• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
Ich war am speicher testen 1600 @ 6-7-7-18 T1
prime lief da ca ne std und mitten drin is der ausgegangen. das wars dann.
ja garantie habe ich noch. hab das brett ja erst seit den 18.03
---------- Beitrag hinzugefügt um 20:41 ---------- Vorheriger Beitrag war um 20:38 ----------
@Mapim. danke fuer die info. dann werde ich gleich mal fragen ob alternate mir auch ein anderes brett zuschickt
mmmmmmm.heist das das der Bull nur eingeschränkt laufen würde auf diesem unserem Brettchen??=
Und noch ne Frage an euch Profs..
Hab auf der northbrigde/southbridge um die 50 grad und höher(beim zocken)
Sommertemps in meinem Raum hier 30-31 grad...
Muss ich mir da Sorgen machen um meine Hardware?
Bin wahrscheinlich von der Wakü verwöhnt und andere Temps gewohnt...
Hab wakü Gewechselt auf Luft(zu teuer und gefährlich)...
naja Sterben werden die Sachen nich ich denke...
greezz vom seltsam
Dann dreh die Lüfter Im Case halt auf .Natürlich wird es dann etwas lauter ;-)
Auch kann es nicht schaden die Wärmeleitpaste auf den Southbridge Chips zu tauschen. Aber die wird in der Tat sehr warm , das habe ich bei mir auch schon mehrfach festgestellt. Am einfachsten ist halt mehr Luft durch das Case zu jagen.
tag zusammen, bin wieda da.
ich bin begeistert von alternate und msi. brett tauschen 2 wochen. das is mal ein service top.
zum thema nb und sb temps, ich habe auch die wlp getauscht. und schon waren die temps 10 bis 15 grad besser.
aber das einfachste ist einen luefter vor die nb haengen @ 5v
1.) leise
2.) temps bei mir ca 10 grad besser.
3.) sich freuen.
Was war den vorher auf den Chips drauf ? Die Pads oder Paste ? Die Heatpiepes abzunehmen ist ja kein großes Ding da sie verschraubt ist.
hi mapim,
org sind pads darunter, klar ist das keine grosse sachen. wenn das brett vor dir liegt.
es gibt aber viele die es nicht unbedingt ausbauen wollen, und da ist der luefter die bessere wahl.
1.) leise
3.) sich freuen.
fand meine temps angemessen, geht da nicht die garantie flöten, oder is das von msi aus erlaubt die wlp zu wechseln ?
Danke dir für die Info AMD64. Ich hatte mich schon mal wie gesagt auch gewundert wie warm die Kühler werden. In meinem Bit Fenix Collossus Case ist ein Großer 23 Lüfter Im Deckel. Ich hab einfach den Lüfter hinten am Case umgedreht so das er rein Pustet.
Bei einem Case mit geschlossenem Deckel würde ich das aber nicht empfehlen ;-)
Das mit der Garantie ist ein Argument GA.
Normal sollte es aber trotz der subjektiv hohen Temperaturen aber nicht zu Problemen kommen wenn genug Luft durch das Case geschaufelt wird.
Ich Frag mal bei MSI an wo da die Schmerzgrenze ist .
Hab eben im MSI Forum ne Anfrage gemacht wie es da mit der den Max bzw. save Temps ausschaut und wie es mit der Garantie bei einem Tausch der Pads bzw Paste ausschaut.
Bin mal gespannt was dabei rum kommt.
das mit der garantie kann ich dir nicht genau sagen, aber ich denk mal das msi sich mein brett angeschaut hat. und dabei ist das mit der wlp mit sicherheit aufgefallen.
trotzdem wurde es getauscht.
und das mit dem heckluefter ist ne gute sache, (wie du schon geschrieben hast) mit luefter im deckel sonst wird das nix mehr.
---------- Beitrag hinzugefügt um 21:07 ---------- Vorheriger Beitrag war um 20:52 ----------
ich denk des wird wie bei asus sein, da kann man auch die kuehler demontieren.
und man hat noch garantie. sollte aber aufgrund des demontieren ein defekt entstehen ist die garantie futsch.
Ja das wäre sehr kulant, aber wie gesagt ich hab im MSI Forum ne Anfrage gemacht und mal sehen was dabei rum kommt. Der Wollex ist bei MSI sehr aktiv ( in Sachen BIOS ) und hat auch hier schon einige male Weiter geholfen. Mit bisschen Glück weiß der was genaues.
richtig,
somit waere das mit dem luefter, ne 100 prozent sache.
eben wegen garantie und aufwand.
---------- Beitrag hinzugefügt um 21:25 ---------- Vorheriger Beitrag war um 21:19 ----------
schau mal ins msi forum,
wollex hat geantwortet, dann habe ich mich gut angestellt :d (gott sei dank)
fazit.
bitte nicht nach machen.
thema kuehler, das sollte oder muss jeder fuer sich entscheiden. was er macht, ich persoenlich finde diese werte von 80 bis 90° grad zuviel.
mapim
ich habe noch den 11.2 drauf da der bei meiner 6950 @ 70 am besten lief. werde aber den 11,4 auch mal testen. in sachen leistung soll der richtig zugelegt haben, bin ja mal gespannt.
Klar ist das viel zu viel und will auch keiner, meine Frage war ja auch wo so die Schmerzgrenze liegt. Wenn ich den Kühler anfasse ist mir das gefühlt mit der Hand immer noch zu viel . Ich vertraue einfach mal darauf das MSI da schon weiß sie machen und unter normalen Umständen nichts passieren sollte.
Zum Treiber 11.4 ich hatte Probleme mit den vorigen und seltsame sporadische Blusreens die mit diesem Treiber hoffentlich passe sind. Interessant ist auch der 100 % Bug der mit diesem Treiber ausgemerzt sein soll . http://www.hardwareluxx.de/community/f14/amd-99-idle-bug-sammelthread-achtung-geloest-795611.html
Wobei ich da eher Probleme Hatte wenn Flash Websites aufgerufen wurden . aber das ist off Topic .
bluescreen usw weiter waren bei mir mit dem 11.3 sehr oft. mit dem 11.2 was alles in butter.
zu dem idle bug kann ich nix sagen, da ich den noch nicht hatte.
darf man nun die wlp paste wechseln oder nicht ?
tempprobs hab ich keine auf der nb..
mmm also wenn das brett vor mir liegt is das komplett?3teiliger kühler den ich vom mobo wegmachen muss?
oben der spawakühler dann der mittlere und der untere...ich denke die sind auch komplett mit einer heatpipe verbunden..
ich werde die tage mein sys zerlegen und die pads gegen ordentliche wpl tauschen..
gute wpl is auf jeden fall besser alz pads..
MM..mehr gehäuse geht nich.oben 2-220 ziger lüfter hinten 140ziger..vorne ein 230siger...nt unten und 135siger lüfter....
Hoffe die wpl bringt es...
werd es die tage tippsen,wie das ergebnis pads zu wpl..
PS zu MSI kulanz...in einem anfall geistiger umnachtung habe ich mir 5(heul)nagelneue msi mobos gehimmelt.
grunz..hab alle auf kulanz ersetzt bekommen..
Deshalb ist mein mobo immer ein MSI mobo))
greezz vom happy seltsam
#PPS..Hab die msi graka 5870lightning die mit 900gpu rennt und nach 4std hl2 gaming unter 60 grad ist..
Das sagt mir mein gehäuseflow rockt)
Falls du die Heatpiepe abmachen willst geht das nur komplett, ist alles miteinander verbunden.
Wenn du das machst mach bitte paar Bilder und sag Bescheid in wie weit sich die Temps verändern
mfg der mapim
next question to the ram modules..
wenn mein rechner startet sagt er mir mein ram läuft in ganged mode 128 bit!
unganged hatte ich auch ma mit 64bit...
ich bin da ein wenig überfordert..wäre froh wenn ein pro mir ma den ram richtig rückt))
greezz
mmm im dunno über da fängt es an..
#wa sagt es aus gnged mode unganged..was is besser?.
ahrgg..will doch nur mein machinchen auf trabb bringen))
bin für jeden tipp dankbar..greezzi
Ich hab den auch im gaged Mode 128 Bit. Ich spüre zum Ungaged keinerlei unterschied.
Ich hab das mal gegoogeld aber was mehr bringt gingen die Meinungen auseinander.
hir fand ich eine relativ einfache Erklärung.
Ganged, unganged - Forum - CHIP Online
unganged sollte theoretisch besser sein deswegen hab ichs auch
ok ok sobald nüchtern und ruhige hand wird ausgebaut.
Ich hasse op^s am offenen herzen.))
Bei einem umbau is ma mein freund kurz mit dem Schraubenzieher abgerutscht..
zu sehen war niks..aber der rechner ging nich mehr.
Das is niks für wurschtfinger))
is die silver wpl das beste oder gibts da bessere?
greezz
greezz
die beste zurzeit is mmn nach prolimatech nanualuminum pk1, silver is schon nen paar jahre nicht mehr das beste
abend zusammen,
ich habe die pad´s gegen prolima. PK1 getauscht und war begeistert.
freu mich auf deinen bericht was es bei dir gebracht hat.
so leute, brett ist drin.
und wenn ich sowas sehe wird mir schlecht. AUX temps (NB-Temps OHNE OC )
85° grad wahnsinn. da trau ich mich net mal testen was die neue cpu kann. sonst ist das zweite im arsch.
zur kuehlung,
das geilste ist ja die aux temp bei everest.
idle 70° linx last 80° grad. etz kommt das beste, steck ich am frontpanel mein iphone steigt die aux temp auf 90° ???????????????
das gleiche temp verhalten zeigt auch AOD.
der kuehler ist aber dabei gerade mal gut hand warm. ich versteh da die welt nicht mehr des is mir zu hoch.
und das alles bei default einstellen ,KEIN OC oder sonst was.
tag zusammen,
ich weiss etz net mal wie ich anfangen soll, sowas habe noch echt noch nicht erlebt.
ich glaub das war vorerst das letzte von msi.
1.) am waermeleitpad auch NOCH DIE FOLIE drauf bei den spannungswandler.
2.) das mit den NB-Temp war leider auch noch richtig, ES WAR KEIN PAD oder SONST WAS auf der NB ???????
ich persoenlich finde das fuer das geld ne frechheit.
ich bin ja heil froh das das brett den kurz einsatz ueberlebt hat.
