• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
Habe da noch mal eine Frage bzgl. OC:
Meine CPU-NB habe ich auf 2.800 MHz übertaktet und dazu die Spannung selbiger erhöht. Ich habe aber zusätzlich die Spannung der NB ebenfalls erhöht und dadurch zwangsläufig hohe NB-Temps. Da ich gerade keine Lust habe das auszutesten, hätte ich gerne gewusst, ob ich die Spannung der NB unbedingt erhöhen muss? Wie habt Ihr es gemacht?
hab die nb nich angetastet aber hab auch nur mit multi übertaktet.. ganz leicht erhöhen schadet sicher nicht
jop seltsam wird laufen :)
wenn ein, 2 features wie stromsparkäse nich gehen isses mir egal^^
ich bin fast der meinung, das nicht mal das zutreffend ist.
aber zu 100 prozent kann mann das eh erst sagen wenn der bulli da is.
Bin Gespannt wie ein Flitzebogen)))
Bull kommt auf jeden Fall aufs brett,werde aber noch was abwarten...
Dazu dann vileicht ne MSI6970...mmm,,ma gucken..
Bin mit meinem jetzigen Equipment an für sich Oberglücklich...))))
greezz vom happy seltsam
gönn dir ne GTX 570/580 haste echt mehr von, hier im forum wechseln viele von der hd 6xxx serie..
haste mehr von
haste mehr von
Ja, kann ich nur bestätigen. Bin auch von ATI/AMD weg und habe mir eine GTX 570 geholt, super Entscheidung !
In sachen graka. bin ich auch mehr auf der seite der gruenen
da die treiber zum kot... sind, aber in sachen cpu bin ich
sehr zufrieden mit amd. und von dem brett ganz zu schweigen
seh ich genauso, auch mit cpu und mobo,
wobei es nicht nur die treiber sind dei bei den roten nichso toll sind, min fps, übertaktbarkeit, bildwqulai, man weiss ja kaum wo man da anfangen soll...
Ich habe im moment noch ne 6950@70 im rechner.
und das einzige was mich persoenlich richtig nervt sind
die treiber. thema bildquali is net so schlimm. da ich fast blind bin
:d
Wenn ich bei dem Board die Speichertimings einstelle, wähle ich immer Both für beide. Dann muss ich die Timings ja einzeln für beide Speicherriegel einstellen. Hatte die ganze Zeit nur den ersten eingestellt, Rest war auf Auto. Laufen denn die Riegel mit unterschiedlichen Timings oder wie ist das?
ich denke ja, aber das lässt sich mit cpu z doch rausfinden.
hab auch both gewählt
Aber CPU-Z zeigt doch die Timings nicht für jeden Riegel einzeln an.
Etz ich mal.
ich komme mit dem x6 nicht klar. GA kannst du mir mal deine biossetting posten bitte.
Von den voltage dankrschoen.
Etz ich mal.
jeder X 6 isja anders, ich werds am we ma posten ,geht vorher nicht da ich jetzt erstma auf die arbeit muss, anfürsich hab ich nich viel mehr als allen stromsparscheiss ausgemacht, voltage is bei mir 1,41 volt im bios, rell sinds laut cpu-z etwas weniger, boost undso is auch aus, und dann einfach multi hoch
genaue settings wie gesagt erst am we
hatte noch nie ne cpu so einfach getaktet, wobei ich mich hochgetastet hab in 100 mhz schritten und wenns instabil wurde vcore etwas hoch, nochma ewig prime usw..
Danke.
dann ist der x6 1100 ein ganz schlechter 4000mhz sind nicht unter 1,495. Drin
vid ist 1,475
ich guck jetzt bei mir und poste dannma ;)
auch meine X6 einstellungen
Ja, ok. Aber bei mir scheint ein anderes Problem vorzuliegen. Bekomme ständig Bluescreens, jetzt auch plötzlich ohne OC und im Windowsbetrieb. Werde später mal meinen Ram mit Memtest checken.
Alles was nich genannt wird beim ram und cpu ist auf auto oder standart
Hab beim Ram Teiler 1:4 und 1600mhz folglich bei der ramfrequenz ,desweiteren 1,513 volt beim ram
ram is auf both aber trotzdem 2 mal eingestellt bei beiden.. bzw automatisch, siehste ja, 1t is auch eingestellt
zur cpu, an user amd 64 bit
hab turbocore, cooln qiet c1e is disabled
core control auf manual und alle kerne an
hab dann alles auf auto bzw standart und nur den multi auf 20 gesetzt sowie nach vielen vielen prime instanzen mit allen 3 presets die voltage bei der cpu auf 1,41 volt und das is stable, stabler gehts nich^^
sonst keine voltage oder frequenz geändert
phase control is aus, sprich alle stromphasen auf maximum
den bootscreen hab ich aus, cpu vid ist 1,352 volt
speichercontroler läuft im unganged modus
unwichtige dinge wie der 2te lancontroler sind natürlich aus..
Tag zusammen.
gestern ist mein schoenes brett gestorben :-(
ich habe echt keine ahnung warum oder wieso. das system ist unter prime einfach ausgegangen. und das wars dann auch startet nicht mehr???
ich habe am anfang gedacht das das NT durch gebrannt ist. aber das NT laeuft noch ohne probs.
was ich nicht verstehen will ist.
cpu-mainboard stormstecker blinken nur kurz die leds auf.
nur mainboard stromstecker laeuft das system an. debug led zeigt dann FF an. steck ich den 8 pin wieder aufs brett geht wieda nix mehr?
ist das etz das brett oder die cpu??????????????????????????????????
Das ist natürlich sehr schade aber schau erst mal an nem anderen PC ob es nicht doch das NT ist .
ich habe das MSI 890FX-GD65 und soweit zufrieden.
Mein 1055T hat eine Vid von 1,375 V aber das Board gibt unter Last 1,480 V, egal ob ich die Voltage per Hand einstelle oder auf Auto lasse :(.
Turbo habe ich natürlich deaktiviert.
Vielleicht vertut sich das Board unter Last mit der Turbocore Vid, weil die ja bei 1,475 V liegt.
Ich habe auch schon das neueste Bios fürs GD70 probiert, ändert aber auch nichts !
Habt ihr mit dem GD70 auch das Problem ?
Meine PCI X-Fi hat auch nur gerauscht und Störungen gehabt beim Musik hören, aber das lag daran das ich C1E enabled hatte, als ich das abgestellt habe war alles Bestens ;).
Hi. Nein es muss das brett sein. speicher cpu und das nt laufen auf meinem alten brett einwandfrei.
Mein gd70 hat keine macken oder sonst was gehabt. trotzdem wuerde ich gerne wissen
was da los war. bin mal gespannt wielang alter.... braucht
meine voltage bleibt auch so wenn ich sie einzeln einstelle und speichere, sonst wäre ocing ja quasi unmöglich..
denke is besser du fragst ma wen der dein board hat, anderes board isja nich gut vergleichbar..
@amd: das is echt schade, warste am ocen oder warum prime ? garantie haste ja noch denk ich ma ?
