Jan 1 00:00:15 WDTV-09cb5 syslog.info syslogd started: BusyBox v1.10.0
Jan 1 00:00:15 WDTV-09cb5 user.notice kernel: klogd started: BusyBox v1.10.0 (2009-02-15 05:09:42 CST)
Jan 1 00:00:15 WDTV-09cb5 user.notice kernel: Linux version 2.6.15-TvDock (william@SVN-server) (gcc version 4.0.4) #11 PREEMPT Wed Dec 24 17:28:32 CST 2008
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Configured for SMP863x (revision ES6+/RevA+), detected SMP8635 (revision ES9/RevC).
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Detected CPU/System/DSP Frequencies: 297.00/198.00/297.00MHz
Jan 1 00:00:15 WDTV-09cb5 user.info kernel: SMP863x/SMP865x Enabled Devices under Linux/XENV 0x48000000 = 0x00023efe
Jan 1 00:00:15 WDTV-09cb5 user.info kernel: BM/IDE PCIHost Ethernet IR FIP I2CM I2CS USB PCIDev1 PCIDev2 PCIDev3 PCIDev4 SCARD
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Valid MEMCFG found at 0x10000fc0.
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: CPU revision is: 00019069
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Determined physical RAM map:
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: memory: 06fe0000 @ 10020000 (usable)
Jan 1 00:00:15 WDTV-09cb5 user.debug kernel: On node 0 totalpages: 94208
Jan 1 00:00:15 WDTV-09cb5 user.debug kernel: DMA zone: 94208 pages, LIFO batch:31
Jan 1 00:00:15 WDTV-09cb5 user.debug kernel: DMA32 zone: 0 pages, LIFO batch:0
Jan 1 00:00:15 WDTV-09cb5 user.debug kernel: Normal zone: 0 pages, LIFO batch:0
Jan 1 00:00:15 WDTV-09cb5 user.debug kernel: HighMem zone: 0 pages, LIFO batch:0
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Built 1 zonelists
Jan 1 00:00:15 WDTV-09cb5 user.notice kernel: Kernel command line: console=ttyS0
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Primary data cache 16kB, 2-way, linesize 16 bytes.
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Synthesized TLB refill handler (20 instructions).
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Synthesized TLB load handler fastpath (32 instructions).
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Synthesized TLB store handler fastpath (32 instructions).
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Synthesized TLB modify handler fastpath (31 instructions).
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: PID hash table entries: 2048 (order: 11, 32768 bytes)
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Using 148.500 MHz high precision timer.
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Console: colour dummy device 80x25
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:15 WDTV-09cb5 user.info kernel: Memory: 107776k/114560k available (2635k kernel code, 6776k reserved, 392k data, 252k init, 0k highmem)
Jan 1 00:00:15 WDTV-09cb5 user.debug kernel: Calibrating delay loop... 291.84 BogoMIPS (lpj=145920)
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Mount-cache hash table entries: 512
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: Checking for 'wait' instruction... available.
Jan 1 00:00:15 WDTV-09cb5 user.info kernel: NET: Registered protocol family 16
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: tangox: creating TLB mapping for 0x20000000 at 0xc0000000, size 0x04000000.
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: PCI: Initializing SMP863x/SMP865x PCI host controller
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: PCI: Remapped PCI I/O space 0x58000000 to 0xc4020000, size 64 kB
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: PCI: Remapped PCI config space 0x50000000 to 0xc4004000, size 10 kB
Jan 1 00:00:15 WDTV-09cb5 user.warn kernel: PCI: Configured SMP863x/SMP865x as PCI slave with 128MB PCI memory
Jan 1 00:00:15 WDTV-09cb5 user.notice root: 1.03.01.WDLXTV-0.5.8.1
Jan 1 00:00:15 WDTV-09cb5 user.notice root: Displaying detected USB devices...
Jan 1 00:00:16 WDTV-09cb5 user.notice root: [13b1:0020] 1-1( 2.00,480m) Compact Wireless-G USB Adapter
Jan 1 00:00:16 WDTV-09cb5 user.notice root: [05dc:0300] 1-2( 2.00,480m) JUMPDRIVE GEYSR/00027D040201412
Jan 1 00:00:17 WDTV-09cb5 user.notice root: [0000:0000] usb1( 2.00,480m) TangoX USB 2.0/tangox-ehci-hcd
Jan 1 00:00:17 WDTV-09cb5 user.notice root: [0000:0000] usb2( 1.10,12m) USB Host Controller/TANGOX OHCI
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: PCI: Region size is 16384KB
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: PCI: Map DMA memory 0x10020000-0x17000000 for PCI at 0x11000000
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: SCSI subsystem initialized
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: usbcore: registered new driver usbfs
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: usbcore: registered new driver hub
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: Created /proc/cpucache_info entry.
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: NTFS driver 2.1.25 [Flags: R/O].
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: fuse init (API version 7.3)
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: Initializing Cryptographic API
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: io scheduler noop registered
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: io scheduler anticipatory registered
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: io scheduler deadline registered
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: io scheduler cfq registered
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: SMP86xx ir (254:0): driver loaded (wait_period = 300ms, buffer_size = 2)
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: SMP86xx led_rst (253:0): driver loaded.
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 9) is a 16550A
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: serial8250: ttyS1 at MMIO 0x0 (irq = 10) is a 16550A
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: loop: loaded (max 8 devices)
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: physmap flash device CS2: 1000000 at 48000000
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: CS2: Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: number of CFI chips: 1
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: Using physmap partition definition
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: Adding partition #1-#5
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: Creating 5 MTD partitions on "CS2: Physically mapped flash":
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: 0x00000000-0x00060000 : "CS2-Part1"
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: 0x00060000-0x00280000 : "CS2-Part2"
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: 0x00280000-0x00fc0000 : "CS2-Part3"
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: 0x00fc0000-0x00fe0000 : "CS2-Part4"
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: 0x00fe0000-0x01000000 : "CS2-Part5"
Jan 1 00:00:17 WDTV-09cb5 user.notice kernel: physmap flash device CS3: 4000000 at 4c000000
Jan 1 00:00:17 WDTV-09cb5 user.debug kernel: CFI: Found no CS3: Physically mapped flash device at location zero
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: driver tangox-ehci-hcd, 10 Dec 2004
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: TangoX USB initializing...
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: tangox-ehci-hcd tangox-ehci-hcd: TangoX USB 2.0
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: tangox-ehci-hcd tangox-ehci-hcd: new USB bus registered, assigned bus number 1
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: tangox-ehci-hcd tangox-ehci-hcd: irq 48, io mem 0xa0021500
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: tangox-ehci-hcd tangox-ehci-hcd: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: hub 1-0:1.0: 2 ports detected
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: TangoX USB was initialized.
Jan 1 00:00:17 WDTV-09cb5 user.warn kernel: Initializing Tango
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: X USB OHCI Controller Membase=0xa0021500, irq=47
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: tangox-ohci-hcd tangox-ohci-hcd: USB Host Controller
Jan 1 00:00:17 WDTV-09cb5 user.info kernel: tangox-ohci-hcd tangox-ohci-hcd: new USB bus registered, assigned bus number 2
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: tangox-ohci-hcd tangox-ohci-hcd: irq 47, io mem 0xa0021500
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: hub 2-0:1.0: USB hub found
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: hub 2-0:1.0: 2 ports detected
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: usb 1-1: new high speed USB device using tangox-ehci-hcd and address 2
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: usb 1-2: new high speed USB device using tangox-ehci-hcd and address 3
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 00:00:18 WDTV-09cb5 user.debug kernel: usb-storage: device found at 3
Jan 1 00:00:18 WDTV-09cb5 user.debug kernel: usb-storage: waiting for device to settle before scanning
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: usbcore: registered new driver usb-storage
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: USB Mass Storage support registered.
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: NET: Registered protocol family 2
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: TCP established hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: TCP reno registered
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: TCP bic registered
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: NET: Registered protocol family 1
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: NET: Registered protocol family 17
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: Freeing unused kernel memory: 252k freed
Jan 1 00:00:18 WDTV-09cb5 user.notice kernel: Vendor: LEXAR Model: GEYSER JUMPDRIVE Rev: 1.00
Jan 1 00:00:18 WDTV-09cb5 user.notice kernel: Type: Direct-Access ANSI SCSI revision: 01 CCS
Jan 1 00:00:18 WDTV-09cb5 user.notice kernel: SCSI device sda: 2014992 512-byte hdwr sectors (1032 MB)
Jan 1 00:00:18 WDTV-09cb5 user.notice kernel: sda: Write Protect is off
Jan 1 00:00:18 WDTV-09cb5 user.debug kernel: sda: Mode Sense: 23 00 00 00
Jan 1 00:00:18 WDTV-09cb5 user.err kernel: sda: assuming drive cache: write through
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: sda: unknown partition table
Jan 1 00:00:18 WDTV-09cb5 user.notice kernel: sd 0:0:0:0: Attached scsi removable disk sda
Jan 1 00:00:18 WDTV-09cb5 user.notice kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 1 00:00:18 WDTV-09cb5 user.debug kernel: usb-storage: device scan complete
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: cdrom: no version for "struct_module" found: kernel tainted.
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: cdrom: No versions for exported symbols. Tainting kernel.
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: llad: module license 'LGPL' taints kernel.
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: em8xxx [/home/andy/WDTV/house_1.03.01/src/libs/2.8.3.0/mrua_SMP8634_2.8.3.0_GCC4_dev.mips/MRUA_src/rua/emhwlib_kernel/kernel_src/krua.c:1463] init_module: begun
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: em8xxx0 [/home/andy/WDTV/house_1.03.01/src/libs/2.8.3.0/mrua_SMP8634_2.8.3.0_GCC4_dev.mips/MRUA_src/rua/emhwlib_kernel/kernel_src/krua.c:1346] identify: board as unknown subid
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: em8xxx [/home/andy/WDTV/house_1.03.01/src/libs/2.8.3.0/mrua_SMP8634_2.8.3.0_GCC4_dev.mips/MRUA_src/rua/emhwlib_kernel/kernel_src/krua.c:1449] identify: device 0x8635 0x86 accepted with software tango2revC
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: mumk_register_tasklet: (0) tasklet c403f000 status @c938aa24
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: em8xxx [/home/andy/WDTV/house_1.03.01/src/libs/2.8.3.0/mrua_SMP8634_2.8.3.0_GCC4_dev.mips/MRUA_src/rua/emhwlib_kernel/kernel_src/krua.c:1581] init_module: done. Found 1 em8xxx
Jan 1 00:00:18 WDTV-09cb5 user.warn kernel: loop: No versions for exported symbols. Tainting kernel.
Jan 1 00:00:18 WDTV-09cb5 user.info kernel: loop: loaded (max 24 devices)
Jan 1 00:00:18 WDTV-09cb5 user.notice crazyboot: /dev/mtdblock2: LABEL="PRIMARY_SYSTEM" TYPE="romfs"
Jan 1 00:00:18 WDTV-09cb5 user.notice crazyboot: /dev/mtdblock3: LABEL="WDLXTV-0.5.8.1" TYPE="cramfs"
Jan 1 00:00:18 WDTV-09cb5 user.notice crazyboot: /dev/sda: UUID="BCE8-7195" TYPE="vfat"
Jan 1 00:00:19 WDTV-09cb5 user.notice xmount: xmounted /dev/sda
Jan 1 00:00:19 WDTV-09cb5 user.notice crazyboot: mounting app binaries...
Jan 1 00:00:20 WDTV-09cb5 user.warn xmount: partition with label (sda) already mounted!
Jan 1 00:00:20 WDTV-09cb5 user.notice crazyboot: checking DEVICE /dev/sda for app.bins
Jan 1 00:00:20 WDTV-09cb5 user.notice crazyboot: log-saver app found
Jan 1 00:00:20 WDTV-09cb5 user.notice crazyboot: Mounting log-saver.app.bin at /apps/log-saver
Jan 1 00:00:20 WDTV-09cb5 user.info kernel: attempt to access beyond end of device
Jan 1 00:00:20 WDTV-09cb5 user.info kernel: loop0: rw=0, want=68, limit=8
Jan 1 00:00:20 WDTV-09cb5 user.info kernel: loop0: rw=0, want=1028, limit=8
Jan 1 00:00:20 WDTV-09cb5 user.info kernel: loop0: rw=0, want=12, limit=8
Jan 1 00:00:20 WDTV-09cb5 user.info kernel: loop0: rw=0, want=1252, limit=8
Jan 1 00:00:20 WDTV-09cb5 user.warn kernel: UDF-fs: No partition found (1)
Jan 1 00:00:20 WDTV-09cb5 user.notice crazyboot: Mounting Optware
Jan 1 00:00:20 WDTV-09cb5 user.warn kernel: UDF-fs: No VRS found
Jan 1 00:00:21 WDTV-09cb5 user.info kernel: kjournald starting. Commit interval 5 seconds
Jan 1 00:00:21 WDTV-09cb5 user.info kernel: EXT3 FS on loop1,
Jan 1 00:00:21 WDTV-09cb5 user.info kernel: internal journal
Jan 1 00:00:21 WDTV-09cb5 user.info kernel: EXT3-fs: recovery complete.
Jan 1 00:00:21 WDTV-09cb5 user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 00:00:21 WDTV-09cb5 user.notice crazyboot: wireless-mod-wdlxtv app found
Jan 1 00:00:21 WDTV-09cb5 user.notice crazyboot: Mounting wireless-mod-wdlxtv.app.bin at /apps/wireless-mod-wdlxtv
Jan 1 00:00:21 WDTV-09cb5 user.warn kernel: UDF-fs: No VRS found
Jan 1 00:00:21 WDTV-09cb5 user.warn kernel: EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
Jan 1 00:00:22 WDTV-09cb5 user.notice crazyboot: extension found on /dev/sda - do not remove device from wdtv
Jan 1 00:00:22 WDTV-09cb5 user.notice crazyboot: adjusting LIBPATH
Jan 1 00:00:25 WDTV-09cb5 user.notice root: adjusting PATH
Jan 1 00:00:25 WDTV-09cb5 user.notice crazyboot: Path set to /opt/sbin:/opt/bin:/apps/wireless-mod-wdlxtv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jan 1 00:00:26 WDTV-09cb5 user.notice mount.watch: starting
Jan 1 00:00:31 WDTV-09cb5 user.warn kernel: wireless_ext: No versions for exported symbols. Tainting kernel.
Jan 1 00:00:31 WDTV-09cb5 user.info kernel: Loading wireless extentions module...
Jan 1 00:00:31 WDTV-09cb5 user.warn kernel: firmware_class: No versions for exported symbols. Tainting kernel.
Jan 1 00:00:35 WDTV-09cb5 daemon.info utelnetd[1050]: utelnetd (port: 23, ifname: any, login: /bin/login) startup succeeded
Jan 1 00:00:36 WDTV-09cb5 user.debug kernel: ir: Enable NEC decoder (0x00000000)
Jan 1 00:00:36 WDTV-09cb5 user.debug kernel: ir: Enable RC5 decoder (0x00000000)
Jan 1 00:00:48 WDTV-09cb5 user.notice mount.watch: Unmounting official device /tmp/media/usb/sda
