e morgen ist die lange erwartete neue Firmware verfügbar:
Download:
WD HD TV Firmware WDTV_FW_1_01_01.
New Features:
Added .MKV chapter selection for video playback for MKV with chapter support
Added .MTS file extension support
Added .TP file extension support
Added .TS file extension support
Added 1080p 24hz support
Added disk volume name to folder navigation in list mode
Added EXIF orientation flag functionality for auto picture rotate
Added file size in filename
Added jump feature to the remote: While fast forwarding or reversing, if the “Next” or “Prev” buttons are pressed, video will jump 10 minutes in the respective direction
Added progress indicator for the duration of the FF or REV function
Added a blinking status LED behavior while drive is mounting; previously the light just stayed on
Added sequential .M2TS file playback function
Added additional subtitle support (SMI, SUB, ASS, SSA)
Added user selectable font size for subtitle support
Added song title scroll in music playback to prevent truncation
Added embedded subtitle display in .MKV files
Added additional subtitle encoding support for the following: Western Europe (ISO), Traditional Chinese (Big5), Simplified Chinese (GB18030), Japanese (Shift-JIS), Korean (EUC-KR), Cyrillic (Windows-1251), Cyrillic (KOI8-R), Greek (ISO); previously only UTF-8 was supported
Added display sizing menu for photo playback: Fit to Screen, Full Screen, Keep as Original
Added accelerating scroll speed based on how long the arrow is held down on the remote when navigating folders with a large number of files; previously only one, constant speed was available
WD TV™ HD Media Player 1.01.01 Firmware Release Notes 3
Resolved Issues:
Resolved issue when 2 drives were connected, then one drive was disconnected, the files from the disconnected drive still showed up on the file list but were not playable
Resolved "repeat one" failure during music playback; previously songs would not repeat
Resolved artist name truncation issue during music playback
Resolved issue where WD TV would not turn back on with remote after extended period of inactivity; previously WD TV had to be unplugged and was unrecoverable with the remote
Resolved image size and position issues during video playback; previously the image displayed did not fill the screen until the picture was zoomed in and then out again
Resolved info bar display issues in PAL (European display standard) mode
Resolved issue of the slideshow playing while in the Option menu during playback, slideshow now pauses if the Option menu is accessed
Resolved issues surrounding drives going to “sleep” and folders showing as empty; previously drives equipped with a sleep feature would not re-initialize before the WD TV timed out and displayed the folders as empty
Resolved issues with DVR-MS file playback, FF and REV now function properly; previously FF or REV during a DVR-MS file would cause the file to stop playing and the video signal to be lost
Resolved issues with forced resolution changes dropping video signal; previously the signal would be lost if the user switched between forced resolution and auto
Resolved photo self re-sizing issue; previously during photo playback the pictures would randomly re-size themselves
Resolved Status LED behavior by blinking to reflect accurate read cycles while data is being read; previously the LED just stayed on
Resolved subtitle default to “on” issue (subtitles now default to “off”, unless there is an external subtitle file created, then subtitles default to “on”)
Resolved subtitle position issue, the subtitles were moved down towards bottom of screen; previously during playback of some files subtitles were positioned too high blocking the view of the video
Resolved the 1-2 second FF during initial playback of .MPG video; previously video would play in what appeared to be FF for the first 1-2 seconds and then slow to standard play rate
Resolved video signal failure when pan function in video files with subtitles is used; previously subtitles would stop functioning, video would stop playing, or TV would lose signal
Resolved zoom issues while file info is displayed during video playback; previously signal would fail or video would stop playing
Resolved zooming issues while subtitles were on; previously the screen used to go black and the video would stop playing
LEUTE HAUT REIN.
gruß
truli
