Versuch eines Virtualisierungs-Servers
Code:
<domain type='kvm'>
  <name>easyvdr</name>
  <uuid>859974db-5b49-56bd-69e3-502d75017b63</uuid>
  <memory>768000</memory>
  <currentMemory>768000</currentMemory>
  <vcpu>1</vcpu>
  <os>
    <type arch='i686' machine='pc'>hvm</type>
    <boot dev='hd'/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <pae/>
  </features>
  <clock offset='localtime'/>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/bin/kvm</emulator>
    <disk type='block' device='disk'>
      <source dev='/dev/vm/easyvdr'/>
      <target dev='hda' bus='ide'/>
    </disk>
    <disk type='file' device='cdrom'>
      <source file='/isos/EasyVDR-liveCD-0.6.08_beta(wolf).iso'/>
      <target dev='hdc' bus='ide'/>
      <readonly/>
    </disk>
    <interface type='bridge'>
      <mac address='54:52:00:1a:19:69'/>
      <source bridge='br0'/>
      <model type='rtl8139'/>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    <console type='pty'>
      <target port='0'/>
    </console>
    <input type='mouse' bus='ps2'/>
    <graphics type='vnc' port='-1' autoport='yes' keymap='de'/>
    <hostdev mode='subsystem' type='pci' managed='no'>
      <source>
        <address domain='0x0000' bus='0x04' slot='0x02' function='0x0'/>
      </source>
    </hostdev>
  </devices>
</domain>
Habe auch schon Qemu als Domäne und usr/bin/qemu-system-x86_64 probiert.
Code:
root@kvmserver:~# tail /var/log/libvirt/qemu/easyvdr.log
Failed to assign irq for "04:02.0": Operation not supported
Perhaps you are assigning a device that shares an IRQ with another device?
LC_ALL=C PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin /usr/bin/kvm -S -M pc -cpu qemu32 -m 750 -smp 1 -name easyvdr -uuid 859974db-5b49-56bd-69e3-502d75017b63 -monitor pty -pidfile /var/run/libvirt/qemu//easyvdr.pid -localtime -boot c -drive file=/dev/vm/easyvdr,if=ide,index=0,boot=on -drive file=/isos/EasyVDR-liveCD-0.6.08_beta(wolf).iso,if=ide,media=cdrom,index=2 -net nic,macaddr=54:52:00:1a:19:69,vlan=0,model=rtl8139 -net tap,fd=20,script=,vlan=0,ifname=vnet3 -serial pty -parallel none -usb -vnc 0.0.0.0:2 -k de -pcidevice host=04:02.0
char device redirected to /dev/pts/4
char device redirected to /dev/pts/5
info cpus
* CPU #0: pc=0x00000000000ffff0 thread_id=3027
cont
mit libvirt ist es irgendwie schwieriger.
bau dir mal ein Start-Script wie meins hier und starte so deine VM, dann gehts eventuell
Konsole:
/usr/bin/qemu-system-x86_64: invalid option -- '-pcidevice'
/var/log/syslog:
Jul 24 20:56:54 kvmserver kernel: [ 3678.288051] pci-stub 0000:04:02.0: restoring config space at offset 0x1 (was 0x84000000, writing 0x84000003)
Jul 24 20:56:54 kvmserver kernel: [ 3678.288070] pci-stub 0000:04:02.0: PCI INT A disabled
Jul 24 20:56:54 kvmserver kernel: [ 3678.289852] br0: port 4(vnet3) entering disabled state
Jul 24 20:56:54 kvmserver kernel: [ 3678.290741] device vnet3 left promiscuous mode
Jul 24 20:56:54 kvmserver kernel: [ 3678.290744] br0: port 4(vnet3) entering disabled state
Hier das Skript:
#!/bin/sh
/usr/bin/qemu-system-x86_64 \
-m 512 \
-smp 2 \
-name easyvdr \
-hda /dev/vm/easyvdr \
-boot c \
-vnc :3 \
-k de \
-net nic,model='rtl8139' \
-pcidevice host=04:02.0 \
Wenn ich /usr/bin/kvm eintrage kommt das:
was spuckt "/usr/bin/qemu-system-x86_64 --help" für eine Versionsnummer aus?
welche kvm-Version hast du drauf (modinfo kvm)?
Das hier hab ich dazu gefunden:
If the device support MSI, msi2intx=1(default value) would resolve the sharing
interrupt issue. So seems the device didn't support MSI...
http://markmail.org/message/nj6nh5s...ugh+page:1+mid:ivl3bfvhrr22dl4h+state:results
Das hier:
root@kvmserver:/usr/src/linux# /usr/bin/qemu-system-x86_64 --help
QEMU PC emulator version 0.10.0, Copyright (c) 2003-2008 Fabrice Bellard
root@kvmserver:/usr/src/linux# modinfo kvm
filename: /lib/modules/2.6.31-rc3-hp200709/kernel/arch/x86/kvm/kvm.ko
license: GPL
author: Qumranet
srcversion: C4D346F1FB84C8B5FA488B7
depends:
vermagic: 2.6.31-rc3-hp200709 SMP mod_unload modversions
parm: oos_shadow:bool
root@kvmserver:/usr/src/linux# kvm | head -1
QEMU PC emulator version 0.9.1 (kvm-84), Copyright (c) 2003-2008 Fabrice Bellard
kompilier dir mal die qemu 0.10.5 ins System, vielleicht gehts damit
gerne, wenn Du mir sagst wie, da häng ich schon länger dran, würde auch gerne die kvm-88 nehmen, aber ich hab leider noch keine Ahnung wie ich Module richtig update
runterladen, auspacken, "./configure --prefix=/usr , make, make install"
Code:
root@kvmserver:/usr/src/qemu-0.10.5# ./configure --prefix=/usr
./configure: 925: pkg-config: not found
Install prefix    /usr
BIOS directory    /usr/share/qemu
binary directory  /usr/bin
Manual directory  /usr/share/man
ELF interp prefix /usr/gnemul/qemu-%M
Source path       /usr/src/qemu-0.10.5
C compiler        gcc
Host C compiler   gcc
ARCH_CFLAGS       -m64
make              make
install           install
host CPU          x86_64
host big endian   no
target list       i386-softmmu x86_64-softmmu arm-softmmu cris-softmmu m68k-softmmu mips-softmmu mipsel-softmmu mips64-softmmu mips64el-softmmu ppc-softmmu ppcemb-softmmu ppc64-softmmu sh4-softmmu sh4eb-softmmu sparc-softmmu i386-linux-user x86_64-linux-user alpha-linux-user arm-linux-user armeb-linux-user cris-linux-user m68k-linux-user mips-linux-user mipsel-linux-user ppc-linux-user ppc64-linux-user ppc64abi32-linux-user sh4-linux-user sh4eb-linux-user sparc-linux-user sparc64-linux-user sparc32plus-linux-user
gprof enabled     no
sparse enabled    no
profiler          no
static build      no
-Werror enabled   no
SDL support       no
curses support    yes
mingw32 support   no
Audio drivers     oss
Extra audio cards ac97 es1370 sb16
Mixer emulation   no
VNC TLS support   no
kqemu support     yes
brlapi support    no
Documentation     no
NPTL support      yes
vde support       no
AIO support       yes
Install blobs     yes
KVM support       no - (#error Missing KVM capability KVM_CAP_DESTROY_MEMORY_REGION_WORKS)
fdt support       no
The error log from compiling the libSDL test is:
/tmp/qemu-conf--8503-.c:1:17: error: SDL.h: No such file or directory
/tmp/qemu-conf--8503-.c: In function ‘main’:
/tmp/qemu-conf--8503-.c:3: error: ‘SDL_INIT_VIDEO’ undeclared (first use in this function)
/tmp/qemu-conf--8503-.c:3: error: (Each undeclared identifier is reported only once
/tmp/qemu-conf--8503-.c:3: error: for each function it appears in.)
ERROR: QEMU requires SDL or Cocoa for graphical output
To build QEMU without graphical output configure with --disable-gfx-check
Note that this will disable all output from the virtual graphics card
except through VNC or curses.
root@kvmserver:/usr/src/qemu-0.10.5# ./configure --prefix=/usr --disable-gfx-check
Install prefix    /usr
C compiler        gcc
Host C compiler   gcc
ARCH_CFLAGS       -m64
make              make
install           install
host CPU          x86_64
host big endian   no
gprof enabled     no
sparse enabled    no
profiler          no
static build      no
-Werror enabled   no
SDL support       no
curses support    yes
mingw32 support   no
Audio drivers     oss
Mixer emulation   no
VNC TLS support   no
kqemu support     yes
brlapi support    no
Documentation     no
NPTL support      yes
vde support       no
AIO support       yes
Install blobs     yes
fdt support       no
/tmp/qemu-conf--8641-.c:1:17: error: SDL.h: No such file or directory
/tmp/qemu-conf--8641-.c: In function ‘main’:
/tmp/qemu-conf--8641-.c:3: error: ‘SDL_INIT_VIDEO’ undeclared (first use in this function)
/tmp/qemu-conf--8641-.c:3: error: (Each undeclared identifier is reported only once
/tmp/qemu-conf--8641-.c:3: error: for each function it appears in.)
Mal abgesehen von den anderen Fehlermeldungen will er ja auch keinen KVM-Support, was stimmt denn da wieder nicht... vlt. muss ich erstmal kvm updaten ?
ne klappt auch nicht:
Code:
Error: libpci check failed
Disable KVM Device Assignment capability.
Install prefix    /usr
Source path       /usr/src/kvm-88
C compiler        gcc
Host C compiler   gcc
ARCH_CFLAGS       -m64
make              make
install           install
host CPU          x86_64
host big endian   no
target list       x86_64-softmmu
tcg debug enabled no
gprof enabled     no
sparse enabled    no
strip binaries    yes
profiler          no
static build      no
-Werror enabled   no
SDL support       no
curses support    yes
curl support      no
mingw32 support   no
Audio drivers     oss
Mixer emulation   no
VNC TLS support   no
VNC SASL support  no
kqemu support     no
xen support       no
CPU emulation     yes
brlapi support    no
Documentation     no
NPTL support      yes
vde support       no
AIO support       yes
IO thread         no
Install blobs     yes
-e KVM support       yes
KVM trace support no
fdt support       no
preadv support    no
make:
In file included from /usr/src/kvm-88/kvm/kernel/x86/trace.h:355,
                 from /usr/src/kvm-88/kvm/kernel/x86/x86.c:83:
include/trace/define_trace.h:53:43: error: arch/x86/kvm/trace.h: No such file or directory
make[4]: *** [/usr/src/kvm-88/kvm/kernel/x86/x86.o] Error 1
make[3]: *** [/usr/src/kvm-88/kvm/kernel/x86] Error 2
make[2]: *** [_module_/usr/src/kvm-88/kvm/kernel] Error 2
make[1]: *** [all] Error 2
make: *** [kvm-kmod] Error 2
root@kvmserver:/usr/src/kvm-88# ls /usr/lib/libpci*
/usr/lib/libpci.so.3 /usr/lib/libpci.so.3.0.0
hab ich alles installiert, configure jetzt ohne Fehler, bei make kommt jetzt:
CC [M] /usr/src/kvm-88/kvm/kernel/x86/x86.o
qemu:
Install prefix /usr
C compiler gcc
Host C compiler gcc
ARCH_CFLAGS -m64
make make
install install
host CPU x86_64
host big endian no
gprof enabled no
sparse enabled no
profiler no
static build no
-Werror enabled no
SDL support yes
SDL static link yes
curses support yes
mingw32 support no
Audio drivers oss
Mixer emulation no
VNC TLS support no
kqemu support yes
brlapi support no
Documentation no
NPTL support yes
vde support no
AIO support yes
Install blobs yes
fdt support no
mit dem 2.6.31er Kernel hab ich keine Erfahrung, in einem meiner Links einen Post weiter oben steht eine eventuelle Lösung drin
probier mal den 2.6.30er Kernel, vielleicht klappts da besser
Danke für die Links, ist mir ja unangenehm, aber wie krieg ich denn die Diffs jetzt verarbeitet ? :confused:
ja ich versuch auch mal den 2.6.30er
ok, wird kompiliert, dann wohl morgen weiter... danke schonmal für die Hilfe!
qemu und kvm sind jetzt upgedatet, Kernel ist 2.6.30.2, funktioniert auch alles soweit, konnte nur noch kein passthrough testen weil ich nun Probleme mit dem Bridging habe und den ganzen Tag daran sitze. Es soll ein Gast zwei Karten bekommen (bisher br0 und br1 in der .xml eingetragen) und die anderen alle nur eine (br0). Ich schaffe es maximal dem IPCop die zwei Karten zuzuweisen (tap0 und tap1), die anderen bekommen dann zwar eine aber es gibt keine Verbindung ins Netz. Zum Glück funktioniert parallel auch libvirt mit der alten qemu. Ich hoffe nicht beim nächsten Bug angekommen zu sein...
HeY
wollte bei kqemu installen für die Full Virt.
bekomme den fehler :
Zeus:/tmp/kqemu-1.4.0pre1# make
make -C common all
make[1]: Entering directory `/tmp/kqemu-1.4.0pre1/common'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/tmp/kqemu-1.4.0pre1/common'
make -C /lib/modules/2.6.26-2-amd64/build M=`pwd` modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.26-2-amd64'
make[2]: *** No rule to make target `/tmp/kqemu-1.4.0pre1/kqemu-mod-x86.o', needed by `/tmp/kqemu-1.4.0pre1/kqemu-mod.o'. Stop.
make[1]: *** [_module_/tmp/kqemu-1.4.0pre1] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.26-2-amd64'
make: *** [kqemu.ko] Error 2
hat wer ne idee ?
Und die header installiert?
Sorry btw, dass ich mich so lang nich gemeldet hab, hatte keine Zeit :( und heute auch nich, danach bin ich in wacken, aba daaanach gehts hier weiter ;)
wie header ?
Hiern Log :
Zeus:/tmp# cd kqemu-*
Zeus:/tmp/kqemu-1.4.0pre1# ./configure
Source path /tmp/kqemu-1.4.0pre1
C compiler gcc
Host C compiler gcc
make make
host CPU x86_64
kernel sources /lib/modules/2.6.26-2-amd64/build
kbuild type 2.6
make -C common all
gcc -Wall -O2 -Werror -g -D__KERNEL__ -I.. -o genoffsets genoffsets.c
./genoffsets > monitor_def.h
gcc -D__KERNEL__ -nostdinc -iwithprefix include -I. -I.. -D__ASSEMBLY__ -c -o x8 6_64/nexus_asm.o x86_64/nexus_asm.S
gcc -D__KERNEL__ -nostdinc -iwithprefix include -I. -I.. -D__ASSEMBLY__ -c -o x8 6_64/monitor_asm.o x86_64/monitor_asm.S
gcc -Wall -O2 -fomit-frame-pointer -fno-strict-aliasing -Werror -mno-red-zone - fno-stack-protector -fpic -D__KERNEL__ -nostdinc -iwithprefix include -I. -I .. -c -o monitor.o monitor.c
gcc -Wall -O2 -fomit-frame-pointer -fno-strict-aliasing -Werror -mno-red-zone - fno-stack-protector -fpic -D__KERNEL__ -nostdinc -iwithprefix include -I. -I .. -c -o monitor-utils.o monitor-utils.c
gcc -Wall -O2 -fomit-frame-pointer -fno-strict-aliasing -Werror -mno-red-zone - fno-stack-protector -fpic -D__KERNEL__ -nostdinc -iwithprefix include -I. -I .. -c -o interp.o interp.c
ld -T x86_64/monitor.ld -o monitor-image.out x86_64/nexus_asm.o x86_64/monitor_a sm.o monitor.o monitor-utils.o interp.o
objcopy -O binary monitor-image.out monitor-image.bin
gcc -Wall -O2 -Werror -g -o genmon genmon.c
./genmon < monitor-image.bin > monitor-image.h
gcc -Wall -O2 -fomit-frame-pointer -fno-strict-aliasing -Werror -mno-red-zone - mcmodel=kernel -D__KERNEL__ -nostdinc -iwithprefix include -I. -I.. -c -o kernel .o kernel.c
gcc -D__KERNEL__ -nostdinc -iwithprefix include -I. -I.. -D__ASSEMBLY__ -c -o x8 6_64/kernel_asm.o x86_64/kernel_asm.S
ld -r -o ../kqemu-mod-x86_64.o kernel.o x86_64/kernel_asm.o
CC [M] /tmp/kqemu-1.4.0pre1/kqemu-linux.o
make[2]: *** No rule to make target `/tmp/kqemu-1.4.0pre1/kqemu-mod-x86.o', need ed by `/tmp/kqemu-1.4.0pre1/kqemu-mod.o'. Stop.
eventuell mal einen aktuelleren Kernel probieren, mit meinem 2.6.30er gibts keine Probleme
hab heute mal meine Windows-Gäste mit SuperPi gebencht.
Hab dabei feststellen müssen, dass es praktisch keinen Unterschied zwischen qemu und kvm gibt, was die Geschwindigkeit der CPU angeht.
SuperPi 4M:
qemu ohne kqemu: 1.42 min
qemu mit kqemu: 1.49min
kvm: 1.48min
Also ich hatte da nen -gefühlten- riesen Unterschied nach der Serverinst. also noch mit der 9er Qemu. Hatte in der xml die /usr/bin/qemu-system.. und /usr/bin/kvm probiert.
Bist Du sicher das qemu nicht doch irgendwo die Hardware-Virtualisierung herholt ? Wär ja irgendwie unlogisch.
Hast Du eigentlich Dein libvirt wieder am laufen ? War doch schon ganz praktisch damit. Ich bleibe zwar jetzt auch lieber bei den neuen Versionen und es laufen auch ein paar Gäste zuverässig aber die virsh fehlt irgendwie ...
also die Gäste ohne "PCI Passthrough" laufen mit libvirt ohne Probleme.
Mein VDR-Gast mit beiden DVB-Karten wird manuell gestartet, da es entweder mit libvirt nicht geht oder ich es nicht hinbekomme.
Die 9er qemu-version hab ich nie probiert, scheinbar holt sich qemu bei mir die Leistung irgendwie aus der Virtualisierungsoption der CPU, ich persönlich merk keinen Unterschied zwischen den verschiedenen Lösungen.
Ja, die cpu stimmt bei mir auch. Hast Du denn diese
QEMU PC emulator version 0.10.50 (qemu-kvm-devel-88), Copyright (c) 2003-2008 Fabrice Bellard
mit libvirt am Laufen? Ich habe libvirt noch nicht updaten können, Dein Tip hier im thread meldet mir irgendwas mit no anonymous user. Die jetzige libvirt bei mir ist 0.6.1 und damit bekomme ich immer Meldungen in der Art:
Connecting to uri: qemu:///system
error: Failed to start domain openqrm
error: internal error Cannot determine QEMU argv syntax /usr/bin/qemu-system-x86_64
Nehme an die libvirt ist zu alt.
Dieselbe xml funktioniert wenn ich /usr/bin/kvm stattdessen angebe, aber dann läuft kvm84 und nicht die 88
Ich mache das doch besser zu Fuß, mit libvirt funktioniert die snapshot Option nicht richtig. Man kann zwar bei virsh über ein extra Skript zusätzliche Startparameter an qemu übergeben, in meinem Fall -snapshot, aber der dazugehörige Befehl zum Speichern der Änderungen (commit all) muss im qemu Monitor ausgeführt werden. Den Befehl gibts bei virsh nicht, zumindest bei der 0.6.4 (die hatte ich fertig kompiliert für Ubuntu gefunden). Aufrufen konnte ich qemu-Monitor in Verbindung mit virsh garnicht.
Und wie siehts bei dir aus?
Bei mir gabs heute ein kleines Update, ein Asus P5E-VM D0 wurde eingebaut, da es laut Hersteller VT-d bietet.
Damit kann ich meine durchgereichten PCI-Karten im Gast auch nutzen, d.h. meine Test-WLAN-Karte findet nun auch Netze, was vorher ohne VT-d nicht möglich war.
Meine DVB-Karten im Gast haben nun auch ein Signal anliegen, also schein ich auf dem richtigen Weg zu sein.
OK, alles zurück. Das Board hat zwar VT-d, aber leider ist ein PCI-Slot belegt wegen doppelter IRQ-Vergabe, daher kann ich nur einen PCI-Slot durchreichen, was mir aber zu wenig ist. Also such ich mal weiter nach einem geeigneten Board.
Ok, morgen kommt ein DFI LANparty UT P45-T2RS, was 3 PCI-Slots hat und angeblich auch VT-d.
Hoffentlich funzt das besser wie das Asus P5E-VM D0.
Musste in der Richtung eine Pause machen aber mit meinem Board scheint es eh nicht zu gehen und ich kann das Problem umgehen in dem ich den Netceiver vom Gast-Easyvdr als DVB-Device nutze. Die Gäste (Clarkconnect, IPCop, Easyvdr, Win7) laufen aber alle sehr stabil und ich musste bisher einmal den Server neu starten, ansonsten keine Probleme. Echt klasse!
@Mirko, habe mir letztens QEMU installiert und wollte Kubuntu 9.10 austesten aber es bootet immer nur in einen Blackscreen, was mache ich falsch? :d
übrigens läuft der Server 2008 R2 da drauf? möchte den zum Spaß mal installieren (hab ja dank dreamspark eine gratis lizenz...)
edit: läuft unter QEMU auch 3D-Grafik? möchte nämlich KDE mit alle special effects mal ausprobieren
