[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Zum kotzen, da die FE ja nun nicht lieferbar ist dachte ich nehm ma halt ne TUF. Nur geht selbst die nicht in mein Case. Baaah.
da könnt IHR mir ja sagen ob das "normal" ist
vorsicht wer soundanlage etwas zu laut hat ich hab GAIN +30db da hört ihr auch das richtig. für mich ein extrem unangenehmes nebengeräusch! bei 20sek geht die karte erstmal auf 0 u/min hatte kleinen schluckauf beim start der aufnahme
Okay das geht gar nicht. Und wenn du den anhältst hört es auf oder mal leichten Druck auf das Cover ausüben aber hört sich schon stark nach nem Lüfterproblem an.
Die non OC hat kein BIOS Switch und man müsste auch noch das 4x8PIN besorgen. Oder halt das Cotsair Kabel. Aber mir reicht die Power so.
Beste Grüße
Gilt das auch für die TUF Non-OC?
Der Karton und die Beschreibung bei ASUS gibt nichts her?
Hat jmd eine TUF OC? Hat diese einen BIOS-Switch?
Bananenkarte….So, bitte geschockt sein. :d und nein, das liegt nicht an der Stütze. Die Karte ist auch so fest und stabil ansich, das man nix verbiegt. Ich warte mal paar Tage ab. Solang die nicht verfügbar sind, wird nen Austausch ja auch nix bringen. Ich hab bei mindfactory den Gold Service. K.a. Ob das was helfen würde.
Das ding ich zurückgehen lassen lol.
Am Ende heißt es du warst das wenn was mit der Karte sein sollte. Dokumentiert das
Ich bin mir sicher das sich das Fiepen vermeiden lassen würde wenn höherwertige Bauteile verbaut werden, oder es eine Qualitätskontrolle geben würde.
Eine Karte für 2000€ muss stock laufen ohne zu nerven.
Aber für "nerven" gibt es keine technische Definition, jeder reagiert da anders. Der eine hat ein superemfindliches Gehör und ein Supersilen System, der nächste weiss nicht mal was Du mit Spulenfiepen überhaupt meinst. Man müsste also absolut unhörbare Spulen konstruieren um auf Nummer sicher zu gehen und das ist hier technisch meines Wissens nicht möglich. Und für jeden Dezibelbruchteil weniger steigt der Preis dramatisch an, das ist eine exponentielle Kurve, keine lineare. Mit 20% der Investition kannst Du nun mal meist bereits 80% des Problems lösen, danach wird es richtig teuer und das rentiert oft nicht für die Gruppe welche die Flöhe husten hören kann. Auch hier kann ich die Hersteller verstehen. Die 4090 ist nun mal eine Karte die mit höherer Wahrscheinlichekit hohe FRameraten erzeugt und damit auch mit höherer Wahrscheinlichekeit das Problem auslöst. Ein zusätzlicher Grund warum ich Spulenfiepen bei meinen Karten bisher nicht hatte lag möglicherweise daran, daß ich überschüssige Leistung immer in mehr Bildqualität investiert habe und damit die Framerate immer relativ niedrig lag und nicht weil es technisch nicht dagewesen wäre.
Ich bin dahe rnicht der Meinung das eine 2000€ keinesfalls Spulenfiepen haben darf, es ist kein technischer Mangel der die Leistung oder Lebensdauer beeinträchtigt. Natürlich sollten Bauteile verwendet werden die so qualitativ hochwerig sind wie möglich aber eine Spule die nicht fiept ist nicht automatisch technisch hochwertiger als eine die fiept, kann genausogut auch umgehert sein. Ich persönlich will lieber eine technisch robuste und zuverlässige Spule als eine die nicht fiept. Auf wen soll der Hersteller jetzt also optimieren wenn man beides gleichzeitg nicht haben kann?
was ist den damit passiert, das sieht nicht gesund aus
Ist der Kühler hinten. Bis zum Board ist alles gerade. Da wo der Luft Durchbruch ist ist sie weggebogen. Ich hab das so aus der Verpackung geholt. Laufen tut sie einwandfrei.
Das selbe bei mir… Knapp 80000€ Warenwert dort bestellt. Einiges zurückgeschickt. Auch Karten mit Wasserblock. War nie ein Problem
Ka was du für Probs mit MF hast, aber ich konnte da bisher alles Retounieren, sogar nach der 14 tägigen Frist auf Kulanz, ohne das ich gesperrt bin - seit vielen Jahren. Und wenn man sich dein salziges Geschreibe so anguckt.. wirds wohl andere Gründe haben für deine Sperre.
Beste Grüße
Die normale auch nicht gibt nur das eine Bios, wär eh riskant wenn da das flashen schief gehen würde
mag ja sein aber was ist in 2-3 wochen oder 2-3 monate ? haste voll den streßß, oder irgendwann willste die auch mal verkaufen, kauft doch keiner so nen banane :) würd mir das bei dem preis ECHT überlegen
So, habe meine Asus TUF non-OC auch bekommen (von Asus direkt), eingebaut und getestet, bin soweit begeistert :-)
Spulenfiepen habe ich beim ersten Hochtakten ein wenig gehört, jetztn ichts mehr, ist aber auch ein geschlossenes Case. Die Karte ist superleise, ich höre sie gar nicht.
Hat keinen BIOS-Switch - richtig?
Hier auch aber deutlich leiser. Ja und jetzt. Kaum Coilwhine Karte sieht super aus und läuft wie Schnitzel. Aber so musst es austauschen. Oder ölen aber was soll das bei nem 2k Produkt😡
auch dich würde ich eben bitten die sn nummer mir noch zukommen zu lassen per pn. damit ich weiter karten dem support melden kann! 100% lüfter charge die hier am arsch ist
Der Gold Service dient nur zur Persönlichen Bereicherung dieses As.... schuppens sonst nix Mindfactory ist der Letzte Händler wo ich bestellen würde. Wenn du die zurück schickst wirst du gesperrt als Kunde, Sie ist ja nicht defekt nur optisch. Jeder händler klar tauschen wir um MF sagt dir genau das.
Kann ich auch nicht bestätigen. So oder so sollte er zumindest mit MF kontakt aufnehmen und das dokumentieren lassen. Wenn man sich darauf einigt das ein Austausch nicht notwendig ist, so hat man zumindest eine Bestätigung dafür, falls mal was anderes mit der Karte später sein sollte ist man so abgesichert.
Dieses Problem war aber locker vermeidbar. Maße waren bekannt. Zollstock und Maßband sollten in jedem Haushalt vorhanden sein und sorgfältig messen ist doch nicht so schwer. Die Maße waren schon Tage vor dem Launch hier im Startpost vorhanden, man hätte sich also in Ruhe vorbereiten können. Oder hattest Du keinen Zugang zu Deinem Gehäuse in der Zeit?
Gut zu wissen. Na, ansich läuft die ja auch super. Nur bissle verbogen. :d viel macht mir das nicht aus. Rechner steht im Nebenraum. Ist mir eigentlich Wurscht
hm, würde ich nicht behalten, allein schon wenn du die Banane mal verkaufen willst fängst du an zu erzählen das war schon immer so...."ja klar, für 200€ weniger nehme ich dir das Obst ab."
Beste Grüße
Du vertust dich da, laut der Palit Seite hat die Non Oc auch ein Dual Bios
Meine TUF (non OC) hat einen Bios Switch auf der Rückseite links neben dem Power Anschluss ( Performance Mode | Quiet Mode)
Im Afterburner lässt sich 133% als Power Target einstellen. Hab random einfach mal auf 3000 Mhz getaktet. Lief ohne Probleme.
Werd ich machen. Mal anrufen was die Optionen sind. Wenn ich die ohne Grund zurückschicke werden die auch denken ich war’s.
Normalerweise kann man auf abfotografierte Bilder nix geben (sind manchmal perspektivisch verzerrt)
Aber die Kante am Kühler ist mit rangehaltenem Lineal kerzengerade. Da wurden die Schrauben mächtig angeballert :rolleyes2:
Wie lang lief die Karte da schon? Und wie war es im kalten Zustand
Yop, der Widerverkaufswert ist dadurch schon mal deutlich geringer später. Und wenn es nicht beim Händler dokunetiert wird, dann fliegt einem das spätestens um die Ohren wenn die Beweislastumkehr einsetzt und man darauf angeweisen ist. Selbst davor kann der Händler leicht argumentieren daß dieses Problem nicht vor dem Verkauf bereits vorhanden war, weil man sonst kaum so lange gewratet hätte.
Ich kann voll und ganz verstehen, daß man aktuell ein Produkt was gut funktioniert aus solchen Gründen nicht tauschen will, habe selbst schon Mängel akzeptiert. Aber offiziell dokumentiert werden sollten sie trotzdem, das rächt sich sonst irgendwann ziemlich sicher.
Die war schon so verbogen, bevor ich sie eingebaut hab. Die lief jetzt zum Test vielleicht 1 Stunde.
Ähnliche Themen
Antworten
6K
Aufrufe
313K
