[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe mir gerade extra für die beiden 4090 das o11d xl gekauft, weil mein Carbide 540 natürlich zu klein ist. Dann geht das direkt wieder Retoure. 🤨 Vertikal ist durch zwei Karten ja keine Option.
Bei mir stört der Adapter. Wegen dem bekomm ich das Seitenteil nicht zu. Vertikal würde easy gehen aber dafür muss man die Halterung für 80€ holen mit pcie 4.0 riser.
Immer wieder schön zu sehen, wenn Games die Leistung einer 4090 voll ausnutzen.
Ich glaub mit einer 3090 war das mit meinen Settings nicht spielbar.
Aber etwas mehr Speicher könnte ich schon noch vertragen. Allerdings in den nächsten 2 Jahren nicht, ich kauf mir keinen Refresh. Das wird dann mit der nächsten Gen kommen.
Wieso Problem?
Dann seh ich wenigstens auf einen Blick durchs Seitenfenster, ob der Rechner an oder aus ist:
Spaß beiseite: Mit Einschalten des Rechners geht die LED aus.
Ich frag mich gerade, wie genau Asus die Prüfung, ob eine Versorgungsleitung angesteckt ist, umgesetzt hat.
Karte hängt an einem be quiet! Dark Power Pro 12 1200W. Vielleicht schaltet das im ausgeschaltet Zustand die Masse von den Anschlüssen weg, wodurch es für die Karte so wirkt, als ob nichts angeschlossen ist.
Entweder hat es was mit dem Adapter zu tun, oder mit dem be quiet! DArk Power Pro 12 1200W.
Mit einem Corsair HX1200i und dem 16Pin-Kabel von Corsair ist die LED nun auch aus, wenn der Rechner aus ist.
Anhang anzeigen 803369Anhang anzeigen 803370
Was ist das für ein game? Wie kommst du auf 17gb vram? Downsampling?
Wer hat 3000 MHz erreicht? Ohne Spannungsanhebung?
Ich musste die Spannung auf 1.1v anheben, damit 3015 MHz bei RDR2 laufen.
Ansonsten komme ich mit +200 MHz auf 2880 MHz bei 1.05v, auch RDR2 -> Habe bei RDR2 alles auf MAX in 4K... was für eine Wucht ^^
Stock macht meine 2775 MHz in RDR2, +225 3000 MHz, ohne Spannungserhöhung.
Mit 1.1v 3070-3100
wollte gerade mal den Cyberpunk Benchmark laufen lassen. Stürzt aber immer an derselben Stelle ab, auch mit Stock Settings. Bug?
Cyberpunk hat momentan ein Problem mit dem aktuellsten nVidia Treiber. Artefakte usw. können dabei entstehen. Vielleicht hängt dein Problem damit auch zusammen
Meine Gaming X Trio hat mit nem Power Limit von 106%, +275 MHz Core Clock und +1500 MHz Mem Clock 20.206 Grafik Punkte in Time-Spy Extreme:
Time Spy Extreme Gaming X Trio
Danach wird's dann aber langsam instabil.
Laufen lass ich die Karte aber im Alltag mit nem Power Limit von 80%, +175 MHz Core Clock und +1250 MHz Mem Clock. Da verbraucht die dann nur noch Peak 360W und ist bis dato überall stabil :d
ich bin jetzt erstmal bei 0.9V, 2610 MHz, +1000 VRAM 230-300W Verbrauch je nach Game, Powerlimit 100%
Und das Speed Way Result is auch okay für ~300W
Wenn es nix anderes gäbe, würde jeder die "Katzen-Zunge" kaufen :fresse:
Bei Wakü-Umbau wäre es eh wurscht...
btw:
Gab es gestern und heute (Amazon) einen Drop?
(hat Amazon überhaupt welche verkauft?)
Die TUF gab es heute Amazon selber wollte aber 2500
habe die zwei gefunden sind aber nur von händlern nicht von amazon
ama1
ama2
Keiner mit einer FE der mal sagen kann was die Max Load Lüfter RPM macht?
So mit OC auf ~2900MHz (AB: +155 MHzCore, +1500 MHz Mem, PL 115%, 100%vCore) ging meine FE auf 1500 Umdrehungen und 72°C im geschlossenen Gehäuse mit reichlich Gehäuselüfter (Front). Spiel: Cyberpunk
Mit 1.1v 3070-3100
Habe meine auf 0.95 v bei 2760 mhz.
Da kannst du auch noch was machen. Machen knapp 100w aus.
Die tuf wirkt echt wertig gegenüber den anderes plastikbombern. Beste wahl nach der fe. Nur bei den thermalpads und der stütze haben sie gepfuscht. Siehe hardware unboxed.
3045mhz gehn bei meiner 4090 suprim x ohne Spannungsanhebung. Mit 1.1v sind 3075-3090 drin ( hängt von der Gpu Temperatur ab ). Alles darüber läuft nicht.
bin im Performance Profil, das erklärts :)
Eigentlich sollte sich im Quiet/Performance BIOS nur die Lüfterkurve unterscheiden mein ich auch gelesen zu haben.
Die Asus GeForce RTX 4090 TUF OC verfügt wie gewohnt über zwei verschiedene BIOS-Modi. Werkseitig ist das Performance-BIOS aktiv, alternativ gibt es das Quiet-BIOS. Es kann mit einem Schalter an der Rückseite der Grafikkarte aktiviert werden – und der Name ist hier Programm. Denn die andere Softwareversion beeinflusst ausschließlich die Lüftersteuerung, die im Quiet-Modus weniger aggressiv arbeitet als im Performance-Modus. Das senkt die Lautstärke, erhöht aber zugleich die Temperatur. Einen weiteren nennenswerten Einfluss gibt es nicht.
Aber gut die Temp hat natürlich auch Einfluss auf den Boost.
Im Hardware Unboxed Video sagt er die TUF könnte maximal auf 520W PT gestellt werden, stimmt nicht ganz :d
hmm, also ich bin da bei 59/60 Grad
Quiet kann ich mir schenken, meine Karte fiept lauter als die Lüfter im Performance Modus :fresse:
Ähnliche Themen
