from this laptop for you all, remember i saw higher than this on ICH8m, final speed is very controller dependent hence why I have been cautious
To finish....we are positioning Vertex for performance OS use, Apex will and does work fine for OS use also although helping the drive with a few OS tweaks makes it shine...Its a value part, one for those looking to build 4 with hardware raid or 2 with SB raid or even 1 drive with a few tweaks if they are on a budget.
We think Apex is a good fast budget solution and will suit many people.
I hope this is OK with you guys, i have tried to be honest here..i love the drive, its in a 2 yr old laptop running vista32 and it flies.
Geizhals gibt mittlerweile 32MB Cache an. Könnte somit ganz ordentlich werden. Aber Liefertermine sind in den Shops auf 9.1. geschoben. Dauert wohl noch nen Monat eh was real ankommt.
flopper schrieb:what does internal raid0 mean?
Tony schrieb:2 nand controllers, 1 raid chip in 1 drive.
split the nand in 2...half to each controller and then raid the output in raid0 to sata. The controller on your board sees it as a standard drive.
Tony schrieb:no there is no cache on the raid controller.
Tony schrieb:the raid is on the drive, all you do is plug it into the board with a sata lead...no software is needed. Remember this is for 1 drive...if you use 2 and want to raid them you will still need to set raid on the motherboard
Also die Apex ist relativ sinnfrei in meinen Augen.
Supertalent wird die Ultradrive zu sehr attraktiven Preisen anbieten, die anders als bei OCZ nur unwesentlich über denen der aktuellen Generation liegen werden.
@TLLmeister
zum Masterdrive OX gibts einen eigenen Thread.
Kurz gesagt. So lange man keine Systemhänger hat, sollte man mit der Platte eigentlich recht glücklich werden. Systemhänger (Rechner reagiert 1-2 Sekunden gar nicht) kanns aber dort geben.
Wenns nicht unbedingt jetzt sein muss, dann warte noch erste Tests der neuen Generation ab. Die soll sich preislich im gleichen Rahmen aufhalten.
ciao Tom
Weiß jemand hier ob der Adaptec 2405 Raid Controller gut mit SSDs klarkommt? Bin ernsthaft am überlegen ob ich mir den für meine aktuellen und spätere SSDs anschaffen soll.
"Arschkauf" ist nix schlimmesEs gibt da irgendwie 2 Anbieter die ihren Sitz in "Leipzig" haben. Aber beide kommen mir nicht ganz koscher vor, weil sie "Afterbuy" unbedingt als Kaufabwicklung haben wollen.
Gilt jedoch nur für den Eee bzw. für andere Netbooks mit gleicher Leistung@ Morpog super vergleich!
Also mit MTRON kommt er garnicht gut klar.
Wenn du Lust und Zeit hast würde ich gerne noch diese Tests (von der Mobi) vom Desktop PC sehen.![]()
Habe gerade meine Mtron 3525 64GB in mein XPS M1530 (ICH8M) eingebaut und Windows 7 Beta installiert.
Ist gefühlt genau so flott wie meine 32GB aber Windows 7 ist an einigen Ecken noch einen Tick fixer. Ich mach gleich mal nen Bootzeit Test mit allen installierten Treibern.
Problem: Habe mal HD Tune angeschmissen und habe nen average read von gerade mal 75 mb/s. BIOS ist auf IDE und Rückschreibcache ist im Gerätemanager aktiviert.
Hat einer eine Idee wie ich sie an die 100mb nominell bekomme?
Die 32GB lag bei 95mb/s unter Vista.
