As always tarballs are available from zfsonlinux.org.
http://archive.zfsonlinux.org/downloads/zfsonlinux/spl/spl-0.6.1.tar.gz
http://archive.zfsonlinux.org/downloads/zfsonlinux/zfs/zfs-0.6.1.tar.gz
To simplify the installation and management of ZFS we have set up new
repositories for Debian, Fedora, and RHEL/CentOS. They can be found at
the following URLs.
Debian: Add to /etc/apt/sources.list
deb
http://archive.zfsonlinux.org/debian wheezy main
deb-src deb
Fedora: See
ZFS on Linux for directions.
rpm http://archive.zfsonlinux.org/fedora/$releasever/$basearch
srpm http://archive.zfsonlinux.org/fedora/$releasever/SRPMS
RHEL/CentOS: See
rpm http://archive.zfsonlinux.org/epel/$releasever/$basearch
spms http://archive.zfsonlinux.org/epel/$releasever/SRPMS
In addition to the usual bug fixes the 0.6.1 release introduces a new
property called 'snapdev'. The 'snapdev' property was introduced to
control the visibility of zvol snapshot devices and may be set to
either 'visible' or 'hidden'. When set to 'hidden', which is the
default, zvol snapshot devices will not be created under /dev/.
To gain access to these devices the property must be set to 'visible'
This behavior is analogous to the existing 'snapdir' property.
Other significant changes include:
* Added Linux 3.9 compatibility
* Added snapdev property to control visibility of zvol snapshots.
* Disabled old on-disk format warning for `zpool status -x`.
* Enabled zfs_arc_memory_throttle_disable by default.
* Improved slab object reclaim behavior.
* Fixed disk cache flushing for 2.6.37 and newer kernels.
* Fixed hot spare functionality.
* Git <id>-<hash> included in release for working builds.
* Updated dkms and kmod compliant packaging.
* Added man pages for splat, fsck.zfs, mount.zfs, zhack,
zinject, zpios, ztest, and zpool-features.
----------------------- SPL Change Log ---------------------------
Brian Behlendorf (16):
Fix atomic64_* autoconf checks
Disable automatic log dumping
Remove INSTALL
Fix spl_config.h install permissions
Add KMODDIR to install target
Remove custom install-data-local for headers
Remove ARCH packaging
Merge branch 'build-system'
Merge branch 'linux-3.9'
Change spl-kmod-devel install path
Refresh RPM packaging
Remove spl-dkms conflict with spl-kmod
Use requested kernel for dkms builds
Use 'git describe' for working builds
Provide ${kmodname}-devel-kmod for yum-builddep
Tag spl-0.6.1
Darik Horn (1):
Create splat man page
Ned Bass (1):
Refresh links to web site
Richard Yao (8):
Fix HAVE_MUTEX_OWNER_TASK_STRUCT autotools check on PPC64
Linux 3.9 compat: Include linux/sched/rt.h
Linux 3.9 compat: Do not depend on f_vfsmnt
Linux 3.9 compat: vfs_getattr takes two arguments
Linux 3.9 compat: set_fs_root takes const struct path *
Drop support for 3 argument version of set_fs_pwd
Linux 3.9 compat: Switch to hlist_for_each{,_rcu}
Do not call cond_resched() in spl_slab_reclaim()
----------------------- ZFS Change Log ---------------------------
Brian Behlendorf (35):
Add zpool-features(5) man page
Fix 1M references in zpool-features.5
Cast 'zfs bad bloc' to ULL for x86
Remove unused machelf.h header
Update the zfs.8 "ZFS Volumes as Swap" section
Add explicit MAXNAMELEN check
Fix broken RPATH in spec file
Enable zfs_arc_memory_throttle_disable by default
Leaf vdevs should not be reopened
Remove wholedisk check from vdev_disk_open()
Fix hot spares
Replace libexecdir with datadir
Fix zfs_config.h install permissions
Add --with-dracutdir configure option
Retire ZFS.RELEASE file
Fix zdb.8 macro warning
Remove COPYING
Change zfs-kmod-devel install path
Configure --with-spl{-obj} auto-detect cleanup
Add metaslab_debug option
Add zio_ddt_free()+ddt_phys_decref() error handling
Add spl-dkms dependency to zfs-dkms
Add missing dependencies
Refresh dracut module setup
Remove zfs-dkms conflict with zfs-kmod
Use BUILD_DEPENDS option for dkms builds
Include init scripts in packages
Tag zfs-0.6.1
Darik Horn (3):
Create mount.zfs, zinject, and zpios man pages.
Create fsck.zfs and zhack man pages.
Fix minor typos and update marketing copy.
Eric Dillmann (1):
Add snapdev=[hidden|visible] dataset property
Etienne Dechamps (2):
Use -Werror for all kernel configure tests.
Remove the bio_empty_barrier() check.
George Wilson (1):
Merge zvol.c changes from PSARC 2010/306 Read-only ZFS pools
Michael Gebetsroither (1):
Import ztest.1 man page.
Ned Bass (2):
Switch KM_SLEEP to KM_PUSHPAGE
Richard Yao (5):
Fix function relocations in libzpool
Make spa.c assertions catch unsupported pre-feature flag pool
versions
Eliminate runtime function pointer mods in autotools checks
Constify structures containing function pointers
Linux 3.9 compat: Undefine GCC_VERSION
Tim Connors (1):
-x shouldn't warn about old on-disk format or unavailable features
Thanks,
Brian
