• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
Bin auch etwas der Meinung das 0095 is nicht 100%ig aber das muß man sehn...
Wie sind Weitere Erfahrungen mit disaem 13xx ?
Kann ich bestätigen
Hm, gut dann kann ich ja mal einen Blick riskieren. Bin noch aufm 0804 unterwegs. Muss ja für den Mist erstmal wieder alles Deaktivieren was Lizenzen hat. Gerade Adobe ist da echt schlimm, jedes Mal muss ich das neu aktivieren :kotz:
bzgl. speicher: danke!
wie ist das mit den downloads zum mainboard ... sowhl auf der asus website als auch auf der rog website gibts das maximus v formula ... aber nur auf der rog seite mit dem zusatz thunder fx ... ich nehme mal an ich sollte die rog-downlods bevorzugen und die asus downloads ignorieren (habe ja das thunder fx)
also wenn ich auf dieser seite stehe ASUS - Mainboards- ASUS Maximus V Formula
und dann hier
Startseite > Mainboards > Intel Socket 1155 > Intel Z77 > Maximus V Formula
auf Intel Z77 klicke öffnet sich ein auswahlmenü und da ist das thunder fx nicht gelistet
aber ist eh etwas komisch denn ich steh auf der .de seite und deutsch ist als sprache gewählt (sollte eigentlich english sein) aber trotzdem wird die ganze seite englisch angezeigt ...
egal, danke!
---------- Post added at 14:29 ---------- Previous post was at 11:26 ----------
neuestes bios ist btw drauf ... wie stelle ich nun den ram von 1333 auf 1866 über das xmp profil, welche punkte muß ich genau ansteuern um nur den ramtakt zu ändern, sonst aber alles so zu belassen wie es ist?
und was muß ich bei secure boot os type einstellen? aktuell steht Other OS ... installiert wird windows 7 ultimate 64 bit ... muß oder sollte ich da was ändern oder so lassen ?
Also ich bekomms in dem Popdown auch gelistet. Die Seite mag dich scheinbar nicht :d
XMP aktivierst du unter AI.
das mit xmp hab ich hinbekommen ... dabei werden erstmal aber ein paar zusätzliche optionen auf manuell bzw. bearbeitbar gestellt und glaub der turbo mode geändert ... hab dann nur den ram geändert und turbo wieder auf auto gestellt
kann es sein dass secure boot nur mit windows 8 relevant ist ? mir also bei windows 7 egal sein kann?
Die Menüs werden zwar aktiv, an den Einstellungen ändert sich soweit aber nichts. Siehst du ja am Zieltakt usw.
hab mir bookmarks gesetzt ...
welcher code wird denn aufm mainboard angezeigt wenn alles ok ist? und zwar wenn ich im bios bin und wenn ich im installierten windows bin ?
A0. Im BIos kann es auch sein, dass es A2 ist.
ok, danke ... ist auch so
ich hab nun windows 7 auf der ssd installiert und dann über stick die ganzen downloads von der asus rog seite für das board auf die ssd kopiert, chipsatzpaket entpackt und installation gestartet ... danach wird dann neu gestartet und die eigentliche installation des chipsatztreibers läuft und danach nochmal neustart
nun krieg ich aber nen post screen "Overclocking failed! Please enter Setup to re-configure your system."
ich hab "overclocking" nur das xmp profil für 1866 gewählt und sonst diesbezüglich eigentlich nichts geändert, die meldung kommt auch erst jetzt nach der chipsatztreiberinstallation ... irgendwelche ideen?
nachdem ich nun wieder zurück auf auto gestellt hab fährt der rechner normal hoch ...
lasse das ganze nun erstmal auf auto
aber nächste frage: hab als nächstes den asmedia treiber über die datei AsusSetup.exe installiert ... soweit auch alles ok aber warum bekomm ich im device manager 2 x angezeigt:
Asmedia 106x SATA Controller
sind da 2 stück von verbaut? ich dachte wär nur einer?
das fängt ja gut an ... hat sich also in 10 jahren nichts geändert
kannst du oder jemand der zeit hat nen screen posten wie im device manager die ide ata/atapi controllers bei euch angezeigt werden?
nach deinstallation der beiden asmedia bekomme ich aktuell - ohne ersmal weiter was gemacht zu haben folgendes angezeigt:
ATA Channel 0
Intel(R) 7 Servies/C216 Chipset Family SATA AHCI Controller - 1E02
nach reboot (windows installiert dann automatisch irgendwas):
ATA Channel 0
ATA Channel 0
ATA Channel 0
ATA Channel 1
ATA Channel 1
Update Drivers mit Angabe des Downloadverzeichnisses der SATA Treiber für den Asmedia Controller von der rog seite hat nichts gebracht, windows sagt der treiber ist bereits installiert
die installationsreihenfolge nach einbau des mainboards war wie folgt:
win7
danach alles ohne asus cd
chipset treiberpaket vom download
asmedia sata
usb intel intel
usb intel asmedia
usb asmedia
lan
und da hab ich dann gekuckt was bei den ide ata/atapi controllern angezeigt wird und ist mir das mit dem 2 x asmedia aufgefallen
usb ist auch so ne sache:
a gibts im intel paket sowohl treiber für intel als auch asmedia und dann gibts noch das asmedia paket nur mit asmedia, hab dann aus dem intel paket zuerst intel und dann asmedia installiert und dann nochmal aus dem asmedia paket asmedia
oh und der bios boot screen meldet mir 2 mäuse und im gerätemanager werden auch 2 mäuse angezeigt (habe aktuell ne Logitech MX318 angeschlossen, nichts dafür installiert)
grad ai suite installiert (komplett) und dann mal rechner neu gestartet, beim runterfahren blue screen - war aber zu schnell weg - und hochfahren dann wieder ok, danach nochmal neustart und kam nicht nochmal
Intel(R) Graphics Accelerator Driver V8.15.10.2669 for Windows 7 32bit & 64bit.(WHQL)
- wofür ist der gut?
- brauch ich den?
- bei der installation bekomme ich gesagt: This computer does not meet the minimum requirements for installing the software
Also im mom läuft es nun mit guten Temps, ich sichere Profil und laß es mal Laufen.
Hoffentlich läuft es jetzt mal ne Weile.
Bios is das ganz neue 1309
Bitte schön:
Schließe mal die Bootplatte/ SSD??? an den Intel controller an.
und versuchs erneut.
Hänge alles ab, was du nicht brauchst, z.b. alle anderen Festplatten, Cardreader, Laufwerke....
Im übrigen wäre ja nicht schlecht, wenn du deine Konfiguration hier mal postet
ich hatte ja alles abgehängt was ich nicht brauche bzw. hab ich am anfang halt nur die samsung 830 256GB SSD am intel controller hängen gehabt, windows 7 ultimate 64bit darauf installiert, dann direkt das chipsatztreiberpaket (vom download, nicht cd) und danach dann die treiberpakete (ebenfalls vom download, nicht cd) intel intel, intel asmedia, asmedia installiert
selbst nach deinstallation beider angezeigter asmedia controller und anschließendem windows neustart wurden mir die beiden dann wieder im gerätemanager angezeigt
bei dir sieht man den asmedia gar nicht insofern bringt mir der screenshot nichts ... hast du den deaktiviert oder verwendest du irgend einen windows standard treiber der den asmedia nicht als asmedia ausweist?
doppelt wäre er bei dir dann ja scheinbar auch?
ich mein ich hab jetzt nicht wirklich ein problem damit solange alles korrekt funktioniert
die frage ist nach wie vor: sind 2 asmedia controller auf dem board oder nur einer ?
"sind 2 asmedia controller auf dem board oder nur einer" ......keine Ahnung.
Habe völlig anders installiert:
(Glaube auch, dass dies der"richtige Weg" ist)
Alles abgehängt bis ein CD-Laufwerk und meine SSD. Hängt am Intelcontroller.
Im Bios auf AHCI gestellt.
Bootoption: CD
Win 7 installiert.
Danach im Bios die Bootoption umgestellt...nur die SSD, alles andere auf disable
Updatepack installiert.
Dann NUR den Lancontroller installiert...Updates suchen.
Hat "sehr vieles gefunden", besonders auch optionale Updates
alles installiert.
Dannn die neusten Treiber geladen von Intel direkt, bzw. Asus
und alle auf das Desktop kopiert.
Dann Gerätemanger auf, dort wo noch Fragezeichen standen, die angeklickt
Pfad zum Desktop angegeben.... und das warst auch schon
hmm ...
da ich aber gar nix am asmedia controller hängen hatte und außer dem usb cd/dvd laufwerk nur die ssd am intel controller denke ich nicht dass ich was falsch gemacht hab ...
was mich an deinem gerätemanager stört bzw. irritiert ist dass der asmedia controller bei dir gar nicht angezeigt wird, bzw. zumindest nicht als solcher ausgewiesen wird
mich würd mal interessieren was andere mit diesem board bzgl. asmedia controller im gerätemanager angezeigt bekommen ... entweder einfach texten oder screenshot
ich hab jetzt mal fröhlich weitergemacht mit installation der ganzen tools und mittlerweile auch die 2. ssd und die 1. caviar black reingehängt ... von daher hab ich jetzt auch nicht wirklich lust nochmal von vorne anzufangen ...
btw bringt mir die ai suite warnungen wie z.b.:
+5V 0,000 V
was soll ich davon halten?
+5V 0,000 V
dass auf der 5Volt-Leitung keine Spannung ist.
Nachmessen mit Multimeter
erstmal wissen wo die 5Volt-Leitung ist :) um alles was mit strom zu tun hat mache ich nen groooooooooooßen bogen :(
kann das was mit den lüftern zu tun haben ... hab an allen 6 lüfteranschlüssen auf dem board lüfter angeschlossen
die spannungs-meldungen kamen jeweils direkt im anschluss an lüfter-meldungen wenn die 600rpm unterschritten wurden
ich hab nun erstmal manuell alle lüfter auf zumindest 650rpm bzw. 750rpm gestellt ... seither kamen keinerlei meldungen
ist auch die frage wie zuverlässig die ai-suite bzw. probe 2 ist
sonst läuft immer noch alles normal
Diese lustigen Warmeldungen gibts seitens der ai suite schon seit Jahren gratis dazu.
Sind Auslesefehler - also hinnehmen oder die Software deinstallieren.
Asmedia Controler waren bei mir im Gerätemanager nur zu sehen, wenn sie im Bios nicht disabled waren (ist ja auch logisch).
da ich 8 festplatten verbaue (2 x ssd, 2 x caviar black, 4 x caviar green) komme ich um den oder die asmedia controller kaum rum
es würde mich zwar nach wie vor interessieren wie das mit asmedia bei anderen im gerätemanager aussieht aber ich hab auch schon das nächste problem - bzw. immer noch ein problem mit vga worauf ich in einem der vorherigen posts schon hingewiesen habe
und zwar kann ich das vga treiberpaket nicht installieren, my computer does not meet the system requirements ... einzige erklärung - aber nicht sicher - ist dass ich windows 7 ultimate 64bit verwende (wobei das 64 bit glaub ich noch nicht mal das problem ist) ...
hab dazu aber ein eigenes topic eröffnet: http://www.hardwareluxx.de/communit...4000-i7-3770k-treiberinstallation-921313.html
Gehe einfach in den Gerätemanager, klicke Treiber neu installieren
und geb den Speicherort an. Win--doof ist nicht dumm und installiert dannn den richtigen Treiber.
Vorher würde ich den alten Treiber noch deinstallieren, kann ja sein, dass du den falschen installiert hast.
Schau mal auch unter diesem Link
ocaholic - Review: ASUS Maximus V Formula - Mainboards - Reviews
bzgl. asmedia: ich glaub das sind wirklich 2 ... auch im bios kann man 2 davon aktivieren/deaktivieren
das mit der integrierten gpu hat sich vorerst erledigt, bzw. wird im separaten topic abgehandelt, kurz: man muß wohl im bios gpu auf auto stellen + noch irgendwas und den lucid kram aktivieren sowie dann die entsprechende software installieren ... im moment egal
viel wichtiger wäre mir den ram auf 1866 über das xmp profil zu bekommen ohne sonstwas zu verstellen
die seite mit den ganzen screen auf ocaholic helfen mir hier leider nicht weiter, ich kenne mich mit der materie zu wenig aus und einlesen würde tage in anspruch nehmen und selbst dann wäre ich mir noch unsicher ... schade dass so viele funktionen dermaßen wenig dokumentiert sind ...
im detail steht bei mir im extreme tweaker menü im bios alles auf disabled oder auto ... d.h. standardeinstellungen
welche optionen muß ich umstellen um nur das xmp profil für den speicher zu laden und ohne was anderes zu verstellen ... am liebsten ohne selber was in den timings einstellen zu müssen
mein erster versuch war folgender, der dann aber warum auch immer in nem oc error endete
ich spiele das jetzt grad nochmal durch:
Ai Overclock Tuner: von Auto auf X.M.P.
das profil 1 des ram ist bereits ausgewählt und auf 1866 gesetzt
exit save changes & reset
danach bleibt er mit bios code 55 hängen ... memory not installed
schalte rechner aus
schalte rechner ein
bios fehlermeldung: Overclocking failed! Please enter Setup to re-configure your system.
also ai overclock tuner erstmal wieder zurück auf auto
hmm ... :(
hay phlebiac man schwieriger nick :d
so ich persönlich halte nichts von XMP profilen wenn du dein speicher mit 1866MHz betreiben willst(wenn er dafür ausgelegt ist ) stelle 1866MHz im reiter "memory frequency" ein , im Dram Timing Controll lässt du alles auf auto , dann stellst du noch manuel Dram Voltage manuel ein
damit die option memory frequency erscheint mußt du AI OVERCLOCK TUNER auf manuel stellen
versuch das man und dann starte den rechner
wenn man oc betreibt betreiben will sollte man auf auto einstellungen verzichten , weil sie manchmal dann einstellungen übernehmen können die jenseids von gut und böse sind ......
ich habe einmal cpu level up angeklickt 4600MHz als ich enter gedrückt habe hat das bios/rechner plötzlich neu gebootet und prompt ne fehler meldung , plötzlich hatte ich 1,8 V core :wall:
also entweder finger davon lassen vom oc oder selbst hand anlegen mit denm einstellungen
sonst kann es sein das das gemeckere hinter her groß ist weil hardware nicht mehr funktioniert .........
der speicher ist dieser hier: Vengeance®
und ich hab das so ausprobiert wie du geschrieben hast, aber entweder fehlt da noch was oder ich mach was falsch oder es klappt trotzdem nicht ... selbe fehlermeldung ...
ohne änderungen läuft der speicher halt auf 1333 ... standard sollte ja zumindest 1600 sein ... d.h. der speicher läuft nicht nur langsamer als er lt. hersteller kann sondern auch langsamer als er soll :(
