bekomme folgenden Fehler wenn nachdem ich das AMP Script laufen hab lassen und der Apache lässt sich net starten. Was ist zu tun?[ Aug 20 16:13:05 Disabled. ]
[ Aug 20 16:13:05 Rereading configuration. ]
[ Aug 20 16:18:26 Enabled. ]
[ Aug 20 16:18:26 Executing start method ("/opt/local/sbin/httpd -k start"). ]
[Wed Aug 20 16:18:26.972901 2014] [:crit] [pid 11555:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
AH00013: Pre-configuration failed
[ Aug 20 16:18:26 Method "start" exited with status 1. ]
[ Aug 20 16:18:27 Executing start method ("/opt/local/sbin/httpd -k start"). ]
[Wed Aug 20 16:18:27.183500 2014] [:crit] [pid 11556:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
[ Aug 20 16:18:27 Method "start" exited with status 1. ]
[Wed Aug 20 16:18:27.391404 2014] [:crit] [pid 11557:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
[ Aug 20 16:20:26 Leaving maintenance because disable requested. ]
[ Aug 20 16:20:26 Disabled. ]
[ Aug 20 16:20:30 Enabled. ]
[ Aug 20 16:20:30 Executing start method ("/opt/local/sbin/httpd -k start"). ]
[Wed Aug 20 16:20:30.236440 2014] [:crit] [pid 11651:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
[ Aug 20 16:20:30 Method "start" exited with status 1. ]
[ Aug 20 16:28:14 Enabled. ]
[ Aug 20 16:28:37 Executing start method ("/opt/local/sbin/httpd -k start"). ]
[Wed Aug 20 16:28:41.263817 2014] [:crit] [pid 424:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
[ Aug 20 16:28:41 Method "start" exited with status 1. ]
[ Aug 20 16:28:41 Executing start method ("/opt/local/sbin/httpd -k start"). ]
[Wed Aug 20 16:28:41.857405 2014] [:crit] [pid 456:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
[ Aug 20 16:28:43 Method "start" exited with status 1. ]
[ Aug 20 16:28:43 Executing start method ("/opt/local/sbin/httpd -k start"). ]
[Wed Aug 20 16:28:43.459508 2014] [:crit] [pid 484:tid 1] Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP.
