• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
Puh das mal derbe, da war wohl jemand nach einer Sauforgie noch nicht ganz wach bei der Montage. Ich werde wenn ich das nächste mal das Brett ausbaue auch mal einen Blick werfen ob es bei mir so ähnlich ausschaut. Ist schon ein starkes Stück muss ich zugeben.
mit was liesst ihr die nb temp aus, bzw aux ? was is aux temp ?
weil dann guck ich ma wies bei mir aussieht..
@amd: am besten ma da melden und trouble machen und auf soforttausch pochen
hi,
jo aux sollte die nb sein. ne mail bekommen sie aber austausch will ich keinen. etz laeuft es ja super
mainboard 36°
aux im idle 30-37 - linx last max 46° grad
@mapim
jo des war heut der hit. bei einem brett fuer 30 lass ich mir sowas ja noch eingehen. aber fuer ne oberklasse scho traurig
Ganz ehrlich so was geht gar nicht. Das hat nichts mit dem Preis zu tun.
Aber man findet immer mal wieder Ausreisser und ich hoffe das es das bei dir auch war.
hi,
mainboard 36°
@mapim
wie liesst du denn diese temps aus ? mit weclhem programm unter windows 7 ?
weil dann teste ichs auchma, interessiert mich grad
oje oje ich hab scho ma nen blick riskiert..
bei mir guckt am einen ende der spawas ein stück dünnes pad hervor...
mmmm also das bei diesem board..((ugrgs
Hab mir PK1 Proli bestellt und werde die tage dieses kleine missgeschick beseitigen..
ich lese aus mit Aida64.das deckt sich mit den biosdaten/hardwaremonitor..
aber 80 grad hatte ich noch nicht..max war ma64grad...
Freue mich schon aufs mobozerlegen))
greezzi
greezzi
gbits das aida umsonst ? naja mir is nix padmässiges aufgefallen ,cih zock jetzt auch schon nen halbes jahr mit den 4ghz ohne probs..
man kann ganz einfach testen ob alles passt.
1.) unter prime oder linx den nb kuehler anfassen. ist der kuehler handwarm und dir werden bei everest 70° grad angezeigt passt was nicht.
2.) steigen und fallen die temps sehr schnell stimmt was mit dem nb-pad nicht. oder es is keins vorhanden :(
wenn es etz ohne probs weiter laeuft bin ich mehr als zufrieden.
---------- Beitrag hinzugefügt um 22:25 ---------- Vorheriger Beitrag war um 22:21 ----------
everest aod oder aida.
greezzi
normal schaut da nix raus. und wenn was raus schaut is es vielleicht auch folie. da bei mir auch ein kleines stueck hervor geschaut hat.
hab mit aida 47 grad unter windows idle bei aux, ist das ok ?
und 16grad bei cpu, ich hasse die defekten x6 temps.. naja + 15grad ca macht 31 grad
also heisser als 55 grad unter prime wird meine nb nicht xD bei mir is alles im lot, dafür cpu 45 grad(+15 grad ca wegen defektem sensor)
Ich hab jetzt auch mal die aux mit HWiNFO32 beobachtet nach paar Stunden Zocken. Mit dem HWINFO im zweiten Moni geht es nicht über 65 Grad, denke das geht auch noch in Ordnung. Lüfter im Case sind auf min.
da brauchst du keine angst habe, da is alles top.
mein erstes brett.
idle 65° - last 80
und bei zweiten war es ja dann noch besser. :d
bei meinem brett ist wohl die msi ligthnnig deluxe3 icecold wlp aufgetragen worden bei 55grad last^^ oder es liegt am case
Mein CPU Kühler ist wegen der Sockelhalterung bei AMD nach oben gerichtet sonst würde der den SPWA mit kühlen. Ich hab den mal gewonnen( OCZ Gladiator Max) und der stand fast ein Jahr bei mir ungenutzt rum :-) Bei Gelegenheit schaffe ich mir nen MUGEN an denke ich. Da der OCZ aber ordentlich Kühlt ist das nicht unbedingt etwas was ich unbedingt machen müsste.
besser den ekl nordwand,günstig und mit kühler bei und genauso schwarz wie das board, hab ich auch
Als CPU Kühler finde ich den Thermalright-Venomous am Besten.
Er hatt eine drehbare befestigungsplatte und kann somit in allen Richtungen montiert werden.
Und Optisch macht er auch was her.
die nordwand kann ebenfalsl in alle richtungen montiert werden.. wobei nach hinten blasend am besten ist
geht ja uach ums p/l verhältnis ,der kostet nur 33 euro mit lüfter, für 60 euro+ gibts nat bessere, nur warum , soviele höher als 4 ghz geht ein X6 nicht, ein X4 schon garnicht unter luft ,nud das packt die nordwand auch
und es ist ne deutsche firma^^
ich war sehr angetan vom Prolimatech Megahalems. optisch top - leistung 5 sterne.
bin aber dann wieda zurueck zur wakü (leise-leistung-traumhaft)
hi,
und danke fuer die info. neues final ist ja auch da, des wird dann getestet wenn der bulli da ist :d
im moment bin ich noch sehr zufrieden mit dem 1,7
mmmm.mit dem 1.7 läufts rund,denke nich das ich das bios weiter flashe...
mit den temps hatt sich was getan...hab den neuen aida64 draufgezogen schon sagt er mir nach zockorgie 48 grad aufem mobo...
mitlerweile vertraue ich keiner tempanzeige mehr,sondern lege hand an den kühler beim ackern...
da mein coolermaster case super belüftet ist denke ich brauche ich mir keine sorgen machen..
war nur ein wenig verwöhnt von meiner wakü..
greezzi
tja was soll ich sagen...wollte mir nich die garantie versaun und hab in meiner schublade gewühlt...
Hab ein paar passende lüfter gefunden und die aufs geile mobo geschnallt.
grunz..das funzt.um die 12 grad weniger...
im happy greezz vom seltsam
hi,
klingt doch super, wie sind etz die temps so bei dir?
bitte vorher und nachher.
kannste nen pic machen ?
verschandelt das nich die gute optik ?
nee,das sieht aus als wenn es so sein sollte.
Hab auf den unteren kühler einen 70ziger lüfter montiert
(war vom AMD boxkühler übrig)
Auf den oberen grösseren kühler hab ich mir ne 3er bank 40ziger lüfter geschraubt.
(von meinem letzten corsairram der dominatorkühler.)
past,funzt,ist super und nur ne minimale Lautstärkeanhebung..
Die montage war ein wenig unortodox,aber da ich flexibel bin gings mir gut von der hand))
pics davon hab ich,Kann ich die hier so reinstellen oder nur links zu den bildern?
ersma luft holen))
greezz
ps.vorher idle.42/39°--last56/65°(hardcoreballerorgie hl2dm über 5std.
graka ebenfalls alle 3 werte um die 60°
neuwerte idle31/29--hl2dm48/44°
ausgelesen mit dem neuesten aida64
top werte,
aber pic´s wuerde ich da auch gerne mal sehen. wenn ich moeglich ist, einfach die links posten langt doch.
mist.....mein kater hatt mein usbcamerakabel gefressen....rrrrrr
ich hab eigenen hl2 server und webspace..
werd da ma ein paar pics hinterlegen und links reinstellen..
Temps in meinem pc raum schwanken aber auch um die 10 grad wegen vollsonnebestrahlung...
bin froh die wakü vom hals zu haben))..wilde kater und das vertragen sich nich..
greezz vom seltsam
irgendwie finde ich im bios keine einstellung damit sich der cpu lüfter automatisch reguliert. Habe V1.7.
Weiß jemand wo ich das einstelle? So ein komplexes Bios hatte ich noch keinem Rechner. Echt krass was man alles einstellen kann ^^
H/W Monitor, das kannst du die Lüfter einstellen.
Welchen CPU Kühler oder Lüfter nutzt du denn?
Den sollte es ein PWM (4 Pin ) Lüfter sein kann man das auch nochmal da einstellen (alt.3 pin )
ich habe es wie Folgt.
Chassis intrusion Disabled ( Case macht alarm wenn es geöffnet wird wenn der PC an ist)
CPU Fan ( 4 PIN ) PWM
CPU Fan smart target 40
CPU Fan min Fan speed 0 Sehr geil der Lüfter dreht erst bei einer gewissen temp auf im idle fast nie bei mir.
Sys Fan 50
Diese Einstellung setzt aber einen Guten CPU Kühler sowie eine ausreichende Belüftung voraus
Teste halt mal
und hat das geklappt?
